Is there any software available that can replace or somewhat replace grub-customizer? Like which can just simply change the order of grub entries.
On uefi âefibootmgrâ in a terminal
efibootmgr
Timeout: 1 seconds
BootOrder: 0000,0004,0007,000D,000C,0008,0002,0009,0005,0006,0003,000B,0001
Boot0000* Arch
Boot0001* ubuntu
Boot0002* debian
Boot0003* grub_uefi
Boot0004* Manjaro
Boot0005* HefftorLinux
Boot0006* ArcoLinux
Boot0007* Windows Boot Manager
Boot0008* rEFInd Boot Manager
Boot0009* UOS
Boot000B* Fedora
Boot000C* Fedora
Boot000D* UEFI: CT500MX500SSD1
As far as i know the best softwares are the following : mousepad, gedit, vimâŚ
efibootmgr just orders/reorders the priority of the various grub bootloaders of all the distros on your machine. Once you decide which distroâs grub should be booted first over the other distrosâ grub, how you customise that chosen grub is a different issue.
For me I make custom entries in /boot/grub/custom.cfg so I can decide on the order of menu entries.
For things like grub background, timeout, etc, you need to edit /etc/default/grub
my own custom grub is the last thing I want !!
There should be no need to change order of GRUB entries
Manjaro GRUB does not function like other distributions that default to the first menuentry
If a user chooses another menuentry, GRUB will save the user choice and continue to boot from that menuentry
If you want to change boot options in GRUB see this previous discussion for how to modify /etc/default/grub configuration â Help setting default grub entry
We discussed this many times. Some folks want Windows as the default for family members etc.
So you can choose the option to fix the main entry, remember the last boot.
The easiest way to do this (GUI) is to hit Alt_Space to pull up krunner.
type kate /etc/default/grub
(or select and copy the text, hit Alt_Space then Ctrl_V)
There are instructions in the fileâŚ
So you can set the âSAVEDEFAULT=falseâ to stop the grub remembering what you last booted.
Then you change the number on GRUB_DEFAULT
When youâre done you must run grub-update too.
No I am not looking for default entry, I am looking for ways to change the position of the different options in grub. Not necessary but I like all the oses one after another and then all the other entries
Like currently it is:
Manjaro
Adv opts for Manjaro
Windows
How can I make it look like:
Manjaro
Windows
grub-customizer would change files in folder /etc/grub.d/ to change the order of menuentry items
But changes made by grub-customizer could cause GRUB to fail when system is next updated
If you want to change the menuentry boot order by modifying the file order in /etc/grub.d/
I suggest you make a backup copy of the files and be aware of how to fix GRUB if changes do not work out
GRUB/Restore the GRUB Bootloader - Manjaro
You move entries (select and drag them to order them).
menuentry "Manjaro Linux" {
set root=(hd0,2)
linux /boot/vmlinuz (add other options here as required)
initrd /boot/initrd.img (if the other kernel uses/needs one)
So move the âManjaroâ menuentry to the top, then âWindowsâ
Thnx everybodyâŚ
[robin0800@robins-desktop ~]$ efibootmgr -h
efibootmgr version 17
usage: efibootmgr [options]
-a | --active sets bootnum active
-A | --inactive sets bootnum inactive
-b | --bootnum XXXX modify BootXXXX (hex)
-B | --delete-bootnum delete bootnum
-c | --create create new variable bootnum and add to bootorder
-C | --create-only create new variable bootnum and do not add to bootorder
-D | --remove-dups remove duplicate values from BootOrder
-d | --disk disk (defaults to /dev/sda) containing loader
-r | --driver Operate on Driver variables, not Boot Variables.
-e | --edd [1|3|-1] force EDD 1.0 or 3.0 creation variables, or guess
-E | --device num EDD 1.0 device number (defaults to 0x80)
-g | --gpt force disk with invalid PMBR to be treated as GPT
-i | --iface name create a netboot entry for the named interface
-l | --loader name (defaults to "\EFI\arch\grub.efi")
-L | --label label Boot manager display label (defaults to "Linux")
-m | --mirror-below-4G t|f mirror memory below 4GB
-M | --mirror-above-4G X percentage memory to mirror above 4GB
-n | --bootnext XXXX set BootNext to XXXX (hex)
-N | --delete-bootnext delete BootNext
-o | --bootorder XXXX,YYYY,ZZZZ,... explicitly set BootOrder (hex)
-O | --delete-bootorder delete BootOrder
-p | --part part partition containing loader (defaults to 1 on partitioned devices)
-q | --quiet be quiet
-t | --timeout seconds set boot manager timeout waiting for user input.
-T | --delete-timeout delete Timeout.
-u | --unicode | --UCS-2 handle extra args as UCS-2 (default is ASCII)
-v | --verbose print additional information
-V | --version return version and exit
-w | --write-signature write unique sig to MBR if needed
-y | --sysprep Operate on SysPrep variables, not Boot Variables.
-@ | --append-binary-args file append extra args from file (use "-" for stdin)
-h | --help show help/usage
Nope.
efibootmgr
will change this boot order in the BIOS, not in GRUB.
I know it works but what it changes I do not know, if it changes the bios how does grub catch up?
Thatâs it, it doesnât affect GRUB. It affects the boot order for EFI, the BIOS, and NOT GRUB.
For uefi systems, each distroâs bootloader (usually grub), if installed, gets installed in that ESP partition. So all it is, is a collection of each distroâs grubs.
Efibootmgr just helps you select which distroâs grub you want to control the booting of your whole machine. Once you have selected the controlling grub, you need to know how to tweak it, so get familiar with editing that distroâs /etc/default/grub file.
After update-grub the grub.cfg resets and I have to do the steps each time grub updates itself. Is there a permanent way?
Probably not as the file you modify is generated on each update. You could maybe craft a pacman hook specifically to modify this file, but thatâs kinda risky if your hook doesnât work properly.
I have saved my modified part as a backup on a 2nd ssd, when grub updates(doesnât update frequently) I will just paste my saved portion of the grub.cfg to the new grub.cfg.
