Hello.
I’ve installed Manjaro in all my PC’s, both KDE and XFCE, depending on the machine specs.
My main PC is an Envy x360, Ryzen 5 2500U, which is running KDE fully updated.
My stylus (to write directly on the screen, not in a drawing tablet) stopped working in Wayland. It works if I login in X11.
It worked ok when I installed Manjaro, in late 2024. I believe it stopped working with the inclusion of the “Drawing Tablet” menu in the System Settings.
It looks like the Systems detects the stylus since the mouse cursor blinks when i touch the screen, but it doesn’t follow the stylus.
I can try to upload a video If you think it helps.
Thanks for the awesome work
Kernel: 6.13.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
root=UUID=71305e3f-3443-4cce-999d-c49be239b312 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Convertible System: HP product: HP ENVY x360 Convertible 13-ag0xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 8496 v: 92.48 serial: <superuser required>
part-nu: 4AW08EA#AB9 uuid: <superuser required> UEFI: AMI v: F.49
date: 05/24/2021
ID-1: BAT0 charge: 38.8 Wh (84.0%) condition: 46.2/46.2 Wh (100.0%)
volts: 15.2 min: 15.4 model: 333-2B-49-A KC04053XL type: Li-ion
serial: <filter> status: discharging
System RAM: total: 8 GiB available: 6.73 GiB used: 2.16 GiB (32.2%)
Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous
unbuffered (unregistered) size: 4 GiB speed: 2400 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
part-no: HMA851S6AFR6N-UH serial: N/A
Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1600 min/max: 1600/2000 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1600 3: 1600
4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 31938
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series
/ Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1 bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300 temp: 32.0 C
Device-2: Lite-On HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 04ca:708e
Device-3: Lite-On HP IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 04ca:708f
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x0597 built: 2017 res: mode: 1920x1080
hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 166 gamma: 1.2 chroma: red:
x: 0.639 y: 0.349 green: x: 0.333 y: 0.627 blue: x: 0.153 y: 0.039 white:
x: 0.314 y: 0.329 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 640x480
EDID-Warnings: 1: parse_edid: unknown flag 2
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven ACO DRM 3.61 6.13.7-1-MANJARO) device-ID: 1002:15dd
memory: 1000 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.304 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15dd
surfaces: xcb,xlib,wayland
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
speed: 8 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.7-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
chip-ID: 10ec:b822 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0bda:b00b
Local Storage: total: 931.51 GiB used: 19.96 GiB (2.1%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620361WD temp: 23.9 C scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
used: 17.62 GiB (9.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 71305e3f-3443-4cce-999d-c49be239b312
ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 7E7C-611E
ID-3: /home raw-size: 722.66 GiB size: 710.24 GiB (98.28%)
used: 2.34 GiB (0.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: c2bfb442-9bb1-4792-811a-c80d46c2ec63
ID-1: swap-1 type: partition size: 13.15 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 5b24223c-deaf-4138-9b62-e58e8451d07b
Device-1: 1-4:2 info: Lite-On HP Wide Vision HD Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04ca:708e class-ID: 0e02
serial: <filter>
Device-1: 3-1:2 info: Lite-On HP IR Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04ca:708f class-ID: 0e02 serial: <filter>
Device-2: 3-2:3 info: Realtek Bluetooth 4.2 Adapter type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 32.6 C mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (rpm): N/A
Packages: 1295 pm: pacman pkgs: 1288 libs: 365 tools: pamac,yay pm: flatpak
pkgs: 7
1: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
2: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
3: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
4: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
5: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
6: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
7: https://linorg.usp.br/manjaro/stable/$repo/$arch
8: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
9: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
10: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
11: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
12: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
13: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
14: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
15: https://mirror.zetup.net/manjaro/stable/$repo/$arch
16: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
18: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
19: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
20: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
21: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
22: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
23: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
24: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
25: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
27: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
28: https://mirrors2.manjaro.org/stable/$repo/$arch
29: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
30: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
31: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
32: https://mirror.koddos.net/manjaro/stable/$repo/$arch
33: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
34: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
35: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
36: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
37: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
38: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
39: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
40: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
41: https://mirror.dc.uz/manjaro/stable/$repo/$arch
42: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
43: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
44: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
46: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
47: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
48: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
49: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
50: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
51: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
52: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
53: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
54: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
55: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
56: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
57: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
58: http://mirror.fcix.net/manjaro/stable/$repo/$arch
59: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
60: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
61: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
62: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
63: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
64: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
65: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
66: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
67: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
68: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
69: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
70: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
71: https://muug.ca/mirror/manjaro/stable/$repo/$arch
72: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
73: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
74: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
75: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
76: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
77: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
78: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
79: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
80: https://manjaro.kurdy.org/stable/$repo/$arch
81: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
82: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
83: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
84: https://mirror.easyname.at/manjaro/stable/$repo/$arch
85: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
86: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
87: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
88: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
89: https://mirror.init7.net/manjaro/stable/$repo/$arch
90: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
91: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
92: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
93: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
94: https://manjaro.ynh.ovh/stable/$repo/$arch
95: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
96: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
98: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
99: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
100: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
101: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
102: http://manjaro.grena.ge/stable/$repo/$arch
103: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
104: https://mirrors.manjaro.org/repo/stable/$repo/$arch
105: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
106: http://manjaro.mirror.ac.za/stable/$repo/$arch
107: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
108: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
109: https://mirror.23m.com/manjaro/stable/$repo/$arch
110: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
111: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
112: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
113: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 268
1: cpu: 12.0% command: floorp pid: 1518 mem: 463.4 MiB (6.7%)
2: cpu: 6.6% command: konsole pid: 2139 mem: 227.1 MiB (3.2%)
3: cpu: 5.5% command: floorp pid: 1704 mem: 324.5 MiB (4.7%)
4: cpu: 4.1% command: kwin_wayland pid: 702 mem: 207.6 MiB (3.0%)
5: cpu: 3.6% command: floorp pid: 1784 mem: 230.8 MiB (3.3%)
Memory top: 5 of 268
1: mem: 463.4 MiB (6.7%) command: floorp pid: 1518 cpu: 12.0%
2: mem: 324.5 MiB (4.7%) command: floorp pid: 1704 cpu: 5.5%
3: mem: 306.1 MiB (4.4%) command: plasmashell pid: 968 cpu: 1.7%
4: mem: 230.8 MiB (3.3%) command: floorp pid: 1784 cpu: 3.6%
5: mem: 227.1 MiB (3.2%) command: konsole pid: 2139 cpu: 6.6%
Processes: 268 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.67 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.37
