Since my switch to manjaro I’ve noticed some very low video playback performance once my CPU utilization goes above 40 or 50 percent because of other processes. The video starts to stutter or freezes completely while only the sound is playing. In other instances the video plays but the sound starts to stutter. Which shouldn’t happen because non of my system parameters are anywhere close to being maxed out in this situation. Disk read is low, load is currently at 4 (with an 8 core CPU) and my cores are running at 40-50% each but I can’t play any video (neither with vlc or mpv). CPU usage and load also doesn’t peak while trying to play the video. Are there any other tools besides top and System Monitor that could help me figuring out where the bottleneck is? Or is this a known problem (maybe because of some missing drivers or missing hardware support)?
I’ve installed manjaro with propritary drivers. I’m running on an i7-6700 with an GeForce GT 710 (driver=nvidia; there is also a second card, but that is used exclusively for virtualization and shouldn’t be used by manjaro at all).
provide formated output from:
inxi -Fazy
mhwd -l && mhwd -li
also try this:
its probably pulse/pipewire issue… install this package: manjaro-pipewire - it will give you dependency issues, so uninstall them first, then instal again the manjaro-pipewire package, reboot and check
Hmm, installing pipewire didn’t solve the issue (and seems to have problems putting out Digital Surround 5.1 which is stuttering everytime - Digital Stereo works fine.)
The other infos you’re asking for:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=/dev/mapper/VolumeGroup-root rw apparmor=1 security=apparmor
udev.log_priority=3 intel_iommu=on
vfio-pci.ids=10de:21c4,10de:1aeb,10de:1aec,10de:1aed kvm.ignore_msrs=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: H170-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3805
date: 05/16/2018
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 54417
Type: l1tf
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
driver: nvidia v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
Device-2: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Gigabyte
driver: vfio-pci v: N/A alternate: nouveau,nvidia_drm,nvidia pcie: gen: 3
speed: 8 GT/s lanes: 4 link-max: lanes: 16 bus-ID: 07:00.0
chip-ID: 10de:21c4 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,vfio-pci
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DVI-D-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2
v: 4.6.0 NVIDIA 470.103.01 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Device-3: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK CMI8786
driver: snd_oxygen v: kernel bus-ID: 03:04.0 chip-ID: 13f6:8788
class-ID: 0401
Device-4: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: vfio-pci alternate: snd_hda_intel pcie: gen: 3 speed: 8 GT/s
lanes: 4 link-max: lanes: 16 bus-ID: 07:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br0 state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
IF-ID-3: virbr1 state: down mac: <filter>
IF-ID-4: virbr2 state: down mac: <filter>
IF-ID-5: virbr3 state: down mac: <filter>
Local Storage: total: 5.46 TiB used: 3.09 TiB (56.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD30PURZ-85GU6Y0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD My Passport 264F size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 2005 scheme: GPT
ID-1: / raw-size: 150 GiB size: 146.59 GiB (97.72%) used: 23.89 GiB (16.3%)
fs: ext4 dev: /dev/dm-2 maj-min: 254:2 mapped: VolumeGroup-root
ID-2: /boot/efi raw-size: 401 MiB size: 400.2 MiB (99.79%)
used: 336 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 1000 GiB size: 983.23 GiB (98.32%)
used: 466.03 GiB (47.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: VolumeGroup-home
ID-1: swap-1 type: partition size: 31.06 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda8 maj-min: 8:8
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 69 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 59%
Processes: 310 Uptime: 3m wakeups: 0 Memory: 62.73 GiB used: 2.85 GiB (4.5%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1499 lib: 365 flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.15
> 0000:01:00.0 (0300:10de:128b) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia-470xx 2021.12.18 false PCI
video-nvidia-390xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:07:00.0 (0300:10de:21c4) Display controller nVidia Corporation:
video-nvidia 2021.12.18 false PCI
> 0000:06:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> Installed PCI configs:
nvidia temp: 69 C
Are you playing a game right now, is it really hot in the room you’re in? Is it time to dust the inside of your desktop? Why is the nvidia temp so hot? Mine hovers around 29-30C with regular (when not gaming) use.
so uninstall pipewire if you have issues with it, and install pulse with: manjaro-pulse - it will automatically remove pipewire…
also noticed that you have only nvidia drivers installed even though you have also intel graphics, so install it with:
sudo mhwd -i pci video-linux
reboot
Maybe 800Mhz are not enough?
Thank you all for your observations!
That is only while idleing - when used it goes up to 3700 what should be normal.
Are you sure this might be a solution? The intel graphics are the onboard chip that came with the system but I don’t use it and the output is not connected. I’m just using the two nividia cards. Of cause I would be willing to try it, but I’m not particular fond on installing additional drivers for unused hardware because that tends to cause problems.
That is indeed a good observation. I will check on that. One is a fan-less card in a small tower, so this one might be running a little warm, but it stays still well within the manufacture specifications even when under stress. I’m not sure for which of the cards this reading is, because the one with a fan is used for the virtual machine and shows way lower temperatures when used. But than it shouldn’t report a fan speed. But I don’t think this is the problem, because I didn’t change any hardware since switching to manjaro four weeks ago. And the system handled the video playback fine while I was still running Ubuntu.
Edit:
According to nvidia-smi this is indeed the temperature of the fan-less card that for some reason also reports a fan-speed?!?
you can try ‘tweaks’ from this link and see
Are you sure? governor: powersave means: stay always at the lowest clock speed, but sure if a program asks for speed, then the governor changes, for example with gamemoderun.
Same readings while playing a video:
Speed (MHz): avg: 1076 high: 1200 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 1200 3: 1200
4: 1200 5: 1001 6: 1179 7: 800 8: 834 bogomips: 54417
…and while running the processor at 70% capacity
Speed (MHz): avg: 2204 high: 3405 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3405 2: 3100 3: 3100
4: 3100 5: 840 6: 800 7: 967 8: 2324 bogomips: 54417
I think this looks good or do you disagree?
Interesting, so powersave on the intel_pstate module acts like conservative on the acpi-cpufreq module. So it clocks down to lowest possible speed, but clock up if needed.
Good to know that
What videos are we talking about? 4k or 2k videos? There it doesn’t matter how high the CPU usage is. Without GPU acceleration it will always stutter.
This link does not work anymore (error: Name not resolved).
