Stuttering and crashes after most recent update - NVIDIA driver problem?
I’m experiencing the following after the most recent update on my Lenovo T590, Plasma
  • When AC is not connected every 3-4 seconds the system hangs for a second.
  • Random crashes, very frequently (with and without AC). My system then freezes and the led on the caps lock key blinks - the same as if the pc would overheat (EDIT: it does not).
System info:
> inxi -v7azy
  Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=1cb6668b-c4b1-4b67-90a2-5706f9cbcef8 rw scsi_mod.use_blk_mq=1
    quiet resume=UUID=1cb6668b-c4b1-4b67-90a2-5706f9cbcef8
    resume_offset=12359680 acpi_osi=!Linux-Lenovo-NV-HDMI-Audio
    pcie_port_pm=off apparmor=1 lsm=lockdown,yama,apparmor,bpf
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 20N5S0DU00 v: ThinkPad T590
  Mobo: LENOVO model: 20N5S0DU00 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_20N5_BU_Think_FM_ThinkPad T590 uuid: <superuser required>
    UEFI: LENOVO v: N2IETA3W (1.81 ) date: 10/26/2023
  ID-1: BAT0 charge: 35.3 Wh (78.4%) condition: 45.0/57.0 Wh (78.9%)
    volts: 12.2 min: 11.5 model: SMP 02DL012 type: Li-poly serial: <filter>
    status: not charging cycles: 1100
  System RAM: total: 40 GiB available: 38.96 GiB used: 4.32 GiB (11.1%)
  Array-1: capacity: 64 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
    spec: 2667 MT/s actual: 2400 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Micron part-no: 4ATS1G64HZ-2G6E1 serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 32 GiB speed:
    spec: 3200 MT/s actual: 2400 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: 85f7 part-no: J644GU44J2320NQ serial: <filter>
  Info: model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Whiskey Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF4
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3699 high: 3701 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3700 2: 3701 3: 3700
    4: 3700 5: 3700 6: 3699 7: 3700 8: 3698 bogomips: 28808
    pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
    ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: N/A
    alternate: nouveau, nvidia_drm, nvidia non-free: 545.xx+ status: current (as
    of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 3c:00.0
    chip-ID: 10de:1d13 class-ID: 0302
  Device-3: Chicony ThinkPad T490 Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 04f2:b681
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2016 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
    device-ID: 8086:3ea0 memory: 38.05 GiB unified: yes
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
  Local Storage: total: 465.76 GiB used: 260.8 GiB (56.0%)
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 50.9 C scheme: GPT
  ID-1: / raw-size: 65 GiB size: 63.43 GiB (97.58%) used: 54.05 GiB (85.2%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 1cb6668b-c4b1-4b67-90a2-5706f9cbcef8
  ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
    used: 32.9 MiB (34.7%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 6A96-A1AA
  ID-3: /home raw-size: 67.99 GiB size: 66.62 GiB (97.99%)
    used: 49.05 GiB (73.6%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
    label: N/A uuid: 0f9d3f21-7313-4974-9238-640c43a88970
  ID-4: /media/common raw-size: 220 GiB size: 220 GiB (100.00%)
    used: 157.66 GiB (71.7%) fs: ntfs dev: /dev/nvme0n1p6 maj-min: 259:6
    label: N/A uuid: 477140335FA41272
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: file size: 10 GiB used: 35 MiB (0.3%) priority: -2
    file: /swapfile
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs
    label: Wiederherstellung uuid: 869A96799A966609
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 111.18 GiB fs: ntfs label: N/A
    uuid: 3C729C7A729C3A9A
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 969 MiB fs: ntfs label: N/A
    uuid: 3CFAEDABFAED621E
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: Alcor Micro AU9540 Smartcard Reader type: smart card
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
  Device-2: 1-8:3 info: Chicony ThinkPad T490 Webcam type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04f2:b681 class-ID: 0e02 serial: <filter>
  Device-3: 1-9:4 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 77.0 C pch: 60.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 3872
  Processes: 317 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 15.58 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 255 default: graphical tool: systemctl
  Packages: 2295 pm: pacman pkgs: 2263 libs: 520 tools: octopi,pamac,yay
    pm: flatpak pkgs: 24 pm: snap pkgs: 8 Compilers: clang: 16.0.6 gcc: 13.2.1
    Shell: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
In my taskmanager I noticed that modprobe keeps restarting all the time and there’s always one CPU core at 100% every few seconds - could be those events are connected. In journalctl I get the following repeatedly:
Mär 08 21:41:51 pc (udev-worker)[3756]: nvidia: Process '/usr/bin/nvidia-modprobe' failed with exit code 1.
Mär 08 21:41:52 pc kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 508
Mär 08 21:41:52 pc kernel: nvidia: probe of 0000:3c:00.0 failed with error -1
Mär 08 21:41:52 pc kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 508
Mär 08 21:41:52 pc (udev-worker)[3756]: nvidia: Process '/usr/bin/nvidia-modprobe -c 0 -u' failed with exit code 1.
Mär 08 21:41:54 pc kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 508
Mär 08 21:41:54 pc kernel: nvidia: probe of 0000:3c:00.0 failed with error -1
Mär 08 21:41:54 pc kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 508
Mär 08 21:41:54 pc (udev-worker)[3756]: nvidia: Process '/usr/bin/nvidia-modprobe' failed with exit code 1.
Mär 08 21:41:55 pc kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 508
Mär 08 21:41:55 pc kernel: nvidia: probe of 0000:3c:00.0 failed with error -1
Mär 08 21:41:55 pc kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 508
Mär 08 21:41:55 pc (udev-worker)[3756]: nvidia: Process '/usr/bin/nvidia-modprobe -c 0 -u' failed with exit code 1.
Mär 08 21:41:56 pc kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 508
Mär 08 21:41:56 pc kernel: nvidia: probe of 0000:3c:00.0 failed with error -1
Mär 08 21:41:56 pc kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 508
I have no idea if this is related to the crashes and stuttering or what to do in general. I would be very thankful for any help.
the infos of the gpu are missing use the mandatory
Thats the same as they used … they just cut it off.
@pulga please show the full output.
inxi -v8zy covers all the things. Let’s use that from now on.
:point_down:
 -v, --verbosity
               Set inxi verbosity level (0-8). Should not be used with -b or
               -F. Example: inxi -v 4
                   0  Same as: inxi
                   1  Basic verbose, -S + basic CPU + -G + basic Disk + -I.
                   2  Networking device (-N), Machine (-M), Battery (-B; if
                      present), and, if present, basic RAID (devices only;
                      notes if inactive). Same as inxi -b
                   3  Advanced CPU (-C), battery (-B), network (-n); triggers
                      -x.
                   4  Partition size/used data (-P) for (if present) /, /home,
                      /var/, /boot. Shows full disk data (-D).
                   5  Audio device (-A), sensors (-s), memory/RAM (-m),
                      bluetooth (if present), partition label (-l), full swap
                      (-j), UUID (-u), short form of optical drives, RAID data
                      (if present).
                   6  Full partition (-p), unmounted partition (-o), optical
                      drive (-d), USB (-J), full RAID; triggers -xx.
                   7  Network IP data (-i), bluetooth, logical (-L), RAID
                      forced, full CPU flags; triggers -xxx.
                   8  Everything available, including advanced gpu EDID
                      (--edid) data, repos (-r), processes (-tcm), PCI slots
                      (--slots); triggers admin (-a).
I dont know that process information is all that needed most of the time.
Nor is optical information, or device labels, or listed but redacted IP things, or CPU flags.
Certainly --nohost is redundant in the ‘long form’ above.
But I still prefer inxi -Fazy in general.
If the repo info is considered all that important then inxi -Farzy I guess, but I dont know if that is really needed all the time. :person_shrugging:
Sorry, I updated the output in the first post.
Here are the others:
> inxi -v8zy
  System RAM: total: 40 GiB available: 38.96 GiB used: 3.95 GiB (10.1%)
  Speed (MHz): avg: 3700 high: 3703 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3701 2: 3700 3: 3701
    4: 3700 5: 3700 6: 3700 7: 3703 8: 3701 bogomips: 28808
    hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.576 y: 0.345 green: x: 0.345
    y: 0.573 blue: x: 0.157 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
    fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
    uuid: 6A96-A1AA
    file: /swapfile
  System Temperatures: cpu: 79.0 C pch: 60.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 3877
  Active pacman repo servers in: /etc/pacman.conf
    1: https://mega.nz/linux/repo/Arch_Extra/$arch
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 294
  1: cpu: 99.0% command: modprobe pid: 6071 mem: 98.2 MiB (0.2%)
  2: cpu: 74.7% command: modprobe pid: 6077 mem: 98.0 MiB (0.2%)
  3: cpu: 27.0% command: konsole pid: 6050 mem: 144.5 MiB (0.3%)
  4: cpu: 15.5% command: baloo_file pid: 1650 mem: 278.2 MiB (0.6%)
  5: cpu: 15.1% command: firefox pid: 3489 mem: 267.1 MiB (0.6%)
  Memory top: 5 of 294
  1: mem: 452.6 MiB (1.1%) command: firefox pid: 3182 cpu: 13.6%
  2: mem: 364.2 MiB (0.9%) command: thunderbird pid: 2499 cpu: 3.9%
  3: mem: 325.3 MiB (0.8%) command: plasmashell pid: 1773 cpu: 5.5%
  4: mem: 278.2 MiB (0.6%) command: baloo_file pid: 1650 cpu: 15.5%
  5: mem: 267.1 MiB (0.6%) command: firefox pid: 3489 cpu: 15.1%
  Processes: 294 Power: uptime: 7m states: freeze,mem,disk suspend: deep
  Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
>  inxi -Fazy
  Speed (MHz): avg: 3750 high: 3907 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3707 2: 3701 3: 3690
    4: 3898 5: 3705 6: 3703 7: 3689 8: 3907 bogomips: 28808
    file: /swapfile
  Fan Speeds (rpm): fan-1: 3880
  Memory: total: 40 GiB available: 38.96 GiB used: 3.81 GiB (9.8%)
  Processes: 295 Power: uptime: 7m states: freeze,mem,disk suspend: deep
In the meanwhile I also checked if my laptop overheats when it freezes - it does not.
There is no driver installed for your NVIDIA GPU. Please see Install NVIDIA drivers
Maybe not, however the more information the better.
It can be. If folks are using third party repos and it can be spotted right away, that could save everyone a lot of time. :wink:
Oh hey look, the OP is using a third-party repo. Not related to the issue at hand, however we never would have known otherwise.
These drivers are installed:
> sudo mhwd -a pci nonfree 0300
> Skipping already installed config 'video-hybrid-intel-nvidia-prime' for device: 0000:00:02.0 (0300:8086:3ea0) Display controller Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620]
> sudo mhwd -a pci nonfree 0302
> Skipping already installed config 'video-hybrid-intel-nvidia-prime' for device: 0000:3c:00.0 (0302:10de:1d13) Display controller nVidia Corporation GP108M [GeForce MX250]
> mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2023.03.23               false            PCI
When running nvidia-settings it complains that there’s no NVIDIA driver loaded however (idk if it was like this before). I’m using the prime driver such that I can deactivate the dGPU. At least until last week this worked with bbswitch in combination with the GRUB-parameter acpi_osi=!LinuxLenovo-NV-HDMI-Audio (I already tried removing the parameter - it does not help).
I tried now removing video-modesetting and video-hybrid-intel-nvidia-prime and installing video-nvidia - it does not help. However when I remove all three of them (i.e. no graphics driver installed according to mhwd) the modprobe service doesn’t restart anymore continuously and the stuttering stops. From the power consumption reported in powertop it also seems that turning the dGPU off with bbswitch still works. Obviously I cannot run programs with prime now anymore, but I don’t really use it on linux anyway.
I guess this resolves the problem, thank you everyone.
