Stuck with s2idle sleep mode and notebook not waking from sleep
I have a notebook Dell G15 5530, which is really not a good Linux Desktop, but I’m stuck with it for a while.
I’m finding weird that S3 sleep mode is not available, because the BIOS clearly has an option to block S3 (it is disabled, should not be blocked), but dmesg shows:
$ sudo dmesg | grep -i "ACPI" | grep -i "supports"
[    0.237657] ACPI: PM: (supports S0 S4 S5)
[    0.285449] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
$ cat /sys/power/mem_sleep
[s2idle]
So, somehow I’m stuck with s2idle. Or could there be something else blocking S3 deep mode?
More importantly, when I put the computer to sleep with s2idle, it does not wake back properly. The keyboard lights turn on, but I get only a black screen. How can I check / fix what’s wrong?
Here’s the inxi output:
  Kernel: 6.16.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
    root=UUID=b9111baf-dc2f-4649-88e9-978c52ee474a rw nvidia-drm.fbdev=1
    nvidia-drm.modeset=1 quiet splash udev.log_priority=3
  Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.19.0
  Type: Laptop System: Dell product: Dell G15 5530 v: N/A
  Mobo: Dell model: 0RKFTM v: A00 serial: <superuser required> part-nu: 0BF8
    uuid: <superuser required> UEFI: Dell v: 1.28.1 date: 09/08/2025
  ID-1: BAT0 charge: 43.3 Wh (100%) condition: 43.3/54.9 Wh (78.9%)
    health: good temp: 30.1 C volts: 12.61 min: 11.4 model: BYD DELL DVG8M34
    made: 2023-04-02 type: Li-poly serial: <filter> charging:
    status: not charging control: start: 50% end: 90% type: adaptive
    avail: adaptive,custom,fast,standard,trickle cycles: 40
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
    status: discharging
  System RAM: total: 16 GiB available: 15.3 GiB used: 2.91 GiB (19.0%)
  Device-1: DIMM A type: DDR5 detail: synchronous size: 8 GiB
    speed: 4800 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: 80AD000080AD part-no: HMCG66AEBSA092N serial: <filter>
  Device-2: DIMM B type: DDR5 detail: synchronous size: 8 GiB
  Info: model: 13th Gen Intel Core i7-13650HX bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x12F
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
    desc: 1x24 MiB
  Speed (MHz): avg: 800 min/max: 800/4700:4900:3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 112127
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb
    pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
    rep_good sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-S UHD Graphics vendor: Dell driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:a78b class-ID: 0300
  Device-2: NVIDIA GA107BM / GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU]
    vendor: Dell driver: nvidia v: 580.95.05
    alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: none bus-ID: 01:00.0 chip-ID: 10de:25ec class-ID: 0300
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0bda:567e
  Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8.3:6
    chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris
    gpu: i915,nv_platform,nvidia,nvidia-nvswitch d-rect: 3840x1080
    display-ID: 0
  Monitor-1: HDMI-A-1 pos: right model: LG (GoldStar) FHD serial: <filter>
    built: 2024 res: mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 82 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux 0x1522 built: 2020
    res: mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 142 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.4-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
    device-ID: 8086:a78b memory: 14.94 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 3 device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: mesa intel v: 25.2.4-arch1.2
    device-ID: 8086:a78b surfaces: N/A device: 1 type: discrete-gpu name: NVIDIA
    GeForce RTX 3050 6GB Laptop GPU driver: nvidia v: 580.95.05
    device-ID: 10de:25ec surfaces: N/A
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel Raptor Lake High Definition Audio vendor: Dell
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0401
  Device-2: NVIDIA GA107 High Definition Audio driver: snd_hda_intel
    v: kernel alternate: nova_core pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max:
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
  Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.16.12-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
    vendor: Dell driver: r8168 v: 8.055.00 modules: r8169 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 317.83 GiB (66.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA
    model: KBG50ZNS512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 11200109 temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 117.19 GiB size: 114.79 GiB (97.95%)
    used: 83.75 GiB (73.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: b9111baf-dc2f-4649-88e9-978c52ee474a
    used: 70.9 MiB (23.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 57D4-0413
  ID-3: /home raw-size: 359.46 GiB size: 352.75 GiB (98.13%)
    used: 234.01 GiB (66.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 38531c57-fe51-4c6e-b4d0-093b3bb3564f
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  Device-1: 1-3:2 info: Realtek Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0bda:567e class-ID: 0e02 serial: <filter>
  Hub-2: 1-8:3 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-8.2:5 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-2: 1-8.3:6 info: Logitech Webcam C270 type: video,audio
  Device-3: 1-14:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  Hub-4: 2-1:2 info: Genesys Logic Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  System Temperatures: cpu: 52.0 C mobo: 46.0 C sodimm: 44.0 C
  Fan Speeds (rpm): cpu: 2010 fan-2: 2329
  Processes: 383 Power: uptime: 11m states: freeze,mem,disk suspend: s2idle
    image: 6.07 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 257 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1733 libs: 404 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.3 running-in: yakuake inxi: 3.3.39
It looks like it just doesn’t support s3. On linux or at all. This is more common in the last years. Pretty much every laptop from the last years does not have it. Because Microsoft wants it that way.
So i am afraid there is nothing you can do.
About not resuming, seems like some recent bug affecting some users/hardware, several topics about this were opened in the last weeks but i cannot help any further.
Yes, it seems S3 is not supported. But it is funny that the bios carries an option to disable it…
Can you point me to these other reports on bugs when resuming? I’ll search for these as well, but if you can give me a link, I appreciate.
Also, any idea which log should I check to investigate the bug? I’m reading dmesg and systemctl, but so far I don’t identify anything relevant.
There might be a solution here:
But I can only try it tomorrow.
Actually when i look now, the 2-3 topic i had in mind are useless. Rant, no info, another problem or abandoned.
Start by providing inxi -zv8 so that someone more competent than me on suspend matters can help.
The suggestions on the link above didn’t work, I always end up with a BSOD when I try to suspend. I didn’t find anything relevant on my logs. As a last resource, I’ll download a couple of fresh isos from different distributions and try to suspend from live sessions to see if it might be a hidden problem with my current installation. This notebook drags a lot of battery! I really need a good suspend mode working.
PS: on the bright side, it actually boots up quite quickly so I get around, but proper suspend would be better. I hope people fix this issue with f**cking microsoft soon.
Ok, I’ve fixed it. The problem was with the kernel. I was using 6.16.12-1-MANJARO, which works fine on my desktop with nvidia, but the desktop has support for S3. On the notebook, I had to go back to the LTS kernel 6.12 and now it is ok.
Nothing is perfect, so now I’ve noticed that hibernation fails. But I never use it anyway, so I will not try to fix this one for now.
