Hello, I’m new to Manjaro and wanted to try and use but after installation it doesn’t boot! I choose Manjaro through Grub and after that it stuck on Asus boot screen (black screen) but I can access console via Alt + F2 and after that I can use Manjaro without problem by pressing Alt + F1 which opens login screen. But everytime I need to do this. Is there a way to fix this problem?
Welcome to the forum!
I don’t know whether what you are describing is what I am thinking of, but situations like that often occur when the CPU doesn’t develop enough entropy of its own. The good news is that you can remedy this by installing haveged
, which is a random number generator.
sudo pacman -Syu haveged
sudo systemctl enable --now haveged
Try that and see whether it makes it a difference. It won’t do any harm to have that installed anyway.
