Computer is failing to wake up from suspend. Upon wake up, it is freezing on the mobo splash screen, appears to reattempt wake up, then freezes on the splash screen again. Note that it does not normally display splash screen - goes straight to login screen on normal wake up. I have to manually power cycle the computer in order to exit from this stuck state and boot into my desktop.
No changes (hardware / software) were made to my computer outside of regular sudo pacman -Syyu commands in terminal.
Issue started occurring on kernel 5.13 around Oct 20th or so. I installed and booted into 5.14 - problem still persisted. Proceeded to boot into 5.4 and uninstall all additional kernels. Rebooted and installed 5.10 to boot into. Problem still persisted.
I have installed hibernator through pacman and executed hibernator. Upon input of systemctl hibernate I am greeted by an error message along the lines of: "ERROR: resume failed to find device ‘y’ ". Prior to installing hibernator, the following error message would display after executing `systemctl hibernate’: “Error: not enough swap space”. I added a swap file to attempt to alleviate this issue, following another post on this forum to do so. Problem still persisted.
I have updated my bios to the most recent distribution per the manufacturer. Problem still persisted. Computer is dual booted.
GRUB was updated through TTY (ctrl + alt + F2). Problem still persisted.
Have scowered through threads related to “hibernate” and “suspend” issues with zero luck in finding resolution to my issue. No idea where to go from here short of reinstalling manjaro (highly aversed to).
System information:
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=86bf5397-2bac-49b6-a9b6-5ddf7e30000c rw quiet
cryptdevice=UUID=73f1760f-9388-484e-a5df-51bda31c489c:luks-73f1760f-9388-484e-a5df-51bda31c489c
root=/dev/mapper/luks-73f1760f-9388-484e-a5df-51bda31c489c
resume=/dev/mapper/luks-73f1760f-9388-484e-a5df-51bda31c489c apparmor=1
security=apparmor udev.log_priority=3 resume= resume_offset=12920832
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop System: Gigabyte product: Z390 AORUS ULTRA v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS ULTRA-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F10h date: 01/19/2021
RAM: total: 15.56 GiB used: 2.42 GiB (15.5%)
Info: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: D (13)
microcode: EA cache: L2: 16 MiB bogomips: 115232
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1e04 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-11.2:6 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 7680x1440 s-dpi: 108 s-size: 1806x342mm (71.1x13.5")
s-diag: 1838mm (72.4")
Monitor-1: HDMI-0 res: 2560x1440 hz: 75 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DP-0 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-3: DP-2 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: NVIDIA TU102 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f7
class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:8 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Device-1: luks-73f1760f-9388-484e-a5df-51bda31c489c maj-min: 254:0
type: LUKS dm: dm-0 size: 448.33 GiB
Components:
p-1: sdb2 maj-min: 8:18 size: 448.34 GiB
Device-2: luks-d6ab813a-218f-4e0e-8a5a-a711a84b4c8d maj-min: 254:1
type: LUKS dm: dm-1 size: 17.13 GiB
Components:
p-1: sdb3 maj-min: 8:19 size: 17.13 GiB
Local Storage: total: 1.82 TiB used: 84 GiB (4.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
ID-1: / raw-size: 448.33 GiB size: 440.3 GiB (98.21%) used: 84 GiB (19.1%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-73f1760f-9388-484e-a5df-51bda31c489c label: N/A
uuid: 86bf5397-2bac-49b6-a9b6-5ddf7e30000c
used: 436 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 46CB-B87F
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%) priority: -3
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-d6ab813a-218f-4e0e-8a5a-a711a84b4c8d label: N/A
uuid: 6f632559-3111-416e-bd46-4d35263ef749
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 99 MiB fs: vfat label: N/A
uuid: 1AC7-07B3
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.29 GiB fs: ntfs label: N/A
uuid: 26E0C908E0C8DEE5
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-5: /dev/sda2 maj-min: 8:2 size: 465.75 GiB fs: ntfs label: New Volume
uuid: 98B26877B2685C2E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-3:2 info: Microdia Backlit Gaming Keyboard type: Keyboard,Mouse
power: 400mA chip-ID: 0c45:652f class-ID: 0301
Device-2: 1-4:3 info: Holtek USB Gaming Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:ad50 class-ID: 0300
Hub-2: 1-11:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-11.2:6 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-2: 1-12:5 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Hub-3: 1-13:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-13.2:9 info: Corsair H150i Platinum type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 64mA
chip-ID: 1b1c:0c12 class-ID: 0000 serial: <filter>
Device-2: 1-14:8 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 320 Uptime: 5m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1426 lib: 416 flatpak: 0
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
journalctl -b output:
Oct 26 22:49:06 potat sddm[684]: Loading theme configuration from ""
Oct 26 22:49:06 potat sddm[684]: Display server starting...
Oct 26 22:49:06 potat sddm[684]: Adding cookie to "/var/run/sddm/{327b7c42-026a-4734-8420-4040281df6d5}"
Oct 26 22:49:06 potat sddm[684]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{327b7c42-026a-4734-8420-4040281df6d5} -noreset -displayfd 17
Oct 26 22:49:06 potat kernel: loop: module loaded
Oct 26 22:49:06 potat kernel: intel_rapl_common: Found RAPL domain package
Oct 26 22:49:06 potat kernel: intel_rapl_common: Found RAPL domain core
Oct 26 22:49:06 potat kernel: NET: Registered protocol family 42
Oct 26 22:49:06 potat ModemManager[813]: [qrtr] socket lookup from 1:0
Oct 26 22:49:06 potat ModemManager[813]: [qrtr] initial lookup finished
Oct 26 22:49:06 potat systemd[1]: Started Modem Manager.
Oct 26 22:49:06 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:06 potat tlp[835]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Oct 26 22:49:06 potat tlp[835]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Oct 26 22:49:06 potat tlp[835]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Oct 26 22:49:06 potat tlp[835]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Oct 26 22:49:06 potat kernel: ahci 0000:00:17.0: port does not support device sleep
Oct 26 22:49:06 potat kernel: iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
Oct 26 22:49:06 potat kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Oct 26 22:49:06 potat systemd[1]: tmp-sanity\x2dmountpoint\x2d830654157.mount: Deactivated successfully.
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.4245] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:14.3/ieee80211/phy0/rfkill0) (driver iwlwifi)
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.4248] ovsdb: Could not connect: No such file or directory
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.4248] ovsdb: disconnected from ovsdb
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.4251] device (wlo1): driver supports Access Point (AP) mode
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.4254] manager: (wlo1): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.4257] modem-manager: ModemManager available
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.4269] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 26 22:49:06 potat snapd[616]: daemon.go:341: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Oct 26 22:49:06 potat systemd[1]: Started Snap Daemon.
Oct 26 22:49:06 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:06 potat snapd[616]: stateengine.go:150: state ensure error: Get "https://api.snapcraft.io/api/v1/snaps/sections": dial tcp: lookup api.snapcraft.io: no such host
Oct 26 22:49:06 potat mtp-probe[1032]: checking bus 1, device 6: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11.2"
Oct 26 22:49:06 potat mtp-probe[1032]: bus: 1, device: 6 was not an MTP device
Oct 26 22:49:06 potat mtp-probe[1033]: checking bus 1, device 9: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13.2"
Oct 26 22:49:06 potat mtp-probe[1033]: bus: 1, device: 9 was not an MTP device
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.6354] device (wlo1): set-hw-addr: set MAC address to 86:22:F3:DA:8D:6A (scanning)
Oct 26 22:49:06 potat kernel: mousedev: PS/2 mouse device common for all mice
Oct 26 22:49:06 potat systemd-logind[617]: Watching system buttons on /dev/input/event3 (SONiX USB DEVICE)
Oct 26 22:49:06 potat systemd-logind[617]: Watching system buttons on /dev/input/event11 (USB Gaming Mouse Consumer Control)
Oct 26 22:49:06 potat kernel: Bluetooth: Core ver 2.22
Oct 26 22:49:06 potat kernel: NET: Registered protocol family 31
Oct 26 22:49:06 potat kernel: Bluetooth: HCI device and connection manager initialized
Oct 26 22:49:06 potat kernel: Bluetooth: HCI socket layer initialized
Oct 26 22:49:06 potat kernel: Bluetooth: L2CAP socket layer initialized
Oct 26 22:49:06 potat kernel: Bluetooth: SCO socket layer initialized
Oct 26 22:49:06 potat systemd-logind[617]: Watching system buttons on /dev/input/event9 (USB Gaming Mouse Keyboard)
Oct 26 22:49:06 potat systemd-logind[617]: Watching system buttons on /dev/input/event6 (SONiX USB DEVICE Consumer Control)
Oct 26 22:49:06 potat systemd-logind[617]: Watching system buttons on /dev/input/event10 (USB Gaming Mouse System Control)
Oct 26 22:49:06 potat systemd-logind[617]: Watching system buttons on /dev/input/event4 (SONiX USB DEVICE Keyboard)
Oct 26 22:49:06 potat dbus-daemon[612]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.5' (uid=0 pid=613 comm="/usr/bin/NetworkManager --no-daemon ")
Oct 26 22:49:06 potat systemd[1]: Starting WPA supplicant...
Oct 26 22:49:06 potat kernel: usbcore: registered new interface driver btusb
Oct 26 22:49:06 potat kernel: Bluetooth: hci0: Firmware revision 0.1 build 166 week 30 2021
Oct 26 22:49:06 potat systemd[1]: Starting Bluetooth service...
Oct 26 22:49:06 potat bluetoothd[1100]: Bluetooth daemon 5.61
Oct 26 22:49:06 potat systemd[1]: Started Bluetooth service.
Oct 26 22:49:06 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:06 potat systemd[1]: Reached target Bluetooth Support.
Oct 26 22:49:06 potat dbus-daemon[612]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Oct 26 22:49:06 potat systemd[1]: Started WPA supplicant.
Oct 26 22:49:06 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:06 potat wpa_supplicant[1099]: Successfully initialized wpa_supplicant
Oct 26 22:49:06 potat bluetoothd[1100]: Starting SDP server
Oct 26 22:49:06 potat avahi-daemon[610]: Server startup complete. Host name is potat.local. Local service cookie is 2340432933.
Oct 26 22:49:06 potat bluetoothd[1100]: Bluetooth management interface 1.18 initialized
Oct 26 22:49:06 potat kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Oct 26 22:49:06 potat kernel: Bluetooth: BNEP filters: protocol multicast
Oct 26 22:49:06 potat kernel: Bluetooth: BNEP socket layer initialized
Oct 26 22:49:06 potat kernel: NET: Registered protocol family 38
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.9475] device (wlo1): supplicant interface state: internal-starting -> disconnected
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.9475] Wi-Fi P2P device controlled by interface wlo1 created
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.9476] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.9477] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.9480] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 26 22:49:06 potat NetworkManager[613]: <info> [1635302946.9482] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Oct 26 22:49:07 potat systemd[1]: Started xrdp daemon.
Oct 26 22:49:07 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=xrdp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:07 potat systemd[1]: Reached target Multi-User System.
Oct 26 22:49:07 potat systemd[1]: Reached target Graphical Interface.
Oct 26 22:49:07 potat systemd[1]: Starting TLP system startup/shutdown...
Oct 26 22:49:07 potat kernel: mc: Linux media interface: v0.10
Oct 26 22:49:07 potat kernel: videodev: Linux video capture interface: v2.00
Oct 26 22:49:07 potat tlp[1116]: Applying power save settings...done.
Oct 26 22:49:07 potat tlp[1116]: Setting battery charge thresholds...done.
Oct 26 22:49:07 potat systemd[1]: Finished TLP system startup/shutdown.
Oct 26 22:49:07 potat systemd[1]: Startup finished in 7.015s (firmware) + 27.396s (loader) + 7.892s (kernel) + 2.371s (userspace) = 44.675s.
Oct 26 22:49:07 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:08 potat xrdp[809]: [INFO ] starting xrdp with pid 809
Oct 26 22:49:08 potat xrdp[809]: [INFO ] address [0.0.0.0] port [3389] mode 1
Oct 26 22:49:08 potat xrdp[809]: [INFO ] listening to port 3389 on 0.0.0.0
Oct 26 22:49:08 potat xrdp[809]: [INFO ] xrdp_listen_pp done
Oct 26 22:49:08 potat kernel: usb 1-11.2: set resolution quirk: cval->res = 384
Oct 26 22:49:08 potat kernel: usbcore: registered new interface driver snd-usb-audio
Oct 26 22:49:08 potat kernel: uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
Oct 26 22:49:08 potat kernel: input: UVC Camera (046d:0825) as /devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11.2/1-11.2:1.0/input/input29
Oct 26 22:49:08 potat kernel: usbcore: registered new interface driver uvcvideo
Oct 26 22:49:08 potat kernel: USB Video Class driver (1.1.1)
Oct 26 22:49:08 potat sddm[684]: Setting default cursor
Oct 26 22:49:08 potat ModemManager[813]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1f.6': not supported by any plugin
Oct 26 22:49:08 potat ModemManager[813]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
Oct 26 22:49:09 potat kernel: e1000e 0000:00:1f.6 eno2: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
Oct 26 22:49:09 potat kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eno2: link becomes ready
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0007] device (eno2): carrier: link connected
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0013] device (eno2): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0026] policy: auto-activating connection 'Wired connection 1' (ca5a19ca-464b-3f41-ae81-3e09976c02ca)
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0037] device (eno2): Activation: starting connection 'Wired connection 1' (ca5a19ca-464b-3f41-ae81-3e09976c02ca)
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0039] device (eno2): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0045] manager: NetworkManager state is now CONNECTING
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0048] device (eno2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0061] device (eno2): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Oct 26 22:49:09 potat NetworkManager[613]: <info> [1635302949.0064] dhcp4 (eno2): activation: beginning transaction (timeout in 45 seconds)
Oct 26 22:49:09 potat avahi-daemon[610]: Joining mDNS multicast group on interface eno2.IPv6 with address fe80::dff7:a38:2bf5:9b20.
Oct 26 22:49:09 potat avahi-daemon[610]: New relevant interface eno2.IPv6 for mDNS.
Oct 26 22:49:09 potat avahi-daemon[610]: Registering new address record for fe80::dff7:a38:2bf5:9b20 on eno2.*.
Oct 26 22:49:09 potat sddm[684]: Could not setup default cursor
Oct 26 22:49:09 potat sddm[684]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
Oct 26 22:49:09 potat sddm[684]: Display server started.
Oct 26 22:49:09 potat sddm[684]: Socket server starting...
Oct 26 22:49:09 potat sddm[684]: Socket server started.
Oct 26 22:49:09 potat sddm[684]: Loading theme configuration from "/usr/share/sddm/themes/WhiteSur/theme.conf"
Oct 26 22:49:09 potat sddm[684]: Greeter starting...
Oct 26 22:49:09 potat sddm-helper[1298]: [PAM] Starting...
Oct 26 22:49:09 potat audit[1298]: USER_AUTH pid=1298 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:09 potat audit[1298]: USER_ACCT pid=1298 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:09 potat sddm-helper[1298]: [PAM] Authenticating...
Oct 26 22:49:09 potat sddm-helper[1298]: [PAM] returning.
Oct 26 22:49:09 potat audit[1298]: CRED_ACQ pid=1298 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:09 potat sddm-helper[1298]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=968) by (uid=0)
Oct 26 22:49:09 potat systemd[1]: Created slice User Slice of UID 968.
Oct 26 22:49:09 potat systemd[1]: Starting User Runtime Directory /run/user/968...
Oct 26 22:49:09 potat systemd-logind[617]: New session c1 of user sddm.
Oct 26 22:49:09 potat systemd[1]: Finished User Runtime Directory /run/user/968.
Oct 26 22:49:09 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:09 potat systemd[1]: Starting User Manager for UID 968...
Oct 26 22:49:09 potat dbus-daemon[612]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.15' (uid=0 pid=1300 comm="(systemd) ")
Oct 26 22:49:09 potat dbus-daemon[612]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 26 22:49:09 potat systemd[1300]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 26 22:49:09 potat audit[1300]: USER_ACCT pid=1300 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:09 potat audit[1300]: CRED_ACQ pid=1300 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 26 22:49:09 potat systemd[1300]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Oct 26 22:49:09 potat systemd[1300]: pam_unix(systemd-user:session): session opened for user sddm(uid=968) by (uid=0)
Oct 26 22:49:09 potat systemd[1300]: pam_env(systemd-user:session): deprecated reading of user environment enabled
Oct 26 22:49:09 potat audit[1300]: USER_START pid=1300 uid=0 auid=968 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? ad>
Oct 26 22:49:09 potat audit: BPF prog-id=16 op=LOAD
Oct 26 22:49:09 potat audit: BPF prog-id=16 op=UNLOAD
Oct 26 22:49:09 potat systemd[1300]: Queued start job for default target Main User Target.
Oct 26 22:49:09 potat systemd[1300]: Created slice User Application Slice.
Oct 26 22:49:09 potat systemd[1300]: Reached target Paths.
Oct 26 22:49:09 potat systemd[1300]: Reached target Timers.
Oct 26 22:49:09 potat systemd[1300]: Starting D-Bus User Message Bus Socket...
Oct 26 22:49:09 potat systemd[1300]: Listening on GnuPG network certificate management daemon.
Oct 26 22:49:09 potat systemd[1300]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 26 22:49:09 potat systemd[1300]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Oct 26 22:49:09 potat systemd[1300]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Oct 26 22:49:09 potat systemd[1300]: Listening on GnuPG cryptographic agent and passphrase cache.
Oct 26 22:49:09 potat systemd[1300]: Listening on p11-kit server.
Oct 26 22:49:09 potat systemd[1300]: Listening on Multimedia System.
Oct 26 22:49:09 potat systemd[1300]: Listening on Sound System.
Oct 26 22:49:09 potat systemd[1300]: Listening on D-Bus User Message Bus Socket.
Oct 26 22:49:09 potat systemd[1300]: Reached target Sockets.
Oct 26 22:49:09 potat systemd[1300]: Reached target Basic System.
Oct 26 22:49:09 potat systemd[1]: Started User Manager for UID 968.
Oct 26 22:49:09 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:09 potat systemd[1300]: Starting Update XDG user dir configuration...
Oct 26 22:49:09 potat systemd[1]: Started Session c1 of User sddm.
Oct 26 22:49:09 potat systemd[1300]: Finished Update XDG user dir configuration.
Oct 26 22:49:09 potat systemd[1300]: Reached target Main User Target.
Oct 26 22:49:09 potat systemd[1300]: Startup finished in 151ms.
Oct 26 22:49:09 potat audit[1298]: USER_START pid=1298 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Oct 26 22:49:09 potat sddm[684]: Greeter session started successfully
Oct 26 22:49:09 potat sddm-greeter[1309]: High-DPI autoscaling not Enabled
Oct 26 22:49:09 potat sddm-greeter[1309]: Reading from "/usr/share/xsessions/plasma.desktop"
Oct 26 22:49:09 potat sddm-greeter[1309]: Loading theme configuration from "/usr/share/sddm/themes/WhiteSur/theme.conf"
Oct 26 22:49:09 potat systemd[1300]: Started D-Bus User Message Bus.
Oct 26 22:49:10 potat sddm-greeter[1309]: Connected to the daemon.
Oct 26 22:49:10 potat sddm-greeter[1309]: QFont::fromString: Invalid description '(empty)'
Oct 26 22:49:10 potat sddm[684]: Message received from greeter: Connect
Oct 26 22:49:10 potat wpa_supplicant[1099]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Oct 26 22:49:10 potat sddm-greeter[1309]: Loading file:///usr/share/sddm/themes/WhiteSur/Main.qml...
Oct 26 22:49:10 potat sddm-greeter[1309]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffdaefb3f90), parent's thread is QThread(0x559c190f2f80), current thread is QThread(0x559c1927ff20)
Oct 26 22:49:10 potat sddm-greeter[1309]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Oct 26 22:49:11 potat dbus-daemon[612]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=613 comm="/usr/bin/NetworkManager --no-daemon ")
Oct 26 22:49:11 potat dbus-daemon[612]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.0446] dhcp4 (eno2): state changed unknown -> bound, address=192.168.0.157
Oct 26 22:49:11 potat avahi-daemon[610]: Joining mDNS multicast group on interface eno2.IPv4 with address 192.168.0.157.
Oct 26 22:49:11 potat avahi-daemon[610]: New relevant interface eno2.IPv4 for mDNS.
Oct 26 22:49:11 potat avahi-daemon[610]: Registering new address record for 192.168.0.157 on eno2.IPv4.
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.0469] device (eno2): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.0513] device (eno2): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.0517] device (eno2): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.0527] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.0533] manager: NetworkManager state is now CONNECTED_SITE
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.0535] policy: set 'Wired connection 1' (eno2) as default for IPv4 routing and DNS
Oct 26 22:49:11 potat dbus-daemon[612]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.17' (uid=968 pid=1309 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-XwRGPG")
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.0609] device (eno2): Activation: successful, device activated.
Oct 26 22:49:11 potat systemd[1]: Starting Disk Manager...
Oct 26 22:49:11 potat udisksd[1319]: udisks daemon version 2.9.4 starting
Oct 26 22:49:11 potat dbus-daemon[612]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Oct 26 22:49:11 potat systemd[1]: Started Disk Manager.
Oct 26 22:49:11 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:11 potat dbus-daemon[612]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.17' (uid=968 pid=1309 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-XwRGPG")
Oct 26 22:49:11 potat kernel: kauditd_printk_skb: 61 callbacks suppressed
Oct 26 22:49:11 potat kernel: audit: type=1130 audit(1635302951.245:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:11 potat audit: BPF prog-id=17 op=LOAD
Oct 26 22:49:11 potat audit: BPF prog-id=18 op=LOAD
Oct 26 22:49:11 potat kernel: audit: type=1334 audit(1635302951.252:74): prog-id=17 op=LOAD
Oct 26 22:49:11 potat kernel: audit: type=1334 audit(1635302951.252:75): prog-id=18 op=LOAD
Oct 26 22:49:11 potat systemd[1]: Starting Daemon for power management...
Oct 26 22:49:11 potat udisksd[1319]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.3149] manager: NetworkManager state is now CONNECTED_GLOBAL
Oct 26 22:49:11 potat upowerd[1328]: did not recognise USB path /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.3/i2c-0/0-0008/power_supply/ucsi-source-psy-0-00081, please report
Oct 26 22:49:11 potat dbus-daemon[612]: [system] Successfully activated service 'org.freedesktop.UPower'
Oct 26 22:49:11 potat systemd[1]: Started Daemon for power management.
Oct 26 22:49:11 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:11 potat kernel: audit: type=1130 audit(1635302951.405:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:11 potat snapd[616]: daemon.go:508: gracefully waiting for running hooks
Oct 26 22:49:11 potat snapd[616]: daemon.go:510: done waiting for running hooks
Oct 26 22:49:11 potat snapd[616]: daemon stop requested to wait for socket activation
Oct 26 22:49:11 potat systemd[1]: snapd.service: Deactivated successfully.
Oct 26 22:49:11 potat audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:11 potat kernel: audit: type=1131 audit(1635302951.452:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:11 potat sddm-greeter[1309]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 26 22:49:11 potat NetworkManager[613]: <info> [1635302951.4754] manager: startup complete
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Main.qml:453:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/VirtualKeyboard.qml:22:1: Type InputPanel unavailable
Oct 26 22:49:11 potat sddm-greeter[1309]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Oct 26 22:49:11 potat sddm-greeter[1309]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Login.qml:115:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Login.qml:124:5: QML Image: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Login.qml:82:13: Unable to assign [undefined] to QString
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Main.qml:75: TypeError: Cannot read property 'text' of undefined
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Login.qml:73:9: Unable to assign [undefined] to QString
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Main.qml:179:13: Unable to assign [undefined] to QString
Oct 26 22:49:11 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Main.qml:178:13: Unable to assign [undefined] to int
Oct 26 22:49:11 potat sddm-greeter[1309]: Adding view for "HDMI-0" QRect(2560,0 2560x1440)
Oct 26 22:49:11 potat systemd[1]: systemd-rfkill.service: Deactivated successfully.
Oct 26 22:49:11 potat audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:11 potat sddm-greeter[1309]: Loading file:///usr/share/sddm/themes/WhiteSur/Main.qml...
Oct 26 22:49:11 potat kernel: audit: type=1131 audit(1635302951.839:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:11 potat sddm-greeter[1309]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Oct 26 22:49:11 potat sddm-greeter[1309]: Adding view for "DP-0" QRect(5120,0 2560x1440)
Oct 26 22:49:11 potat sddm-greeter[1309]: Adding view for "DP-2" QRect(0,0 2560x1440)
Oct 26 22:49:12 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Login.qml:124:5: QML Image: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Oct 26 22:49:12 potat sddm-greeter[1309]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.18'
Oct 26 22:49:12 potat sddm-greeter[1309]: Message received from daemon: Capabilities
Oct 26 22:49:12 potat sddm-greeter[1309]: Message received from daemon: HostName
Oct 26 22:49:16 potat systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Oct 26 22:49:16 potat audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:16 potat kernel: audit: type=1131 audit(1635302956.055:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:23 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Login.qml:124:5: QML Image: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
Oct 26 22:49:26 potat kernel: sd 2:0:0:0: [sda] Synchronizing SCSI cache
Oct 26 22:49:26 potat kernel: sd 2:0:0:0: [sda] Stopping disk
Oct 26 22:49:28 potat sddm-greeter[1309]: Reading from "/usr/share/xsessions/plasma.desktop"
Oct 26 22:49:28 potat sddm[684]: Message received from greeter: Login
Oct 26 22:49:28 potat sddm[684]: Reading from "/usr/share/xsessions/plasma.desktop"
Oct 26 22:49:28 potat sddm[684]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11"
Oct 26 22:49:28 potat sddm-helper[1360]: [PAM] Starting...
Oct 26 22:49:28 potat sddm-helper[1360]: [PAM] Authenticating...
Oct 26 22:49:28 potat sddm-helper[1360]: [PAM] Preparing to converse...
Oct 26 22:49:28 potat sddm-helper[1360]: [PAM] Conversation with 1 messages
Oct 26 22:49:28 potat sddm-helper[1360]: pam_kwallet5(sddm:auth): (null): pam_sm_authenticate
Oct 26 22:49:28 potat audit[1360]: USER_AUTH pid=1360 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="justinb" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:28 potat sddm-helper[1360]: [PAM] returning.
Oct 26 22:49:28 potat dbus-daemon[612]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.20' (uid=0 pid=1360 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-autha")
Oct 26 22:49:28 potat dbus-daemon[612]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Oct 26 22:49:28 potat sddm-helper[1360]: pam_systemd_home(sddm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 26 22:49:28 potat audit[1360]: USER_ACCT pid=1360 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="justinb" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:28 potat sddm[684]: Authenticated successfully
Oct 26 22:49:28 potat sddm-greeter[1309]: Message received from daemon: LoginSucceeded
Oct 26 22:49:28 potat sddm-helper[1360]: pam_kwallet5(sddm:setcred): pam_kwallet5: pam_sm_setcred
Oct 26 22:49:28 potat audit[1360]: CRED_ACQ pid=1360 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="justinb" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:28 potat kernel: audit: type=1100 audit(1635302968.509:80): pid=1360 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="justinb" exe="/usr/lib/sddm/sddm-helper" hostname=? add>
Oct 26 22:49:28 potat kernel: audit: type=1101 audit(1635302968.509:81): pid=1360 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="justinb" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal>
Oct 26 22:49:28 potat kernel: audit: type=1103 audit(1635302968.509:82): pid=1360 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="justinb" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? ter>
Oct 26 22:49:28 potat kernel: audit: type=1006 audit(1635302968.509:83): pid=1360 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Oct 26 22:49:28 potat sddm-helper[1360]: pam_unix(sddm:session): session opened for user justinb(uid=1000) by (uid=0)
Oct 26 22:49:28 potat systemd[1]: Created slice User Slice of UID 1000.
Oct 26 22:49:28 potat systemd[1]: Starting User Runtime Directory /run/user/1000...
Oct 26 22:49:28 potat systemd-logind[617]: New session 2 of user justinb.
Oct 26 22:49:28 potat systemd[1]: Finished User Runtime Directory /run/user/1000.
Oct 26 22:49:28 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:28 potat systemd[1]: Starting User Manager for UID 1000...
Oct 26 22:49:28 potat kernel: audit: type=1130 audit(1635302968.519:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:28 potat dbus-daemon[612]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.22' (uid=0 pid=1362 comm="(systemd) ")
Oct 26 22:49:28 potat systemd[1362]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Oct 26 22:49:28 potat audit[1362]: USER_ACCT pid=1362 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="justinb" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:28 potat audit[1362]: CRED_ACQ pid=1362 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="justinb" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 26 22:49:28 potat systemd[1362]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[justinb] ruser=[<unknown>] rhost=[<unknown>]
Oct 26 22:49:28 potat systemd[1362]: pam_unix(systemd-user:session): session opened for user justinb(uid=1000) by (uid=0)
Oct 26 22:49:28 potat systemd[1362]: pam_env(systemd-user:session): deprecated reading of user environment enabled
Oct 26 22:49:28 potat audit[1362]: USER_START pid=1362 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="justinb" exe="/usr/lib/systemd/systemd" hostname=>
Oct 26 22:49:28 potat kernel: audit: type=1101 audit(1635302968.522:85): pid=1362 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="justinb" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=>
Oct 26 22:49:28 potat kernel: audit: type=1103 audit(1635302968.522:86): pid=1362 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="justinb" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 26 22:49:28 potat kernel: audit: type=1006 audit(1635302968.522:87): pid=1362 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
Oct 26 22:49:28 potat kernel: audit: type=1105 audit(1635302968.522:88): pid=1362 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="justinb" exe="/usr/lib>
Oct 26 22:49:28 potat audit: BPF prog-id=19 op=LOAD
Oct 26 22:49:28 potat audit: BPF prog-id=19 op=UNLOAD
Oct 26 22:49:28 potat kernel: audit: type=1334 audit(1635302968.525:89): prog-id=19 op=LOAD
Oct 26 22:49:28 potat systemd-xdg-autostart-generator[1368]: /home/justinb/.config/autostart/org.kde.latte-dock.desktop:96: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Oct 26 22:49:28 potat systemd-xdg-autostart-generator[1368]: Configuration file /home/justinb/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Main.qml:421: TypeError: Cannot read property 'smallSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/Battery.qml:27: TypeError: Cannot read property 'smallSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Main.qml:157: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/ActionButton.qml:102: TypeError: Cannot read property 'smallSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/ActionButton.qml:39: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/ActionButton.qml:55: TypeError: Cannot read property 'smallSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/ActionButton.qml:41: TypeError: Cannot read property 'largeSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/ActionButton.qml:42: TypeError: Cannot read property 'smallSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/SessionManagementScreen.qml:84: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/SessionManagementScreen.qml:114: TypeError: Cannot read property 'largeSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/SessionManagementScreen.qml:100: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/SessionManagementScreen.qml:101: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/SessionManagementScreen.qml:91: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/UserDelegate.qml:103: TypeError: Cannot read property 'largeSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/UserDelegate.qml:44: TypeError: Cannot read property 'smallSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/UserDelegate.qml:69: TypeError: Cannot read property 'largeSpacing' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/UserDelegate.qml:95: TypeError: Cannot read property 'gridUnit' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/UserDelegate.qml:75: TypeError: Cannot read property 'longDuration' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/components/UserDelegate.qml:50: TypeError: Cannot read property 'longDuration' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Main.qml:241: TypeError: Cannot read property 'longDuration' of null
Oct 26 22:49:28 potat sddm-greeter[1309]: file:///usr/share/sddm/themes/WhiteSur/Main.qml:426: TypeError: Cannot read property 'longDuration' of null
Oct 26 22:49:28 potat sddm-helper[1298]: [PAM] Closing session
Oct 26 22:49:28 potat sddm-helper[1298]: pam_unix(sddm-greeter:session): session closed for user sddm
Oct 26 22:49:28 potat systemd[1362]: Queued start job for default target Main User Target.
Oct 26 22:49:28 potat systemd[1362]: Created slice User Application Slice.
Oct 26 22:49:28 potat systemd[1362]: Reached target Paths.
Oct 26 22:49:28 potat audit[1298]: USER_END pid=1298 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Oct 26 22:49:28 potat audit[1298]: CRED_DISP pid=1298 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Oct 26 22:49:28 potat systemd[1362]: Reached target Timers.
Oct 26 22:49:28 potat sddm-helper[1298]: [PAM] Ended.
Oct 26 22:49:28 potat systemd[1362]: Starting D-Bus User Message Bus Socket...
Oct 26 22:49:28 potat systemd[1362]: Listening on GnuPG network certificate management daemon.
Oct 26 22:49:28 potat systemd[1362]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 26 22:49:28 potat systemd[1362]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Oct 26 22:49:28 potat systemd[1362]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Oct 26 22:49:28 potat systemd[1362]: Listening on GnuPG cryptographic agent and passphrase cache.
Oct 26 22:49:28 potat systemd[1362]: Listening on p11-kit server.
Oct 26 22:49:28 potat systemd[1362]: Listening on Multimedia System.
Oct 26 22:49:28 potat systemd[1362]: Listening on Sound System.
Oct 26 22:49:28 potat sddm[684]: Auth: sddm-helper exited successfully
Oct 26 22:49:28 potat sddm[684]: Greeter stopped.
Oct 26 22:49:28 potat systemd[1]: session-c1.scope: Deactivated successfully.
Oct 26 22:49:28 potat systemd[1]: session-c1.scope: Consumed 2.195s CPU time.
Oct 26 22:49:28 potat systemd-logind[617]: Session c1 logged out. Waiting for processes to exit.
Oct 26 22:49:28 potat systemd-logind[617]: Removed session c1.
Oct 26 22:49:28 potat systemd[1362]: Listening on D-Bus User Message Bus Socket.
Oct 26 22:49:28 potat systemd[1362]: Reached target Sockets.
Oct 26 22:49:28 potat systemd[1362]: Reached target Basic System.
Oct 26 22:49:28 potat systemd[1]: Started User Manager for UID 1000.
Oct 26 22:49:28 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:28 potat systemd[1362]: Starting Update XDG user dir configuration...
Oct 26 22:49:28 potat systemd[1]: Started Session 2 of User justinb.
Oct 26 22:49:28 potat systemd[1362]: Finished Update XDG user dir configuration.
Oct 26 22:49:28 potat systemd[1362]: Reached target Main User Target.
Oct 26 22:49:28 potat systemd[1362]: Startup finished in 85ms.
Oct 26 22:49:28 potat sddm-helper[1360]: pam_env(sddm:session): deprecated reading of user environment enabled
Oct 26 22:49:28 potat sddm-helper[1360]: pam_kwallet5(sddm:session): pam_kwallet5: pam_sm_open_session
Oct 26 22:49:28 potat sddm-helper[1374]: pam_kwallet5: final socket path: /run/user/1000/kwallet5.socket
Oct 26 22:49:28 potat audit[1360]: USER_START pid=1360 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="justinb" exe="/usr/lib/sddm/sddm-helper" hostname>
Oct 26 22:49:28 potat sddm-helper[1360]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Oct 26 22:49:28 potat sddm-helper[1376]: Adding cookie to "/home/justinb/.Xauthority"
Oct 26 22:49:28 potat sddm[684]: Session started
Oct 26 22:49:28 potat systemd[1362]: Started D-Bus User Message Bus.
Oct 26 22:49:28 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating service name='org.kde.KSplash' requested by ':1.2' (uid=1000 pid=1376 comm="/usr/bin/startplasma-x11 ")
Oct 26 22:49:28 potat systemd[1362]: Reloading.
Oct 26 22:49:28 potat systemd-xdg-autostart-generator[1404]: /home/justinb/.config/autostart/org.kde.latte-dock.desktop:96: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Oct 26 22:49:28 potat systemd-xdg-autostart-generator[1404]: Configuration file /home/justinb/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 26 22:49:28 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.kde.KSplash'
Oct 26 22:49:29 potat klauncher[1430]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Oct 26 22:49:29 potat kcminit_startup[1435]: Initializing "kcm_mouse" : "kcminit_mouse"
Oct 26 22:49:29 potat kcminit_startup[1435]: Initializing "kcm_style" : "kcminit_style"
Oct 26 22:49:29 potat kcminit_startup[1435]: QDBusConnection: error: could not send signal to service "" path "//home/justinb/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/justinb/.kde4/share/config/kdeglobals
Oct 26 22:49:29 potat plasma_session[1407]: org.kde.plasma.session: process job "kcminit_startup" finished with exit code 0
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating via systemd: service name='org.kde.kglobalaccel' unit='plasma-kglobalaccel.service' requested by ':1.8' (uid=1000 pid=1445 comm="/usr/bin/kded5 ")
Oct 26 22:49:30 potat systemd[1362]: Created slice User Background Tasks Slice.
Oct 26 22:49:30 potat systemd[1362]: Starting KDE Global Shortcuts Server...
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.kde.kglobalaccel'
Oct 26 22:49:30 potat systemd[1362]: Started KDE Global Shortcuts Server.
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.9' (uid=1000 pid=1445 comm="/usr/bin/kded5 ")
Oct 26 22:49:30 potat systemd[1362]: Starting User preferences database...
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'ca.desrt.dconf'
Oct 26 22:49:30 potat systemd[1362]: Started User preferences database.
Oct 26 22:49:30 potat kded5[1445]: bluedevil: Created
Oct 26 22:49:30 potat kded5[1445]: Installing the delayed initialization callback.
Oct 26 22:49:30 potat NetworkManager[613]: <info> [1635302970.4596] agent-manager: agent[748fde56061c83f6,:1.25/org.kde.plasma.networkmanagement/1000]: agent registered
Oct 26 22:49:30 potat kded5[1445]: kcm_touchpad: Using X11 backend
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5093:48: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:47: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5099:46: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:48: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5111:46: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5113:46: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5117:45: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5120:46: this compose sequence is a duplicate of another; skipping line
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: Couldn't process include statement for 'us(\0)'
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: Abandoning symbols file "(unnamed)"
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: Failed to compile xkb_symbols
Oct 26 22:49:30 potat kwin_x11[1449]: kwin_xkbcommon: XKB: Failed to compile keymap
Oct 26 22:49:30 potat kded5[1445]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
Oct 26 22:49:30 potat kded5[1445]: Delayed initialization.
Oct 26 22:49:30 potat kded5[1445]: Reloading the khotkeys configuration
Oct 26 22:49:30 potat kded5[1445]: Version 2 File!
Oct 26 22:49:30 potat kded5[1445]: true
Oct 26 22:49:30 potat kded5[1445]: Imported file "/usr/share/khotkeys/defaults.khotkeys"
Oct 26 22:49:30 potat kded5[1445]: Imported file "/usr/share/khotkeys/kde32b1.khotkeys"
Oct 26 22:49:30 potat kded5[1445]: Imported file "/usr/share/khotkeys/konqueror_gestures_kde321.khotkeys"
Oct 26 22:49:30 potat kded5[1445]: Imported file "/usr/share/khotkeys/konsole.khotkeys"
Oct 26 22:49:30 potat kded5[1445]: bluedevil: ObexManager operational changed false
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating service name='org.kde.KScreen' requested by ':1.8' (uid=1000 pid=1445 comm="/usr/bin/kded5 ")
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.8' (uid=1000 pid=1445 comm="/usr/bin/kded5 ")
Oct 26 22:49:30 potat systemd[1362]: Starting Bluetooth OBEX service...
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating service name='org.freedesktop.Notifications' requested by ':1.8' (uid=1000 pid=1445 comm="/usr/bin/kded5 ")
Oct 26 22:49:30 potat obexd[1505]: OBEX daemon 5.61
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.bluez.obex'
Oct 26 22:49:30 potat systemd[1362]: Started Bluetooth OBEX service.
Oct 26 22:49:30 potat kernel: Bluetooth: RFCOMM TTY layer initialized
Oct 26 22:49:30 potat kernel: Bluetooth: RFCOMM socket layer initialized
Oct 26 22:49:30 potat kernel: Bluetooth: RFCOMM ver 1.11
Oct 26 22:49:30 potat kded5[1445]: bluedevil: Bluetooth operational changed true
Oct 26 22:49:30 potat kded5[1445]: bluedevil: Agent registered
Oct 26 22:49:30 potat kded5[1445]: bluedevil: Requested default Agent
Oct 26 22:49:30 potat ksmserver[1499]: Qt: Session management error: networkIdsList argument is NULL
Oct 26 22:49:30 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.kde.KScreen'
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Connected output 445 to CRTC 442
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Connected output 476 to CRTC 443
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Connected output 485 to CRTC 441
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Detected XRandR 1.6
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Event Base: 89
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Event Error: 147
Oct 26 22:49:30 potat kded5[1445]: kscreen.kded: PowerDevil SuspendSession action not available!
Oct 26 22:49:30 potat kcminit_startup[1435]: Initializing "kcm_kgamma" : "kcminit_kgamma"
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: XRandR::setConfig
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Requested screen size is QSize(7680, 1440)
Oct 26 22:49:30 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/kaccess.desktop" ("/usr/bin/kaccess")
Oct 26 22:49:30 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/baloo_file.desktop" ("/usr/lib/baloo_file")
Oct 26 22:49:30 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pam_kwallet_init.desktop" ("/usr/lib/pam_kwallet_init")
Oct 26 22:49:30 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/polkit-kde-authentication-agent-1.desktop" ("/usr/lib/polkit-kde-authentication-agent-1")
Oct 26 22:49:30 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/xembedsniproxy.desktop" ("/usr/bin/xembedsniproxy")
Oct 26 22:49:30 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/org.kde.plasmashell.desktop" ("/usr/bin/plasmashell")
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Needed CRTCs: 3
Oct 26 22:49:30 potat kaccess[1518]: Xlib XKB extension major= 1 minor= 0
Oct 26 22:49:30 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/powerdevil.desktop" ("/usr/lib/org_kde_powerdevil")
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Actions to perform:
Primary Output: true
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Old: 445
New: 485
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Change Screen Size: false
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Disable outputs: false
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Change outputs: true
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: (445, 476, 485)
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Enable outputs: false
Oct 26 22:49:30 potat kscreen_backend_launcher[1504]: kscreen.xrandr: RRSetCrtcConfig (change output)
Output: 445 ( "HDMI-0" )
CRTC: 442
Pos: QPoint(0,0)
Mode: 446 KScreen::Mode(Id: "446" , Size: QSize(2560, 1440) @ 74.9949 )
Rotation: KScreen::Output::None
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Result: 0
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: XRandROutput 445 update
m_connected: 0
m_crtc XRandRCrtc(0x558bcbf6c270)
CRTC: 442
MODE: 446
Connection: 0
Primary: false
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: RRSetCrtcConfig (change output)
Output: 476 ( "DP-0" )
CRTC: 443
Pos: QPoint(5120,0)
Mode: 477 KScreen::Mode(Id: "477" , Size: QSize(2560, 1440) @ 143.973 )
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: XRandROutput 476 update
m_connected: 0
m_crtc XRandRCrtc(0x558bcbf6bc20)
CRTC: 443
MODE: 477
Connection: 0
Primary: false
Output: 485 ( "DP-2" )
CRTC: 441
Pos: QPoint(2560,0)
Mode: 486 KScreen::Mode(Id: "486" , Size: QSize(2560, 1440) @ 144 )
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: XRandROutput 485 update
m_connected: 0
m_crtc XRandRCrtc(0x558bcbf6c450)
CRTC: 441
MODE: 486
Connection: 0
Primary: true
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: RRSetOutputPrimary
New primary: 485
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: XRandR::setConfig done!
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: RRNotify_CrtcChange
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: CRTC: 442
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Mode: 446
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Rotation: "Rotate_0"
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Geometry: 0 0 2560 1440
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: RRScreenChangeNotify
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Window: 27262981
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Root: 496
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Size ID: 65535
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Size: 7680 1440
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: SizeMM: 1806 342
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: CRTC: 441
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Mode: 486
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Geometry: 2560 0 2560 1440
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: RRNotify_OutputChange
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Output: 445
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Connection: "Connected"
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Subpixel Order: 0
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xcb.helper: Output: 485
m_connected: 0
CRTC: 442
MODE: 446
Connection: 0
Primary: false
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Output 445 : connected = true , enabled = true
m_connected: 0
CRTC: 441
MODE: 486
Connection: 0
Primary: true
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Output 485 : connected = true , enabled = true
m_connected: 0
CRTC: 442
MODE: 446
Connection: 0
Primary: false
m_connected: 0
CRTC: 441
MODE: 486
Connection: 0
Primary: true
Oct 26 22:49:31 potat kcminit_startup[1435]: Initializing "kded_touchpad" : "kcminit_touchpad"
Oct 26 22:49:31 potat kcminit_startup[1435]: kcm_touchpad: Using X11 backend
Oct 26 22:49:31 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/home/justinb/.config/autostart/org.kde.latte-dock.desktop" ("/usr/bin/latte-dock")
Oct 26 22:49:31 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/gmenudbusmenuproxy.desktop" ("/usr/bin/gmenudbusmenuproxy")
Oct 26 22:49:31 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/org.kde.kdeconnect.daemon.desktop" ("/usr/lib/kdeconnectd")
Oct 26 22:49:31 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pulseaudio.desktop" ("/usr/bin/start-pulseaudio-x11")
Oct 26 22:49:31 potat systemd[1362]: Created slice User Core Session Slice.
Oct 26 22:49:31 potat systemd[1362]: Starting Sound Service...
Oct 26 22:49:31 potat systemd[1362]: Started Latte - Dock.
Oct 26 22:49:31 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating via systemd: service name='org.kde.ActivityManager' unit='plasma-kactivitymanagerd.service' requested by ':1.19' (uid=1000 pid=1532 comm="/usr/lib/org_kde_powerdevil ")
Oct 26 22:49:31 potat dbus-daemon[612]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.30' (uid=1000 pid=1551 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo")
Oct 26 22:49:31 potat systemd[1362]: Starting KActivityManager Activity manager Service...
Oct 26 22:49:31 potat systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Oct 26 22:49:31 potat dbus-daemon[612]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Oct 26 22:49:31 potat systemd[1]: Started RealtimeKit Scheduling Policy Service.
Oct 26 22:49:31 potat audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:31 potat rtkit-daemon[1559]: Successfully called chroot.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Successfully dropped privileges.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Successfully limited resources.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Canary thread running.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Watchdog thread running.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Running.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Successfully made thread 1551 of process 1551 owned by '1000' high priority at nice level -11.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Supervising 1 threads of 1 processes of 1 users.
Oct 26 22:49:31 potat dbus-daemon[612]: [system] Activating service name='org.kde.powerdevil.discretegpuhelper' requested by ':1.29' (uid=1000 pid=1532 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
Oct 26 22:49:31 potat dbus-daemon[612]: [system] Successfully activated service 'org.kde.powerdevil.discretegpuhelper'
Oct 26 22:49:31 potat dbus-daemon[612]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.29' (uid=1000 pid=1532 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
Oct 26 22:49:31 potat kded5[1445]: bluedevil: ObexManager operational changed true
Oct 26 22:49:31 potat kded5[1445]: bluedevil: ObexAgent registered
Oct 26 22:49:31 potat dbus-daemon[612]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
Oct 26 22:49:31 potat polkit-kde-authentication-agent-1[1524]: New PolkitAgentListener 0x55dbfc357e00
Oct 26 22:49:31 potat polkit-kde-authentication-agent-1[1524]: Adding new listener PolkitQt1::Agent::Listener(0x55dbfc65dc50) for 0x55dbfc357e00
Oct 26 22:49:31 potat dbus-daemon[612]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.29' (uid=1000 pid=1532 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
Oct 26 22:49:31 potat polkit-kde-authentication-agent-1[1524]: Listener online
Oct 26 22:49:31 potat polkitd[615]: Registered Authentication Agent for unix-session:2 (system bus name :1.40 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Oct 26 22:49:31 potat polkit-kde-authentication-agent-1[1524]: Authentication agent result: true
Oct 26 22:49:31 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.kde.ActivityManager'
Oct 26 22:49:31 potat systemd[1362]: Started KActivityManager Activity manager Service.
Oct 26 22:49:31 potat backlighthelper[1583]: org.kde.powerdevil: no kernel backlight interface found
Oct 26 22:49:31 potat kaccess[1518]: X server XKB extension major= 1 minor= 0
Oct 26 22:49:31 potat dbus-daemon[612]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Oct 26 22:49:31 potat org_kde_powerdevil[1532]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 26 22:49:31 potat kwin_x11[1449]: qml: FORCE-BLUR: starting the script
Oct 26 22:49:31 potat kwin_x11[1449]: qml: ["yakuake","urxvt","keepassxc"]
Oct 26 22:49:31 potat org_kde_powerdevil[1532]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Oct 26 22:49:31 potat systemd[1362]: Started Manjaro Notifier KDE Settings.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Successfully made thread 1601 of process 1551 owned by '1000' RT at priority 5.
Oct 26 22:49:31 potat rtkit-daemon[1559]: Supervising 2 threads of 1 processes of 1 users.
Oct 26 22:49:31 potat org_kde_powerdevil[1532]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Oct 26 22:49:31 potat org_kde_powerdevil[1532]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 26 22:49:31 potat kwin_x11[1449]: kwin_core: XCB error: 10 (BadAccess), sequence: 907, resource id: 496, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Oct 26 22:49:31 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1003, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:31 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1035, resource id: 25165830, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:31 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1039, resource id: 25165831, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:31 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1063, resource id: 25165832, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:31 potat kwin_x11[1449]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Oct 26 22:49:31 potat kwin_x11[1449]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Oct 26 22:49:31 potat kwin_x11[1449]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
Oct 26 22:49:31 potat kwin_x11[1449]: kf.config.core: "\"fsrestore4\" - conversion of \"0,0,0,0\" to QRect failed"
Oct 26 22:49:31 potat kwin_x11[1449]: kf.config.core: "\"fsrestore5\" - conversion of \"0,0,0,0\" to QRect failed"
Oct 26 22:49:31 potat kwin_x11[1449]: kf.config.core: "\"fsrestore6\" - conversion of \"0,0,0,0\" to QRect failed"
Oct 26 22:49:31 potat kscreen_backend_launcher[1504]: kscreen.xrandr: Emitting configChanged()
Oct 26 22:49:31 potat kernel: usb 1-11.2: reset high-speed USB device number 6 using xhci_hcd
Oct 26 22:49:31 potat systemd[1362]: Started Yakuake - Drop-down Terminal.
Oct 26 22:49:31 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1067, resource id: 25165833, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:31 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1131, resource id: 25165834, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:31 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1135, resource id: 25165835, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:31 potat kded5[1445]: Registering ":1.30/StatusNotifierItem" to system tray
Oct 26 22:49:31 potat plasmashell[1530]: kf.plasma.quick: Applet preload policy set to 1
Oct 26 22:49:31 potat systemd[1362]: Started /usr/bin/pamac-tray-plasma.
Oct 26 22:49:32 potat latte-dock[1542]: "An instance is already running!, use --replace to restart Latte"
Oct 26 22:49:32 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1322, resource id: 50331656, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:32 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating via systemd: service name='org.kde.ksystemstats' unit='plasma-ksystemstats.service' requested by ':1.28' (uid=1000 pid=1530 comm="/usr/bin/plasmashell ")
Oct 26 22:49:32 potat systemd[1362]: Starting Track hardware statistics...
Oct 26 22:49:32 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pamac-tray-plasma.desktop" ("/usr/bin/pamac-tray-plasma")
Oct 26 22:49:32 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/snapshot-detect.desktop" ("/usr/bin/snapshot-detect")
Oct 26 22:49:32 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/home/justinb/.config/autostart/manjaro-hello.desktop" ("/usr/bin/manjaro-hello")
Oct 26 22:49:32 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/xapp-sn-watcher.desktop" ("/usr/lib/xapps/sn-watcher/xapp-sn-watcher")
Oct 26 22:49:32 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/msm_kde_notifier.desktop" ("/usr/bin/msm_kde_notifier")
Oct 26 22:49:32 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/home/justinb/.config/autostart/org.kde.yakuake.desktop" ("/usr/bin/yakuake")
Oct 26 22:49:32 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/snap-userd-autostart.desktop" ("/bin/snap", "userd", "--autostart")
Oct 26 22:49:32 potat plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/geoclue-demo-agent.desktop" ("/usr/lib/geoclue-2.0/demos/agent")
Oct 26 22:49:32 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.39' (uid=1000 pid=1613 comm="/usr/bin/pamac-tray-plasma -session 10e46f74610001")
Oct 26 22:49:32 potat systemd[1362]: Starting Virtual filesystem service...
Oct 26 22:49:32 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.gtk.vfs.Daemon'
Oct 26 22:49:32 potat systemd[1362]: Started Virtual filesystem service.
Oct 26 22:49:32 potat kded5[1445]: Registering ":1.35/StatusNotifierItem" to system tray
Oct 26 22:49:32 potat audit[613]: USYS_CONFIG pid=613 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="eno2" ifindex=2 args=500 pid=1615 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:32 potat NetworkManager[613]: <info> [1635302972.2641] audit: op="statistics" interface="eno2" ifindex=2 args="500" pid=1615 uid=1000 result="success"
Oct 26 22:49:32 potat audit[613]: USYS_CONFIG pid=613 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="wlo1" ifindex=3 args=500 pid=1615 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Oct 26 22:49:32 potat NetworkManager[613]: <info> [1635302972.2706] audit: op="statistics" interface="wlo1" ifindex=3 args="500" pid=1615 uid=1000 result="success"
Oct 26 22:49:32 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.kde.ksystemstats'
Oct 26 22:49:32 potat systemd[1362]: Started Track hardware statistics.
Oct 26 22:49:32 potat NetworkManager[613]: <info> [1635302972.3081] audit: op="statistics" interface="wlo1" ifindex=3 args="500" pid=1615 uid=1000 result="success"
Oct 26 22:49:32 potat msm_kde_notifier[1630]: MSM Notifier is already running, shutting down.
Oct 26 22:49:32 potat msm_kde_notifier[1630]: Shutting down MSM Notifier...
Oct 26 22:49:32 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1542, resource id: 58720261, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:49:32 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.46' (uid=1000 pid=1625 comm="python3 /usr/bin/manjaro-hello ")
Oct 26 22:49:32 potat systemd[1362]: Starting Accessibility services bus...
Oct 26 22:49:32 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.a11y.Bus'
Oct 26 22:49:32 potat systemd[1362]: Started Accessibility services bus.
Oct 26 22:49:32 potat at-spi-bus-launcher[1697]: dbus-daemon[1697]: Activating service name='org.a11y.atspi.Registry' requested by ':1.1' (uid=1000 pid=1598 comm="/usr/bin/msm_kde_notifier -session 10e46f746100015")
Oct 26 22:49:32 potat at-spi-bus-launcher[1697]: dbus-daemon[1697]: Successfully activated service 'org.a11y.atspi.Registry'
Oct 26 22:49:32 potat at-spi-bus-launcher[1699]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Oct 26 22:49:32 potat kded5[1445]: Registering ":1.43/StatusNotifierItem" to system tray
Oct 26 22:49:32 potat plasmashell[1530]: trying to show an empty dialog
Oct 26 22:49:32 potat plasmashell[1530]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
Oct 26 22:49:32 potat kwin_x11[1449]: kwin_core: XCB error: 3 (BadWindow), sequence: 2690, resource id: 16777355, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Oct 26 22:49:33 potat rtkit-daemon[1559]: Supervising 2 threads of 1 processes of 1 users.
Oct 26 22:49:33 potat rtkit-daemon[1559]: Successfully made thread 1717 of process 1551 owned by '1000' RT at priority 5.
Oct 26 22:49:33 potat rtkit-daemon[1559]: Supervising 3 threads of 1 processes of 1 users.
Oct 26 22:49:33 potat rtkit-daemon[1559]: Successfully made thread 1732 of process 1551 owned by '1000' RT at priority 5.
Oct 26 22:49:33 potat rtkit-daemon[1559]: Supervising 4 threads of 1 processes of 1 users.
Oct 26 22:49:33 potat rtkit-daemon[1559]: Successfully made thread 1734 of process 1551 owned by '1000' RT at priority 5.
Oct 26 22:49:33 potat rtkit-daemon[1559]: Supervising 5 threads of 1 processes of 1 users.
Oct 26 22:49:33 potat pulseaudio[1551]: module-combine is deprecated: Please use module-combine-sink instead of module-combine!
Oct 26 22:49:33 potat pulseaudio[1551]: We will now load module-combine-sink. Please make sure to remove module-combine from your configuration.
Oct 26 22:49:33 potat rtkit-daemon[1559]: Successfully made thread 1741 of process 1551 owned by '1000' RT at priority 6.
Oct 26 22:49:33 potat rtkit-daemon[1559]: Supervising 6 threads of 1 processes of 1 users.
Oct 26 22:49:33 potat pulseaudio[1551]: Failed to parse module arguments.
Oct 26 22:49:33 potat pulseaudio[1551]: Failed to load module "module-remap-source" (argument: "source_name=record_mono master=alsa_input.pci-0000_00_1f.3.analog-stereo master_channel_map=front-left channel_map-mono set-default-source record_mono"): initialization failed.
Oct 26 22:49:33 potat systemd[1362]: Started Sound Service.
Oct 26 22:49:33 potat bluetoothd[1100]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSink/sbc
Oct 26 22:49:33 potat bluetoothd[1100]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSource/sbc
Oct 26 22:49:33 potat bluetoothd[1100]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Oct 26 22:49:33 potat bluetoothd[1100]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Oct 26 22:49:33 potat bluetoothd[1100]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Oct 26 22:49:33 potat bluetoothd[1100]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Oct 26 22:49:33 potat bluetoothd[1100]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Oct 26 22:49:33 potat bluetoothd[1100]: Endpoint registered: sender=:1.53 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Oct 26 22:49:34 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.plasma.panelspacer/contents/ui/main.qml:53:5: Unable to assign [undefined] to QQuickGridLayout*
Oct 26 22:49:34 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.milou/contents/ui/main.qml:47:17: Unable to assign double to QQuickAnchorLine
Oct 26 22:49:34 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:56:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Oct 26 22:49:35 potat plasmashell[1530]: Loading Calendar plugin HolidaysEventsPlugin(0x5624cb2dc200)
Oct 26 22:49:35 potat plasmashell[1530]: Loading Calendar plugin AstronomicalEventsPlugin(0x5624c8fd6a00)
Oct 26 22:49:35 potat plasmashell[1530]: file:///home/justinb/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/calendars/PlasmaCalendarManager.qml:16: Error: Qt.createQmlObject(): failed to create object:
file:///home/justinb/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/calendars/inline:1:1: module "org.kde.plasma.PimCalendars" is not installed
Oct 26 22:49:35 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:56:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
Oct 26 22:49:35 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Oct 26 22:49:35 potat plasmashell[1530]: trying to show an empty dialog
Oct 26 22:49:35 potat plasmashell[1530]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml:35:1: QML CompactRepresentation: Binding loop detected for property "implicitHeight"
Oct 26 22:49:35 potat plasmashell[1530]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:98:13: Unable to assign [undefined] to int
Oct 26 22:49:35 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.plasma.panelspacer/contents/ui/main.qml:53:5: Unable to assign [undefined] to QQuickGridLayout*
Oct 26 22:49:35 potat plasmashell[1530]: 5
Oct 26 22:49:35 potat plasmashell[1530]: libkcups: CUPS-Get-Printers last error: 1282 Bad file descriptor
Oct 26 22:49:35 potat plasmashell[1530]: libkcups: Create-Printer-Subscriptions last error: 1282 Bad file descriptor
Oct 26 22:49:35 potat plasmashell[1530]: libkcups: Request failed 1282 -1
Oct 26 22:49:35 potat plasmashell[1530]: libkcups: Get-Jobs last error: 1282 Bad file descriptor
Oct 26 22:49:36 potat plasmashell[1530]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Oct 26 22:49:36 potat dbus-daemon[1385]: [session uid=1000 pid=1385] Successfully activated service 'org.freedesktop.Notifications'
Oct 26 22:50:27 potat systemd-timesyncd[606]: Initial synchronization to time server 37.59.63.125:123 (2.manjaro.pool.ntp.org).
Oct 26 22:50:27 potat kded5[1445]: Registering "org.kde.StatusNotifierHost-1530" as system tray
Oct 26 22:50:27 potat plasmashell[1530]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 26 22:50:28 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:75:17: Unable to assign [undefined] to int
Oct 26 22:50:28 potat plasmashell[1530]: libkcups: CUPS-Get-Printers last error: 1282 Bad file descriptor
Oct 26 22:50:28 potat plasmashell[1530]: libkcups: Get-Jobs last error: 1282 Bad file descriptor
Oct 26 22:50:28 potat plasmashell[1530]: Plasma Shell startup completed
Oct 26 22:50:28 potat plasmashell[1530]: trying to show an empty dialog
Oct 26 22:50:28 potat plasmashell[1530]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
Oct 26 22:50:28 potat kwin_x11[1449]: kwin_core: XCB error: 152 (BadDamage), sequence: 7292, resource id: 16777248, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Oct 26 22:50:28 potat kwin_x11[1449]: kwin_core: XCB error: 152 (BadDamage), sequence: 7312, resource id: 16777249, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Oct 26 22:50:28 potat kwin_x11[1449]: kwin_core: XCB error: 152 (BadDamage), sequence: 7339, resource id: 16777250, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Oct 26 22:50:28 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7345, resource id: 4194348, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:50:28 potat plasmashell[1530]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 26 22:50:28 potat kioslave5[1806]: Qt: Session management error: networkIdsList argument is NULL
Oct 26 22:50:28 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
Oct 26 22:50:29 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
Oct 26 22:50:29 potat plasmashell[1530]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 26 22:50:29 potat plasmashell[1530]: trying to show an empty dialog
Oct 26 22:50:29 potat plasmashell[1530]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/LeaveButtons.qml:69:5: QML ToolButton: Binding loop detected for property "display"
Oct 26 22:50:30 potat systemd[1]: Stopping User Manager for UID 968...
Oct 26 22:50:30 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8583, resource id: 44040304, major code: 15 (QueryTree), minor code: 0
Oct 26 22:50:30 potat systemd[1300]: Stopped target Main User Target.
Oct 26 22:50:30 potat systemd[1300]: Stopping D-Bus User Message Bus...
Oct 26 22:50:30 potat systemd[1300]: Stopped D-Bus User Message Bus.
Oct 26 22:50:30 potat systemd[1300]: Stopped target Basic System.
Oct 26 22:50:30 potat systemd[1300]: Stopped target Paths.
Oct 26 22:50:30 potat systemd[1300]: Stopped target Sockets.
Oct 26 22:50:30 potat systemd[1300]: Stopped target Timers.
Oct 26 22:50:30 potat systemd[1300]: Closed D-Bus User Message Bus Socket.
Oct 26 22:50:30 potat systemd[1300]: Closed GnuPG network certificate management daemon.
Oct 26 22:50:30 potat systemd[1300]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 26 22:50:30 potat systemd[1300]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Oct 26 22:50:30 potat systemd[1300]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Oct 26 22:50:30 potat systemd[1300]: Closed GnuPG cryptographic agent and passphrase cache.
Oct 26 22:50:30 potat systemd[1300]: Closed p11-kit server.
Oct 26 22:50:30 potat systemd[1300]: Closed Multimedia System.
Oct 26 22:50:30 potat systemd[1300]: Closed Sound System.
Oct 26 22:50:30 potat systemd[1300]: Removed slice User Application Slice.
Oct 26 22:50:30 potat systemd[1300]: Reached target Shutdown.
Oct 26 22:50:30 potat systemd[1300]: Finished Exit the Session.
Oct 26 22:50:30 potat systemd[1300]: Reached target Exit the Session.
Oct 26 22:50:30 potat systemd[1301]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Oct 26 22:50:30 potat systemd[1]: user@968.service: Deactivated successfully.
Oct 26 22:50:30 potat systemd[1]: Stopped User Manager for UID 968.
Oct 26 22:50:30 potat audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:50:30 potat kernel: kauditd_printk_skb: 9 callbacks suppressed
Oct 26 22:50:30 potat kernel: audit: type=1131 audit(1635303030.037:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:50:30 potat systemd[1]: Stopping User Runtime Directory /run/user/968...
Oct 26 22:50:30 potat systemd[1]: run-user-968.mount: Deactivated successfully.
Oct 26 22:50:30 potat systemd[1]: user-runtime-dir@968.service: Deactivated successfully.
Oct 26 22:50:30 potat systemd[1]: Stopped User Runtime Directory /run/user/968.
Oct 26 22:50:30 potat audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:50:30 potat systemd[1]: Removed slice User Slice of UID 968.
Oct 26 22:50:30 potat systemd[1]: user-968.slice: Consumed 2.406s CPU time.
Oct 26 22:50:30 potat kernel: audit: type=1131 audit(1635303030.057:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:50:30 potat plasmashell[1530]: trying to show an empty dialog
Oct 26 22:50:30 potat plasmashell[1530]: file:///home/justinb/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/Logic.qml:96: TypeError: Cannot read property 'showMeteogram' of null
Oct 26 22:50:31 potat plasmashell[1530]: file:///home/justinb/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/Logic.qml:140: TypeError: Cannot call method 'updateUI' of null
Oct 26 22:50:31 potat kioslave5[1881]: Qt: Session management error: networkIdsList argument is NULL
Oct 26 22:50:32 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10795, resource id: 62914567, major code: 15 (QueryTree), minor code: 0
Oct 26 22:50:34 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 12829, resource id: 44040324, major code: 15 (QueryTree), minor code: 0
Oct 26 22:50:41 potat systemd[1362]: Started Firefox - Web Browser.
Oct 26 22:50:43 potat rtkit-daemon[1559]: Supervising 6 threads of 1 processes of 1 users.
Oct 26 22:50:43 potat rtkit-daemon[1559]: Successfully made thread 1996 of process 1890 owned by '1000' RT at priority 10.
Oct 26 22:50:43 potat rtkit-daemon[1559]: Supervising 7 threads of 2 processes of 1 users.
Oct 26 22:50:44 potat kwin_x11[1449]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Oct 26 22:50:44 potat kwin_x11[1449]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
Oct 26 22:50:44 potat rtkit-daemon[1559]: Supervising 7 threads of 2 processes of 1 users.
Oct 26 22:50:45 potat rtkit-daemon[1559]: Supervising 7 threads of 2 processes of 1 users.
Oct 26 22:50:52 potat rtkit-daemon[1559]: Supervising 7 threads of 2 processes of 1 users.
Oct 26 22:50:52 potat rtkit-daemon[1559]: Successfully made thread 2228 of process 1983 owned by '1000' RT at priority 10.
Oct 26 22:50:52 potat rtkit-daemon[1559]: Supervising 8 threads of 3 processes of 1 users.
Oct 26 22:50:53 potat systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Oct 26 22:50:53 potat audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:50:53 potat kernel: audit: type=1131 audit(1635303053.541:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 26 22:50:53 potat audit: BPF prog-id=15 op=UNLOAD
Oct 26 22:50:53 potat audit: BPF prog-id=14 op=UNLOAD
Oct 26 22:50:53 potat audit: BPF prog-id=13 op=UNLOAD
Oct 26 22:50:53 potat kernel: audit: type=1334 audit(1635303053.644:102): prog-id=15 op=UNLOAD
Oct 26 22:50:53 potat kernel: audit: type=1334 audit(1635303053.644:103): prog-id=14 op=UNLOAD
Oct 26 22:50:53 potat kernel: audit: type=1334 audit(1635303053.644:104): prog-id=13 op=UNLOAD
Oct 26 22:51:23 potat msm_kde_notifier[1598]: "qt5-translations"
Oct 26 22:51:49 potat rtkit-daemon[1559]: Supervising 8 threads of 3 processes of 1 users.
Oct 26 22:51:52 potat rtkit-daemon[1559]: Supervising 8 threads of 3 processes of 1 users.
Oct 26 22:51:52 potat rtkit-daemon[1559]: Successfully made thread 2318 of process 2168 owned by '1000' RT at priority 10.
Oct 26 22:51:52 potat rtkit-daemon[1559]: Supervising 9 threads of 4 processes of 1 users.
Oct 26 22:51:56 potat rtkit-daemon[1559]: Supervising 9 threads of 4 processes of 1 users.
Oct 26 22:52:00 potat rtkit-daemon[1559]: Supervising 9 threads of 4 processes of 1 users.
Oct 26 22:52:00 potat rtkit-daemon[1559]: Successfully made thread 2372 of process 2261 owned by '1000' RT at priority 10.
Oct 26 22:52:00 potat rtkit-daemon[1559]: Supervising 10 threads of 5 processes of 1 users.
Oct 26 22:53:29 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4660, resource id: 4194312, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:53:32 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5537, resource id: 60817416, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:55:09 potat systemd[1362]: Started Konsole - Terminal.
Oct 26 22:55:09 potat kwin_x11[1449]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34109, resource id: 12582919, major code: 18 (ChangeProperty), minor code: 0
Oct 26 22:55:10 potat kwin_x11[1449]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
