Hello, I’m reaching to you because my computer freezes on the “Dell” Logo when I’m booting with a 6.1 kernel. The main problem is that this does not happens every time.
I have already put “ibt=off” at the end of my grub command line as suggested in a previous post.
Here is my config from inxi -Fza, please note that I booted back to a 5.15 kernel but that the sound isn’t working (which motivated my switch to 6.1 kernels first).
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=bb09de88-802f-4d59-aa39-8b09146a5217 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 ibt=off
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Dell product: Inspiron 16 7610 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 09FDV3 v: A01 serial: <filter> UEFI: Dell v: 1.3.0
date: 11/05/2021
ID-1: BAT0 charge: 35.6 Wh (56.1%) condition: 63.5/84.3 Wh (75.3%)
volts: 12.1 min: 11.4 model: BYD DELL M59JH18 type: Li-poly serial: <filter>
status: charging
ID-2: hidpp_battery_0 charge: 52% condition: N/A volts: 3.8 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: discharging
Info: model: 11th Gen Intel Core i7-11800H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x42
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1203 high: 3730 min/max: 800/4600 base/boost: 2277/5000
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 791 2: 801 3: 801 4: 801 5: 833 6: 3730
7: 1839 8: 801 9: 800 10: 1827 11: 800 12: 801 13: 1391 14: 800 15: 800
16: 1639 bogomips: 73744
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nouveau v: kernel non-free: 525.xx+ status: current (as of 2022-12)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-5 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-5:3 chip-ID: 0c45:6725 class-ID: 0e02
Display: server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: N/A unloaded: modesetting
alternate: fbdev,vesa gpu: i915 note: X driver n/a display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1200 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: XWAYLAND0 pos: primary,bottom-l
model: AU Optronics 0xc99e built: 2020 res: 1920x1080 hz: 60 dpi: 81
gamma: 1.2 size: 600x340mm (23.62x13.39") diag: 406mm (16") ratio: 16:10
modes: 3072x1920
Monitor-2: HDMI-A-1 mapped: XWAYLAND1 pos: top-right
model: Idek Iiyama PL2730H serial: <filter> built: 2020 res: 1920x1200
hz: 60 dpi: 143 gamma: 1.2 size: 340x220mm (13.39x8.66") diag: 686mm (27")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
bus-ID: 3-14:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 210.2 GiB (22.0%)
model: PM991a NVMe 1024GB size: 953.87 GiB block-size: physical: 512 B
rev: 26304039 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 299.5 GiB size: 293.74 GiB (98.08%)
used: 210.1 GiB (71.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
ID-2: /boot/efi raw-size: 150 MiB size: 146 MiB (97.33%)
used: 104.8 MiB (71.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-1: swap-1 type: partition size: 47.23 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 379 Uptime: 33m wakeups: 44 Memory: 15.37 GiB
used: 4.45 GiB (29.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1495
pm: pacman pkgs: 1483 libs: 359 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 0 pm: snap pkgs: 12 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.24
Here is the journalctl -b -2 -p err for my attempt to boot with the 6.1 Kernel
janv. 08 02:13:20 mirabelle systemd-udevd[511]: /etc/udev/rules.d/51-android-usb.rules:1 Unknown group 'plugdev', ignoring
janv. 08 02:13:20 mirabelle kernel: ACPI BIOS Error (bug): Could not resolve symbol [\S4CT], AE_NOT_FOUND (20220331/psargs-330)
janv. 08 02:13:20 mirabelle kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._CRT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
janv. 08 02:13:20 mirabelle kernel: ACPI BIOS Error (bug): Could not resolve symbol [\S4HT], AE_NOT_FOUND (20220331/psargs-330)
janv. 08 02:13:20 mirabelle kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._HOT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
janv. 08 02:13:20 mirabelle kernel: ACPI BIOS Error (bug): Could not resolve symbol [\S4PT], AE_NOT_FOUND (20220331/psargs-330)
janv. 08 02:13:20 mirabelle kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._PSV due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
janv. 08 02:13:20 mirabelle kernel: ACPI BIOS Error (bug): Could not resolve symbol [\S4AT], AE_NOT_FOUND (20220331/psargs-330)
janv. 08 02:13:20 mirabelle kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._AC0 due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
janv. 08 02:13:21 mirabelle kernel: BUG: kernel NULL pointer dereference, address: 0000000000000020
janv. 08 02:13:21 mirabelle kernel: #PF: supervisor read access in kernel mode
janv. 08 02:13:21 mirabelle kernel: #PF: error_code(0x0000) - not-present page
janv. 08 02:13:21 mirabelle kernel: dell_smm_hwmon: unable to get SMM Dell signature
janv. 08 02:13:22 mirabelle bluetoothd[872]: src/plugin.c:plugin_init() Failed to init vcp plugin
janv. 08 02:13:22 mirabelle bluetoothd[872]: src/plugin.c:plugin_init() Failed to init mcp plugin
janv. 08 02:13:22 mirabelle bluetoothd[872]: src/plugin.c:plugin_init() Failed to init bap plugin
janv. 08 02:13:22 mirabelle systemd[1]: Failed to start pkgfile database update.
janv. 08 02:13:23 mirabelle kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
janv. 08 02:13:33 mirabelle gdm-launch-environment][972]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:13:33 mirabelle gdm-launch-environment][991]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:13:33 mirabelle gdm-launch-environment][997]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:13:33 mirabelle gdm-launch-environment][1003]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:13:33 mirabelle gdm-launch-environment][1009]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:13:33 mirabelle gdm-launch-environment][1015]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
And here is my second attempt (which normally always work) to boot with initramfs:
janv. 08 02:14:36 mirabelle systemd-udevd[531]: /etc/udev/rules.d/51-android-usb.rules:1 Unknown group 'plugdev', ignoring
janv. 08 02:14:36 mirabelle kernel: ACPI BIOS Error (bug): Could not resolve symbol [\S4CT], AE_NOT_FOUND (20220331/psargs-330)
janv. 08 02:14:36 mirabelle kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._CRT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
janv. 08 02:14:36 mirabelle kernel: ACPI BIOS Error (bug): Could not resolve symbol [\S4HT], AE_NOT_FOUND (20220331/psargs-330)
janv. 08 02:14:36 mirabelle kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._HOT due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
janv. 08 02:14:36 mirabelle kernel: ACPI BIOS Error (bug): Could not resolve symbol [\S4PT], AE_NOT_FOUND (20220331/psargs-330)
janv. 08 02:14:36 mirabelle kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._PSV due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
janv. 08 02:14:36 mirabelle kernel: ACPI BIOS Error (bug): Could not resolve symbol [\S4AT], AE_NOT_FOUND (20220331/psargs-330)
janv. 08 02:14:36 mirabelle kernel: ACPI Error: Aborting method \_SB.PC00.LPCB.ECDV.NGFF._AC0 due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
janv. 08 02:14:37 mirabelle kernel: BUG: kernel NULL pointer dereference, address: 0000000000000020
janv. 08 02:14:37 mirabelle kernel: #PF: supervisor read access in kernel mode
janv. 08 02:14:37 mirabelle kernel: #PF: error_code(0x0000) - not-present page
janv. 08 02:14:38 mirabelle kernel: dell_smm_hwmon: unable to get SMM Dell signature
janv. 08 02:14:38 mirabelle bluetoothd[855]: src/plugin.c:plugin_init() Failed to init vcp plugin
janv. 08 02:14:38 mirabelle bluetoothd[855]: src/plugin.c:plugin_init() Failed to init mcp plugin
janv. 08 02:14:38 mirabelle bluetoothd[855]: src/plugin.c:plugin_init() Failed to init bap plugin
janv. 08 02:14:39 mirabelle kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
janv. 08 02:14:48 mirabelle gdm-launch-environment][926]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:14:49 mirabelle gdm-launch-environment][945]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:14:49 mirabelle gdm-launch-environment][952]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:14:49 mirabelle gdm-launch-environment][958]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:14:49 mirabelle gdm-launch-environment][965]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
janv. 08 02:14:49 mirabelle gdm-launch-environment][971]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Many thanks in advance for every help you may give me
