So I have been using Manjaro for a while now and everything worked perfectly, until today. I wanted to restart my laptop but when it tried to boot it was stuck on a blank screen with a not blinking underscore. After restarting again with the power button it booted and then was stuck on the boot logo from HP and the Manjaro Logo under it. After a while the Manjaro logo disappears.
This already happened when I duabooted with windows 10, now I only have manjaro.
brahma
February 14, 2023, 8:05am
2
and what were you doing prior to this? updating/installing/modifying something?
the best option is to chroot, so boot into manjaro live usb, make sure you are connected to internet, open terminal and chroot:
manjaro-chroot -a
rerun update:
pacman-mirrors -f 5 && pacman -Syyu
if there are errors post the output here, if there are no errors and you are up to date, post output from:
mhwd-kernel -li && mhwd -l -li
and logs from the failed boot:
journalctl -b-1 -p4 --no-pager
Thank you for your response!
I installed Wine before this, then my steam bugged and I tried restarting.
When I tried cheroot I got this: grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map Probably because I don’t have Grub since I don’t dual boot.
The mhdw Command got me this: Manjaro version 6.1.7-1 (linux61)
My PCI configs:
video-hybrid-intel-nvidia-prime 2021.11.04 false
video-linux 2018.05.04 true
video-modesetting 2020.01.13 true
No installed USB configs
0000:01:00.0 (0302:10de:1f97) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false
video-nvidia 2021.11.04 false
video-nvidia-470xx 2021.11.04 false
0000:00:02.0 (0300:8086:9a49) Display controller Intel Corporation:
video-vesa 2017.03.12 true
All types are PCI
brahma
February 14, 2023, 1:03pm
4
use formatting for the outputs, click this icon in editor </>
and copy the output there;
or use:
your output here
or:
your output here
this is normal, its from the usb …
did you rerun the update and were there any errors?
post formatted output of the mhwd commands and the logs
Oh ok, sorry, here:
Currently running: 6.1.7-1-MANJARO (linux61)
* linux61
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-vesa 2017.03.12 true PCI
The logs (I forgot, sorry)
Feb 14 00:08:56 probook kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Feb 14 00:08:56 probook kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Feb 14 00:08:56 probook kernel: pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Feb 14 00:08:56 probook kernel: hpet_acpi_add: no address or irqs in _CRS
Feb 14 00:08:56 probook kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
Feb 14 00:08:56 probook kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Feb 14 00:08:56 probook kernel: usb: port power management may be unreliable
Feb 14 00:08:56 probook systemd-journald[399]: File /var/log/journal/50c428a8366d4f8e95e5b4f94fa6ff3a/system.journal corrupted or uncleanly shut down, renaming and replacing.
Feb 14 00:08:56 probook kernel: wmi_bus wmi_bus-PNP0C14:02: WQZZ data block query control method not found
Feb 14 00:08:57 probook kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
Feb 14 00:08:57 probook kernel: caller __uncore_imc_init_box+0xc4/0x120 [intel_uncore] mapping multiple BARs
Feb 14 00:08:57 probook kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Feb 14 00:08:57 probook kernel: hp_wmi: query 0x4 returned error 0x5
Feb 14 00:08:57 probook kernel: thermal thermal_zone16: failed to read out thermal zone (-61)
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Feb 14 00:08:58 probook kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
Feb 14 00:08:58 probook kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
Feb 14 00:08:58 probook kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Feb 14 00:08:58 probook kernel: nvidia: loading out-of-tree module taints kernel.
Feb 14 00:08:58 probook kernel: nvidia: module license 'NVIDIA' taints kernel.
Feb 14 00:08:58 probook kernel: Disabling lock debugging due to kernel taint
Feb 14 00:08:58 probook kernel: traps: Missing ENDBR: _nv012309rm+0x0/0x10 [nvidia]
Feb 14 00:08:58 probook kernel: ------------[ cut here ]------------
Feb 14 00:08:58 probook kernel: kernel BUG at arch/x86/kernel/traps.c:255!
Feb 14 00:08:58 probook kernel: invalid opcode: 0000 [#1] PREEMPT SMP NOPTI
Feb 14 00:08:58 probook kernel: CPU: 1 PID: 280 Comm: systemd-modules Tainted: P OE 6.1.11-1-MANJARO #1 8c467824508c019b53c014f88969d3d36fb7ef88
Feb 14 00:08:58 probook kernel: Hardware name: HP HP ProBook 650 G8 Notebook PC/87ED, BIOS T74 Ver. 01.09.01 05/05/2022
Feb 14 00:08:58 probook kernel: RIP: 0010:exc_control_protection+0xc2/0xd0
Feb 14 00:08:58 probook kernel: Code: fa ff 45 31 c9 49 89 d8 b9 09 00 00 00 48 8b 93 80 00 00 00 be fc 00 00 00 48 c7 c7 f1 4d a4 87 e8 c3 84 46 ff e9 64 ff ff ff <0f> 0b 66 66 2e 0f 1f 84 00 00 00 00 00 90 66 0f 1f 00 55 53 48 89
Feb 14 00:08:58 probook kernel: RSP: 0018:ffffa85042087b88 EFLAGS: 00010002
Feb 14 00:08:58 probook kernel: RAX: 0000000000000033 RBX: ffffa85042087ba8 RCX: 0000000000000027
Feb 14 00:08:58 probook kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8d081fe61660
Feb 14 00:08:58 probook kernel: RBP: 0000000000000003 R08: 0000000000000000 R09: ffffa85042087a20
Feb 14 00:08:58 probook kernel: R10: 0000000000000003 R11: ffffffff882cb948 R12: 0000000000000000
Feb 14 00:08:58 probook kernel: R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
Feb 14 00:08:58 probook kernel: FS: 00007f8c97db0080(0000) GS:ffff8d081fe40000(0000) knlGS:0000000000000000
Feb 14 00:08:58 probook kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Feb 14 00:08:58 probook kernel: CR2: 00007f8c938bf000 CR3: 000000010157a003 CR4: 0000000000f70ee0
Feb 14 00:08:58 probook kernel: PKRU: 55555554
Feb 14 00:08:58 probook kernel: Call Trace:
Feb 14 00:08:58 probook kernel: <TASK>
Feb 14 00:08:58 probook kernel: asm_exc_control_protection+0x26/0x30
Feb 14 00:08:58 probook kernel: RIP: 0010:_nv012309rm+0x0/0x10 [nvidia]
Feb 14 00:08:58 probook kernel: Code: 66 2e 0f 1f 84 00 00 00 00 00 48 83 ec 08 e8 f7 d1 1f 00 48 83 c4 08 48 89 c7 e9 bb ff ff ff 66 2e 0f 1f 84 00 00 00 00 00 90 <48> 89 f7 e9 18 08 00 00 0f 1f 84 00 00 00 00 00 48 89 f7 e9 18 08
Feb 14 00:08:58 probook kernel: RSP: 0018:ffffa85042087c50 EFLAGS: 00010202
Feb 14 00:08:58 probook kernel: RAX: ffffffffc1e54380 RBX: ffffffffc4eb7130 RCX: 0000000000000000
Feb 14 00:08:58 probook kernel: RDX: 000000000007e9ed RSI: 0000000000000010 RDI: ffffffffc4eb7130
Feb 14 00:08:58 probook kernel: RBP: ffff8d0483812fe0 R08: ffffa85042087be0 R09: ffffffffc4eb7170
Feb 14 00:08:58 probook kernel: R10: ffffffffc4e80fb0 R11: 0000000000000000 R12: 0000000000000010
Feb 14 00:08:58 probook kernel: R13: ffff8d0483810000 R14: 0000557e1925dc30 R15: ffffa85042087dd0
Feb 14 00:08:58 probook kernel: ? _nv038466rm+0x20/0x20 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: _nv012307rm+0x24/0xe0 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: _nv038467rm+0xe/0xa0 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: _nv038470rm+0x1d/0x30 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: _nv038472rm+0x2f/0x40 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: _nv017028rm+0x15/0x70 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: _nv000690rm+0x9/0x20 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: ? cdev_add+0x50/0x70
Feb 14 00:08:58 probook kernel: rm_init_rm+0x17/0x60 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: nvidia_init_module+0x24e/0x622 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: ? nvidia_init_module+0x622/0x622 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: nvidia_frontend_init_module+0x50/0x94 [nvidia 39e759f0e15ed10fd6d1135300a116c663170fb1]
Feb 14 00:08:58 probook kernel: do_one_initcall+0x5a/0x220
Feb 14 00:08:58 probook kernel: do_init_module+0x4a/0x1e0
Feb 14 00:08:58 probook kernel: __do_sys_init_module+0x17f/0x1b0
Feb 14 00:08:58 probook kernel: do_syscall_64+0x5c/0x90
Feb 14 00:08:58 probook kernel: ? syscall_exit_to_user_mode+0x1b/0x40
Feb 14 00:08:58 probook kernel: ? do_syscall_64+0x6b/0x90
Feb 14 00:08:58 probook kernel: ? exc_page_fault+0x74/0x170
Feb 14 00:08:58 probook kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd
Feb 14 00:08:58 probook kernel: RIP: 0033:0x7f8c988e7eee
Feb 14 00:08:58 probook kernel: Code: 48 8b 0d 85 ee 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 52 ee 0c 00 f7 d8 64 89 01 48
Feb 14 00:08:58 probook kernel: RSP: 002b:00007ffd7875b988 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
Feb 14 00:08:58 probook kernel: RAX: ffffffffffffffda RBX: 0000557e1925e2f0 RCX: 00007f8c988e7eee
Feb 14 00:08:58 probook kernel: RDX: 0000557e1925dc30 RSI: 00000000058e2118 RDI: 00007f8c8dfdd010
Feb 14 00:08:58 probook kernel: RBP: 0000557e1925dc30 R08: 0000557e1925e540 R09: 00007ffd78757948
Feb 14 00:08:58 probook kernel: R10: 0000000000000005 R11: 0000000000000246 R12: 0000000000020000
Feb 14 00:08:58 probook kernel: R13: 0000557e1925e370 R14: 0000557e1925e2f0 R15: 0000557e1925e7a0
Feb 14 00:08:58 probook kernel: </TASK>
Feb 14 00:08:58 probook kernel: Modules linked in: nvidia(POE+) hid_logitech_dj(+) snd_ctl_led snd_soc_skl_hda_dsp snd_soc_intel_hda_dsp_common snd_soc_hdac_hdmi snd_sof_probes uvcvideo btusb videobuf2_vmalloc btrtl videobuf2_memops btbcm videobuf2_v4l2 btintel videobuf2_common btmtk videodev mc bluetooth usbhid ecdh_generic snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio snd_soc_dmic snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus joydev mousedev snd_soc_core intel_tcc_cooling x86_pkg_temp_thermal snd_compress ac97_bus intel_powerclamp snd_pcm_dmaengine coretemp crct10dif_pclmul snd_hda_intel iTCO_wdt snd_intel_dspcfg crc32_pclmul iwlmvm polyval_clmulni snd_intel_sdw_acpi intel_pmc_bxt polyval_generic hid_multitouch mei_hdcp mei_pxp intel_rapl_msr ee1004
Feb 14 00:08:58 probook kernel: iTCO_vendor_support gf128mul hp_wmi mac80211 i915 platform_profile wmi_bmof snd_hda_codec ghash_clmulni_intel snd_hda_core snd_hwdep sha512_ssse3 libarc4 aesni_intel pmt_telemetry pmt_class crypto_simd cryptd drm_buddy snd_pcm ttm rapl processor_thermal_device_pci_legacy processor_thermal_device iwlwifi intel_cstate vfat processor_thermal_rfim fat snd_timer cfg80211 pcspkr intel_uncore processor_thermal_mbox drm_display_helper spi_nor snd ucsi_acpi intel_lpss_pci mei_me processor_thermal_rapl i2c_i801 intel_lpss soundcore e1000e mei i2c_smbus rfkill mtd intel_rapl_common typec_ucsi cec idma64 i2c_hid_acpi video i2c_hid typec int3403_thermal roles intel_soc_dts_iosf intel_gtt int340x_thermal_zone intel_vsec igen6_edac wmi intel_hid int3400_thermal sparse_keymap acpi_thermal_rel acpi_pad wireless_hotkey mac_hid squashfs loop crypto_user fuse bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw atkbd nvme libps2 vivaldi_fmap nvme_core nvme_common
Feb 14 00:08:58 probook kernel: spi_intel_pci xhci_pci spi_intel xhci_pci_renesas crc32c_intel vmd i8042 serio
Feb 14 00:08:58 probook kernel: ---[ end trace 0000000000000000 ]---
Feb 14 00:08:58 probook systemd[1]: systemd-modules-load.service: Main process exited, code=killed, status=11/SEGV
Feb 14 00:08:58 probook systemd[1]: systemd-modules-load.service: Failed with result 'signal'.
Feb 14 00:08:58 probook systemd[1]: Failed to start Load Kernel Modules.
Feb 14 00:08:58 probook bluetoothd[1041]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Feb 14 00:08:58 probook bluetoothd[1041]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 14 00:08:58 probook bluetoothd[1041]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Feb 14 00:08:58 probook bluetoothd[1041]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 14 00:08:58 probook bluetoothd[1041]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Feb 14 00:08:58 probook bluetoothd[1041]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 14 00:08:58 probook kernel: kauditd_printk_skb: 225 callbacks suppressed
Feb 14 00:08:59 probook systemd[1]: snap.network-manager.networkmanager.service: Failed with result 'exit-code'.
Feb 14 00:08:59 probook kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Feb 14 00:09:00 probook systemd[1]: snap.network-manager.networkmanager.service: Failed with result 'exit-code'.
Feb 14 00:09:01 probook systemd[1]: snap.network-manager.networkmanager.service: Failed with result 'exit-code'.
Feb 14 00:09:01 probook systemd[1]: snap.network-manager.networkmanager.service: Start request repeated too quickly.
Feb 14 00:09:01 probook systemd[1]: Failed to start Service for snap application network-manager.networkmanager.
Feb 14 00:09:03 probook kernel: kauditd_printk_skb: 56 callbacks suppressed
Feb 14 00:09:03 probook dnsmasq[1795]: chown of PID file /var/run/nm-dnsmasq-wlp0s20f3.pid failed: Operation not permitted
Feb 14 00:09:03 probook dnsmasq[1795]: no servers found in /etc/resolv.conf, will retry
Feb 14 00:10:02 probook kernel: kauditd_printk_skb: 2 callbacks suppressed
Feb 14 00:11:57 probook systemd-udevd[400]: 0000:01:00.0: Worker [426] processing SEQNUM=3656 killed
brahma
February 14, 2023, 1:52pm
6
and are you up to date?
it looks like its nvidia related…
so first reinstall the current kernel:
pacman -S linux61
then install also the 5.15:
mhwd-kernel -i linux515
if there are errors from this, post them here…
now lets add ibt parameter:
nano /etc/default/grub
and inside this line: GRUB_CMDLINE_LINUX_DEFAULT
inside the quotes add this parameter:
ibt=off
dont remove anything, just add it to existing parameters;
then edit this line to look like this:
GRUB_TIMEOUT_STYLE=menu
save the file with ctrl+x
, press Y, update grub:
update-grub
exit chroot:
exit
reboot
now the grub menu will be shown so in the advanced options select the kernel 6.1 - not the fallback one and see if you can boot with it, if not try with the kernel 5.15…
Wait so maybe I am dumb but I have opened a file now with nano /etc/default/grub
? I dont know what to do now, sorry.
brahma
February 14, 2023, 2:08pm
8
yes in the opened file locate this line:
and add there the parameter as instructed above…
then edit this line:
GRUB_TIMEOUT_STYLE=
to look like this:
then save it as instructed above
Yes, it worked!! Thank you very much, I never thought this would work! Is there any way I can support you?
system
Closed
February 17, 2023, 4:21am
10
