full inxi?
Please save this to a file:
#!/bin/bash
shopt -s nullglob
for g in `find /sys/kernel/iommu_groups/* -maxdepth 0 -type d | sort -V`; do
echo "IOMMU Group ${g##*/}:"
for d in $g/devices/*; do
echo -e "\t$(lspci -nns ${d##*/})"
done;
done;
and run it with:
sudo bash filename
Then post the result here.
first the inxi:
Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=a27f0baf-14fa-41db-844a-9ff44f8c8f6f rw quiet apparmor=1
security=apparmor resume=UUID=d0dac5d0-5548-41e7-8572-14de99a109cc
udev.log_priority=3 iommu=pt vfio-pci.ids=10de:13c2
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop System: Micro-Star product: MS-7B86 v: 4.0 serial: <filter>
Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0 serial: <filter>
BIOS: American Megatrends LLC. v: M.D1 date: 04/12/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 15.55 GiB used: 2.71 GiB (17.4%)
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 4 MiB bogomips: 115257
Speed: 2200 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2200 2: 2110 3: 2054 4: 3600 5: 3600 6: 3602 7: 2051 8: 2057 9: 1889
10: 3600 11: 3599 12: 3603 13: 2061 14: 2059 15: 2196 16: 2198
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050]
vendor: PC Partner Limited / Sapphire driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 25:00.0 chip-ID: 10de:1c81
class-ID: 0300
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 26:00.0
chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.9x11.7") diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio
vendor: PC Partner Limited / Sapphire driver: snd_hda_intel v: kernel
bus-ID: 25:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 26:00.1 chip-ID: 10de:0fbb
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter type: USB
driver: N/A bus-ID: 3-2:2 chip-ID: 0bda:8812 class-ID: 0000 serial: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 3.87 TiB used: 572.89 GiB (14.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD10EZEX-00WN4A0
type: HDD rpm: 7200 serial: <filter> rev: 1A01 scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 907.15 GiB (98.31%)
used: 572.89 GiB (63.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: a27f0baf-14fa-41db-844a-9ff44f8c8f6f
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: d0dac5d0-5548-41e7-8572-14de99a109cc
ID-1: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ext4 label: N/A
uuid: 5757cf41-d650-4984-9e58-01ab341fba59
ID-2: /dev/sdc1 maj-min: 8:33 size: 50 MiB fs: ntfs label: System Reserved
uuid: DCC8CC0BC8CBE23E
ID-3: /dev/sdc2 maj-min: 8:34 size: 232.35 GiB fs: ntfs label: N/A
uuid: 440ACCBD0ACCACEC
ID-4: /dev/sdc3 maj-min: 8:35 size: 499 MiB fs: ntfs label: N/A
uuid: 602278FB2278D80C
ID-5: /dev/sdd1 maj-min: 8:49 size: 931.51 GiB fs: ntfs
label: Lokaler Datentr\xc3\xa4ger uuid: 40ACC3BCACC3AB2C
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-2:3 info: ROCCAT Ryos MK Glow Keyboard type: Keyboard,HID
driver: ryos,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1e7d:31ce class-ID: 0300
Device-3: 1-4:4 info: Google Nexus/Pixel Device (charging + debug)
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 18d1:4ee7 class-ID: 0000 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2
info: Realtek RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter type: WiFi
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.8 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 50%
Processes: 337 Uptime: 10m wakeups: 2 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1276 pacman: 1260 lib: 330
flatpak: 9 snap: 7 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
inxi: 3.3.06
IOMMU Group 0:
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 1:
00:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 2:
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 3:
00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 4:
00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 5:
00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 6:
00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 7:
00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 8:
00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 9:
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 10:
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 11:
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 12:
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0 [1022:1440]
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1 [1022:1441]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2 [1022:1442]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3 [1022:1443]
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4 [1022:1444]
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5 [1022:1445]
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6 [1022:1446]
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7 [1022:1447]
IOMMU Group 13:
03:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller [1022:43d5] (rev 01)
03:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller [1022:43c8] (rev 01)
03:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge [1022:43c6] (rev 01)
20:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
20:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
20:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
22:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
25:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050] [10de:1c81] (rev a1)
25:00.1 Audio device [0403]: NVIDIA Corporation GP107GL High Definition Audio Controller [10de:0fb9] (rev a1)
IOMMU Group 14:
26:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 970] [10de:13c2] (rev a1)
26:00.1 Audio device [0403]: NVIDIA Corporation GM204 High Definition Audio Controller [10de:0fbb] (rev a1)
IOMMU Group 15:
27:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 16:
28:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 17:
28:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
IOMMU Group 18:
28:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 19:
28:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
I see Group 13 … GTX 1050 is not properly grouped by the UEFI. So in general, when using GTX 1050 here, the whole group will be blocked for the HOST, what is not very gentle and would make the system unusable.
Group 14 should work with GTX 970…
So in grub:
vfio-pci.ids=10de:13c2,10de:0fbb
in mkinitcpio:
MODULES=(vfio_pci vfio vfio_iommu_type1 vfio_virqfd nvidia nvidia_modeset nvidia_uvm nvidia_drm)
this ensures that vfio_pci is loaded first.
ill convert the ( to "
running xfce
Just to mention:
- MODULES="" ← old method, only there for legacy
- MODULES=() ← new method, is default and will replace the old behavior in the future
okay by accident i did try 2 things at once, both with mkinitcpio regenerated:
one with grub not updated (but the parameter set):
that got me to a responsive system that i could blindly reboot from with the ctrl + alt + f2 thing or whatever the key combination is for that console where you have to login first.
and i think i could login to desktop on manjaro before rebooting, not sure about that though.
But still no gpu output!
and one with the grub updated:
there i got the same result from earlier: unresponsive numlock, no picture and i could not access the console to reboot
were nearing a solution guys, i can feel it!
So the GTX 1050 has no output (no screen)?
if you can do this, then THERE IS A GPU OUTPUT!
If you have a network connection, then you can simply upload terminal outputs:
<command> | curl -F'file=@-' https://0x0.st
remove quiet
from the kernel parameter and you see an output.
yes
how would i do that with no screen
is that an independent advice from what youve said earlyer in the message?
Yes, you see the boot process then and where it stucks and not just a black screen.
- remove
quiet
- add
systemd.unit=multi-user.target
Maybe this works then.
remove quiet from the grub file?
Yes this file mentioned earlier:
(and update-grub of course what I don’t have to mention…)
okay will try
and also add the systemd.unit parameter to the grub file i assume…
okay im back
running it like that only gave me the line :: running early hook [udev]
my theory is that it tried to display everything on the gtx970, which im passing through, so my guess is that the gpu just got turned off by that command and nothing else got displayed anymore.
im talking about a static picture with no movement/new content at all, just that line of text
i got into the console again, i think, but didnt expect it because it was my first time booting like that, so i had to manually reboot because i was in an unknown system state - i could not blindly navigate through the menues anymore.
ive got an idea:
maybe the kernel parameters conflict with my
options vfio-pci ids=10de:13c2,10de:0fbb
in vfio.conf
Same ids, so no.
Kernel Parameter: early load
Modprobe: late load
if i would test something right now, i would choose to test if reinstalling the nvidia drivers works with only one gpu connected (the 1050) would work, together with starting manjaro, still having only one gpu connected, reconnecting the 970 after and trying booting again with the 5.10 kernel.
i think that led me to my “setup” that i had a working second gpu in, with the system just ignoring my 970, not even detecting monitors on that card.
i feel like i have to ask for permission tho, since i did some things on my own earlier and that led confusion about what i already tried or want to do in general.
The nVidia drivers just load themselves on all hardware (autodetect) so that would be a step back.
We’re not a bunch of arseholes, dumbwits N00bs trying to hamper you; we’re trying to help you and as it’s harder to shoot at a moving target, we’re just asking you to stand still, is all…
So, just to be sure, another full inxi
, please and a
mhwd --listinstalled
if you don’t mind.
yeah sorry about my attitude, didnt know how to really adress that topic. English is not my first language…
i know that i just moved too fast to follow, didnt quite know how to put that into words.
udev.log_priority=3 iommu=pt vfio-pci.ids=10de:13c2,10de:0fbb
status: Discharging
RAM: total: 15.55 GiB used: 3.22 GiB (20.7%)
L2: 4 MiB bogomips: 115256
Speed: 2199 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2199 2: 2057 3: 2057 4: 2055 5: 2181 6: 1868 7: 2799 8: 1865 9: 2400
10: 2056 11: 2741 12: 1867 13: 2800 14: 1867 15: 3592 16: 2401
class-ID: 0300
s-diag: 583mm (23")
direct render: Yes
class-ID: 0403
class-ID: 0403
Local Storage: total: 3.87 TiB used: 573 GiB (14.5%)
ID-1: / raw-size: 922.71 GiB size: 907.15 GiB (98.31%) used: 573 GiB (63.2%)
Device-1: 3-2:2
System Temperatures: cpu: 36.5 C mobo: N/A gpu: nvidia temp: 35 C
Processes: 360 Uptime: 2h 28m wakeups: 4 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1276
pacman: 1260 lib: 330 flatpak: 9 snap: 7 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
