Device-1: NVIDIA GP107 [GeForce GTX 1050]
vendor: PC Partner Limited / Sapphire driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 25:00.0 chip-ID: 10de:1c81
class-ID: 0300
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 26:00.0
chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.9x11.7") diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
you meant that youre walking me through that one right?
thats why you told me to inxi
Fabby
8 September 2021 15:36
23
Now: nvidia driver loaded on both cards in the host OS
Shoxx98:
class-ID: 0300
Previously, the vfio-pci
loaded, ready for pass-through to your VM:
Shoxx98:
class-ID: 0300
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: vfio-pci
v: 0.2 alternate: nouveau,nvidia_drm,nvidia bus-ID: 26:00.0
you have to ensure it’s correct on both the host and the VM…
okay ill just pass through then.
probably not gonna just work because the second gpu doesnt work like this but okay ill try.
just to give some progress:
sudo mkinitcpio -p linux512
[sudo] password for jonas:
==> Building image from preset: /etc/mkinitcpio.d/linux512.preset: 'default'
-> -k /boot/vmlinuz-5.12-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.12-x86_64.img
==> Starting build: 5.12.19-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux512.preset: 'fallback'
-> -k /boot/vmlinuz-5.12-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.12-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.12-x86_64-fallback.img
[jonas@jonas-ms7b86 ~]$ uname -r
5.12.19-1-MANJARO
ill be using 5.12 for now. behaviour on 5.10 and 5.12 is the same afaik
just as i said, no gpu worked with this setup.
the passed through gpu did not turn on, as planned, and the other gpu did not turn on as well.
also i could not activate numlock so the pc literally froze
i am back on 5.14 because i would have to remove my gtx970 from the pcie slot now to make 5.12 run and i dont feel like removing it 50 times
Fabby
8 September 2021 16:00
28
Stick to 5.10 LTS (Long Time Support) instead of 5.12 EOL (End Of Life) then…
sudo mkinitcpio -p linux510
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.61-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
restarting
5.10 testing done
same outcome as 5.12
lspci -nnk -d 10de:1c81
lspci -nnk -d 10de:13c2
sudo dmesg | grep -i vfio
When? On the Guest or on the Host? If vfio-pci
is loaded correctly for a GPU, then it should be able to passthrough to the VM. I would rather think that the configuration on the VM is faulty.
on the host no gpu turned on
[jonas@jonas-ms7b86 ~]$ lspci -nnk -d 10de:1c81
25:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050] [10de:1c81] (rev a1)
Subsystem: PC Partner Limited / Sapphire Technology Device [174b:5454]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
[jonas@jonas-ms7b86 ~]$ lspci -nnk -d 10de:13c2
26:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 970] [10de:13c2] (rev a1)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:367a]
[jonas@jonas-ms7b86 ~]$ sudo dmesg | grep -i vfio
im back on 5.14 because 5.10 is non-operable
As you see both loaded the nvidia driver. One have to be loaded with the vfio-pci
driver.
Have look here: https://wiki.archlinux.org/title/PCI_passthrough_via_OVMF#Binding_vfio-pci_via_device_ID
yes. obviously they load the nvidia driver because im on 5.14 and the mkinitcpio was for 5.10!
i cannot use the 5.10 kernel after i did sudo mkinitcpio -p linux510
with the MODULES="vfio_pci vfio vfio_iommu_type1 vfio_virqfd"
line
because i get a blackscreen every time
on both gpus
What is on your kernel parameter?
cat /etc/default/grub | grep GRUB_CMDLINE
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=d0dac5d0-5548-41e7-8572-14de99a109cc udev.log_priority=3 iommu=pt"
GRUB_CMDLINE_LINUX=""
add there:
vfio-pci.ids=10de:13c2
sudo update-grub
And it will only choose GTX 970 …
in the default parameter?
that did nothing on 5.10
parameters look like this now, just to confirm
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=d0dac5d0-5548-41e7-8572-14de99a109cc udev.log_priority=3 iommu=pt vfio-pci.ids=10de:13c2"
Fabby
8 September 2021 16:56
41
Yet another inxi
, please?
