Hi,
I own an MSI nvidia optimus gaming laptop and am trying to launch a KDE Wayland session in which my secondary monitor is detected. After some research a reason for why the hdmi connected monitor is not detected could be, that nvidia_drm.modeset=1 is not enabled as a kernel parameter. Trying to do so ends in my system getting stuck during the boot process. Only solution is removing the entry from grub or a modprobe config file (I tried both ways to get the kernel parameter running) by chrooting from a live system.
What could be the issue?
nvidia and wayland isn’t compatible. whatever you do but you’ll have to use x11 with nvidia.
also post the mandatory
output and use the preformatted text option to paste it inside it.
Well, that’s kind of an unsubstantial killer phrase.
Afaik KDE says otherwise: Plasma/Wayland/Nvidia - KDE Community Wiki
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9e744c1a-ec40-4c90-b092-da43ca14110d rw quiet
cryptdevice=UUID=3352fb98-8855-4902-9528-db429256c07d:luks-3352fb98-8855-4902-9528-db429256c07d
root=/dev/mapper/luks-3352fb98-8855-4902-9528-db429256c07d
resume=/dev/mapper/luks-3352fb98-8855-4902-9528-db429256c07d apparmor=1
security=apparmor udev.log_priority=3 intel_pstate=disable
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.113.0 wm: kwin_x11 tools: avail: light-locker,xscreensaver vt: 2 dm:
1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Micro-Star product: GE73 Raider RGB 8RF v: REV:1.0
Mobo: Micro-Star model: MS-17C5 v: REV:1.0 serial: <superuser required>
part-nu: 17C5.1 uuid: <superuser required> UEFI: American Megatrends
v: E17C5IMS.10F date: 05/20/2019
ID-1: BAT1 charge: 41.9 Wh (97.2%) condition: 43.1/53.4 Wh (80.7%)
volts: 11.9 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
System RAM: total: 16 GiB available: 15.47 GiB used: 5.54 GiB (35.8%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A2K43CB1-CTD
serial: <filter>
Device-2: ChannelB-DIMM0 type: no module installed
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 2200 high: 2201 min/max: 800/2201 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2201 6: 2200 7: 2201 8: 2201 9: 2201 10: 2201 11: 2200
12: 2201 bogomips: 52815
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-01; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1ba1
class-ID: 0300
Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:10 chip-ID: 5986:1140
Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.4.3:12
chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: vesa
alternate: fbdev,nouveau,nv dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: eDP-1 pos: right res: 1920x1080 hz: 120 dpi: 128
size: 381x214mm (15x8.43") diag: 437mm (17.2") modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
device-ID: 8086:3e9b memory: 15.1 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 10 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.3.3-manjaro1.1
device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 545.29.06
device-ID: 10de:1ba1 surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f0 class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:11
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
status: discoverable: no pairing: yes
Device-1: luks-654e7435-e8ca-4b13-8abb-18733a64eff7 maj-min: 254:1
type: LUKS dm: dm-1 size: 1.82 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 1.82 TiB
Device-2: luks-3352fb98-8855-4902-9528-db429256c07d maj-min: 254:0
type: LUKS dm: dm-0 size: 237.47 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 237.47 GiB
Local Storage: total: 2.99 TiB used: 786.48 GiB (25.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3256GJ
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: E8FK11.C temp: 38.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Micron model: CT1000X8SSD9
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: PMAP scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Hama model: Hama size: 29.82 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1100
scheme: MBR
ID-1: / raw-size: 237.47 GiB size: 232.69 GiB (97.98%)
used: 85.77 GiB (36.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3352fb98-8855-4902-9528-db429256c07d label: N/A
uuid: 9e744c1a-ec40-4c90-b092-da43ca14110d
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 456 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6C3E-CC70
ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 683.97 GiB (37.3%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-654e7435-e8ca-4b13-8abb-18733a64eff7 label: N/A
uuid: eebc0eac-242a-49fb-b6d2-968d79f5c330
ID-4: /run/media/ralf/Ventoy raw-size: 29.79 GiB size: 29.79 GiB (99.99%)
used: 16.74 GiB (56.2%) fs: exfat dev: /dev/sdc1 maj-min: 8:33 label: Ventoy
uuid: 4CE9-C018
ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: exfat label: Free
uuid: 6FFB-8557
ID-2: /dev/sdc2 maj-min: 8:34 size: 32 MiB fs: vfat label: VTOYEFI
uuid: F767-A619
Device-1: 1-1:2 info: Razer USA BlackWidow Lite (2018) type: keyboard,mouse
driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0235 class-ID: 0300
Device-2: 1-2:3 info: Razer USA DeathAdder Elite type: mouse,keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:005c class-ID: 0300
Hub-2: 1-3:4 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Hub-3: 1-3.4:7 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Device-1: 1-3.4.3:12 info: Logitech HD Pro Webcam C920 type: video,audio
Hub-4: 1-4:5 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2815
Device-1: 1-6:6 info: SteelSeries ApS ALC type: HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1124 class-ID: 0300
Device-2: 1-7:8 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-3: 1-9:9 info: SteelSeries ApS KLC type: HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1122 class-ID: 0300
Device-4: 1-13:10 info: Bison HD Webcam type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:1140 class-ID: 0e02 serial: <filter>
Device-5: 1-14:11 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-5: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-6: 2-3:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Hub-7: 2-3.4:4 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
Hub-8: 2-4:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0815
Device-1: 2-4.1:6 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
Drive type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
Device-2: 2-4.2:5 info: Micron CT1000X8SSD9 type: mass storage driver: uas
interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
power: 896mA chip-ID: 0634:5602 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 46.0 C pch: 40.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 364 Power: uptime: 1h 5m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 6.13 GiB
daemons: upowerd,org_kde_powerdevil Init: systemd v: 255 default: graphical
tool: systemctl
Packages: 2997 pm: pacman pkgs: 2953 libs: 544 tools: pamac,paru,yay
pm: flatpak pkgs: 41 pm: snap pkgs: 3 Compilers: clang: 16.0.6 gcc: 13.2.1
Shell: Zsh v: 5.9 running-in: terminator inxi: 3.3.32
were you able to get this to work? I am having the same issue.
I dont know but the original posters premise was wrong.
Using a hybrid system - it makes sense the boot would lock up with an nvidia modesetting option as it would be initially booting into the iGPU and using that by default.
nvidia_drm.modeset=1 is a boot parameter but not the only way to pass a module option.
You can set an option for the module using something like /etc/modprobe.d/mynv.conf
options nvidia_drm modeset=1
(though this is probably already present from any of the nvidia mhwd profiles)
Well, I think I mixed up two problems in my initial question that are not related and tried to fix them this way - my thought was that this could cause my external monitor to be undetected.
I have and had no problem with logging into a Wayland session from SDDM on the internal screen, but I usually do not use that one and that problem really nags me.
In the meantime I came across possible solutions for the external monitor recognition problem but that is maybe caused by a deleted xorg.conf file that I have no backup of.
Maybe it is time to make a complete Manjaro re-install and hope for the best.
But I also realized that gaming performance on a wayland session is worse than with X11 on my specific system. So at this point of time wayland is not a real option for me.
