Maybe I messed up with grub file and not able to restore it as described here
https://wiki.manjaro.org/index.php/GRUB/Restore_the_GRUB_Bootloader
Any solution?!
Any solution?!
do you have any arch based distro iso?
you can reastore it
Unfortunately no
any linux iso image
BSD too
I have the manjaro iso but it is on the same laptop
Is there a way to use it?
the filesystem is which and if its ext4 windows will not recognize it you have to get a linux laptop/desktop and and remove the hdd/ssd from your laptop/desktop and connect it to an linux system and copy the imp data in it and reinstall manjaro because it it possible to reastore the grub but its a very conplicated process
hope it helps
Thank you for your help
I managed to fix the issue
As I know the line I edited in grub file and what it was before editing
I used split and cat commands to edit this line
It works now
