/dev/mapper/luks-7262977c-d0cc-4daa-a444-725f2fc63224: clean, 416922/30507008 fi
les, 25327181/122018184 blocks
My screen is stuck on this every time I try to turn on the computer. It started after I downloaded the bottom/last open source Nvidia driver in the settings menu. CTRL ALT F3 works but I have no command line knowledge. I’m wondering what command I need to use to delete/remove that Nvidia driver from within the command line. I only have all three open source Nvidia drivers installed, that last one seems to be giving issues.
Before that though I was installing wayland and upgrading to a new Linux kernel version but was still able to boot/login after changing those.
When I type in startx, it gives errors and says unable to connect to X server: No route to host
