Hallo forum members,
I would appriciate help with my loginloop problem.
I have looked at entries concerning this problem and know that:
there is plenty of disk space
all dirs and files in my home dir are owned by me
I removed the .Xauthotity file
I deleted caches (pacman etc)
I removed pacman orphan packages
These measures did not help
I have the following information
inxi output
dmesg output
journalctl -p 3 -xb output
xorg.log output
I hope you can help me.
inxi:
Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.4-x86_64
root=UUID=8db5451a-ffb6-473a-a485-35204e74c5ca rw rootflags=subvol=@ quiet
Console: tty 2 DM: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: SLIMBOOK product: PROX-AMD5 v: Standard serial: <filter>
Mobo: SLIMBOOK model: SLIMBOOK v: Standard serial: <filter> UEFI: American
Megatrends LLC. v: N.1.06GRU06 date: 05/25/2022
ID-1: BAT0 charge: 61.7 Wh (76.0%) condition: 81.2/91.6 Wh (88.6%)
volts: 11.9 min: 11.6 model: standard type: Li-ion serial: <filter>
status: discharging
Info: model: AMD Ryzen 7 5700U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1500 high: 1800 min/max: 1400/4370 boost: enabled
base/boost: 1800/4350 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1800 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1800 10: 1400 11: 1400 12: 1800 13: 1800
14: 1400 15: 1400 16: 1400 bogomips: 57518
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Tongfang Hongkong driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 32.0 C
Device-2: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b71a
Display: x11 server: X.org v: 1.21.1.8 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
tty: 240x67
Monitor-1: eDP-1 model: ChiMei InnoLux 0x152d built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: GL data unavailable in console and glxinfo missing.
Device-1: AMD Renoir Radeon High Definition Audio vendor: Tongfang Hongkong
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.4.6-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.75 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl,pavucontrol
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.4:4 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 931.52 GiB used: 86.34 GiB (9.3%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
used: 86.34 GiB (18.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:3
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:2
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
maj-min: 259:3
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
maj-min: 259:3
System Temperatures: cpu: 34.0 C mobo: N/A gpu: amdgpu temp: 31.0 C
Processes: 298 Uptime: 1h 35m wakeups: 288 Memory: total: 32 GiB note: est.
available: 30.74 GiB used: 905.8 MiB (2.9%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1341 libs: 389 tools: pamac pm: flatpak pkgs: 0
Shell: Bash (su) v: 5.1.16 running-in: tty 2 inxi: 3.3.28
journal:
aug 09 07:42:12 prox kernel: amd_gpio AMDI0030:00: Invalid config param 0014
aug 09 07:42:12 prox kernel: amd_gpio AMDI0030:00: Invalid config param 0001
aug 09 07:42:15 prox kernel: amdgpu 0000:05:00.0: amdgpu: Secure display: Generic Failure.
aug 09 07:42:15 prox kernel: amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
aug 09 07:42:16 prox kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
aug 09 07:42:25 prox lightdm[1160]: gkr-pam: unable to locate daemon control file
dmsg:
[ 0.291739] #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.399418] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.399421] pci 0000:00:00.2: PCI INT A: not connected
[ 0.693306] amd_gpio AMDI0030:00: Invalid config param 0014
[ 0.693326] amd_gpio AMDI0030:00: Invalid config param 0014
[ 0.693340] amd_gpio AMDI0030:00: Invalid config param 0014
[ 0.782022] tpm tpm0: AMD fTPM version 0x3004900000005 causes system stutter; hwrng disabled
[ 0.968610] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.988186] nvme nvme0: missing or invalid SUBNQN field.
[ 0.989286] nvme nvme1: missing or invalid SUBNQN field.
[ 1.502805] memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
[ 1.805764] usb: port power management may be unreliable
[ 2.422162] amd_gpio AMDI0030:00: Invalid config param 0014
[ 2.422175] amd_gpio AMDI0030:00: Invalid config param 0001
[ 2.428723] acpi PNP0C14:01: duplicate WMI GUID ABBC0F6A-8EA1-11D1-00A0-C90629100000 (first instance was on PNP0C14:00)
[ 2.654553] asus_wmi: ASUS Management GUID not found
[ 2.805545] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-78.ucode failed with error -2
[ 2.813028] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 3.030174] thermal thermal_zone1: failed to read out thermal zone (-61)
[ 5.354115] kauditd_printk_skb: 55 callbacks suppressed
[ 6.026915] [drm] psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
[ 6.027134] [drm] psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
[ 6.027140] amdgpu 0000:05:00.0: amdgpu: Secure display: Generic Failure.
[ 6.027144] amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
[ 6.286596] amdgpu: SRAT table not found
[ 7.056922] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[ 89.786682] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=11859 DF PROTO=2
[ 214.803006] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=12194 DF PROTO=2
[ 265.141204] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=40.132.2.42 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=12484 PROTO=ICMP TYPE=9 CODE=0
[ 265.141222] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=40.132.2.42 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=50224 PROTO=ICMP TYPE=9 CODE=0
[ 281.216669] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=1.1.168.192 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=54320 PROTO=ICMP TYPE=9 CODE=0
[ 339.817391] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=15950 DF PROTO=2
[ 464.833886] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=17232 DF PROTO=2
[ 4965.747478] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=25915 DF PROTO=2
[ 5066.225157] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=40.132.2.42 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=12420 PROTO=ICMP TYPE=9 CODE=0
[ 5066.225175] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=40.132.2.42 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=33840 PROTO=ICMP TYPE=9 CODE=0
[ 5082.300683] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=1.1.168.192 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=21552 PROTO=ICMP TYPE=9 CODE=0
[ 5090.760792] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=26424 DF PROTO=2
[ 5215.776687] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=33619 DF PROTO=2
[ 5340.795103] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=45719 DF PROTO=2
[ 5366.667903] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=40.132.2.42 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=12292 PROTO=ICMP TYPE=9 CODE=0
[ 5366.667922] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=40.132.2.42 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=1072 PROTO=ICMP TYPE=9 CODE=0
[ 5382.735484] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:01:68:aa:c4:bf:8b:bf:08:00 SRC=1.1.168.192 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=58416 PROTO=ICMP TYPE=9 CODE=0
[ 5465.807481] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=46122 DF PROTO=2
[ 5590.823376] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=52312 DF PROTO=2
[ 5715.839271] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=53800 DF PROTO=2
[ 5840.857446] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=65249 DF PROTO=2
[ 5965.871244] [UFW BLOCK] IN=wlp3s0 OUT= MAC=14:85:7f:0b:00:e0:68:aa:c4:bf:8b:bf:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x10 PREC=0x80 TTL=1 ID=8437 DF PROTO=2
xorglog:
[ 17.932]
X.Org X Server 1.21.1.8
[ 17.932] Current Operating System: Linux prox 6.4.6-1-MANJARO #1 SMP PREEMPT_DYNAMIC Tue Jul 25 09:30:58 UTC 2023 x86_64
[ 17.932] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.4-x86_64 root=UUID=8db5451a-ffb6-473a-a485-35204e74c5ca rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
[ 17.932]
[ 17.932] Current version of pixman: 0.42.2
[ 17.932] Before reporting problems, check http://wiki.x.org
[ 17.932] Markers: (--) probed, (**) from config file, (==) default setting,
[ 17.932] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 9 07:42:27 2023
[ 17.932] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 17.932] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 17.932] (==) No Layout section. Using the first Screen section.
[ 17.932] (==) No screen section available. Using defaults.
[ 17.932] (**) |-->Screen "Default Screen Section" (0)
[ 17.932] (**) | |-->Monitor "<default monitor>"
[ 17.932] (==) No monitor specified for screen "Default Screen Section".
[ 17.932] (==) Automatically adding devices
[ 17.932] (==) Automatically enabling devices
[ 17.932] (==) Automatically adding GPU devices
[ 17.932] (==) Automatically binding GPU devices
[ 17.932] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 17.932] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 17.932] Entry deleted from font path.
[ 17.932] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 17.932] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 17.932] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 17.932] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 17.932] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 17.932] (II) The server relies on udev to provide the list of input devices.
[ 17.932] (II) Module ABI versions:
[ 17.932] X.Org ANSI C Emulation: 0.4
[ 17.932] X.Org Video Driver: 25.2
[ 17.932] X.Org XInput driver : 24.4
[ 17.932] X.Org Server Extension : 10.0
[ 17.933] (++) using VT number 7
[ 17.934] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 17.935] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 17.935] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.0/drm/card0
[ 17.962] (--) PCI:*(5@0:0:0) 1002:164c:1d05:115d rev 193, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfcb00000/524288, I/O @ 0x0000e000/256
[ 17.962] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 17.962] (II) LoadModule: "glx"
[ 17.962] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 17.963] (II) Module glx: vendor="X.Org Foundation"
[ 17.963] compiled for 1.21.1.8, module version = 1.0.0
[ 17.963] ABI class: X.Org Server Extension, version 10.0
[ 17.963] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 17.963] loading driver: amdgpu
[ 17.963] (==) Matched amdgpu as autoconfigured driver 0
[ 17.963] (==) Matched ati as autoconfigured driver 1
[ 17.963] (==) Matched modesetting as autoconfigured driver 2
[ 17.963] (==) Matched fbdev as autoconfigured driver 3
[ 17.963] (==) Matched vesa as autoconfigured driver 4
[ 17.963] (==) Assigned the driver to the xf86ConfigLayout
[ 17.963] (II) LoadModule: "amdgpu"
[ 17.963] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 17.964] (II) Module amdgpu: vendor="X.Org Foundation"
[ 17.964] compiled for 1.21.1.7, module version = 23.0.0
[ 17.964] Module class: X.Org Video Driver
[ 17.964] ABI class: X.Org Video Driver, version 25.2
[ 17.964] (II) LoadModule: "ati"
[ 17.964] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 17.964] (II) Module ati: vendor="X.Org Foundation"
[ 17.964] compiled for 1.21.1.8, module version = 22.0.0
[ 17.993] (II) LoadModule: "modesetting"
[ 17.993] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 17.993] (II) Module modesetting: vendor="X.Org Foundation"
[ 17.993] compiled for 1.21.1.8, module version = 1.21.1
[ 17.993] Module class: X.Org Video Driver
[ 17.993] ABI class: X.Org Video Driver, version 25.2
[ 17.993] (II) LoadModule: "fbdev"
[ 17.994] (WW) Warning, couldn't open module fbdev
[ 17.994] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 17.994] (II) LoadModule: "vesa"
[ 17.994] (WW) Warning, couldn't open module vesa
[ 17.994] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 17.994] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 17.994] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 17.998] (WW) Falling back to old probe method for modesetting
[ 17.998] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 17.998] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 17.998] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 17.998] (==) AMDGPU(0): Default visual is TrueColor
[ 17.998] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card0
[ 17.998] (==) AMDGPU(0): RGB weight 888
[ 17.998] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 17.998] (--) AMDGPU(0): Chipset: "AMD Radeon Graphics" (ChipID = 0x164c)
[ 17.998] (II) Loading sub module "fb"
[ 17.998] (II) LoadModule: "fb"
[ 17.998] (II) Module "fb" already built-in
[ 17.998] (II) Loading sub module "dri2"
[ 17.998] (II) LoadModule: "dri2"
[ 17.998] (II) Module "dri2" already built-in
[ 18.026] (II) Loading sub module "glamoregl"
[ 18.026] (II) LoadModule: "glamoregl"
[ 18.026] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 18.028] (II) Module glamoregl: vendor="X.Org Foundation"
[ 18.028] compiled for 1.21.1.8, module version = 1.0.1
[ 18.028] ABI class: X.Org ANSI C Emulation, version 0.4
[ 18.034] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon Graphics (renoir, LLVM 15.0.7, DRM 3.52, 6.4.6-1-MANJARO)
[ 18.034] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 18.034] (==) AMDGPU(0): TearFree property default: auto
[ 18.034] (==) AMDGPU(0): VariableRefresh: disabled
[ 18.034] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[ 18.034] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 18.036] (II) AMDGPU(0): Output eDP has no monitor section
[ 18.036] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 18.036] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 18.045] (II) AMDGPU(0): EDID for output eDP
[ 18.045] (II) AMDGPU(0): Manufacturer: CMN Model: 152d Serial#: 0
[ 18.045] (II) AMDGPU(0): Year: 2021 Week: 9
[ 18.045] (II) AMDGPU(0): EDID Version: 1.4
[ 18.045] (II) AMDGPU(0): Digital Display Input
[ 18.045] (II) AMDGPU(0): 8 bits per channel
[ 18.045] (II) AMDGPU(0): Digital interface is DisplayPort
[ 18.045] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 18.045] (II) AMDGPU(0): Gamma: 2.20
[ 18.045] (II) AMDGPU(0): No DPMS capabilities specified
[ 18.045] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[ 18.045] (II) AMDGPU(0): First detailed timing is preferred mode
[ 18.045] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 18.045] (II) AMDGPU(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 18.045] (II) AMDGPU(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 18.045] (II) AMDGPU(0): Manufacturer's mask: 0
[ 18.045] (II) AMDGPU(0): Supported detailed timing:
[ 18.045] (II) AMDGPU(0): clock: 138.8 MHz Image Size: 344 x 193 mm
[ 18.045] (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 18.045] (II) AMDGPU(0): v_active: 1080 v_sync: 1090 v_sync_end 1096 v_blanking: 1112 v_border: 0
[ 18.045] (II) AMDGPU(0): N156HCE-EN1
[ 18.045] (II) AMDGPU(0): CMN
[ 18.045] (II) AMDGPU(0): EDID (in hex):
[ 18.045] (II) AMDGPU(0): 00ffffffffffff000dae2d1500000000
[ 18.045] (II) AMDGPU(0): 091f0104a522137802ee95a3544c9926
[ 18.045] (II) AMDGPU(0): 0f505400000001010101010101010101
[ 18.045] (II) AMDGPU(0): 010101010101363680a0703820403020
[ 18.045] (II) AMDGPU(0): a60058c110000018000000fe004e3135
[ 18.045] (II) AMDGPU(0): 364843452d454e310a20000000fe0043
[ 18.045] (II) AMDGPU(0): 4d4e0a202020202020202020000000fe
[ 18.045] (II) AMDGPU(0): 004e3135364843452d454e310a2000c9
[ 18.045] (II) AMDGPU(0): Printing probed modes for output eDP
[ 18.045] (II) AMDGPU(0): Modeline "1920x1080"x60.0 138.78 1920 1968 2000 2080 1080 1090 1096 1112 -hsync -vsync (66.7 kHz eP)
[ 18.045] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 18.045] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 18.045] (II) AMDGPU(0): Output eDP connected
[ 18.045] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 18.045] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 18.045] (II) AMDGPU(0): Using exact sizes for initial modes
[ 18.045] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[ 18.045] (II) AMDGPU(0): mem size init: gart size :3d7017000 vram size: s:1df68000 visible:1df68000
[ 18.045] (==) AMDGPU(0): DPI set to (96, 96)
[ 18.045] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 18.045] (II) Loading sub module "ramdac"
[ 18.045] (II) LoadModule: "ramdac"
[ 18.045] (II) Module "ramdac" already built-in
[ 18.045] (II) UnloadModule: "modesetting"
[ 18.045] (II) Unloading modesetting
[ 18.045] (II) AMDGPU(0): [DRI2] Setup complete
[ 18.045] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 18.045] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 18.054] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[ 18.054] (II) AMDGPU(0): SYNC extension fences enabled
[ 18.054] (II) AMDGPU(0): Present extension enabled
[ 18.054] (==) AMDGPU(0): DRI3 enabled
[ 18.054] (==) AMDGPU(0): Backing store enabled
[ 18.054] (II) AMDGPU(0): Direct rendering enabled
[ 18.060] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 18.060] (II) AMDGPU(0): Acceleration enabled
[ 18.060] (==) AMDGPU(0): DPMS enabled
[ 18.060] (==) AMDGPU(0): Silken mouse enabled
[ 18.060] (II) AMDGPU(0): Set up textured video (glamor)
[ 18.077] (WW) AMDGPU(0): Option "HotplugDriver" is not used
[ 18.077] (II) Initializing extension Generic Event Extension
[ 18.077] (II) Initializing extension SHAPE
[ 18.077] (II) Initializing extension MIT-SHM
[ 18.077] (II) Initializing extension XInputExtension
[ 18.077] (II) Initializing extension XTEST
[ 18.077] (II) Initializing extension BIG-REQUESTS
[ 18.077] (II) Initializing extension SYNC
[ 18.078] (II) Initializing extension XKEYBOARD
[ 18.078] (II) Initializing extension XC-MISC
[ 18.078] (II) Initializing extension SECURITY
[ 18.078] (II) Initializing extension XFIXES
[ 18.078] (II) Initializing extension RENDER
[ 18.078] (II) Initializing extension RANDR
[ 18.078] (II) Initializing extension COMPOSITE
[ 18.078] (II) Initializing extension DAMAGE
[ 18.078] (II) Initializing extension MIT-SCREEN-SAVER
[ 18.078] (II) Initializing extension DOUBLE-BUFFER
[ 18.078] (II) Initializing extension RECORD
[ 18.078] (II) Initializing extension DPMS
[ 18.078] (II) Initializing extension Present
[ 18.078] (II) Initializing extension DRI3
[ 18.078] (II) Initializing extension X-Resource
[ 18.078] (II) Initializing extension XVideo
[ 18.078] (II) Initializing extension XVideo-MotionCompensation
[ 18.078] (II) Initializing extension GLX
[ 18.082] (II) AIGLX: Loaded and initialized radeonsi
[ 18.082] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 18.082] (II) Initializing extension XFree86-VidModeExtension
[ 18.082] (II) Initializing extension XFree86-DGA
[ 18.083] (II) Initializing extension XFree86-DRI
[ 18.083] (II) Initializing extension DRI2
[ 18.083] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[ 18.152] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 18.152] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 18.152] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 18.152] (**) Video Bus: Applying InputClass "system-keyboard"
[ 18.152] (II) LoadModule: "libinput"
[ 18.152] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 18.154] (II) Module libinput: vendor="X.Org Foundation"
[ 18.154] compiled for 1.21.1.8, module version = 1.3.0
[ 18.154] Module class: X.Org XInput Driver
[ 18.154] ABI class: X.Org XInput driver, version 24.4
[ 18.154] (II) Using input driver 'libinput' for 'Video Bus'
[ 18.154] (**) Video Bus: always reports core events
[ 18.154] (**) Option "Device" "/dev/input/event5"
[ 18.155] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 18.155] (II) event5 - Video Bus: device is a keyboard
[ 18.155] (II) event5 - Video Bus: device removed
[ 18.203] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/LNXVIDEO:00/input/input5/event5"
[ 18.203] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 18.203] (**) Option "xkb_layout" "us"
[ 18.203] (**) Option "xkb_variant" "euro"
[ 18.219] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 18.220] (II) event5 - Video Bus: device is a keyboard
[ 18.220] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 18.220] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 18.220] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 18.220] (**) Power Button: Applying InputClass "system-keyboard"
[ 18.220] (II) Using input driver 'libinput' for 'Power Button'
[ 18.220] (**) Power Button: always reports core events
[ 18.220] (**) Option "Device" "/dev/input/event0"
[ 18.220] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 18.220] (II) event0 - Power Button: device is a keyboard
[ 18.220] (II) event0 - Power Button: device removed
[ 18.250] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 18.250] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 18.250] (**) Option "xkb_layout" "us"
[ 18.250] (**) Option "xkb_variant" "euro"
[ 18.252] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 18.252] (II) event0 - Power Button: device is a keyboard
[ 18.252] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 18.252] (II) No input driver specified, ignoring this device.
[ 18.252] (II) This device may have been added with another device file.
[ 18.253] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 18.253] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 18.253] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 18.253] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 18.253] (II) Using input driver 'libinput' for 'Sleep Button'
[ 18.253] (**) Sleep Button: always reports core events
[ 18.253] (**) Option "Device" "/dev/input/event1"
[ 18.253] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 18.253] (II) event1 - Sleep Button: device is a keyboard
[ 18.253] (II) event1 - Sleep Button: device removed
[ 18.300] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 18.300] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 18.300] (**) Option "xkb_layout" "us"
[ 18.300] (**) Option "xkb_variant" "euro"
[ 18.301] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 18.301] (II) event1 - Sleep Button: device is a keyboard
[ 18.302] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event8)
[ 18.302] (II) No input driver specified, ignoring this device.
[ 18.302] (II) This device may have been added with another device file.
[ 18.302] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event9)
[ 18.302] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event10)
[ 18.303] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event11)
[ 18.303] (II) No input driver specified, ignoring this device.
[ 18.303] (II) This device may have been added with another device file.
[ 18.303] (II) config/udev: Adding input device UNIW0001:00 093A:0255 Mouse (/dev/input/event6)
[ 18.303] (**) UNIW0001:00 093A:0255 Mouse: Applying InputClass "evdev pointer catchall"
[ 18.303] (**) UNIW0001:00 093A:0255 Mouse: Applying InputClass "libinput pointer catchall"
[ 18.303] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:0255 Mouse'
[ 18.303] (**) UNIW0001:00 093A:0255 Mouse: always reports core events
[ 18.303] (**) Option "Device" "/dev/input/event6"
[ 18.304] (II) event6 - UNIW0001:00 093A:0255 Mouse: is tagged by udev as: Mouse Pointingstick
[ 18.304] (II) event6 - UNIW0001:00 093A:0255 Mouse: device is a pointer
[ 18.304] (II) event6 - UNIW0001:00 093A:0255 Mouse: device removed
[ 18.377] (II) libinput: UNIW0001:00 093A:0255 Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 18.377] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:01/i2c-0/i2c-UNIW0001:00/0018:093A:0255.0001/input/input8/event6"
[ 18.377] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:0255 Mouse" (type: MOUSE, id 9)
[ 18.377] (**) Option "AccelerationScheme" "none"
[ 18.377] (**) UNIW0001:00 093A:0255 Mouse: (accel) selected scheme none/0
[ 18.377] (**) UNIW0001:00 093A:0255 Mouse: (accel) acceleration factor: 2.000
[ 18.377] (**) UNIW0001:00 093A:0255 Mouse: (accel) acceleration threshold: 4
[ 18.379] (II) event6 - UNIW0001:00 093A:0255 Mouse: is tagged by udev as: Mouse Pointingstick
[ 18.379] (II) event6 - UNIW0001:00 093A:0255 Mouse: device is a pointer
[ 18.380] (II) config/udev: Adding input device UNIW0001:00 093A:0255 Mouse (/dev/input/mouse0)
[ 18.380] (II) No input driver specified, ignoring this device.
[ 18.380] (II) This device may have been added with another device file.
[ 18.380] (II) config/udev: Adding input device UNIW0001:00 093A:0255 Touchpad (/dev/input/event7)
[ 18.380] (**) UNIW0001:00 093A:0255 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 18.380] (**) UNIW0001:00 093A:0255 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 18.380] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:0255 Touchpad'
[ 18.380] (**) UNIW0001:00 093A:0255 Touchpad: always reports core events
[ 18.380] (**) Option "Device" "/dev/input/event7"
[ 18.381] (II) event7 - UNIW0001:00 093A:0255 Touchpad: is tagged by udev as: Touchpad
[ 18.381] (II) event7 - UNIW0001:00 093A:0255 Touchpad: device is a touchpad
[ 18.382] (II) event7 - UNIW0001:00 093A:0255 Touchpad: device removed
[ 18.440] (II) libinput: UNIW0001:00 093A:0255 Touchpad: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 18.441] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:01/i2c-0/i2c-UNIW0001:00/0018:093A:0255.0001/input/input9/event7"
[ 18.441] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:0255 Touchpad" (type: TOUCHPAD, id 10)
[ 18.442] (**) Option "AccelerationScheme" "none"
[ 18.442] (**) UNIW0001:00 093A:0255 Touchpad: (accel) selected scheme none/0
[ 18.442] (**) UNIW0001:00 093A:0255 Touchpad: (accel) acceleration factor: 2.000
[ 18.442] (**) UNIW0001:00 093A:0255 Touchpad: (accel) acceleration threshold: 4
[ 18.443] (II) event7 - UNIW0001:00 093A:0255 Touchpad: is tagged by udev as: Touchpad
[ 18.443] (II) event7 - UNIW0001:00 093A:0255 Touchpad: device is a touchpad
[ 18.444] (II) config/udev: Adding input device UNIW0001:00 093A:0255 Touchpad (/dev/input/mouse1)
[ 18.444] (II) No input driver specified, ignoring this device.
[ 18.444] (II) This device may have been added with another device file.
[ 18.444] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 18.444] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 18.444] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 18.444] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 18.444] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 18.444] (**) AT Translated Set 2 keyboard: always reports core events
[ 18.444] (**) Option "Device" "/dev/input/event3"
[ 18.445] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 18.445] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 18.445] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 18.467] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 18.467] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[ 18.467] (**) Option "xkb_layout" "us"
[ 18.467] (**) Option "xkb_variant" "euro"
[ 18.468] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 18.468] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 18.469] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 18.469] (II) No input driver specified, ignoring this device.
[ 18.469] (II) This device may have been added with another device file.
[ 21.057] (II) event5 - Video Bus: device removed
[ 21.093] (II) event0 - Power Button: device removed
[ 21.127] (II) event1 - Sleep Button: device removed
[ 21.143] (II) event6 - UNIW0001:00 093A:0255 Mouse: device removed
[ 21.176] (II) event7 - UNIW0001:00 093A:0255 Touchpad: device removed
[ 21.220] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 21.240] (II) AIGLX: Suspending AIGLX clients for VT switch
