Stuck at “Waiting for 1 Module” in installer
Hi, Im stuck at “Waiting for 1 module” in the Installer. I had a search around but I didn’t find anything that helped with the problem. Im trying to reinstall so I can use XFCE as I don’t like gnome.
Output of inxi -Fazy
  Kernel: 5.10.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCEM_2121 quiet
    systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
    nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Dell product: G3 3579 v: N/A
  Mobo: Dell model: 0JYXHN v: A00 serial: <superuser required> UEFI: Dell
    v: 1.17.0 date: 09/03/2021
  ID-1: BAT0 charge: 22.3 Wh (69.3%) condition: 32.2/56.0 Wh (57.5%)
    volts: 15.1 min: 15.2 model: Samsung SDI DELL W7NKD97 type: Li-ion
    serial: <filter> status: Discharging
  RAM: total: 15.49 GiB used: 3.23 GiB (20.9%)
  RAM Report:
  Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1397 high: 1440 min/max: 800/4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1389 2: 1394 3: 1392
    4: 1383 5: 1401 6: 1396 7: 1440 8: 1383 bogomips: 36812
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
    hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
    pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
    xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
    driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
    driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
    chip-ID: 10de:1c8c class-ID: 0302
  Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
    driver: uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:28c1 class-ID: 0e02
  Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0.0
    screens: 1
    s-diag: 582mm (22.9")
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.89-1-MANJARO running: yes
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 1.85 TiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P2SSD8
    lanes: 4 type: SSD serial: <filter> rev: P2CR033 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    type: HDD rpm: 5400 serial: <filter> rev: 0D scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Verbatim model: STORE N GO
    size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 2.00 scheme: MBR
  Message: No partition data found.
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 512 MiB fs: vfat label: N/A
    uuid: 9E46-F60B
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 8 GiB fs: swap label: N/A
    uuid: 3272a2af-6c47-41f1-a907-77dc85c73359
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 923.01 GiB fs: ext4 label: N/A
    uuid: 26ff2066-79b1-48e3-ba6a-b0d85b3c12cc
  ID-4: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: Storage
    uuid: ffe29364-dc47-48b8-a85e-bd5ac0aa1fd4
  ID-5: /dev/sdb1 maj-min: 8:17 size: 2.53 GiB fs: iso9660
  ID-6: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 79C6-8483
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-2:2 info: Verbatim Flash Drive type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
    chip-ID: 18a5:0302 class-ID: 0806 serial: <filter>
  Device-2: 1-5:3 info: Sunplus Innovation Integrated_Webcam_HD type: Video
  Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 48.0 C pch: 52.0 C mobo: N/A
  Processes: 277 Uptime: 15m wakeups: 1 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 976 lib: 275 Shell: Bash v: 5.1.12
  running-in: xfce4-terminal inxi: 3.3.11
Hello,
Looks like you are using a very old ISO.
Grab the latest one https://manjaro.org/downloads/official/xfce/
Boot with proprietary drivers …
I tried the latest iso as I was using the Minimal LTS iso. The only change I noticed with the regular iso that my fans were at max.
I just had to wait a bit for it to load the module it takes around 3 minutes where I was waiting 2
