This happens randomly, when shutting down my laptop gets stuck at " a stop job is running for TLP system" then I have to force the power off by keeping the power button. This is part of the logs that shows me when turning it off
may 06 21:16:39 max-aspire systemd[1]: Removed slice User Slice of UID 1000.
may 06 21:16:39 max-aspire systemd[1]: user-1000.slice: Consumed 11min 20.760s CPU time.
may 06 21:18:08 max-aspire systemd[1]: tlp.service: State 'stop-sigterm' timed out. Killing.
may 06 21:18:08 max-aspire systemd[1]: tlp.service: Killing process 1193 (tlp) with signal SIGKILL.
may 06 21:19:38 max-aspire systemd[1]: tlp.service: Processes still around after SIGKILL. Ignoring.
may 06 21:21:09 max-aspire systemd[1]: tlp.service: State 'final-sigterm' timed out. Killing.
may 06 21:21:09 max-aspire systemd[1]: tlp.service: Killing process 1193 (tlp) with signal SIGKILL.
may 06 21:22:39 max-aspire systemd[1]: tlp.service: Processes still around after final SIGKILL. Entering failed mode.
may 06 21:22:39 max-aspire systemd[1]: tlp.service: Failed with result 'timeout'.
may 06 21:22:39 max-aspire systemd[1]: tlp.service: Unit process 1193 (tlp) remains running after unit stopped.
I already tried adding these lines to grub:
GRUB_CMDLINE_LINUX_DEFAULT=“acpi=force apm=power_off apparmor=1 security=apparmor udev.log_priority=3”
I added the acpi=force and apm:power_off
and sometimes it shutsdown with no problems, but other times gets stuck
These are the specs of my laptop
CPU: 8-core AMD Ryzen 7 7730U with Radeon Graphics (-MT MCP-)
speed/min/max: 462/400/4546 MHz Kernel: 6.6.26-1-MANJARO x86_64 Up: 32m
Mem: 1.93/7.12 GiB (27.1%) Storage: 476.94 GiB (30.2% used) Procs: 349
Shell: Zsh inxi: 3.3.34
