Hello,
I rebooted after noticing I could no longer use lutris because vulkan issues. I had just updated system so thought a reboot might be first order then got stuck at loading screen.
TTY will only stay on the screen if I hold crl + alt f1,f2 etc (can’t enter any commands)
Chrooted in on liveISO and did the following, and got the following errors.
mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.1.49-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [encrypt]
-> Running build hook: [openswap]
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
[manjaro-gnome /]# pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
resolving dependencies...
Packages (2) libpamac-11.6.2+3+g76d2753-1 libpamac-flatpak-plugin-11.6.2+3+g76d2753-1
Total Download Size: 0.88 MiB
Total Installed Size: 3.77 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
libpamac-flatpak-plugin-11.6.2+3+g76d2753-1-x86_64 31.4 KiB 177 KiB/s 00:00 [#############################################################################] 100%
libpamac-11.6.2+3+g76d2753-1-x86_64 872.8 KiB 2.15 MiB/s 00:00 [#############################################################################] 100%
Total (2/2) 904.2 KiB 1350 KiB/s 00:01 [#############################################################################] 100%
(2/2) checking keys in keyring [#############################################################################] 100%
(2/2) checking package integrity [#############################################################################] 100%
(2/2) loading package files [#############################################################################] 100%
(2/2) checking for file conflicts [#############################################################################] 100%
(2/2) checking available disk space [#############################################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
Using system disk as snapshot device for creating snapshots in BTRFS mode
** (process:82): CRITICAL **: 09:26:29.763: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:82): CRITICAL **: 09:26:29.764: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:82): CRITICAL **: 09:26:29.766: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:82): CRITICAL **: 09:26:29.766: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
E: Selected snapshot device is not a system disk
E: Select BTRFS system disk with root subvolume (@)
** (process:122): CRITICAL **: 09:26:29.864: gee_abstract_collection_get_size: assertion 'self != NULL' failed
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
Detecting snapshots ...
Found snapshot: 2023-08-29 15:47:08 | timeshift-btrfs/snapshots/2023-08-29_15-47-08/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-08-29 15:42:51 | timeshift-btrfs/snapshots/2023-08-29_15-42-50/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-08-26 13:20:52 | timeshift-btrfs/snapshots/2023-08-26_13-20-52/@ | ondemand | N/A |
Found snapshot: 2023-08-26 08:07:47 | timeshift-btrfs/snapshots/2023-08-26_08-07-47/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found 4 snapshot(s)
Unmount /tmp/grub-btrfs.ZfPXo9jGXf .. Success
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(1/2) upgrading libpamac [#############################################################################] 100%
(2/2) upgrading libpamac-flatpak-plugin [#############################################################################] 100%
(1/4) Reloading system manager configuration...
Skipped: Running in chroot.
(2/4) Arming ConditionNeedsUpdate...
(3/4) Updating the MIME type database...
(4/4) Reloading system bus configuration...
pacman -S linux
warning: linux61-6.1.49-1 is up to date -- reinstalling
Packages (1) linux61-6.1.49-1
Total Download Size: 138.68 MiB
Total Installed Size: 143.17 MiB
linux61-6.1.49-1-x86_64 138.7 MiB 21.1 MiB/s 00:07 [#############################################################################] 100%
(1/1) checking keys in keyring [#############################################################################] 100%
(1/1) checking package integrity [#############################################################################] 100%
(1/1) loading package files [#############################################################################] 100%
(1/1) checking for file conflicts [#############################################################################] 100%
(1/1) checking available disk space [#############################################################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
** (process:8099): CRITICAL **: 09:32:47.113: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:8099): CRITICAL **: 09:32:47.113: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:8099): CRITICAL **: 09:32:47.115: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:8099): CRITICAL **: 09:32:47.115: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
** (process:8139): CRITICAL **: 09:32:47.206: gee_abstract_collection_get_size: assertion 'self != NULL' failed
Found 4 snapshot(s)
Unmount /tmp/grub-btrfs.hraj04tJK6 .. Success
done
(2/2) Remove upgraded DKMS modules
(1/1) reinstalling linux61 [#############################################################################] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Updating module dependencies...
(3/6) Install DKMS modules
==> ERROR: Missing 6.1.49-1-MANJARO kernel headers for module nvidia/535.104.05.
(4/6) Updating linux initcpios...
(5/6) Updating Kernel initcpios for Nvidia-DRM...
(6/6) Updating Grub-Bootmenu
Found 4 snapshot(s)
Unmount /tmp/grub-btrfs.hdUiTdbhca .. Success
done
pacman -Syu $(pacman -Qqen)
core is up to date
extra 8.6 MiB 8.05 MiB/s 00:01 [#############################################################################] 100%
warning: acpi-1.7-3 is up to date -- reinstalling
warning: acpid-2.0.34-1 is up to date -- reinstalling
warning: adobe-source-han-sans-cn-fonts-2.004-1 is up to date -- reinstalling
warning: adobe-source-han-sans-jp-fonts-2.004-1 is up to date -- reinstalling
warning: adobe-source-han-sans-kr-fonts-2.004-1 is up to date -- reinstalling
warning: adobe-source-sans-fonts-3.052-1 is up to date -- reinstalling
warning: adw-gtk-theme-1.1-1 is up to date -- reinstalling
warning: alacarte-1:3.44.3-1 is up to date -- reinstalling
warning: apparmor-3.1.6-2 is up to date -- reinstalling
warning: b43-fwcutter-019-4 is up to date -- reinstalling
warning: baobab-44.0-1 is up to date -- reinstalling
warning: base-3-2 is up to date -- reinstalling
warning: bibata-cursor-theme-2.0.3-4 is up to date -- reinstalling
warning: bmenu-0.20-1 is up to date -- reinstalling
warning: brave-browser-1.57.53-1 is up to date -- reinstalling
warning: btrfs-progs-6.3.3-1 is up to date -- reinstalling
warning: btrfsmaintenance-1:0.5-1 is up to date -- reinstalling
warning: bzip2-1.0.8-5 is up to date -- reinstalling
warning: caffeine-ng-4.2.0-2 is up to date -- reinstalling
warning: clamav-1.0.1-1 is up to date -- reinstalling
warning: cmatrix-2.0-2 is up to date -- reinstalling
warning: collision-3.5.0-2 is up to date -- reinstalling
warning: coreutils-9.3-1 is up to date -- reinstalling
warning: cpupower-6.3-4 is up to date -- reinstalling
warning: cronie-1.6.1-1 is up to date -- reinstalling
warning: cryptsetup-2.6.1-3.4 is up to date -- reinstalling
warning: deja-dup-44.2-1 is up to date -- reinstalling
warning: device-mapper-2.03.22-2 is up to date -- reinstalling
warning: dhclient-4.4.3.P1-2 is up to date -- reinstalling
warning: dhcpcd-10.0.2-1 is up to date -- reinstalling
warning: diffutils-3.10-1 is up to date -- reinstalling
warning: dmidecode-3.5-1 is up to date -- reinstalling
warning: dmraid-1.0.0.rc16.3-14 is up to date -- reinstalling
warning: dnsmasq-2.89-1 is up to date -- reinstalling
warning: dosfstools-4.2-3 is up to date -- reinstalling
warning: e2fsprogs-1.47.0-1 is up to date -- reinstalling
warning: ecryptfs-utils-111-7 is up to date -- reinstalling
warning: efibootmgr-18-2 is up to date -- reinstalling
warning: endeavour-43.0-2 is up to date -- reinstalling
warning: evince-44.3-1 is up to date -- reinstalling
warning: exfatprogs-1.2.1-1 is up to date -- reinstalling
warning: f2fs-tools-1.16.0-2 is up to date -- reinstalling
warning: ffmpeg-audio-thumbnailer-1.1.1-3 is up to date -- reinstalling
warning: ffmpegthumbnailer-2.2.2-5 is up to date -- reinstalling
warning: file-roller-43.0-2 is up to date -- reinstalling
warning: firefox-116.0.3-1 is up to date -- reinstalling
warning: fprintd-1.94.2-2 is up to date -- reinstalling
warning: gdm-44.1-1 is up to date -- reinstalling
warning: gedit-44.2-2 is up to date -- reinstalling
warning: gnome-backgrounds-44.0-1 is up to date -- reinstalling
warning: gnome-browser-connector-42.1-4 is up to date -- reinstalling
warning: gnome-calculator-44.0-1 is up to date -- reinstalling
warning: gnome-calendar-44.1-1 is up to date -- reinstalling
warning: gnome-characters-44.0-1 is up to date -- reinstalling
warning: gnome-chess-43.2-1 is up to date -- reinstalling
warning: gnome-clocks-44.0-1 is up to date -- reinstalling
warning: gnome-connections-44.1-2 is up to date -- reinstalling
warning: gnome-control-center-44.3-1 is up to date -- reinstalling
warning: gnome-disk-utility-44.0-1 is up to date -- reinstalling
warning: gnome-firmware-43.2-1 is up to date -- reinstalling
warning: gnome-font-viewer-44.0-1 is up to date -- reinstalling
warning: gnome-keyring-1:42.1-3 is up to date -- reinstalling
warning: gnome-layout-switcher-0.8.36-2 is up to date -- reinstalling
warning: gnome-logs-43.0-1 is up to date -- reinstalling
warning: gnome-maps-44.4-1 is up to date -- reinstalling
warning: gnome-remote-desktop-44.2-1 is up to date -- reinstalling
warning: gnome-session-44.0-1 is up to date -- reinstalling
warning: gnome-settings-daemon-44.1-1 is up to date -- reinstalling
warning: gnome-shell-extension-appindicator-1:53-1 is up to date -- reinstalling
warning: gnome-shell-extension-arc-menu-48-0 is up to date -- reinstalling
warning: gnome-shell-extension-custom-accent-colors-6-1 is up to date -- reinstalling
warning: gnome-shell-extension-dash-to-dock-84-1 is up to date -- reinstalling
warning: gnome-shell-extension-dash-to-panel-56-3 is up to date -- reinstalling
warning: gnome-shell-extension-gnome-ui-tune-1.7.3-2 is up to date -- reinstalling
warning: gnome-shell-extension-gsconnect-55-2 is up to date -- reinstalling
warning: gnome-shell-extension-gtk4-desktop-icons-ng-1:49-1 is up to date -- reinstalling
warning: gnome-shell-extension-legacy-theme-auto-switcher-r12.22bea52-1 is up to date -- reinstalling
warning: gnome-shell-extension-x11gestures-17-1 is up to date -- reinstalling
warning: gnome-shell-extensions-44.0-1 is up to date -- reinstalling
warning: gnome-shell-maia-44.4-1 is up to date -- reinstalling
warning: gnome-system-monitor-44.0-1 is up to date -- reinstalling
warning: gnome-terminal-3.48.2-1 is up to date -- reinstalling
warning: gnome-themes-extra-3.28+r6+g45b1d457-1 is up to date -- reinstalling
warning: gnome-tweaks-42beta+r14+g2d9d76c-3 is up to date -- reinstalling
warning: gnome-user-docs-44.3-1 is up to date -- reinstalling
warning: gnome-user-share-43.0-1 is up to date -- reinstalling
warning: gnome-weather-44.0-1 is up to date -- reinstalling
warning: gnuchess-6.2.9-3 is up to date -- reinstalling
warning: grilo-plugins-1:0.3.16-1 is up to date -- reinstalling
warning: grub-2.06.r499.ge67a551a4-4 is up to date -- reinstalling
warning: grub-btrfs-4.13-1 is up to date -- reinstalling
warning: grub-theme-manjaro-20.2-16 is up to date -- reinstalling
warning: gthumb-3.12.2-7 is up to date -- reinstalling
warning: gtksourceview-pkgbuild-5-1 is up to date -- reinstalling
warning: gufw-22.04-2 is up to date -- reinstalling
warning: gvfs-1.50.6-1 is up to date -- reinstalling
warning: gvfs-afc-1.50.6-1 is up to date -- reinstalling
warning: gvfs-google-1.50.6-1 is up to date -- reinstalling
warning: gvfs-gphoto2-1.50.6-1 is up to date -- reinstalling
warning: gvfs-mtp-1.50.6-1 is up to date -- reinstalling
warning: gvfs-nfs-1.50.6-1 is up to date -- reinstalling
warning: gvfs-smb-1.50.6-1 is up to date -- reinstalling
warning: haveged-1.9.18-1 is up to date -- reinstalling
warning: htop-3.2.2-1 is up to date -- reinstalling
warning: ibus-1.5.28-4 is up to date -- reinstalling
warning: inetutils-2.4-1 is up to date -- reinstalling
warning: intel-ucode-20230808-1 is up to date -- reinstalling
warning: inxi-3.3.29.1-1 is up to date -- reinstalling
warning: jfsutils-1.1.15-8 is up to date -- reinstalling
warning: kate-23.08.0-1 is up to date -- reinstalling
warning: kvantum-manjaro-0.13.5+5+g0179d45-1 is up to date -- reinstalling
warning: less-1:643-1 is up to date -- reinstalling
warning: lib32-alsa-lib-1.2.9-1 is up to date -- reinstalling
warning: lib32-alsa-plugins-1.2.7.1-2 is up to date -- reinstalling
warning: lib32-giflib-5.2.1-1 is up to date -- reinstalling
warning: lib32-gnutls-3.8.1-1 is up to date -- reinstalling
warning: lib32-gst-plugins-base-libs-1.22.5-1 is up to date -- reinstalling
warning: lib32-gtk3-1:3.24.38-1 is up to date -- reinstalling
warning: lib32-libjpeg-turbo-3.0.0-1 is up to date -- reinstalling
warning: lib32-libpulse-16.1-6 is up to date -- reinstalling
warning: lib32-libva-2.19.0-1 is up to date -- reinstalling
warning: lib32-libxcomposite-0.4.6-1 is up to date -- reinstalling
warning: lib32-libxinerama-1.1.5-1 is up to date -- reinstalling
warning: lib32-libxslt-1.1.38-1 is up to date -- reinstalling
warning: lib32-mpg123-1.31.3-1 is up to date -- reinstalling
warning: lib32-nvidia-utils-535.104.05-1 is up to date -- reinstalling
warning: lib32-ocl-icd-2.3.2-1 is up to date -- reinstalling
warning: lib32-openal-1.23.1-1 is up to date -- reinstalling
warning: lib32-sqlite-3.43.0-1 is up to date -- reinstalling
warning: lib32-v4l-utils-1.24.1-1 is up to date -- reinstalling
warning: lib32-vulkan-intel-23.1.6-1 is up to date -- reinstalling
warning: libdvdcss-1.4.3-1 is up to date -- reinstalling
warning: libreoffice-still-7.5.5-2 is up to date -- reinstalling
warning: libxnvctrl-535.104.05-1 is up to date -- reinstalling
warning: logrotate-3.21.0-2 is up to date -- reinstalling
warning: lrzip-0.651-2 is up to date -- reinstalling
warning: lutris-0.5.13-7 is up to date -- reinstalling
warning: lvm2-2.03.22-2 is up to date -- reinstalling
warning: lynis-3.0.9-1 is up to date -- reinstalling
warning: make-4.4.1-2 is up to date -- reinstalling
warning: man-db-2.11.2-1 is up to date -- reinstalling
warning: man-pages-6.05.01-1 is up to date -- reinstalling
warning: manjaro-alsa-20221002-1 is up to date -- reinstalling
warning: manjaro-base-skel-20171029-3 is up to date -- reinstalling
warning: manjaro-browser-settings-20220522-1 is up to date -- reinstalling
warning: manjaro-gdm-branding-20221120-1 is up to date -- reinstalling
warning: manjaro-gnome-backgrounds-20221208-1 is up to date -- reinstalling
warning: manjaro-gnome-extension-settings-20230517-2 is up to date -- reinstalling
warning: manjaro-gnome-settings-20230525-2 is up to date -- reinstalling
warning: manjaro-gstreamer-20221002-1 is up to date -- reinstalling
warning: manjaro-hello-0.7.1-2 is up to date -- reinstalling
warning: manjaro-input-20221002-1 is up to date -- reinstalling
warning: manjaro-log-helper-0.3.4+3+ga471e55-1 is up to date -- reinstalling
warning: manjaro-modem-20221002-1 is up to date -- reinstalling
warning: manjaro-printer-20220924-1 is up to date -- reinstalling
warning: manjaro-pulse-20221015-2 is up to date -- reinstalling
warning: manjaro-ranger-settings-20230527-1 is up to date -- reinstalling
warning: manjaro-release-23.0.0-1 is up to date -- reinstalling
warning: manjaro-settings-manager-0.5.7-16 is up to date -- reinstalling
warning: manjaro-settings-manager-notifier-0.5.7-16 is up to date -- reinstalling
warning: manjaro-system-20230401-1 is up to date -- reinstalling
warning: manjaro-zsh-config-0.26-1 is up to date -- reinstalling
warning: mdadm-4.2-2 is up to date -- reinstalling
warning: memtest86+-6.20-1 is up to date -- reinstalling
warning: memtest86+-efi-6.20-1 is up to date -- reinstalling
warning: mesa-utils-9.0.0-2 is up to date -- reinstalling
warning: mhwd-0.6.5-26 is up to date -- reinstalling
warning: mhwd-db-0.6.5-26 is up to date -- reinstalling
warning: mkinitcpio-openswap-0.1.0-3 is up to date -- reinstalling
warning: modemmanager-1.20.6-2 is up to date -- reinstalling
warning: nano-7.2-1 is up to date -- reinstalling
warning: nano-syntax-highlighting-2020.10.10+10+g1aa64a8-2 is up to date -- reinstalling
warning: nautilus-44.2.1-1 is up to date -- reinstalling
warning: nautilus-admin-1.1.9+5+ga51885e-4 is up to date -- reinstalling
warning: nautilus-empty-file-1.2-2 is up to date -- reinstalling
warning: neofetch-7.1.0-2 is up to date -- reinstalling
warning: network-manager-sstp-1.3.1-2 is up to date -- reinstalling
warning: networkmanager-1.42.6-1 is up to date -- reinstalling
warning: networkmanager-openconnect-1.2.10-1 is up to date -- reinstalling
warning: networkmanager-openvpn-1.10.2-3 is up to date -- reinstalling
warning: networkmanager-pptp-1.2.12-1 is up to date -- reinstalling
warning: networkmanager-strongswan-1.6.0-1.0 is up to date -- reinstalling
warning: networkmanager-vpnc-1.2.8-3 is up to date -- reinstalling
warning: nfs-utils-2.6.3-1 is up to date -- reinstalling
warning: noto-fonts-1:23.8.1-1 is up to date -- reinstalling
warning: noto-fonts-emoji-20220920-1 is up to date -- reinstalling
warning: nss-mdns-0.15.1-1 is up to date -- reinstalling
warning: ntfs-3g-2022.10.3-1 is up to date -- reinstalling
warning: nvidia-dkms-535.104.05-1 is up to date -- reinstalling
warning: nvidia-settings-535.104.05-1 is up to date -- reinstalling
warning: nvidia-utils-535.104.05-1 is up to date -- reinstalling
warning: obsidian-1.3.7-1 is up to date -- reinstalling
warning: openresolv-3.13.2-1 is up to date -- reinstalling
warning: openssh-9.4p1-2 is up to date -- reinstalling
warning: os-prober-1.81-1 is up to date -- reinstalling
warning: p7zip-1:17.05-1 is up to date -- reinstalling
warning: pacui-1.14+56+g4976123-3 is up to date -- reinstalling
warning: pamac-gnome-integration-11.6.0-0.2 is up to date -- reinstalling
warning: pamac-gtk-11.6.0-0.2 is up to date -- reinstalling
warning: papirus-maia-icon-theme-20200702-1 is up to date -- reinstalling
warning: perl-5.38.0-1 is up to date -- reinstalling
warning: pkgconf-1.8.1-1 is up to date -- reinstalling
warning: plymouth-theme-manjaro-2.2-1 is up to date -- reinstalling
warning: power-profiles-daemon-0.13-1 is up to date -- reinstalling
warning: qt5ct-1.7-1 is up to date -- reinstalling
warning: qt6ct-0.8-6 is up to date -- reinstalling
warning: reiserfsprogs-3.6.27-4 is up to date -- reinstalling
warning: rkhunter-1.4.6-3 is up to date -- reinstalling
warning: rsync-3.2.7-4 is up to date -- reinstalling
warning: rygel-1:0.42.4-1 is up to date -- reinstalling
warning: s-nail-14.9.24-2 is up to date -- reinstalling
warning: seahorse-1:43.0-2 is up to date -- reinstalling
warning: sof-firmware-2.2.6-1 is up to date -- reinstalling
warning: spectre-meltdown-checker-0.46+20+g9b7b09a-1 is up to date -- reinstalling
warning: squashfs-tools-4.6.1-1 is up to date -- reinstalling
warning: sudo-1.9.14.p3-1 is up to date -- reinstalling
warning: sushi-44.2-1 is up to date -- reinstalling
warning: sysfsutils-2.1.1-1 is up to date -- reinstalling
warning: system-config-printer-1.5.18-2 is up to date -- reinstalling
warning: systemd-253.8-1 is up to date -- reinstalling
warning: texinfo-7.0.3-1 is up to date -- reinstalling
warning: timeshift-23.07.1-2 is up to date -- reinstalling
warning: timeshift-autosnap-manjaro-0.10-1 is up to date -- reinstalling
warning: touche-2.0.9-1 is up to date -- reinstalling
warning: tracker3-miners-3.5.2-2 is up to date -- reinstalling
warning: ttf-dejavu-2.37+18+g9b5d1b2f-4 is up to date -- reinstalling
warning: ttf-droid-20121017-10 is up to date -- reinstalling
warning: ttf-hack-3.003-6 is up to date -- reinstalling
warning: ttf-inconsolata-1:3.000-3 is up to date -- reinstalling
warning: ttf-indic-otf-0.2-11 is up to date -- reinstalling
warning: ttf-liberation-2.1.5-1 is up to date -- reinstalling
warning: unace-2.5-11 is up to date -- reinstalling
warning: unrar-1:6.2.10-1 is up to date -- reinstalling
warning: usbutils-015-3 is up to date -- reinstalling
warning: vi-1:070224-6 is up to date -- reinstalling
warning: vulkan-intel-23.1.6-2 is up to date -- reinstalling
warning: wget-1.21.4-1 is up to date -- reinstalling
warning: which-2.21-6 is up to date -- reinstalling
warning: wine-staging-8.14-1 is up to date -- reinstalling
warning: winetricks-20220411-1 is up to date -- reinstalling
warning: wireless-regdb-2023.05.03-1 is up to date -- reinstalling
warning: wpa_supplicant-2:2.10-8 is up to date -- reinstalling
warning: xdg-desktop-portal-gnome-44.2-1 is up to date -- reinstalling
warning: xdg-user-dirs-gtk-0.11-2 is up to date -- reinstalling
warning: xdg-utils-1.1.3+45+g301a1a4-1 is up to date -- reinstalling
warning: xfsprogs-6.4.0-1 is up to date -- reinstalling
warning: xorg-server-21.1.8-2 is up to date -- reinstalling
warning: xorg-xinit-1.4.2-1 is up to date -- reinstalling
warning: yay-12.1.2-1 is up to date -- reinstalling
warning: yubikey-manager-qt-1.2.5-1 is up to date -- reinstalling
warning: dependency cycle detected:
warning: mhwd-db will be installed before its mhwd dependency
Packages (253) libpamac-11.6.2+3+g76d2753-1 acpi-1.7-3 acpid-2.0.34-1 adobe-source-han-sans-cn-fonts-2.004-1 adobe-source-han-sans-jp-fonts-2.004-1 adobe-source-han-sans-kr-fonts-2.004-1
adobe-source-sans-fonts-3.052-1 adw-gtk-theme-1.1-1 alacarte-1:3.44.3-1 apparmor-3.1.6-2 b43-fwcutter-019-4 baobab-44.0-1 base-3-2 bibata-cursor-theme-2.0.3-4 bmenu-0.20-1
brave-browser-1.57.53-1 btrfs-progs-6.3.3-1 btrfsmaintenance-1:0.5-1 bzip2-1.0.8-5 caffeine-ng-4.2.0-2 clamav-1.0.1-1 cmatrix-2.0-2 collision-3.5.0-2 coreutils-9.3-1 cpupower-6.3-4
cronie-1.6.1-1 cryptsetup-2.6.1-3.4 deja-dup-44.2-1 device-mapper-2.03.22-2 dhclient-4.4.3.P1-2 dhcpcd-10.0.2-1 diffutils-3.10-1 dmidecode-3.5-1 dmraid-1.0.0.rc16.3-14 dnsmasq-2.89-1
dosfstools-4.2-3 e2fsprogs-1.47.0-1 ecryptfs-utils-111-7 efibootmgr-18-2 endeavour-43.0-2 evince-44.3-1 exfatprogs-1.2.1-1 f2fs-tools-1.16.0-2 ffmpeg-audio-thumbnailer-1.1.1-3
ffmpegthumbnailer-2.2.2-5 file-roller-43.0-2 firefox-116.0.3-1 fprintd-1.94.2-2 gdm-44.1-1 gedit-44.2-2 gnome-backgrounds-44.0-1 gnome-browser-connector-42.1-4 gnome-calculator-44.0-1
gnome-calendar-44.1-1 gnome-characters-44.0-1 gnome-chess-43.2-1 gnome-clocks-44.0-1 gnome-connections-44.1-2 gnome-control-center-44.3-1 gnome-disk-utility-44.0-1 gnome-firmware-43.2-1
gnome-font-viewer-44.0-1 gnome-keyring-1:42.1-3 gnome-layout-switcher-0.8.36-2 gnome-logs-43.0-1 gnome-maps-44.4-1 gnome-remote-desktop-44.2-1 gnome-session-44.0-1
gnome-settings-daemon-44.1-1 gnome-shell-extension-appindicator-1:53-1 gnome-shell-extension-arc-menu-48-0 gnome-shell-extension-custom-accent-colors-6-1
gnome-shell-extension-dash-to-dock-84-1 gnome-shell-extension-dash-to-panel-56-3 gnome-shell-extension-gnome-ui-tune-1.7.3-2 gnome-shell-extension-gsconnect-55-2
gnome-shell-extension-gtk4-desktop-icons-ng-1:49-1 gnome-shell-extension-legacy-theme-auto-switcher-r12.22bea52-1 gnome-shell-extension-x11gestures-17-1 gnome-shell-extensions-44.0-1
gnome-shell-maia-44.4-1 gnome-system-monitor-44.0-1 gnome-terminal-3.48.2-1 gnome-themes-extra-3.28+r6+g45b1d457-1 gnome-tweaks-42beta+r14+g2d9d76c-3 gnome-user-docs-44.3-1
gnome-user-share-43.0-1 gnome-weather-44.0-1 gnuchess-6.2.9-3 grilo-plugins-1:0.3.16-1 grub-2.06.r499.ge67a551a4-4 grub-btrfs-4.13-1 grub-theme-manjaro-20.2-16 gthumb-3.12.2-7
gtksourceview-pkgbuild-5-1 gufw-22.04-2 gvfs-1.50.6-1 gvfs-afc-1.50.6-1 gvfs-google-1.50.6-1 gvfs-gphoto2-1.50.6-1 gvfs-mtp-1.50.6-1 gvfs-nfs-1.50.6-1 gvfs-smb-1.50.6-1 haveged-1.9.18-1
htop-3.2.2-1 ibus-1.5.28-4 inetutils-2.4-1 intel-ucode-20230808-1 inxi-3.3.29.1-1 jfsutils-1.1.15-8 kate-23.08.0-1 kvantum-manjaro-0.13.5+5+g0179d45-1 less-1:643-1 lib32-alsa-lib-1.2.9-1
lib32-alsa-plugins-1.2.7.1-2 lib32-giflib-5.2.1-1 lib32-gnutls-3.8.1-1 lib32-gst-plugins-base-libs-1.22.5-1 lib32-gtk3-1:3.24.38-1 lib32-libjpeg-turbo-3.0.0-1 lib32-libpulse-16.1-6
lib32-libva-2.19.0-1 lib32-libxcomposite-0.4.6-1 lib32-libxinerama-1.1.5-1 lib32-libxslt-1.1.38-1 lib32-mpg123-1.31.3-1 lib32-nvidia-utils-535.104.05-1 lib32-ocl-icd-2.3.2-1
lib32-openal-1.23.1-1 lib32-sqlite-3.43.0-1 lib32-v4l-utils-1.24.1-1 lib32-vulkan-intel-23.1.6-1 libdvdcss-1.4.3-1 libpamac-flatpak-plugin-11.6.2+3+g76d2753-1 libreoffice-still-7.5.5-2
libxnvctrl-535.104.05-1 linux61-6.1.49-1 logrotate-3.21.0-2 lrzip-0.651-2 lutris-0.5.13-7 lvm2-2.03.22-2 lynis-3.0.9-1 make-4.4.1-2 man-db-2.11.2-1 man-pages-6.05.01-1
manjaro-alsa-20221002-1 manjaro-base-skel-20171029-3 manjaro-browser-settings-20220522-1 manjaro-gdm-branding-20221120-1 manjaro-gnome-backgrounds-20221208-1
manjaro-gnome-extension-settings-20230517-2 manjaro-gnome-settings-20230525-2 manjaro-gstreamer-20221002-1 manjaro-hello-0.7.1-2 manjaro-input-20221002-1
manjaro-log-helper-0.3.4+3+ga471e55-1 manjaro-modem-20221002-1 manjaro-printer-20220924-1 manjaro-pulse-20221015-2 manjaro-ranger-settings-20230527-1 manjaro-release-23.0.0-1
manjaro-settings-manager-0.5.7-16 manjaro-settings-manager-notifier-0.5.7-16 manjaro-system-20230401-1 manjaro-zsh-config-0.26-1 mdadm-4.2-2 memtest86+-6.20-1 memtest86+-efi-6.20-1
mesa-utils-9.0.0-2 mhwd-0.6.5-26 mhwd-db-0.6.5-26 mkinitcpio-openswap-0.1.0-3 modemmanager-1.20.6-2 nano-7.2-1 nano-syntax-highlighting-2020.10.10+10+g1aa64a8-2 nautilus-44.2.1-1
nautilus-admin-1.1.9+5+ga51885e-4 nautilus-empty-file-1.2-2 neofetch-7.1.0-2 network-manager-sstp-1.3.1-2 networkmanager-1.42.6-1 networkmanager-openconnect-1.2.10-1
networkmanager-openvpn-1.10.2-3 networkmanager-pptp-1.2.12-1 networkmanager-strongswan-1.6.0-1.0 networkmanager-vpnc-1.2.8-3 nfs-utils-2.6.3-1 noto-fonts-1:23.8.1-1
noto-fonts-emoji-20220920-1 nss-mdns-0.15.1-1 ntfs-3g-2022.10.3-1 nvidia-dkms-535.104.05-1 nvidia-settings-535.104.05-1 nvidia-utils-535.104.05-1 obsidian-1.3.7-1 openresolv-3.13.2-1
openssh-9.4p1-2 os-prober-1.81-1 p7zip-1:17.05-1 pacui-1.14+56+g4976123-3 pamac-gnome-integration-11.6.0-0.2 pamac-gtk-11.6.0-0.2 papirus-maia-icon-theme-20200702-1 perl-5.38.0-1
pkgconf-1.8.1-1 plymouth-theme-manjaro-2.2-1 power-profiles-daemon-0.13-1 qt5ct-1.7-1 qt6ct-0.8-6 reiserfsprogs-3.6.27-4 rkhunter-1.4.6-3 rsync-3.2.7-4 rygel-1:0.42.4-1 s-nail-14.9.24-2
seahorse-1:43.0-2 sof-firmware-2.2.6-1 spectre-meltdown-checker-0.46+20+g9b7b09a-1 squashfs-tools-4.6.1-1 sudo-1.9.14.p3-1 sushi-44.2-1 sysfsutils-2.1.1-1 system-config-printer-1.5.18-2
systemd-253.8-1 texinfo-7.0.3-1 timeshift-23.07.1-2 timeshift-autosnap-manjaro-0.10-1 touche-2.0.9-1 tracker3-miners-3.5.2-2 ttf-dejavu-2.37+18+g9b5d1b2f-4 ttf-droid-20121017-10
ttf-hack-3.003-6 ttf-inconsolata-1:3.000-3 ttf-indic-otf-0.2-11 ttf-liberation-2.1.5-1 unace-2.5-11 unrar-1:6.2.10-1 usbutils-015-3 vi-1:070224-6 vulkan-intel-23.1.6-2 wget-1.21.4-1
which-2.21-6 wine-staging-8.14-1 winetricks-20220411-1 wireless-regdb-2023.05.03-1 wpa_supplicant-2:2.10-8 xdg-desktop-portal-gnome-44.2-1 xdg-user-dirs-gtk-0.11-2
xdg-utils-1.1.3+45+g301a1a4-1 xfsprogs-6.4.0-1 xorg-server-21.1.8-2 xorg-xinit-1.4.2-1 yay-12.1.2-1 yubikey-manager-qt-1.2.5-1
Total Download Size: 1385.56 MiB
Total Installed Size: 3866.27 MiB
mhwd-kernel -li
Currently running: 6.1.30-1-MANJARO (linux61)
* linux61
mount
/dev/mapper/lvm on / type btrfs (rw,relatime,ssd,space_cache=v2,subvolid=256,subvol=/@)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=8134768k,nr_inodes=2033692,mode=755,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
shm on /dev/shm type tmpfs (rw,nosuid,nodev,relatime,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
tmp on /tmp type tmpfs (rw,nosuid,nodev,inode64)
overlay on /etc/resolv.conf type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,xino=off)
sudo fdisk -l /dev/sda ✔
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 850
Disklabel type: gpt
Disk identifier: 70D684B2-6687-7141-8F46-71A8527477C4
Device Start End Sectors Size Type
/dev/sda1 4096 618495 614400 300M EFI System
/dev/sda2 618496 940846613 940228118 448.3G Linux filesystem
/dev/sda3 940846614 976768064 35921451 17.1G Linux filesystem
lsblk -f ✔
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda
├─sda1 vfat FAT32 0129-99AE
├─sda2 crypto_LUKS 1 afc8dbf2-bb6f-4855-b624-99e873362355
└─sda3 crypto_LUKS 1 b53917a4-44f9-4777-8c97-98ed4b9d3ac6
sdb
├─sdb1 ntfs System Reserved A04A7A754A7A4854
└─sdb2 ntfs 6EF2B158F2B124ED
sdc
└─sdc1 vfat FAT32 2CC5-9D24 113.4G 1% /run/media/manjaro/2CC5-9D24
sdd iso9660 Joliet Extension MANJARO_GNOME_2213 2023-05-29-09-36-46-00 0 100% /run/miso/bootmnt
├─sdd1 iso9660 Joliet Extension MANJARO_GNOME_2213 2023-05-29-09-36-46-00
└─sdd2 vfat FAT12 MISO_EFI D0A3-C7FC
sr0
