tried to install qflipper using this guide. Updated everything along the way. After that, login screen shows, i enter the correct password and nothing happens. Switching to tty via f keys just shows me same login screen. Currently booted with a live usb.
journalctl -b -1 -p 4
[manjaro /]# journalctl -b -1 -p 4
Mar 27 02:32:00 t480s kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/>
Mar 27 02:32:00 t480s kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-gu>
Mar 27 02:32:00 t480s kernel: #5 #6 #7
Mar 27 02:32:00 t480s kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Mar 27 02:32:00 t480s kernel: pnp 00:0b: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mar 27 02:32:00 t480s kernel: pnp 00:0b: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mar 27 02:32:00 t480s kernel: pnp 00:0b: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mar 27 02:32:00 t480s kernel: pnp 00:0b: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mar 27 02:32:00 t480s kernel: hpet_acpi_add: no address or irqs in _CRS
Mar 27 02:32:00 t480s kernel: usb: port power management may be unreliable
Mar 27 02:32:00 t480s systemd-udevd[304]: /etc/udev/rules.d/42-flipperzero.rules:2 Unknown group 'dialout', ignoring.
Mar 27 02:32:00 t480s systemd-udevd[304]: /etc/udev/rules.d/42-flipperzero.rules:4 Unknown group 'dialout', ignoring.
Mar 27 02:32:00 t480s systemd-udevd[304]: /etc/udev/rules.d/42-flipperzero.rules:6 Unknown group 'dialout', ignoring.
Mar 27 02:32:01 t480s kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfe>
Mar 27 02:32:01 t480s kernel: caller snb_uncore_imc_init_box+0x84/0xd0 [intel_uncore] mapping multiple BARs
Mar 27 02:32:01 t480s kernel: iwlwifi 0000:3d:00.0: api flags index 2 larger than supported by driver
Mar 27 02:32:01 t480s kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
Mar 27 02:32:01 t480s kernel: elan_i2c 1-0015: supply vcc not found, using dummy regulator
Mar 27 02:32:01 t480s kernel: elan_i2c 1-0015: unexpected iap version 0x00 (ic type: 0x20), firmware update will not work
Mar 27 02:32:02 t480s systemd[1]: dbus.socket: Socket service dbus.service not loaded, refusing.
Mar 27 02:32:02 t480s systemd[1]: Failed to listen on D-Bus System Message Bus Socket.
Mar 27 02:32:02 t480s systemd[1]: Dependency failed for Modem Manager.
Mar 27 02:32:02 t480s systemd[1]: Dependency failed for Authorization Manager.
Mar 27 02:32:02 t480s systemd[1]: Dependency failed for Bluetooth service.
Mar 27 02:32:02 t480s systemd[1]: Dependency failed for Thunderbolt system service.
Mar 27 02:32:02 t480s systemd-logind[540]: Failed to connect to system bus: No such file or directory
Mar 27 02:32:02 t480s systemd-logind[540]: Failed to fully start up daemon: No such file or directory
Mar 27 02:32:02 t480s systemd[1]: systemd-logind.service: Failed with result 'exit-code'.
Mar 27 02:32:02 t480s systemd[1]: Failed to start User Login Management.
Mar 27 02:32:02 t480s systemd-logind[554]: Failed to connect to system bus: No such file or directory
Mar 27 02:32:02 t480s systemd-logind[554]: Failed to fully start up daemon: No such file or directory
Mar 27 02:32:02 t480s systemd-logind[560]: Failed to connect to system bus: No such file or directory
Mar 27 02:32:02 t480s systemd-logind[560]: Failed to fully start up daemon: No such file or directory
Mar 27 02:32:03 t480s systemd-logind[566]: Failed to connect to system bus: No such file or directory
Mar 27 02:32:03 t480s systemd-logind[566]: Failed to fully start up daemon: No such file or directory
Mar 27 02:32:03 t480s systemd[1]: systemd-logind.service: Failed with result 'exit-code'.
Mar 27 02:32:03 t480s systemd[1]: Failed to start User Login Management.
Mar 27 02:32:03 t480s systemd[1]: dbus.socket: Socket service dbus.service not loaded, refusing.
Mar 27 02:32:03 t480s systemd[1]: Failed to listen on D-Bus System Message Bus Socket.
Mar 27 02:32:03 t480s systemd-logind[572]: Failed to connect to system bus: No such file or directory
Mar 27 02:32:03 t480s systemd-logind[572]: Failed to fully start up daemon: No such file or directory
Mar 27 02:32:03 t480s systemd[1]: dbus.socket: Start request repeated too quickly.
Mar 27 02:32:03 t480s systemd[1]: dbus.socket: Failed with result 'start-limit-hit'.
Mar 27 02:32:03 t480s kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Mar 27 02:32:03 t480s systemd[1]: systemd-logind.service: Start request repeated too quickly.
Mar 27 02:32:08 t480s sddm-helper[597]: pam_systemd(sddm-greeter:session): Failed to connect to system bus: No such file or directory
Mar 27 02:32:09 t480s sddm-greeter[598]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sddm'
Mar 27 02:32:09 t480s sddm-greeter[598]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd32d381c0), parent's thread is QThread(0x55ed18dcac40), current thread i>
Mar 27 02:32:09 t480s sddm-greeter[598]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Mar 27 02:32:09 t480s sddm-greeter[598]: Could not load a session backend. Session management operations such as shutdown will not be operational>
Mar 27 02:32:09 t480s sddm-greeter[598]: virtual QStringList Solid::Backends::UPower::UPowerManager::allDevices() error: "org.freedesktop.DBus.>
Mar 27 02:32:09 t480s sddm-greeter[598]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Mar 27 02:32:09 t480s sddm-greeter[598]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Mar 27 02:32:09 t480s sddm-greeter[598]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugi>
Mar 27 02:32:09 t480s sddm-greeter[598]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Mar 27 02:32:10 t480s sddm-greeter[598]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Mar 27 02:32:30 t480s sddm-helper[620]: pam_systemd_home(sddm:auth): Failed to connect to system bus: No such file or directory
Mar 27 02:32:31 t480s sddm-helper[620]: [PAM] authenticate: Authentication failure
Mar 27 02:32:31 t480s sddm[581]: Authentication error: SDDM::Auth::ERROR_AUTHENTICATION "Authentication failure"
Mar 27 02:32:31 t480s sddm-helper[620]: [PAM] Asked to close the session but it wasn't previously open
Mar 27 02:32:31 t480s sddm[581]: Auth: sddm-helper exited with 1
Mar 27 02:32:33 t480s sddm-helper[623]: pam_systemd_home(sddm:auth): Failed to connect to system bus: No such file or directory
Mar 27 02:32:35 t480s sddm-helper[623]: [PAM] authenticate: Authentication failure
Mar 27 02:32:35 t480s sddm[581]: Authentication error: SDDM::Auth::ERROR_AUTHENTICATION "Authentication failure"
Mar 27 02:32:35 t480s sddm-helper[623]: [PAM] Asked to close the session but it wasn't previously open
Mar 27 02:32:35 t480s sddm[581]: Auth: sddm-helper exited with 1
Mar 27 02:32:57 t480s sddm-helper[626]: pam_systemd_home(sddm:auth): Failed to connect to system bus: No such file or directory
Mar 27 02:32:57 t480s sddm-helper[626]: pam_systemd_home(sddm:account): Failed to connect to system bus: No such file or directory
Mar 27 02:32:57 t480s sddm-helper[626]: pam_systemd_home(sddm:session): Failed to connect to system bus: No such file or directory
Mar 27 02:32:57 t480s sddm-helper[626]: pam_systemd(sddm:session): Failed to connect to system bus: No such file or directory
Mar 27 02:32:58 t480s systemd-coredump[671]: [LNK] Process 669 (kwin_wayland_wr) of user 1001 dumped core.
Stack trace of thread 669:
#0 0x00007f51676ab32c n/a (libc.so.6 + 0x9132c)
#1 0x00007f516765a6c8 raise (libc.so.6 + 0x406c8)
#2 0x00007f51676424b8 abort (libc.so.6 + 0x284b8)
#3 0x00007f5167c980c2 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x980c2)
#4 0x0000558294c5fd5f n/a (kwin_wayland_wrapper + 0x4d5f)
#5 0x00007f5167643cd0 n/a (libc.so.6 + 0x29cd0)
#6 0x00007f5167643d8a __libc_start_main (libc.so.6 + 0x29d8a)
#7 0x0000558294c60b75 n/a (kwin_wayland_wrapper + 0x5b75)
Mar 27 02:33:33 t480s sddm[581]: Auth: sddm-helper exited with 64
Mar 27 02:33:34 t480s sddm-helper[691]: pam_systemd(sddm-greeter:session): Failed to connect to system bus: No such file or directory
Mar 27 02:33:34 t480s sddm-greeter[692]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sddm'
Mar 27 02:33:34 t480s sddm-greeter[692]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffec209ca30), parent's thread is QThread(0x55acf1d16c40), current thread i>
Mar 27 02:33:34 t480s sddm-greeter[692]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Mar 27 02:33:34 t480s sddm-greeter[692]: Could not load a session backend. Session management operations such as shutdown will not be operational>
Mar 27 02:33:34 t480s sddm-greeter[692]: virtual QStringList Solid::Backends::UPower::UPowerManager::allDevices() error: "org.freedesktop.DBus.>
Mar 27 02:33:34 t480s sddm-greeter[692]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Mar 27 02:33:34 t480s sddm-greeter[692]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Mar 27 02:33:34 t480s sddm-greeter[692]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugi>
Mar 27 02:33:35 t480s sddm-greeter[692]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Mar 28 00:00:06 t480s systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Mar 28 00:00:06 t480s systemd[1]: Failed to start pkgfile database update.
Mar 29 00:00:05 t480s systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Mar 29 00:00:05 t480s systemd[1]: Failed to start pkgfile database update.
Mar 29 14:37:51 t480s systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Mar 29 14:42:53 t480s systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Mar 29 14:47:54 t480s systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Mar 29 14:52:54 t480s systemd[1]: archlinux-keyring-wkd-sync.service: Start request repeated too quickly.
Mar 29 14:52:54 t480s systemd[1]: archlinux-keyring-wkd-sync.service: Failed with result 'exit-code'.
Mar 29 14:52:54 t480s systemd[1]: Failed to start Refresh existing keys of archlinux-keyring.
[manjaro /]# mhwd-kernel --listinstalled
Currently running: 6.6.10-1-MANJARO (linux66)
* linux61
[manjaro /]# mhwd --listinstalled
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
[manjaro /]#
