My manjaro keeps getting stuck at the grub bootloader screen (I am not sure if it is called like this, what I mean is the interface that you can select grub menuentries) after reboot. “Stuck” means that the countdown stopped (the whole screen stopped) and any keyboard input has no response that I have to press the power button to shutdown and boot again. It seems that this problem only happens every time I do a reboot. If I just shutdown the system and then cold boot it’s ok. I don’t know when this problem started as it used to work properly.
Tell me if any logs and configurations is needed to locate the problem.
post full system info:
inxi -zav7
are you dual booting with windows? if yes, disable fast startup;
and disable fast boot in your bios/uefi - you may not have this option
Additionaly i would suggest to try different kernels
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already
for your problem in the forum ? (Wisdom lies in asking → listening → reading
journalctl output from those failed restarts ?
Fast boot is already disabled.
Luckily the problem disappeared, though I didn’t do anything specific.
P.S. I noticed that my swapfile broke and I fixed it. I don’t know why. Perhaps this is related to my problem?
