Rebooted after an update and now it gets stuck after GRUB.
I was on linux54 and also tried with linux510 kernel, didn’t work. I can’t even get into TTY.
I booted a live usb and mounted the drive via chroot and pacman says everything is up to date and no conflicting packages. What to do now?
Boot the live ISO again, open a terminal window, enter
inxi -Fza
and post the output here.
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2121 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81FV v: Lenovo Legion Y530-15ICH
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion Y530-15ICH
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: 8JCN52WW date: 06/14/2019
ID-1: BAT0 charge: 41.6 Wh (100.0%) condition: 41.6/52.5 Wh (79.2%)
volts: 12.7 min: 11.4 model: CPT-COS L17C3PG1 type: Li-poly
serial: <filter> status: Full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52815
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Lenovo
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
Device-3: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 5986:2113 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A
modules: rtw88_8822be port: 4000 bus-ID: 07:00.0 chip-ID: 10ec:b822
class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 08:00.0
IF: enp8s0 state: down mac: <filter>
Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:4 chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 2.06 TiB used: 0 KiB (0.0%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
type: HDD rpm: 5400 serial: <filter> rev: LDM2 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 14.41 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 46.0 C pch: 62.0 C mobo: N/A gpu: nouveau
temp: 44.0 C
Processes: 305 Uptime: 55m wakeups: 1 Memory: 15.5 GiB
used: 3.66 GiB (23.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1150 lib: 317 flatpak: 0 Shell: Bash v: 5.1.12
running-in: xfce4-terminal inxi: 3.3.11
Have you interrupted the update process?
No, the update completed without errors.
Your system logs looks unobtrusive. I would run GParted from a live ISO and have the main partitions checked.
Everything looks fine in gparted. I really don’t get it what’s happening.
“Looking fine” is not the same as using the “check partition” functionality of GParted.
GParted 1.3.1
configuration --enable-libparted-dmraid --enable-online-resize
libparted 3.4
Device: /dev/nvme0n1
Model: Samsung SSD 970 EVO Plus 250GB
Serial:
Sector size: 512
Total sectors: 488397168
Heads: 255
Sectors/track: 2
Cylinders: 957641
Partition table: gpt
Partition Type Start End Flags Partition Name File System Label Mount Point
/dev/nvme0n1p1 Primary 2048 206847 boot, esp EFI system partition fat32
/dev/nvme0n1p2 Primary 206848 239615 msftres Microsoft reserved partition unknown
/dev/nvme0n1p3 Primary 239616 487371479 msftdata Basic data partition ntfs
/dev/nvme0n1p4 Primary 487372800 488394751 hidden, diag ntfs
Device: /dev/sda
Model: ATA ST2000LM007-1R81
Serial: WDZF27S4
Sector size: 512
Total sectors: 3907029168
Heads: 255
Sectors/track: 2
Cylinders: 7660841
/dev/sda1 Primary 2048 1023999999 msftdata Basic data partition ntfs New Volume
/dev/sda2 Primary 1024002048 1945602047 msftdata Basic data partition ntfs
/dev/sda3 Primary 1945602048 2867202047 msftdata Basic data partition ntfs
/dev/sda4 Primary 2867202048 3054030847 ext4
/dev/sda5 Primary 3054032896 3086260223 swap linux-swap
/dev/sda6 Primary 3086260224 3907028991 ext4
Device: /dev/sdb
Model: Kingston DataTraveler 3.0
Serial:
Sector size: 512
Total sectors: 30218842
Heads: 255
Sectors/track: 2
Cylinders: 59252
Partition table: none
/dev/sdb Unpartitioned 0 30218841 iso9660 MANJARO_XFCE_2121 /run/miso/bootmnt
Check and repair file system (ext4) on /dev/sda4 00:00:25 ( SUCCESS )
calibrate /dev/sda4 00:00:00 ( SUCCESS )
path: /dev/sda4 (partition)
start: 2867202048
end: 3054030847
size: 186828800 (89.09 GiB)
check file system on /dev/sda4 for errors and (if possible) fix them 00:00:25 ( SUCCESS )
e2fsck -f -y -v -C 0 '/dev/sda4' 00:00:25 ( SUCCESS )
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
525511 inodes used (9.00%, out of 5840896)
1604 non-contiguous files (0.3%)
375 non-contiguous directories (0.1%)
# of inodes with ind/dind/tind blocks: 0/0/0
Extent depth histogram: 451873/406
8972939 blocks used (38.42%, out of 23353600)
0 bad blocks
1 large file
416136 regular files
35509 directories
0 character device files
0 block device files
0 fifos
4610 links
73857 symbolic links (73224 fast symbolic links)
0 sockets
530112 files
e2fsck 1.46.4 (18-Aug-2021)
grow file system to fill the partition 00:00:00 ( SUCCESS )
resize2fs -p '/dev/sda4' 00:00:00 ( SUCCESS )
resize2fs 1.46.4 (18-Aug-2021)
The filesystem is already 23353600 (4k) blocks long. Nothing to do!
Check and repair file system (ext4) on /dev/sda6 00:00:22 ( SUCCESS )
calibrate /dev/sda6 00:00:02 ( SUCCESS )
path: /dev/sda6 (partition)
start: 3086260224
end: 3907028991
size: 820768768 (391.37 GiB)
check file system on /dev/sda6 for errors and (if possible) fix them 00:00:20 ( SUCCESS )
e2fsck -f -y -v -C 0 '/dev/sda6' 00:00:20 ( SUCCESS )
650386 inodes used (2.54%, out of 25649152)
2416 non-contiguous files (0.4%)
223 non-contiguous directories (0.0%)
Extent depth histogram: 603662/391
16193563 blocks used (15.78%, out of 102596096)
0 bad blocks
6 large files
519037 regular files
84956 directories
1 fifo
26 links
46383 symbolic links (46324 fast symbolic links)
0 sockets
650403 files
resize2fs -p '/dev/sda6' 00:00:00 ( SUCCESS )
The filesystem is already 102596096 (4k) blocks long. Nothing to do!
Try what is described here:
I’ve tried everything from the thread,
CTRL + ALT + Fn doesn’t work so I chrooted from live usb. No new packages found with packman. I also reinstalled the graphics drivers and nothing new happened. The laptop is still flickering the logo on boot and I just get a flickering underscore at the top left corner of my screen. It doesn’t let me to open the terminal or nothing.
I disabled lightdm and I managed to boot but now I don’t know how to get the greeter again.
