I do know know exactly for what this is happening but last time I was trying to create a virtual monitor with vdl-monitor which I think uses xrendr.
after reboot what happend is written in titel
please help
$ sudo inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2213 quiet systemd.show_status=1
splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: Gigabyte model: F2A55M-DS2 v: x.x serial: N/A
UEFI: American Megatrends v: FD date: 01/09/2014
System RAM: available: 6.97 GiB used: 1.95 GiB (28.0%)
Array-1: capacity: 16 GiB note: est. slots: 4 EC: None
max-module-size: 4 GiB note: est.
Device-1: Node0_Dimm0 type: no module installed
Device-2: Node0_Dimm1 type: DDR3 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 1333 MT/s volts: N/A width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMZ4GX3M1A160 serial: N/A
Device-3: Node0_Dimm2 type: no module installed
Device-4: Node0_Dimm3 type: DDR3 detail: synchronous unbuffered
Info: model: AMD A8-6600K APU with Radeon HD Graphics socket: FM2 (P0)
note: check bits: 64 type: MT MCP arch: Piledriver level: v2 built: 2012-13
process: GF 32nm family: 0x15 (21) model-id: 0x13 (19) stepping: 1
microcode: 0x6001119
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 1900 min/max: 1900/3900 boost: enabled
base/boost: 3900/3900 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.3 V ext-clock: 100 MHz cores: 1: 1900 2: 1900 3: 1900 4: 1900
bogomips: 31157
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor
msr mtrr nonstop_tsc nopl npt nrip_save nx osvw pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean vme vmmcall
wdt xop xsave
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Richland [Radeon HD 8570D] driver: radeon v: kernel
alternate: amdgpu arch: TeraScale-3 code: Northern Islands process: TSMC 32nm
built: 2010-13 ports: active: VGA-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 00:01.0
chip-ID: 1002:990e class-ID: 0300
Device-2: Logitech Webcam C170 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-4:5 chip-ID: 046d:082b
class-ID: 0102
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa dri: r600 gpu: radeon display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: VGA-1 mapped: VGA-0 model: LG (GoldStar) FULL HD
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.5 Mesa 23.0.3 renderer: AMD ARUBA (DRM 2.50.0 /
6.1.30-1-MANJARO LLVM 15.0.7) direct-render: Yes
Device-1: AMD Trinity HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-3: Logitech Webcam C170 driver: snd-usb-audio,uvcvideo type: USB
class-ID: 0102
API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with: wireplumber
status: active tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 946.53 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
family: Barracuda 7200.14 (AF) size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 3.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: CC43 temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 305d 7h cycles: 6849
read: 1.25 PiB written: 76.6 TiB Pre-Fail: reallocated sector: 99
threshold: 10 attribute: Spin_Retry_Count value: 100 worst: 100
threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: HP model: v220w size: 15.02 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 speed: <unknown> tech: N/A serial: <filter> fw-rev: 1100
scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSB0 rev: LM01
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
Message: No partition data found.
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.59 GiB fs: iso9660
ID-2: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 9E58-98B8
ID-3: /dev/sda2 maj-min: 8:2 size: 931.22 GiB fs: ext4 label: N/A
uuid: e7612f8f-268d-41db-a436-8289b3ca7f84
ID-4: /dev/sdb1 maj-min: 8:17 size: 14.98 GiB fs: exfat label: Ventoy
uuid: BF28-28A2
ID-5: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 83A6-E98E
Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 2.0
Device-1: 1-3:2 info: HP v220w type: mass storage driver: usb-storage
power: 300mA chip-ID: 03f0:5a07 class-ID: 0806 serial: <filter>
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
Device-1: 2-4:5 info: Logitech Webcam C170 type: video,audio
chip-ID: 046d:082b class-ID: 0102
Hub-3: 3-0:1 info: full speed or root hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: full speed or root hub ports: 5 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-5: 5-0:1 info: full speed or root hub ports: 5 rev: 1.1
Device-1: 5-1:2 info: Logitech Unifying Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Device-2: 5-2:3 info: Dell MS116 Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:301a class-ID: 0301
Device-3: 5-3:4 info: SINO WEALTH Gaming KB type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:002a class-ID: 0300
Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-7: 7-0:1 info: full speed or root hub ports: 4 rev: 1.1
System Temperatures: cpu: 25.0 C mobo: N/A gpu: radeon temp: 9.0 C
Processes: 196 Uptime: 3m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1211 libs: 330 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh (sudo)
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
sudo startx output
and after opening the log
