Hey all, I came back to using my desktop after a few months away, but I’m greeted with a black screen with an underscore. I can drop into a TTY with ctrl+alt+f3 just fine.
Output of inxi --full --admin --filter --width
Kernel: 6.1.68-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=782a54fe-8f94-48e2-bc19-0e819fde0595 rw udev.log_priority=3
Console: tty 3 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: PRO Z690-A WIFI DDR4(MS-7D25) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.10
date: 12/13/2021
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x32
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 800 min/max: 800/4900:5100:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 144440
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915 v: kernel
ports: active: HDMI-A-1 empty: DP-1, DP-2, HDMI-A-2, HDMI-A-3, HDMI-A-4
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0380
Device-2: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: ASUSTeK
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:21c4
class-ID: 0300
Device-3: 2M UVC CAMERA NexiGo N660 FHD Webcam
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-5.2:5 chip-ID: 1d6c:0103 class-ID: 0102
serial: <filter>
Display: server: X.org v: 1.21.1.10 driver: X: loaded: nvidia gpu: i915
tty: 240x67
Monitor-1: HDMI-A-1 model: LG (GoldStar) 24GL600F serial: <filter>
built: 2021 res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia inactive: wayland,x11,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1
note: console (EGL sourced) renderer: NVIDIA GeForce GTX 1660
SUPER/PCIe/SSE2, Mesa Intel UHD Graphics 770 (ADL-S GT1), llvmpipe (LLVM
16.0.6 256 bits)
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 SUPER driver: nvidia v: 545.29.06 device-ID: 10de:21c4
surfaces: N/A device: 1 type: integrated-gpu name: Intel UHD Graphics 770
(ADL-S GT1) driver: mesa intel v: 23.1.9-manjaro1.1 device-ID: 8086:4680
surfaces: N/A
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
serial: <filter>
API: ALSA v: k6.1.68-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: off with: pulseaudio-alsa type: plugin
tools: pacat,pactl,pavucontrol
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: br-86fd7da06b69 state: down mac: <filter>
IF-ID-2: br-91342eeb8bd1 state: down mac: <filter>
IF-ID-3: br-982c1c55d5d0 state: down mac: <filter>
IF-ID-4: br-bf7ebd0eb5a5 state: down mac: <filter>
IF-ID-5: br-dbfe2d9355db state: down mac: <filter>
IF-ID-6: br-e60aa567f0af state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-7: docker0 state: down mac: <filter>
IF-ID-8: veth3ed93b5 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-9: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-10: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.82 TiB used: 772.9 GiB (41.5%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 3B2QEXM7 temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 772.87 GiB (84.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 25.7 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (rpm): N/A
Processes: 348 Uptime: 3m wakeups: 0 Memory: total: 32 GiB
available: 31.17 GiB used: 1.34 GiB (4.3%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 2117 libs: 450 tools: pamac,yay
pm: rpm pkgs: 0 pm: flatpak pkgs: 0 Shell: Bash (login) v: 5.2.21
running-in: tty 3 inxi: 3.3.31
Output of sudo dmesg --level emerg,alert,crit,err,warn
[ 0.192519] #17 #18 #19
[ 0.256744] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.SADX], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259060] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.SADS], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.RDLY], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14._DSM], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.BTRT], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14._PRR], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.BRDY], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.BRDS], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.ECKY], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.ECKV], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.GPCX], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.GPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.BTLY], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.259064] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14.BTLC], AE_ALREADY_EXISTS (20220331/dswload2-326)
[ 0.349059] pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.852847] ata2.00: supports DRM functions and may not be fully accessible
[ 0.857217] ata2.00: supports DRM functions and may not be fully accessible
[ 1.995140] vboxdrv: loading out-of-tree module taints kernel.
[ 2.021535] VBoxNetAdp: Successfully started.
[ 2.022431] VBoxNetFlt: Successfully started.
[ 2.783479] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 2.797397] nvidia: module license 'NVIDIA' taints kernel.
[ 2.797400] Disabling lock debugging due to kernel taint
[ 3.002200] thermal thermal_zone1: failed to read out thermal zone (-61)
[ 3.044630] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
[ 3.664536] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 4.541095] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
I’ve also uninstalled and re-installed my graphics drivers with sudo mhwd -r pci video-nvidia
and sudo mhwd -a pci nonfree 0300
. When I uninstalled the drivers and rebooted, there were logs displayed until [OK] Reached target Graphical Interface
. When I reinstall the drivers and reboot, I’m back to the black screen with an underscore.
Any ideas on how to fix this?
