I am using Manjaro Gnome Linux with Kernel version 6.6.
I also have 5.15 installed, but it is affected as well (I don’t use it, but tested it now).
My system is a Legion 15ACH6H with Ryzen 5800H and Nvidia 3060.
The behaviour is that I am greeted with a login screen, I enter a CORRECT password, the spinner starts loading for a bit (as it should) and then it dissapears and it gets stuck there.
If I try mashing my keys, sometimes I provoke it to go back to the user selection screen, but the same behaviour remains after I type the password.
What DOES work is going into tty session and running startx. It starts the GUI just fine (altough a bit laggish compared to normally run one).
I have googled a lot, but didn’t find the solution.
Things I have tried:
- (re)moving .config and .local inside my user’s home folder
- Checking gdm status, output:
Maj 26 16:40:00 nedim-Legion gdm-password][6187]: gkr-pam: unable to locate daemon control file
Maj 26 16:40:00 nedim-Legion gdm-password][6187]: gkr-pam: stashed password to try later in open session
- Running inxi, output:
Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
root=UUID=2449faac-31a7-4d2f-84bf-a780dedd1851 rw
resume=UUID=ff80626e-bd99-4df8-a68e-3e6b0fb9d07c quiet splash apparmor=1
resume=UUID=ff80626e-bd99-4df8-a68e-3e6b0fb9d07c amd_iommu=off
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 82JQ v: Legion 5 Pro 16ACH6H
serial: <filter> Chassis: type: 10 v: Legion 5 Pro 16ACH6H serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter>
part-nu: LENOVO_MT_82JQ_BU_idea_FM_Legion 5 Pro 16ACH6H
uuid: f1705b8f-03e1-11ec-80f0-902e16d819a4 UEFI: LENOVO v: GKCN53WW
date: 02/25/2022
ID-1: BAT0 charge: 48.1 Wh (69.0%) condition: 69.7/80.0 Wh (87.1%)
power: 13.4 W volts: 15.7 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: discharging cycles: 653
System RAM: total: 16 GiB available: 14.49 GiB used: 4.62 GiB (31.9%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Hynix
part-no: HMAA1GS6CJR6N-XN serial: <filter>
Info: model: AMD Ryzen 7 5800H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/4463 base/boost: 3200/4450 scaling:
driver: amd-pstate-epp governor: powersave volts: 1.2 V ext-clock: 100 MHz
cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400 bogomips: 102245
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,
DP-2, HDMI-A-1, eDP-2 bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 41.0 C
Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 174f:2435
class-ID: 0e02
Display: server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: amdgpu dri: radeonsi gpu: amdgpu display-ID: :2 screens: 1
Screen-1: 0 s-res: 2560x1600 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model-id: CSO 0x1609 built: 2021 res: 2560x1600 hz: 165
dpi: 188 gamma: 1.2 size: 345x215mm (13.58x8.46") diag: 407mm (16")
ratio: 16:10 modes: max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 17.0.6 DRM 3.54 6.6.30-2-MANJARO) device-ID: 1002:1638
memory: 1000 MiB unified: no
API: Vulkan v: 1.3.279 layers: 2 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.78 device-ID: 10de:2560
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RENOIR) driver: mesa radv v: 24.0.6-manjaro1.1
device-ID: 1002:1638 surfaces: xcb,xlib
Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.5 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active (root, process) with:
tools: pacat,pactl,pamixer
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
IF-ID-3: vethd39fe88 state: up speed: 10000 Mbps duplex: full mac: <filter>
Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3
chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Report: hciconfig ID: hci0 rfk-id: 3 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Info: acl-mtu: 1021:6 sco-mtu: 240:8 link-policy: rswitch sniff
link-mode: peripheral accept
Local Storage: total: 953.87 GiB used: 256.12 GiB (26.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3L1QEXF7 temp: 44.9 C
scheme: GPT
ID-1: / raw-size: 68.22 GiB size: 66.6 GiB (97.62%) used: 35.75 GiB (53.7%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 2449faac-31a7-4d2f-84bf-a780dedd1851
ID-2: /boot/efi raw-size: 300.3 MiB size: 299.7 MiB (99.80%)
used: 25.7 MiB (8.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p9
maj-min: 259:9 label: NO_LABEL uuid: 1581-564C
ID-3: /home raw-size: 270 GiB size: 264.7 GiB (98.04%)
used: 220.35 GiB (83.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: N/A uuid: 0cfdcb46-c400-47c6-97ef-3464e6a2e4d5
ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: ff80626e-bd99-4df8-a68e-3e6b0fb9d07c
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 208.44 GiB fs: ntfs label: N/A
uuid: B4F0C947F0C91092
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 390.62 GiB fs: ntfs label: Data
uuid: 1CD2820ED281EBF8
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 530 MiB fs: ntfs label: N/A
uuid: E2201C28201C0667
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 509 MiB fs: ntfs label: N/A
uuid: E0DAF6D2DAF6A3C6
Hub-2: 1-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-3:3 info: Syntek Integrated Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 174f:2435 class-ID: 0e02
Device-2: 1-4:4 info: Integrated Express ITE Device(8910) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c101 class-ID: 0301
Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-4: 2-2:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Integrated Express ITE Device(8295)
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 048d:c965 class-ID: 0300
Device-2: 3-4:3 info: Foxconn / Hon Hai MediaTek Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 3 rev: 2.1
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 42.4 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Processes: 567 Power: uptime: 32m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.78 GiB services: gsd-power,
tool: systemctl
Packages: 1858 pm: pacman pkgs: 1841 libs: 465
tools: gnome-software,pamac,yay pm: pkg pkgs: 0 pm: flatpak pkgs: 0 pm: snap
pkgs: 17 Compilers: gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
default: Bash v: 5.2.26 running-in: gnome-terminal inxi: 3.3.34
- Cleaning up disk storage space:
├─nvme0n1p6 swap 1 ff80626e-bd99-4df8-a68e-3e6b0fb9d07c [SWAP]
├─nvme0n1p7 ext4 1.0 0cfdcb46-c400-47c6-97ef-3464e6a2e4d5 30,8G 83% /home
├─nvme0n1p8 ext4 1.0 2449faac-31a7-4d2f-84bf-a780dedd1851 27,4G 54% /
└─nvme0n1p9 vfat FAT32 NO_LABEL 1581-564C 274M 9% /boot/efi
- Running
pacman -Syyu - Creating a new user and trying to login with it, for example nedim2 in this case, but it remains the same
- (re)moving .Xauthority from home dir
- Resolving .pacnew and .pacsave files
- Deleting and installing nvidia drivers, currently installed ones are:
mhwd -li ✔ 9s
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
video-hybrid-amd-nvidia-prime 2023.03.23 false PCI
Any ideas what else I can try? Any help is greatly appreciated
