I’m really struggling to setup my laptop. i search a lot in other threads, and i didn’t find any solution that work for me.
Currently my configuration work well in fact of video driver with 5.15 kernel, so if i call the command
prime-run glxinfo | grep 'OpenGL renderer'
i effectively start to using my RTX, but unfortunately my audio sound didn’t work, and searching on the forum i was adviced to upgrade kernel to linux60.
unfortunately with this kernel i’m uneable to use nvidia-* command because they are in infinite loading and not emit output
i was feeling brave, so i decided to remove the ‘video-hybrid-intel-nvidia-470xx-prime’ and installing the ‘video-hybrid-intel-nvidia-prime’ outputted from mhwd -l -d command.
But after the reboot i went to a black screen, unable to do anything, not even enter to tty.
So i restore the ‘video-hybrid-intel-nvidia-470xx-prime’ and now i’m here, with the kernel 6.0.15 that let me listen spotify, but with a flickering screen and without my dedicated GPU, and the kernel 5.15 that let me use the gpu, but at the price of no techno.
I excuse me if i did newbie things, and this is a newbie error, and i hope someone can help me
this are my system info
Kernel: 6.0.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=82fbc9b4-a735-4aa9-9c48-e86807b81015 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 21CX v: ThinkBook 14 G4+ IAP
serial: <filter> Chassis: type: 10 v: ThinkBook 14 G4+ IAP serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN serial: <filter>
UEFI: LENOVO v: HYCN37WW date: 06/14/2022
ID-1: BAT0 charge: 61.3 Wh (97.3%) condition: 63.0/62.0 Wh (101.6%)
volts: 17.5 min: 15.5 model: SMP L21M4PD6 type: Li-ion serial: <filter>
status: not charging cycles: 4
RAM: total: 15.36 GiB used: 3.53 GiB (23.0%)
Array-1: capacity: 16 GiB slots: 8 EC: None max-module-size: 2 GiB
note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous size: 2 GiB
speed: spec: 6400 MT/s actual: 4800 MT/s volts: curr: 0.5 width (bits):
data: 16 total: 16 manufacturer: Samsung part-no: K3LKBKB@BM-MGCP
serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous size: 2 GiB
serial: N/A
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous size: 2 GiB
serial: N/A
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous size: 2 GiB
serial: N/A
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous size: 2 GiB
serial: N/A
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous size: 2 GiB
serial: N/A
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous size: 2 GiB
serial: N/A
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous size: 2 GiB
serial: N/A
Info: model: 12th Gen Intel Core i7-1260P socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 1808 high: 2500 min/max: 400/4700:3400
base/boost: 3762/4700 scaling: driver: intel_pstate governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 710 2: 2500 3: 678 4: 2500 5: 543
6: 2500 7: 707 8: 2500 9: 2500 10: 2500 11: 2500 12: 533 13: 2500 14: 2500
15: 767 16: 2500 bogomips: 79888
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 2050] vendor: Lenovo driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 4 speed: 16 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a9 class-ID: 0302
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-6:3
chip-ID: 174f:1811 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2240x1400 s-dpi: 96 s-size: 592x370mm (23.31x14.57")
s-diag: 698mm (27.48")
Monitor-1: eDP-1 model: InfoVision Optronics/Kunshan 0x8c45 built: 2020
res: 2240x1400 hz: 60 dpi: 188 gamma: 1.2 size: 302x188mm (11.89x7.4")
diag: 356mm (14") ratio: 16:10 modes: 2240x1400
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Sound API: ALSA v: k6.0.15-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Device-2: Realtek vendor: Lenovo driver: N/A pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 2c:00.0 chip-ID: 10ec:b852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-10:4 chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 13.68 GiB (2.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZAL4512HBLU-00BL2
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 7L1QHXC7 temp: 23.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 13.67 GiB (2.9%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 82fbc9b4-a735-4aa9-9c48-e86807b81015
used: 8.3 MiB (2.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 820A-6D0A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Holtek USB Gaming Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04d9:a118 class-ID: 0300
Device-2: 3-6:3 info: Syntek Integrated Camera type: Video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:1811
Device-3: 3-10:4 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
here my mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
xorg log
[ 11.288]
X.Org X Server 1.21.1.6
[ 11.288] Current Operating System: Linux presNB 6.0.15-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Dec 21 21:14:38 UTC 2022 x86_64
[ 11.288] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64 root=UUID=82fbc9b4-a735-4aa9-9c48-e86807b81015 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 11.288]
[ 11.288] Current version of pixman: 0.42.2
[ 11.288] Before reporting problems, check http://wiki.x.org
[ 11.288] Markers: (--) probed, (**) from config file, (==) default setting,
[ 11.288] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 6 17:16:34 2023
[ 11.288] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 11.288] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 11.289] (==) ServerLayout "layout"
[ 11.289] (==) No screen section available. Using defaults.
[ 11.289] (**) |-->Screen "Default Screen Section" (0)
[ 11.289] (**) | |-->Monitor "<default monitor>"
[ 11.289] (==) No monitor specified for screen "Default Screen Section".
[ 11.289] (==) Automatically adding devices
[ 11.289] (==) Automatically enabling devices
[ 11.289] (==) Automatically adding GPU devices
[ 11.289] (==) Automatically binding GPU devices
[ 11.289] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.289] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 11.289] Entry deleted from font path.
[ 11.289] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 11.289] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 11.289] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 11.289] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 11.289] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 11.289] (II) The server relies on udev to provide the list of input devices.
[ 11.289] (II) Module ABI versions:
[ 11.289] X.Org ANSI C Emulation: 0.4
[ 11.289] X.Org Video Driver: 25.2
[ 11.289] X.Org XInput driver : 24.4
[ 11.289] X.Org Server Extension : 10.0
[ 11.290] (++) using VT number 7
[ 11.290] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 11.290] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 11.290] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 11.300] (--) PCI:*(0@0:2:0) 8086:46a6:17aa:3f96 rev 12, Mem @ 0x6102000000/16777216, 0x4000000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 11.300] (--) PCI: (1@0:0:0) 10de:25a9:17aa:3811 rev 161, Mem @ 0x5f000000/16777216, 0x6000000000/4294967296, 0x6100000000/33554432, I/O @ 0x00004000/128
[ 11.300] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 11.300] (II) LoadModule: "glx"
[ 11.300] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.303] (II) Module glx: vendor="X.Org Foundation"
[ 11.303] compiled for 1.21.1.6, module version = 1.0.0
[ 11.303] ABI class: X.Org Server Extension, version 10.0
[ 11.303] (II) Applying OutputClass "intel" to /dev/dri/card0
[ 11.303] loading driver: modesetting
[ 11.303] (==) Matched modesetting as autoconfigured driver 0
[ 11.303] (==) Matched fbdev as autoconfigured driver 1
[ 11.303] (==) Matched vesa as autoconfigured driver 2
[ 11.303] (==) Assigned the driver to the xf86ConfigLayout
[ 11.303] (II) LoadModule: "modesetting"
[ 11.303] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 11.303] (II) Module modesetting: vendor="X.Org Foundation"
[ 11.304] compiled for 1.21.1.6, module version = 1.21.1
[ 11.304] Module class: X.Org Video Driver
[ 11.304] ABI class: X.Org Video Driver, version 25.2
[ 11.304] (II) LoadModule: "fbdev"
[ 11.304] (WW) Warning, couldn't open module fbdev
[ 11.304] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 11.304] (II) LoadModule: "vesa"
[ 11.304] (WW) Warning, couldn't open module vesa
[ 11.304] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 11.304] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 11.331] (II) modeset(0): using drv /dev/dri/card0
[ 11.331] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 11.331] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 11.331] (==) modeset(0): RGB weight 888
[ 11.331] (==) modeset(0): Default visual is TrueColor
[ 11.331] (II) Loading sub module "glamoregl"
[ 11.331] (II) LoadModule: "glamoregl"
[ 11.331] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 11.334] (II) Module glamoregl: vendor="X.Org Foundation"
[ 11.334] compiled for 1.21.1.6, module version = 1.0.1
[ 11.334] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.463] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) Graphics (ADL GT2)
[ 11.463] (II) modeset(0): glamor initialized
[ 11.463] (==) modeset(0): VariableRefresh: disabled
[ 11.463] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 11.465] (II) modeset(0): Output eDP-1 has no monitor section
[ 11.465] (II) modeset(0): Output HDMI-1 has no monitor section
[ 11.466] (II) modeset(0): Output DP-1 has no monitor section
[ 11.466] (II) modeset(0): Output DP-2 has no monitor section
[ 11.466] (II) modeset(0): Output DP-3 has no monitor section
[ 11.466] (II) modeset(0): Output DP-4 has no monitor section
[ 11.468] (II) modeset(0): EDID for output eDP-1
[ 11.468] (II) modeset(0): Manufacturer: IVO Model: 8c45 Serial#: 0
[ 11.468] (II) modeset(0): Year: 2020 Week: 0
[ 11.468] (II) modeset(0): EDID Version: 1.4
[ 11.468] (II) modeset(0): Digital Display Input
[ 11.468] (II) modeset(0): 8 bits per channel
[ 11.468] (II) modeset(0): Digital interface is DisplayPort
[ 11.468] (II) modeset(0): Max Image Size [cm]: horiz.: 30 vert.: 19
[ 11.468] (II) modeset(0): Gamma: 2.20
[ 11.468] (II) modeset(0): No DPMS capabilities specified
[ 11.468] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 11.468] (II) modeset(0): First detailed timing is preferred mode
[ 11.468] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 11.468] (II) modeset(0): redX: 0.640 redY: 0.329 greenX: 0.300 greenY: 0.600
[ 11.468] (II) modeset(0): blueX: 0.149 blueY: 0.060 whiteX: 0.312 whiteY: 0.328
[ 11.468] (II) modeset(0): Manufacturer's mask: 0
[ 11.468] (II) modeset(0): Supported detailed timing:
[ 11.468] (II) modeset(0): clock: 206.2 MHz Image Size: 302 x 188 mm
[ 11.468] (II) modeset(0): h_active: 2240 h_sync: 2264 h_sync_end 2312 h_blank_end 2400 h_border: 0
[ 11.468] (II) modeset(0): v_active: 1400 v_sync: 1403 v_sync_end 1415 v_blanking: 1432 v_border: 0
[ 11.468] (II) modeset(0): InfoVision
[ 11.468] (II) modeset(0): M140NWHE R0
[ 11.468] (II) modeset(0): EDID (in hex):
[ 11.469] (II) modeset(0): 00ffffffffffff0026cf458c00000000
[ 11.469] (II) modeset(0): 001e0104a51e137802de50a3544c9926
[ 11.469] (II) modeset(0): 0f505400000001010101010101010101
[ 11.469] (II) modeset(0): 0101010101018c50c0a0807820501830
[ 11.469] (II) modeset(0): 3c002ebc100000190000000000000000
[ 11.469] (II) modeset(0): 00000000000000000000000000fe0049
[ 11.469] (II) modeset(0): 6e666f566973696f6e0a2020000000fe
[ 11.469] (II) modeset(0): 004d3134304e574845205230200a0075
[ 11.469] (II) modeset(0): Printing probed modes for output eDP-1
[ 11.469] (II) modeset(0): Modeline "2240x1400"x60.0 206.20 2240 2264 2312 2400 1400 1403 1415 1432 -hsync -vsync (85.9 kHz eP)
[ 11.469] (II) modeset(0): Modeline "1856x1392"x60.0 218.30 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[ 11.469] (II) modeset(0): Modeline "1792x1344"x60.0 204.80 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "2048x1152"x120.0 406.50 2048 2220 2444 2840 1152 1153 1156 1193 doublescan -hsync +vsync (143.1 kHz d)
[ 11.469] (II) modeset(0): Modeline "2048x1152"x120.0 302.50 2048 2072 2088 2128 1152 1153 1156 1185 doublescan +hsync -vsync (142.2 kHz d)
[ 11.469] (II) modeset(0): Modeline "2048x1152"x59.9 197.00 2048 2184 2400 2752 1152 1155 1160 1195 -hsync +vsync (71.6 kHz d)
[ 11.469] (II) modeset(0): Modeline "2048x1152"x59.9 156.75 2048 2096 2128 2208 1152 1155 1160 1185 +hsync -vsync (71.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 11.469] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 11.469] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 11.469] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 11.469] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 11.469] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 11.469] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 11.469] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 11.469] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 11.469] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 11.469] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 11.469] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 11.469] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 11.469] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 11.469] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 11.469] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 11.469] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 11.469] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 11.469] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 11.469] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 11.469] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 11.469] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 11.469] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 11.469] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 11.469] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 11.469] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 11.469] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 11.469] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 11.469] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 11.469] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 11.469] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 11.469] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 11.469] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 11.469] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 11.469] (II) modeset(0): EDID for output HDMI-1
[ 11.469] (II) modeset(0): EDID for output DP-1
[ 11.469] (II) modeset(0): EDID for output DP-2
[ 11.469] (II) modeset(0): EDID for output DP-3
[ 11.469] (II) modeset(0): EDID for output DP-4
[ 11.469] (II) modeset(0): Output eDP-1 connected
[ 11.469] (II) modeset(0): Output HDMI-1 disconnected
[ 11.469] (II) modeset(0): Output DP-1 disconnected
[ 11.469] (II) modeset(0): Output DP-2 disconnected
[ 11.469] (II) modeset(0): Output DP-3 disconnected
[ 11.469] (II) modeset(0): Output DP-4 disconnected
[ 11.469] (II) modeset(0): Using exact sizes for initial modes
[ 11.469] (II) modeset(0): Output eDP-1 using initial mode 2240x1400 +0+0
[ 11.469] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.469] (==) modeset(0): DPI set to (96, 96)
[ 11.469] (II) Loading sub module "fb"
[ 11.469] (II) LoadModule: "fb"
[ 11.469] (II) Module "fb" already built-in
[ 11.479] (==) modeset(0): Backing store enabled
[ 11.479] (==) modeset(0): Silken mouse enabled
[ 11.566] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 11.566] (==) modeset(0): DPMS enabled
[ 11.566] (II) modeset(0): [DRI2] Setup complete
[ 11.566] (II) modeset(0): [DRI2] DRI driver: iris
[ 11.566] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 11.566] (II) Initializing extension Generic Event Extension
[ 11.566] (II) Initializing extension SHAPE
[ 11.566] (II) Initializing extension MIT-SHM
[ 11.566] (II) Initializing extension XInputExtension
[ 11.567] (II) Initializing extension XTEST
[ 11.567] (II) Initializing extension BIG-REQUESTS
[ 11.567] (II) Initializing extension SYNC
[ 11.567] (II) Initializing extension XKEYBOARD
[ 11.567] (II) Initializing extension XC-MISC
[ 11.567] (II) Initializing extension SECURITY
[ 11.567] (II) Initializing extension XFIXES
[ 11.567] (II) Initializing extension RENDER
[ 11.567] (II) Initializing extension RANDR
[ 11.567] (II) Initializing extension COMPOSITE
[ 11.567] (II) Initializing extension DAMAGE
[ 11.567] (II) Initializing extension MIT-SCREEN-SAVER
[ 11.568] (II) Initializing extension DOUBLE-BUFFER
[ 11.568] (II) Initializing extension RECORD
[ 11.568] (II) Initializing extension DPMS
[ 11.568] (II) Initializing extension Present
[ 11.568] (II) Initializing extension DRI3
[ 11.568] (II) Initializing extension X-Resource
[ 11.568] (II) Initializing extension XVideo
[ 11.568] (II) Initializing extension XVideo-MotionCompensation
[ 11.568] (II) Initializing extension GLX
[ 11.573] (II) AIGLX: Loaded and initialized iris
[ 11.573] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 11.573] (II) Initializing extension XFree86-VidModeExtension
[ 11.573] (II) Initializing extension XFree86-DGA
[ 11.573] (II) Initializing extension XFree86-DRI
[ 11.573] (II) Initializing extension DRI2
[ 11.573] (II) modeset(0): Damage tracking initialized
[ 11.573] (II) modeset(0): Setting screen physical size to 592 x 370
[ 11.598] (II) config/udev: Adding input device Video Bus (/dev/input/event16)
[ 11.598] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 11.598] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 11.598] (**) Video Bus: Applying InputClass "system-keyboard"
[ 11.598] (II) LoadModule: "libinput"
[ 11.598] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 11.599] (II) Module libinput: vendor="X.Org Foundation"
[ 11.599] compiled for 1.21.1.3, module version = 1.2.1
[ 11.599] Module class: X.Org XInput Driver
[ 11.599] ABI class: X.Org XInput driver, version 24.4
[ 11.599] (II) Using input driver 'libinput' for 'Video Bus'
[ 11.599] (**) Video Bus: always reports core events
[ 11.599] (**) Option "Device" "/dev/input/event16"
[ 11.602] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 11.602] (II) event16 - Video Bus: device is a keyboard
[ 11.602] (II) event16 - Video Bus: device removed
[ 11.671] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input17/event16"
[ 11.671] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 11.671] (**) Option "xkb_layout" "it"
[ 11.689] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 11.689] (II) event16 - Video Bus: device is a keyboard
[ 11.689] (II) config/udev: Adding input device Video Bus (/dev/input/event15)
[ 11.689] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 11.689] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 11.689] (**) Video Bus: Applying InputClass "system-keyboard"
[ 11.689] (II) Using input driver 'libinput' for 'Video Bus'
[ 11.689] (**) Video Bus: always reports core events
[ 11.689] (**) Option "Device" "/dev/input/event15"
[ 11.689] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 11.689] (II) event15 - Video Bus: device is a keyboard
[ 11.689] (II) event15 - Video Bus: device removed
[ 11.738] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input16/event15"
[ 11.738] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 11.738] (**) Option "xkb_layout" "it"
[ 11.739] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 11.739] (II) event15 - Video Bus: device is a keyboard
[ 11.740] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 11.740] (II) No input driver specified, ignoring this device.
[ 11.740] (II) This device may have been added with another device file.
[ 11.740] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 11.740] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 11.740] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 11.740] (**) Power Button: Applying InputClass "system-keyboard"
[ 11.740] (II) Using input driver 'libinput' for 'Power Button'
[ 11.740] (**) Power Button: always reports core events
[ 11.740] (**) Option "Device" "/dev/input/event1"
[ 11.741] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 11.741] (II) event1 - Power Button: device is a keyboard
[ 11.741] (II) event1 - Power Button: device removed
[ 11.798] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 11.798] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 11.798] (**) Option "xkb_layout" "it"
[ 11.800] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 11.800] (II) event1 - Power Button: device is a keyboard
[ 11.801] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 11.801] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 11.801] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 11.801] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 11.801] (II) Using input driver 'libinput' for 'Sleep Button'
[ 11.801] (**) Sleep Button: always reports core events
[ 11.801] (**) Option "Device" "/dev/input/event2"
[ 11.803] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 11.803] (II) event2 - Sleep Button: device is a keyboard
[ 11.803] (II) event2 - Sleep Button: device removed
[ 11.838] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 11.838] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 11.838] (**) Option "xkb_layout" "it"
[ 11.839] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 11.839] (II) event2 - Sleep Button: device is a keyboard
[ 11.839] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event9)
[ 11.839] (**) USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 11.839] (**) USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 11.839] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
[ 11.839] (**) USB Gaming Mouse: always reports core events
[ 11.839] (**) Option "Device" "/dev/input/event9"
[ 11.895] (II) event9 - USB Gaming Mouse: is tagged by udev as: Mouse
[ 11.895] (II) event9 - USB Gaming Mouse: device is a pointer
[ 11.895] (II) event9 - USB Gaming Mouse: device removed
[ 11.961] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.0/0003:04D9:A118.0002/input/input10/event9"
[ 11.961] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: MOUSE, id 10)
[ 11.962] (**) Option "AccelerationScheme" "none"
[ 11.962] (**) USB Gaming Mouse: (accel) selected scheme none/0
[ 11.962] (**) USB Gaming Mouse: (accel) acceleration factor: 2.000
[ 11.962] (**) USB Gaming Mouse: (accel) acceleration threshold: 4
[ 12.022] (II) event9 - USB Gaming Mouse: is tagged by udev as: Mouse
[ 12.022] (II) event9 - USB Gaming Mouse: device is a pointer
[ 12.023] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
[ 12.023] (II) No input driver specified, ignoring this device.
[ 12.023] (II) This device may have been added with another device file.
[ 12.024] (II) config/udev: Adding input device USB Gaming Mouse Keyboard (/dev/input/event10)
[ 12.024] (**) USB Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 12.024] (**) USB Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 12.024] (**) USB Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 12.024] (II) Using input driver 'libinput' for 'USB Gaming Mouse Keyboard'
[ 12.024] (**) USB Gaming Mouse Keyboard: always reports core events
[ 12.024] (**) Option "Device" "/dev/input/event10"
[ 12.025] (II) event10 - USB Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 12.025] (II) event10 - USB Gaming Mouse Keyboard: device is a keyboard
[ 12.025] (II) event10 - USB Gaming Mouse Keyboard: device removed
[ 12.045] (II) libinput: USB Gaming Mouse Keyboard: needs a virtual subdevice
[ 12.045] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:04D9:A118.0003/input/input11/event10"
[ 12.045] (II) XINPUT: Adding extended input device "USB Gaming Mouse Keyboard" (type: MOUSE, id 11)
[ 12.045] (**) Option "AccelerationScheme" "none"
[ 12.045] (**) USB Gaming Mouse Keyboard: (accel) selected scheme none/0
[ 12.045] (**) USB Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[ 12.045] (**) USB Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[ 12.048] (II) event10 - USB Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 12.048] (II) event10 - USB Gaming Mouse Keyboard: device is a keyboard
[ 12.049] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event11)
[ 12.049] (II) No input driver specified, ignoring this device.
[ 12.049] (II) This device may have been added with another device file.
[ 12.050] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/js0)
[ 12.050] (II) No input driver specified, ignoring this device.
[ 12.050] (II) This device may have been added with another device file.
[ 12.051] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event12)
[ 12.051] (II) No input driver specified, ignoring this device.
[ 12.051] (II) This device may have been added with another device file.
[ 12.051] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event13)
[ 12.051] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[ 12.051] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[ 12.051] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[ 12.051] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[ 12.051] (**) Integrated Camera: Integrated C: always reports core events
[ 12.051] (**) Option "Device" "/dev/input/event13"
[ 12.053] (II) event13 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 12.053] (II) event13 - Integrated Camera: Integrated C: device is a keyboard
[ 12.053] (II) event13 - Integrated Camera: Integrated C: device removed
[ 12.131] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.0/input/input14/event13"
[ 12.131] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 12)
[ 12.131] (**) Option "xkb_layout" "it"
[ 12.133] (II) event13 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 12.133] (II) event13 - Integrated Camera: Integrated C: device is a keyboard
[ 12.134] (II) config/udev: Adding input device Integrated Camera: Integrated I (/dev/input/event14)
[ 12.134] (**) Integrated Camera: Integrated I: Applying InputClass "evdev keyboard catchall"
[ 12.134] (**) Integrated Camera: Integrated I: Applying InputClass "libinput keyboard catchall"
[ 12.134] (**) Integrated Camera: Integrated I: Applying InputClass "system-keyboard"
[ 12.134] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated I'
[ 12.134] (**) Integrated Camera: Integrated I: always reports core events
[ 12.134] (**) Option "Device" "/dev/input/event14"
[ 12.136] (II) event14 - Integrated Camera: Integrated I: is tagged by udev as: Keyboard
[ 12.136] (II) event14 - Integrated Camera: Integrated I: device is a keyboard
[ 12.136] (II) event14 - Integrated Camera: Integrated I: device removed
[ 12.181] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.2/input/input15/event14"
[ 12.181] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated I" (type: KEYBOARD, id 13)
[ 12.181] (**) Option "xkb_layout" "it"
[ 12.184] (II) event14 - Integrated Camera: Integrated I: is tagged by udev as: Keyboard
[ 12.184] (II) event14 - Integrated Camera: Integrated I: device is a keyboard
[ 12.186] (II) config/udev: Adding input device ELAN0662:00 04F3:317C Mouse (/dev/input/event7)
[ 12.186] (**) ELAN0662:00 04F3:317C Mouse: Applying InputClass "evdev pointer catchall"
[ 12.186] (**) ELAN0662:00 04F3:317C Mouse: Applying InputClass "libinput pointer catchall"
[ 12.186] (II) Using input driver 'libinput' for 'ELAN0662:00 04F3:317C Mouse'
[ 12.186] (**) ELAN0662:00 04F3:317C Mouse: always reports core events
[ 12.186] (**) Option "Device" "/dev/input/event7"
[ 12.187] (II) event7 - ELAN0662:00 04F3:317C Mouse: is tagged by udev as: Mouse Pointingstick
[ 12.187] (II) event7 - ELAN0662:00 04F3:317C Mouse: device is a pointer
[ 12.187] (II) event7 - ELAN0662:00 04F3:317C Mouse: device removed
[ 12.238] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-9/i2c-ELAN0662:00/0018:04F3:317C.0001/input/input19/event7"
[ 12.238] (II) XINPUT: Adding extended input device "ELAN0662:00 04F3:317C Mouse" (type: MOUSE, id 14)
[ 12.238] (**) Option "AccelerationScheme" "none"
[ 12.238] (**) ELAN0662:00 04F3:317C Mouse: (accel) selected scheme none/0
[ 12.238] (**) ELAN0662:00 04F3:317C Mouse: (accel) acceleration factor: 2.000
[ 12.238] (**) ELAN0662:00 04F3:317C Mouse: (accel) acceleration threshold: 4
[ 12.241] (II) event7 - ELAN0662:00 04F3:317C Mouse: is tagged by udev as: Mouse Pointingstick
[ 12.242] (II) event7 - ELAN0662:00 04F3:317C Mouse: device is a pointer
[ 12.245] (II) config/udev: Adding input device ELAN0662:00 04F3:317C Mouse (/dev/input/mouse1)
[ 12.245] (II) No input driver specified, ignoring this device.
[ 12.245] (II) This device may have been added with another device file.
[ 12.245] (II) config/udev: Adding input device ELAN0662:00 04F3:317C Touchpad (/dev/input/event8)
[ 12.245] (**) ELAN0662:00 04F3:317C Touchpad: Applying InputClass "evdev touchpad catchall"
[ 12.246] (**) ELAN0662:00 04F3:317C Touchpad: Applying InputClass "libinput touchpad catchall"
[ 12.246] (II) Using input driver 'libinput' for 'ELAN0662:00 04F3:317C Touchpad'
[ 12.246] (**) ELAN0662:00 04F3:317C Touchpad: always reports core events
[ 12.246] (**) Option "Device" "/dev/input/event8"
[ 12.247] (II) event8 - ELAN0662:00 04F3:317C Touchpad: is tagged by udev as: Touchpad
[ 12.249] (II) event8 - ELAN0662:00 04F3:317C Touchpad: device is a touchpad
[ 12.249] (II) event8 - ELAN0662:00 04F3:317C Touchpad: device removed
[ 12.290] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-9/i2c-ELAN0662:00/0018:04F3:317C.0001/input/input21/event8"
[ 12.290] (II) XINPUT: Adding extended input device "ELAN0662:00 04F3:317C Touchpad" (type: TOUCHPAD, id 15)
[ 12.293] (**) Option "AccelerationScheme" "none"
[ 12.294] (**) ELAN0662:00 04F3:317C Touchpad: (accel) selected scheme none/0
[ 12.294] (**) ELAN0662:00 04F3:317C Touchpad: (accel) acceleration factor: 2.000
[ 12.294] (**) ELAN0662:00 04F3:317C Touchpad: (accel) acceleration threshold: 4
[ 12.295] (II) event8 - ELAN0662:00 04F3:317C Touchpad: is tagged by udev as: Touchpad
[ 12.297] (II) event8 - ELAN0662:00 04F3:317C Touchpad: device is a touchpad
[ 12.298] (II) config/udev: Adding input device ELAN0662:00 04F3:317C Touchpad (/dev/input/mouse2)
[ 12.298] (II) No input driver specified, ignoring this device.
[ 12.298] (II) This device may have been added with another device file.
[ 12.301] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event6)
[ 12.301] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[ 12.301] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[ 12.301] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[ 12.301] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[ 12.301] (**) Ideapad extra buttons: always reports core events
[ 12.301] (**) Option "Device" "/dev/input/event6"
[ 12.302] (II) event6 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 12.302] (II) event6 - Ideapad extra buttons: device is a keyboard
[ 12.302] (II) event6 - Ideapad extra buttons: device removed
[ 12.364] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input6/event6"
[ 12.365] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 16)
[ 12.365] (**) Option "xkb_layout" "it"
[ 12.367] (II) event6 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 12.368] (II) event6 - Ideapad extra buttons: device is a keyboard
[ 12.369] (II) config/udev: Adding input device Intel HID events (/dev/input/event4)
[ 12.369] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[ 12.369] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[ 12.369] (**) Intel HID events: Applying InputClass "system-keyboard"
[ 12.369] (II) Using input driver 'libinput' for 'Intel HID events'
[ 12.369] (**) Intel HID events: always reports core events
[ 12.369] (**) Option "Device" "/dev/input/event4"
[ 12.370] (II) event4 - Intel HID events: is tagged by udev as: Keyboard
[ 12.370] (II) event4 - Intel HID events: device is a keyboard
[ 12.370] (II) event4 - Intel HID events: device removed
[ 12.391] (**) Option "config_info" "udev:/sys/devices/platform/INTC1070:00/input/input4/event4"
[ 12.391] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 17)
[ 12.391] (**) Option "xkb_layout" "it"
[ 12.393] (II) event4 - Intel HID events: is tagged by udev as: Keyboard
[ 12.393] (II) event4 - Intel HID events: device is a keyboard
[ 12.394] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event5)
[ 12.394] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[ 12.395] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[ 12.395] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[ 12.395] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[ 12.395] (**) Intel HID 5 button array: always reports core events
[ 12.395] (**) Option "Device" "/dev/input/event5"
[ 12.396] (II) event5 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 12.396] (II) event5 - Intel HID 5 button array: device is a keyboard
[ 12.396] (II) event5 - Intel HID 5 button array: device removed
[ 12.434] (**) Option "config_info" "udev:/sys/devices/platform/INTC1070:00/input/input5/event5"
[ 12.435] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 18)
[ 12.435] (**) Option "xkb_layout" "it"
[ 12.437] (II) event5 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 12.437] (II) event5 - Intel HID 5 button array: device is a keyboard
[ 12.439] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 12.439] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 12.439] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 12.439] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 12.439] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 12.439] (**) AT Translated Set 2 keyboard: always reports core events
[ 12.439] (**) Option "Device" "/dev/input/event3"
[ 12.440] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 12.440] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 12.442] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 12.478] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 12.478] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 19)
[ 12.478] (**) Option "xkb_layout" "it"
[ 12.479] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 12.479] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 12.480] (II) config/udev: Adding input device PC Speaker (/dev/input/event17)
[ 12.480] (II) No input driver specified, ignoring this device.
[ 12.480] (II) This device may have been added with another device file.
[ 12.503] (**) USB Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 12.503] (**) USB Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 12.504] (**) USB Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 12.504] (II) Using input driver 'libinput' for 'USB Gaming Mouse Keyboard'
[ 12.504] (**) USB Gaming Mouse Keyboard: always reports core events
[ 12.504] (**) Option "Device" "/dev/input/event10"
[ 12.504] (II) libinput: USB Gaming Mouse Keyboard: is a virtual subdevice
[ 12.504] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:04D9:A118.0003/input/input11/event10"
[ 12.504] (II) XINPUT: Adding extended input device "USB Gaming Mouse Keyboard" (type: KEYBOARD, id 20)
[ 12.504] (**) Option "xkb_layout" "it"
[ 12.570] (II) config/udev: removing device Integrated Camera: Integrated I
[ 12.570] (II) event14 - Integrated Camera: Integrated I: device removed
[ 12.611] (II) UnloadModule: "libinput"
[ 12.613] (II) config/udev: Adding input device Integrated Camera: Integrated I (/dev/input/event14)
[ 12.613] (**) Integrated Camera: Integrated I: Applying InputClass "evdev keyboard catchall"
[ 12.613] (**) Integrated Camera: Integrated I: Applying InputClass "libinput keyboard catchall"
[ 12.613] (**) Integrated Camera: Integrated I: Applying InputClass "system-keyboard"
[ 12.613] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated I'
[ 12.613] (**) Integrated Camera: Integrated I: always reports core events
[ 12.613] (**) Option "Device" "/dev/input/event14"
[ 12.615] (II) event14 - Integrated Camera: Integrated I: is tagged by udev as: Keyboard
[ 12.615] (II) event14 - Integrated Camera: Integrated I: device is a keyboard
[ 12.616] (II) event14 - Integrated Camera: Integrated I: device removed
[ 12.674] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.2/input/input15/event14"
[ 12.675] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated I" (type: KEYBOARD, id 13)
[ 12.675] (**) Option "xkb_layout" "it"
[ 12.678] (II) event14 - Integrated Camera: Integrated I: is tagged by udev as: Keyboard
[ 12.678] (II) event14 - Integrated Camera: Integrated I: device is a keyboard
[ 12.679] (II) config/udev: removing device Video Bus
[ 12.679] (II) event15 - Video Bus: device removed
[ 12.735] (II) UnloadModule: "libinput"
[ 12.736] (II) config/udev: Adding input device Video Bus (/dev/input/event15)
[ 12.736] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 12.736] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 12.736] (**) Video Bus: Applying InputClass "system-keyboard"
[ 12.736] (II) Using input driver 'libinput' for 'Video Bus'
[ 12.736] (**) Video Bus: always reports core events
[ 12.736] (**) Option "Device" "/dev/input/event15"
[ 12.738] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 12.738] (II) event15 - Video Bus: device is a keyboard
[ 12.739] (II) event15 - Video Bus: device removed
[ 12.791] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input16/event15"
[ 12.791] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 12.791] (**) Option "xkb_layout" "it"
[ 12.794] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 12.794] (II) event15 - Video Bus: device is a keyboard
[ 12.796] (II) config/udev: removing device Video Bus
[ 12.796] (II) event16 - Video Bus: device removed
[ 12.874] (II) UnloadModule: "libinput"
[ 12.875] (II) config/udev: Adding input device Video Bus (/dev/input/event16)
[ 12.875] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 12.875] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 12.875] (**) Video Bus: Applying InputClass "system-keyboard"
[ 12.875] (II) Using input driver 'libinput' for 'Video Bus'
[ 12.875] (**) Video Bus: always reports core events
[ 12.875] (**) Option "Device" "/dev/input/event16"
[ 12.876] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 12.876] (II) event16 - Video Bus: device is a keyboard
[ 12.876] (II) event16 - Video Bus: device removed
[ 12.928] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input17/event16"
[ 12.928] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 12.928] (**) Option "xkb_layout" "it"
[ 12.928] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 12.928] (II) event16 - Video Bus: device is a keyboard
[ 12.929] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
[ 12.929] (II) No input driver specified, ignoring this device.
[ 12.929] (II) This device may have been added with another device file.
[ 12.929] (II) config/udev: Adding input device ELAN0662:00 04F3:317C Touchpad (/dev/input/mouse2)
[ 12.929] (II) config/udev: Adding input device ELAN0662:00 04F3:317C Mouse (/dev/input/mouse1)
[ 12.929] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/js0)
[ 12.929] (II) config/udev: Adding input device PC Speaker (/dev/input/event17)
[ 12.929] (II) config/udev: removing device ELAN0662:00 04F3:317C Mouse
[ 12.929] (II) event7 - ELAN0662:00 04F3:317C Mouse: device removed
[ 13.014] (II) UnloadModule: "libinput"
[ 13.015] (II) config/udev: Adding input device ELAN0662:00 04F3:317C Mouse (/dev/input/event7)
[ 13.015] (**) ELAN0662:00 04F3:317C Mouse: Applying InputClass "evdev pointer catchall"
[ 13.015] (**) ELAN0662:00 04F3:317C Mouse: Applying InputClass "libinput pointer catchall"
[ 13.015] (II) Using input driver 'libinput' for 'ELAN0662:00 04F3:317C Mouse'
[ 13.015] (**) ELAN0662:00 04F3:317C Mouse: always reports core events
[ 13.015] (**) Option "Device" "/dev/input/event7"
[ 13.017] (II) event7 - ELAN0662:00 04F3:317C Mouse: is tagged by udev as: Mouse Pointingstick
[ 13.017] (II) event7 - ELAN0662:00 04F3:317C Mouse: device is a pointer
[ 13.019] (II) event7 - ELAN0662:00 04F3:317C Mouse: device removed
[ 13.061] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-9/i2c-ELAN0662:00/0018:04F3:317C.0001/input/input19/event7"
[ 13.061] (II) XINPUT: Adding extended input device "ELAN0662:00 04F3:317C Mouse" (type: MOUSE, id 14)
[ 13.062] (**) Option "AccelerationScheme" "none"
[ 13.062] (**) ELAN0662:00 04F3:317C Mouse: (accel) selected scheme none/0
[ 13.062] (**) ELAN0662:00 04F3:317C Mouse: (accel) acceleration factor: 2.000
[ 13.062] (**) ELAN0662:00 04F3:317C Mouse: (accel) acceleration threshold: 4
[ 13.064] (II) event7 - ELAN0662:00 04F3:317C Mouse: is tagged by udev as: Mouse Pointingstick
[ 13.065] (II) event7 - ELAN0662:00 04F3:317C Mouse: device is a pointer
[ 13.068] (II) config/udev: removing device ELAN0662:00 04F3:317C Touchpad
[ 13.068] (II) event8 - ELAN0662:00 04F3:317C Touchpad: device removed
[ 13.121] (II) UnloadModule: "libinput"
[ 13.122] (II) config/udev: Adding input device ELAN0662:00 04F3:317C Touchpad (/dev/input/event8)
[ 13.122] (**) ELAN0662:00 04F3:317C Touchpad: Applying InputClass "evdev touchpad catchall"
[ 13.122] (**) ELAN0662:00 04F3:317C Touchpad: Applying InputClass "libinput touchpad catchall"
[ 13.122] (II) Using input driver 'libinput' for 'ELAN0662:00 04F3:317C Touchpad'
[ 13.123] (**) ELAN0662:00 04F3:317C Touchpad: always reports core events
[ 13.123] (**) Option "Device" "/dev/input/event8"
[ 13.125] (II) event8 - ELAN0662:00 04F3:317C Touchpad: is tagged by udev as: Touchpad
[ 13.127] (II) event8 - ELAN0662:00 04F3:317C Touchpad: device is a touchpad
[ 13.127] (II) event8 - ELAN0662:00 04F3:317C Touchpad: device removed
[ 13.192] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-9/i2c-ELAN0662:00/0018:04F3:317C.0001/input/input21/event8"
[ 13.192] (II) XINPUT: Adding extended input device "ELAN0662:00 04F3:317C Touchpad" (type: TOUCHPAD, id 15)
[ 13.195] (**) Option "AccelerationScheme" "none"
[ 13.195] (**) ELAN0662:00 04F3:317C Touchpad: (accel) selected scheme none/0
[ 13.195] (**) ELAN0662:00 04F3:317C Touchpad: (accel) acceleration factor: 2.000
[ 13.195] (**) ELAN0662:00 04F3:317C Touchpad: (accel) acceleration threshold: 4
[ 13.196] (II) event8 - ELAN0662:00 04F3:317C Touchpad: is tagged by udev as: Touchpad
[ 13.198] (II) event8 - ELAN0662:00 04F3:317C Touchpad: device is a touchpad
[ 13.200] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=4 (/dev/input/event21)
[ 13.200] (II) No input driver specified, ignoring this device.
[ 13.200] (II) This device may have been added with another device file.
[ 13.200] (II) config/udev: Adding input device sof-hda-dsp Headphone (/dev/input/event19)
[ 13.200] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=5 (/dev/input/event22)
[ 13.200] (II) config/udev: Adding input device sof-hda-dsp Mic (/dev/input/event18)
[ 13.201] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=3 (/dev/input/event20)
[ 13.201] (II) No input driver specified, ignoring this device.
[ 13.201] (II) This device may have been added with another device file.
[ 18.026] (II) modeset(0): EDID vendor "IVO", prod id 35909
[ 18.026] (II) modeset(0): Printing DDC gathered Modelines:
[ 18.026] (II) modeset(0): Modeline "2240x1400"x0.0 206.20 2240 2264 2312 2400 1400 1403 1415 1432 -hsync -vsync (85.9 kHz eP)
[ 18.435] (II) modeset(0): EDID vendor "IVO", prod id 35909
[ 18.435] (II) modeset(0): Printing DDC gathered Modelines:
[ 18.435] (II) modeset(0): Modeline "2240x1400"x0.0 206.20 2240 2264 2312 2400 1400 1403 1415 1432 -hsync -vsync (85.9 kHz eP)
[ 23.357] (II) modeset(0): EDID vendor "IVO", prod id 35909
[ 23.357] (II) modeset(0): Printing DDC gathered Modelines:
[ 23.357] (II) modeset(0): Modeline "2240x1400"x0.0 206.20 2240 2264 2312 2400 1400 1403 1415 1432 -hsync -vsync (85.9 kHz eP)
[ 38.361] (II) modeset(0): EDID vendor "IVO", prod id 35909
[ 38.361] (II) modeset(0): Printing DDC gathered Modelines:
[ 38.361] (II) modeset(0): Modeline "2240x1400"x0.0 206.20 2240 2264 2312 2400 1400 1403 1415 1432 -hsync -vsync (85.9 kHz eP)
[ 56.023] (EE) event8 - ELAN0662:00 04F3:317C Touchpad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.22.0/touchpad-jumping-cursors.html for details
[ 56.065] (EE) event8 - ELAN0662:00 04F3:317C Touchpad: kernel bug: Touch jump detected and discarded.
[ 63.369] (II) modeset(0): EDID vendor "IVO", prod id 35909
[ 63.369] (II) modeset(0): Printing DDC gathered Modelines:
[ 63.369] (II) modeset(0): Modeline "2240x1400"x0.0 206.20 2240 2264 2312 2400 1400 1403 1415 1432 -hsync -vsync (85.9 kHz eP)
[ 1264.752] (II) modeset(0): EDID vendor "IVO", prod id 35909
[ 1264.752] (II) modeset(0): Printing DDC gathered Modelines:
[ 1264.752] (II) modeset(0): Modeline "2240x1400"x0.0 206.20 2240 2264 2312 2400 1400 1403 1415 1432 -hsync -vsync (85.9 kHz eP)
[ 1384.844] (II) modeset(0): EDID vendor "IVO", prod id 35909
[ 1384.844] (II) modeset(0): Printing DDC gathered Modelines:
[ 1384.844] (II) modeset(0): Modeline "2240x1400"x0.0 206.20 2240 2264 2312 2400 1400 1403 1415 1432 -hsync -vsync (85.9 kHz eP)
[ 1425.606] (EE) event9 - USB Gaming Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
[ 1450.662] (EE) event9 - USB Gaming Mouse: client bug: event processing lagging behind by 27ms, your system is too slow
[ 1573.712] (II) event9 - USB Gaming Mouse: device removed
[ 1573.731] (II) config/udev: removing device USB Gaming Mouse
[ 1573.738] (II) UnloadModule: "libinput"
[ 1573.835] (II) event10 - USB Gaming Mouse Keyboard: device removed
[ 1573.855] (II) config/udev: removing device USB Gaming Mouse Keyboard
[ 1573.859] (II) UnloadModule: "libinput"
[ 1573.860] (II) config/udev: removing device USB Gaming Mouse Keyboard
[ 1573.861] (II) UnloadModule: "libinput"
[ 1580.383] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
[ 1580.384] (II) No input driver specified, ignoring this device.
[ 1580.384] (II) This device may have been added with another device file.
[ 1580.385] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/js0)
[ 1580.385] (II) No input driver specified, ignoring this device.
[ 1580.385] (II) This device may have been added with another device file.
[ 1580.437] (II) config/udev: Adding input device USB Gaming Mouse Keyboard (/dev/input/event10)
[ 1580.437] (**) USB Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 1580.437] (**) USB Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 1580.437] (**) USB Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 1580.437] (II) Using input driver 'libinput' for 'USB Gaming Mouse Keyboard'
[ 1580.437] (**) USB Gaming Mouse Keyboard: always reports core events
[ 1580.437] (**) Option "Device" "/dev/input/event10"
[ 1580.438] (II) event10 - USB Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 1580.438] (II) event10 - USB Gaming Mouse Keyboard: device is a keyboard
[ 1580.438] (II) event10 - USB Gaming Mouse Keyboard: device removed
[ 1580.495] (II) libinput: USB Gaming Mouse Keyboard: needs a virtual subdevice
[ 1580.495] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:04D9:A118.0006/input/input28/event10"
[ 1580.495] (II) XINPUT: Adding extended input device "USB Gaming Mouse Keyboard" (type: MOUSE, id 10)
[ 1580.496] (**) Option "AccelerationScheme" "none"
[ 1580.497] (**) USB Gaming Mouse Keyboard: (accel) selected scheme none/0
[ 1580.497] (**) USB Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[ 1580.497] (**) USB Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[ 1580.500] (II) event10 - USB Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 1580.500] (II) event10 - USB Gaming Mouse Keyboard: device is a keyboard
[ 1580.500] (**) USB Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 1580.500] (**) USB Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 1580.500] (**) USB Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 1580.500] (II) Using input driver 'libinput' for 'USB Gaming Mouse Keyboard'
[ 1580.500] (**) USB Gaming Mouse Keyboard: always reports core events
[ 1580.500] (**) Option "Device" "/dev/input/event10"
[ 1580.500] (II) libinput: USB Gaming Mouse Keyboard: is a virtual subdevice
[ 1580.500] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:04D9:A118.0006/input/input28/event10"
[ 1580.500] (II) XINPUT: Adding extended input device "USB Gaming Mouse Keyboard" (type: KEYBOARD, id 11)
[ 1580.500] (**) Option "xkb_layout" "it"
[ 1580.501] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event11)
[ 1580.501] (II) No input driver specified, ignoring this device.
[ 1580.501] (II) This device may have been added with another device file.
[ 1580.501] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event12)
[ 1580.538] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event9)
[ 1580.538] (**) USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 1580.538] (**) USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 1580.538] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
[ 1580.538] (**) USB Gaming Mouse: always reports core events
[ 1580.538] (**) Option "Device" "/dev/input/event9"
[ 1580.598] (II) event9 - USB Gaming Mouse: is tagged by udev as: Mouse
[ 1580.598] (II) event9 - USB Gaming Mouse: device is a pointer
[ 1580.599] (II) event9 - USB Gaming Mouse: device removed
[ 1580.641] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.0/0003:04D9:A118.0005/input/input27/event9"
[ 1580.641] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: MOUSE, id 20)
[ 1580.643] (**) Option "AccelerationScheme" "none"
[ 1580.644] (**) USB Gaming Mouse: (accel) selected scheme none/0
[ 1580.644] (**) USB Gaming Mouse: (accel) acceleration factor: 2.000
[ 1580.644] (**) USB Gaming Mouse: (accel) acceleration threshold: 4
[ 1580.704] (II) event9 - USB Gaming Mouse: is tagged by udev as: Mouse
[ 1580.705] (II) event9 - USB Gaming Mouse: device is a pointer
[ 1640.531] (II) event9 - USB Gaming Mouse: device removed
[ 1640.561] (II) config/udev: removing device USB Gaming Mouse
[ 1640.567] (II) UnloadModule: "libinput"
[ 1640.641] (II) event10 - USB Gaming Mouse Keyboard: device removed
[ 1640.675] (II) config/udev: removing device USB Gaming Mouse Keyboard
[ 1640.679] (II) UnloadModule: "libinput"
[ 1640.679] (II) config/udev: removing device USB Gaming Mouse Keyboard
[ 1640.681] (II) UnloadModule: "libinput"
[ 1838.318] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
[ 1838.319] (II) No input driver specified, ignoring this device.
[ 1838.319] (II) This device may have been added with another device file.
[ 1838.319] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/js0)
[ 1838.390] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event11)
[ 1838.391] (II) No input driver specified, ignoring this device.
[ 1838.391] (II) This device may have been added with another device file.
[ 1838.393] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event12)
[ 1838.393] (II) No input driver specified, ignoring this device.
[ 1838.393] (II) This device may have been added with another device file.
[ 1838.403] (II) config/udev: Adding input device USB Gaming Mouse Keyboard (/dev/input/event10)
[ 1838.403] (**) USB Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 1838.403] (**) USB Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 1838.403] (**) USB Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 1838.403] (II) Using input driver 'libinput' for 'USB Gaming Mouse Keyboard'
[ 1838.403] (**) USB Gaming Mouse Keyboard: always reports core events
[ 1838.403] (**) Option "Device" "/dev/input/event10"
[ 1838.404] (II) event10 - USB Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 1838.404] (II) event10 - USB Gaming Mouse Keyboard: device is a keyboard
[ 1838.404] (II) event10 - USB Gaming Mouse Keyboard: device removed
[ 1838.441] (II) libinput: USB Gaming Mouse Keyboard: needs a virtual subdevice
[ 1838.441] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:04D9:A118.0009/input/input32/event10"
[ 1838.441] (II) XINPUT: Adding extended input device "USB Gaming Mouse Keyboard" (type: MOUSE, id 10)
[ 1838.442] (**) Option "AccelerationScheme" "none"
[ 1838.442] (**) USB Gaming Mouse Keyboard: (accel) selected scheme none/0
[ 1838.443] (**) USB Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[ 1838.443] (**) USB Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[ 1838.444] (II) event10 - USB Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 1838.444] (II) event10 - USB Gaming Mouse Keyboard: device is a keyboard
[ 1838.446] (**) USB Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[ 1838.446] (**) USB Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 1838.446] (**) USB Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 1838.446] (II) Using input driver 'libinput' for 'USB Gaming Mouse Keyboard'
[ 1838.446] (**) USB Gaming Mouse Keyboard: always reports core events
[ 1838.446] (**) Option "Device" "/dev/input/event10"
[ 1838.446] (II) libinput: USB Gaming Mouse Keyboard: is a virtual subdevice
[ 1838.446] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1/0003:04D9:A118.0009/input/input32/event10"
[ 1838.446] (II) XINPUT: Adding extended input device "USB Gaming Mouse Keyboard" (type: KEYBOARD, id 11)
[ 1838.446] (**) Option "xkb_layout" "it"
[ 1838.447] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event9)
[ 1838.447] (**) USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 1838.447] (**) USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 1838.447] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
[ 1838.447] (**) USB Gaming Mouse: always reports core events
[ 1838.447] (**) Option "Device" "/dev/input/event9"
[ 1838.504] (II) event9 - USB Gaming Mouse: is tagged by udev as: Mouse
[ 1838.505] (II) event9 - USB Gaming Mouse: device is a pointer
[ 1838.505] (II) event9 - USB Gaming Mouse: device removed
[ 1838.551] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.0/0003:04D9:A118.0008/input/input31/event9"
[ 1838.551] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: MOUSE, id 20)
[ 1838.552] (**) Option "AccelerationScheme" "none"
[ 1838.553] (**) USB Gaming Mouse: (accel) selected scheme none/0
[ 1838.553] (**) USB Gaming Mouse: (accel) acceleration factor: 2.000
[ 1838.554] (**) USB Gaming Mouse: (accel) acceleration threshold: 4
[ 1838.614] (II) event9 - USB Gaming Mouse: is tagged by udev as: Mouse
[ 1838.614] (II) event9 - USB Gaming Mouse: device is a pointer
[ 1934.809] (EE) event9 - USB Gaming Mouse: client bug: event processing lagging behind by 25ms, your system is too slow
[ 2472.597] (EE) event9 - USB Gaming Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
[ 2681.238] (EE) event9 - USB Gaming Mouse: client bug: event processing lagging behind by 26ms, your system is too slow
[ 2862.629] (EE) event9 - USB Gaming Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
