When I plug my Headset into my windows computer and record via Audacity, there is almost no background noise.
When plugged into my Manjaro 5.14 Laptop and using ALSA sysdefault as input, there is super strong noise when recording with Audacity. (pulse input does not work)
Problem is, that the pulse input doesn’t work. Also here my /etc/pulse/default.pa
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
