A friend found s-tui in the repo that I had not seen before. You can monitor your device’s cpu in real time and it will also perform a stress test and if you want you can export the data to a .csv format.
The README can be found here:
https://github.com/amanusk/s-tui
Thank you for sharing!
However, could you do me a favour and:
- edit your question by pressing the 3 dots and the pencil icon
- make it into a real question
- cut and paste the solution into a reply to your own question
- click the 3 dots below your own answer to mark a solution like this:
so that the next person that has the exact same problem you just had will benefit from your post as your question will now be in the “solved” status.
P.S Alternatively, post it in the #contributions:tutorials section…
