My UEFI behaves strange. For example:
I was in my PCs UEFI menu to show some settings to @fabby , but after this there are 2 new entries showing in efibootmgr
. But i did not save anything in UEFI. I did try to boot some of the entries, went into the EFI-shell and then just exit
ed it and booted Manjaro again with grub
before:
efibootmgr [127]
BootCurrent: 0000
Timeout: 1 seconds
BootOrder: 0000,001A,0004,0020,001B,0021,0022,0003
Boot0000* manjaro
Boot0003* UEFI: Built-in EFI Shell
Boot0004* UEFI OS
Boot001A* UEFI OS
Boot001B* Hard Drive
Boot0020* UEFI OS
Boot0021* USB
Boot0022* UEFI: USB DISK 2.0 PMAP, Partition 1
I went into UEFI, and am back:
efibootmgr
BootCurrent: 0000
Timeout: 1 seconds
BootOrder: 0000,001A,0004,0020,0023,001B,0024,0021,0022,0003
Boot0000* manjaro
Boot0004* UEFI OS
Boot001A* UEFI OS
Boot0020* UEFI OS
Boot0021* USB
Boot0023* UEFI OS
Boot0024* CD/DVD Drive
Do you notice ? now there are 2 lines added which where not there last time
I give in, i do have a complicated setup on my machine. This is because i don’t often buy new hardware, but i do gradually upgrade part by part. Since some time i am afraid to change anything in the UEFI or boot-order because my UEFI does (for me) strange things. I do use Linux since more then 20 years, my actual Manjaro install is from 2017. Once i used lilo
then grub
, I had rEFInd, (but lost it) today I am with grub 2.06.
(Sorry for the spelling errors: not a native )
Ah, and yes
inxi -Fazy
Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=3487ba3d-1cba-4cdc-a043-c420ebca2aca rw rootflags=subvol=@
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
modprobe.blacklist=ccp udev.log_priority=3 audit=0 sysrq_always_enabled=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter>
UEFI: American Megatrends v: P1.10 date: 06/19/2018
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 4 MiB
bogomips: 102255
Speed: 1547 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 1547 2: 1546 3: 1542 4: 1547 5: 1547 6: 1546 7: 1378 8: 1377 9: 1515
10: 1383 11: 1512 12: 1460 13: 1390 14: 1444 15: 1376 16: 1377
disabled, RSB filling
Device-1: NVIDIA GK107 [GeForce GT 740] vendor: eVga.com. driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fc8 class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte
driver: nouveau v: kernel bus-ID: 27:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-3: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-6.1:5 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
OpenGL: renderer: NV137 v: 4.3 Mesa 21.1.6 direct render: Yes
Device-1: NVIDIA GK107 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 27:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-3: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 29:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-4: Logitech C922 Pro Stream Webcam type: USB
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.33 running: yes
vendor: ASRock driver: r8169 v: kernel port: c000 bus-ID: 25:00.0
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-6.2:6 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 3.41 TiB used: 459.37 GiB (13.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH31000G
type: SSD serial: <filter> rev: 10RL scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SP610 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 2C scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: A-Data model: SX900 size: 119.24 GiB
serial: <filter> rev: 7a scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB model: USB DISK 2.0 size: 59.53 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: GPT
ID-1: / raw-size: 900 GiB size: 900 GiB (100.00%) used: 459.37 GiB (51.0%)
fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 953 MiB size: 951.1 MiB (99.80%)
used: 564 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 900 GiB size: 900 GiB (100.00%)
used: 459.37 GiB (51.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 37.8 C mobo: N/A
GPU: device: nouveau temp: 40.0 C mV: 975.00 device: nouveau temp: 61.0 C
fan: 0
Processes: 445 Uptime: 19m wakeups: 2 Memory: 46.99 GiB
used: 10.15 GiB (21.6%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2062 lib: 457 Shell: Zsh v: 5.8
running-in: xfce4-terminal inxi: 3.3.06
âžś efi
fabby said to ask for @stephane
I would like to:
- reinstall rEFInd (for safety)
- clean the entries in UEFI and keep only the necessary
This is not urgent, but it has to be done sometime from me (and yes i know - my pc - my responsibility)
I did reinstall rEFInd 10 minutes ago
Install refind with ERRORS
âžś efi export LANG=C;trizen -S refind
:: Pacman command: /usr/bin/sudo /usr/bin/pacman -S refind
[sudo] password for andreas:
warning: refind-0.13.2-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) refind-0.13.2-1
Total Installed Size: 5.01 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [------------------------------------------------------------------] 100%
(1/1) checking package integrity [------------------------------------------------------------------] 100%
(1/1) loading package files [------------------------------------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------------------------------------] 100%
(1/1) checking available disk space [------------------------------------------------------------------] 100%
(1/1) Performing snapper pre snapshots for the following configurations...
==> root: 18647
(1/1) reinstalling refind [------------------------------------------------------------------] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Removing unnecessary cached files (keeping the latest two)…
==> no candidate packages found for pruning
(3/5) Checking which packages need to be rebuilt
(4/5) Updating rEFInd on ESP
ShimSource is none
Installing rEFInd on Linux....
ESP was found at /boot/efi using vfat
Found rEFInd installation in /boot/efi/EFI/refind; upgrading it.
Installing driver for btrfs (btrfs_x64.efi)
Copied rEFInd binary files
Notice: Backed up existing icons directory as icons-backup.
Existing refind.conf file found; copying sample file as refind.conf-sample
to avoid overwriting your customizations.
Creating new NVRAM entry
ALERT: There were problems running the efibootmgr program! You may need to
rename the refind_x64.efi binary to the default name (EFI/BOOT/bootx64.efi
on x86-64 systems, EFI/BOOT/bootia32.efi on x86 systems, or
EFI/BOOT/bootaa64.efi on ARM64 systems) to have it run!
Existing //boot/refind_linux.conf found; not overwriting.
(5/5) Performing snapper post snapshots for the following configurations...
==> root: 18648
âžś efi
and i did install manjaro-refind-installer
(didn’t know this existed)
but i did not reboot yet
