I just installed Ventoy from the official Repo’s and i see a strange output with the install logs.
Is there something wrong with the install? The application is starting up btw.
Preparing...
Resolving dependencies...
Checking inter-conflicts...
Download of ventoy (1.0.97-1) started
Download of ventoy (1.0.97-1) finished
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Installing ventoy (1.0.97-1)...
tput: No value for $TERM and no -T specified
-> NOTE: You can create persistence images for ventoy with the "ventoy-persistent" command,
-> and losslessly expand persistence ".dat" files using "ventoy-extend-persistent",
-> which are shortcuts to "/opt/ventoy/CreatePersistentImg.sh" and
-> "/opt/ventoy/ExtendPersistentImg.sh", respectively.
-> (See https://www.ventoy.net/en/plugin_persistence.html for documentation.)
Arming ConditionNeedsUpdate...
Updating the desktop file MIME type cache...
