Recently (after some update) I am getting several messages during startup similar to :
Proxy Daemon Started
Proxy Daemon Stopped
Calling “journalctl -b” I noticed :
08:52:40 manjaro dbus-daemon[673]: [system] Activating via systemd: service name='org.pacrunner' unit='pacrunner.service' requested by ':1.4' (uid=0 pid=792 comm="/usr/bin/NetworkManager --no-daemon")
08:52:40 manjaro dbus-daemon[673]: [system] Successfully activated service 'org.pacrunner'
08:52:40 manjaro pacrunner[972]: PAC Runner version 0.19
08:52:40 manjaro pacrunner[972]: Terminating
08:52:40 manjaro pacrunner[972]: Exit
08:52:40 manjaro systemd[1]: pacrunner.service: Deactivated successfully.
08:52:40 manjaro pacrunner[1013]: PAC Runner version 0.19
08:52:40 manjaro pacrunner[1013]: Terminating
08:52:40 manjaro pacrunner[1013]: Exit
08:52:40 manjaro pacrunner[1032]: PAC Runner version 0.19
08:52:40 manjaro pacrunner[1032]: Terminating
08:52:40 manjaro pacrunner[1032]: Exit
The amount of those entries is variable , each time I make a reboot.
Sometimes it becomes a single entry though …
Any ideas what is happening ?
cscs
20 April 2024 08:27
2
Well … pacrunner
is not default.
It must have been added.
Are you saying you intend to use it but it is not functioning as expected?
I do not remember which program calls pacrunner …
Or how it was installed …
How can I get a list of programs that is calling such service ?
Can I call pacman to find it reverse dependencies ?
cscs
20 April 2024 08:42
4
A general search of installed;
pacman -Qs pacrunner
More information (including ‘required by’ etc) of an installed package;
pacman -Qi pacrunner
Other tools and approaches exist, such as to see everything relying on package pacrunner
pactree -r pacrunner
As a non-critical program it should be safe to remove.
A removal, along with its dependencies that are not required by other packages would be;
sudo pacman -Rns pacrunner
The odd part is calling :
Install Reason : Installed as a dependency for another package
Although pactree -r pacrunner
pacrunner
└─manjaro-connman
I can try to remove it …
But I feel that I might loose network afterwards …
cscs
20 April 2024 08:49
6
markmarques:
└─manjaro-connman
So thats why.
Do you need connman?
Your confusion makes it seem as if you dont need any of these things.
https://wiki.archlinux.org/title/ConnMan
Most systems … and Manjaro systems … by default use NetworkManager.
I am going to remove “manjaro-connman” ;
Although this machine has bluetooth and Wifi connections …
but most of the time they are not needed …
Sometimes I make some experiments with USB bluetooth dongles …
It’s just a meta-package:
$ pacman -Sii manjaro-connman
Description : Manjaro meta package for complete ConnMan support
Required By : None
Depends On : avahi connman dnsmasq nss-mdns openconnect resolvconf openssh openvpn ntp pacrunner pptpclient rp-pppoe wpa_supplicant
So how do I activate NetworkManager as my default network manager ?
In this case how do I swap from connman to networkmanager without breaking the “network” ?
It should already be. But if you wish to confirm, please provide the output for:
systemctl status NetworkManager.service
As requested the NetworkManager.service output is :
NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
Active: active (running) since Sat 2024-04-20 08:52:40 WEST; 1h 51min ago
Docs: man:NetworkManager(8)
Main PID: 792 (NetworkManager)
Tasks: 4 (limit: 37790)
Memory: 22.6M (peak: 23.6M)
CPU: 351ms
CGroup: /system.slice/NetworkManager.service
└─792 /usr/bin/NetworkManager --no-daemon
Apr 20 08:52:48 manjaro NetworkManager[792]: <info> [1713599568.4525] device (eno1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 20 08:52:48 manjaro NetworkManager[792]: <info> [1713599568.4528] manager: NetworkManager state is now CONNECTED_SITE
Apr 20 08:52:48 manjaro NetworkManager[792]: <info> [1713599568.4531] device (eno1): Activation: successful, device activated.
Apr 20 08:52:48 manjaro NetworkManager[792]: <info> [1713599568.4536] manager: startup complete
Apr 20 08:52:48 manjaro NetworkManager[792]: <info> [1713599568.4681] dhcp6 (eno1): activation: beginning transaction (timeout in 45 seconds)
Apr 20 08:52:48 manjaro NetworkManager[792]: <info> [1713599568.4685] policy: set 'Intel interface' (eno1) as default for IPv6 routing and DNS
Apr 20 08:52:48 manjaro NetworkManager[792]: <info> [1713599568.4755] dhcp6 (eno1): state changed new lease
Apr 20 08:52:48 manjaro NetworkManager[792]: <info> [1713599568.6326] manager: NetworkManager state is now CONNECTED_GLOBAL
Apr 20 09:01:58 manjaro NetworkManager[792]: <info> [1713600118.6699] agent-manager: agent[eb7841f1ce30d5e5,:1.74/org.freedesktop.nm-applet/1000]: agent registered
Apr 20 09:52:48 manjaro NetworkManager[792]: <info> [1713603168.2584] dhcp4 (eno1): state changed new lease, address=172.18.61.69
It seems that is the same PID ( 792) as the journalctl pacrunner lines …
Well, if you are sure you don’t use it, I think it can be removed. And since manjaro-connman
doesn’t have any Dependencies and doesn’t provide any functionality in and of itself, and I don’t have either installed, I think they are safe to be removed:
pamac remove pacrunner manjaro-connman
However, there’s no way for me to be absolutely certain, so if something breaks, reinstall said packages:
pamac install pacrunner manjaro-connman
Apparently the removal of pacrunner and manjaro-connman packages, solved my strange startup messages …
Although I have to ask :
if I need to enable “manjaro-connman”, should I manually disable the NetworkManager.service ?
I can honestly not say. But I don’t think so, seeing as manjaro-connman doesn’t do anything itself. But I don’t know if the packages it pulls in have any conflicts with NetworkManager.
connman
in Manjaro extra repository does not require pacrunner
If you install connman
Network Manager should be disabled
ConnMan - ArchWiki
Before enabling connman.service
, ensure any existing network configuration is disabled.
system
Closed
22 April 2024 00:52
16
