Hi everybody,
After in installed the latest updates my login screen shows (very fast btw) but in the wrong resolution. The mouse is not working and i see the input cursor blinks but the keyboard is not working. After a while the cursor does not blink anymore and that’s it. CTRL-ALT-DEL still works.
Then i removed all my USB external devices except mouse and keyboard. The system still starts in the wrong resolution but after a while (after 20 seconds) it shows me the correct resolution and the mouse and keyboard works.
I looked at the bootlogs but can’t figure out where it goes wrong.
journalctl --boot=-1 --priority=3 --catalog --no-pager ✔ 7s
aug 08 12:17:17 precisiontower5810 kernel: nouveau 0000:03:00.0: bus: MMIO read of 00000000 FAULT at 3e6684 [ IBUS ]
aug 08 12:17:17 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 01 [WRITE] at 00000000011be000 engine 05 [BAR2] client 08 [HUB/HOST_CPU_NB] reason 02 [PTE] on channel -1 [007fd38000 unknown]
aug 08 12:17:17 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 01 [WRITE] at 0000000001000000 engine 05 [BAR2] client 08 [HUB/HOST_CPU_NB] reason 02 [PTE] on channel -1 [007fd38000 unknown]
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 00 [READ] at 0000000000100000 engine 04 [BAR1] client 07 [HUB/HOST_CPU] reason 00 [PDE] on channel -1 [007fce7000 unknown]
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 01 [WRITE] at 0000000000108000 engine 04 [BAR1] client 08 [HUB/HOST_CPU_NB] reason 00 [PDE] on channel -1 [007fce7000 unknown]
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: disp: chid 0 stat 00007088 reason 7 [UNRESOLVABLE_HANDLE] mthd 0088 data f0000000 code 00000000
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: disp: chid 0 stat 1000508c reason 5 [INVALID_STATE] mthd 008c data 00000000 code 0000102b
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 00 [READ] at 0000000000108000 engine 04 [BAR1] client 07 [HUB/HOST_CPU] reason 00 [PDE] on channel -1 [007fce7000 unknown]
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 00 [READ] at 000000ffc4a07000 engine 00 [GR] client 04 [HUB/FE] reason 03 [VA_LIMIT_VIOLATION] on channel -1 [007fae0000 unknown]
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: bus: MMIO read of 00000000 FAULT at 400700 [ IBUS ]
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: bus: MMIO read of 00000000 FAULT at 40060c [ IBUS ]
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 01 [WRITE] at 0000000000008000 engine 00 [GR] client 15 [HUB/SCC_NB] reason 04 [UNBOUND_INST_BLOCK] on channel -1 [0000000000 unknown]
aug 08 12:17:18 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 00 [READ] at 0000000e34638000 engine 00 [GR] client 04 [HUB/FE] reason 0a [UNSUPPORTED_APERTURE] on channel -1 [007f9d8000 unknown]
aug 08 12:17:19 precisiontower5810 kernel: sd 10:0:0:0: [sdb] No Caching mode page found
aug 08 12:17:19 precisiontower5810 kernel: sd 10:0:0:0: [sdb] Assuming drive cache: write through
aug 08 12:17:20 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: wait for idle timeout (en: 1, ctxsw: 0, busy: 1)
aug 08 12:17:22 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: wait for idle timeout (en: 1, ctxsw: 0, busy: 1)
aug 08 12:17:24 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: wait for idle timeout (en: 1, ctxsw: 0, busy: 1)
aug 08 12:17:26 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: wait for idle timeout (en: 1, ctxsw: 0, busy: 1)
aug 08 12:17:28 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: wait for idle timeout (en: 1, ctxsw: 0, busy: 1)
aug 08 12:17:28 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: failed to construct context
aug 08 12:17:28 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: init failed, -16
aug 08 12:17:28 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: fault 01 [WRITE] at 0000000000140000 engine 04 [BAR1] client 08 [HUB/HOST_CPU_NB] reason 00 [PDE] on channel -1 [007fce7000 unknown]
aug 08 12:17:28 precisiontower5810 kernel: nouveau 0000:03:00.0: fifo: DROPPED_MMU_FAULT 00000000
aug 08 12:17:28 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: fecs falcon already acquired by gr!
aug 08 12:17:30 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: wait for idle timeout (en: 1, ctxsw: 0, busy: 1)
aug 08 12:17:32 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: wait for idle timeout (en: 1, ctxsw: 0, busy: 1)
aug 08 12:17:34 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: failed to construct context
aug 08 12:17:34 precisiontower5810 kernel: nouveau 0000:03:00.0: gr: init failed, -16
aug 08 12:19:50 precisiontower5810 systemd-coredump[1084]: Failed to connect to coredump service: Connection refused
Can you point me in a direction where i can solve this? Thanks!
Edit… Some more info. I see i am using LXDM (duh).
Kernel: 5.9.11-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=bc73af6d-c766-4284-b3fa-a482c96812c9 rw quiet
udev.log_priority=3
Desktop: Openbox v: 3.6.1 dm: LXDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Dell product: Precision Tower 5810 v: N/A
serial: <filter> Chassis: type: 7 serial: <filter>
Mobo: Dell model: 0K240Y v: A02 serial: <filter> UEFI: Dell v: A09
date: 09/26/2015
Info: model: Intel Xeon E5-1620 v3 socket: LGA2011-3 bits: 64 type: MT MCP
arch: Haswell built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3F (63) stepping: 2 microcode: 0x49
L3: 10 MiB desc: 1x10 MiB
Speed (MHz): avg: 1379 high: 2164 min/max: 1200/3600
base/boost: 3500/4000 scaling: driver: intel_cpufreq governor: schedutil
volts: 1.8 V ext-clock: 100 MHz cores: 1: 2164 2: 1197 3: 1198 4: 1198
5: 1688 6: 1198 7: 1198 8: 1198 bogomips: 55894
vulnerable
prctl and seccomp
Device-1: NVIDIA GM107GL [Quadro K620] driver: nouveau v: kernel
non-free: 515.xx+ status: current (as of 2022-07) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: DVI-I-1 empty: DP-1 bus-ID: 03:00.0 chip-ID: 10de:13bb
class-ID: 0300
Display: server: X.Org v: 21.1.4 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.48x10.91")
s-diag: 523mm (20.6")
Monitor-1: DVI-I-1 model: Idek Iiyama PL2201W serial: <filter>
built: 2007 res: 1680x1050 hz: 60 dpi: 87 gamma: 1.2
size: 490x320mm (19.29x12.6") diag: 585mm (23") ratio: 3:2 modes:
max: 1680x1050 min: 720x400
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel C610/X99 series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
bus-ID: 03:00.1 chip-ID: 10de:0fbc class-ID: 0403
Sound Server-1: ALSA v: k5.9.11-3-MANJARO running: yes
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f020 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel C600/X79 series SATA RAID Controller driver: ahci v: 3.0
port: f000 bus-ID: 00:1f.2 chip-ID: 8086:2826 rev: N/A class-ID: 0104
Local Storage: total: 29.82 GiB used: 9.48 GiB (31.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX size: 29.82 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
serial: <filter> rev: 1.31 scheme: GPT
ID-1: / raw-size: 29.52 GiB size: 28.93 GiB (98.00%) used: 9.48 GiB (32.8%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 37.0 C mobo: N/A sodimm: SODIMM C gpu: nouveau
temp: 44.0 C
Fan Speeds (RPM): cpu: 1056 gpu: nouveau fan: 2220
Processes: 206 Uptime: 1h 37m wakeups: 0 Memory: 31.29 GiB used: 1.69 GiB
(5.4%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.1 Packages: pacman: 901 lib: 195 Shell: Zsh (sudo) v: 5.9
default: Bash v: 5.1.16 running-in: sakura inxi: 3.3.20
