Strange graphical glitch in Plasma's task bar
Hello,
I recently migrated to Wayland, and everything it’s working smoothly. However I’ve noticed a minor visual glitch on Plasma’s taskbar that I find a bit annoying. I’ve captured a video showing the issue. This doesn’t happen under X11.
visual_glitch
Notice how the little window where the application name is displayed doesn’t always resize correctly. I know this is really nitpicky and I suppose it might be a Plasma bug. But I guess Nvidia is also a suspect, as always.
Anybody has observed a similar behavior?
yeah… sometimes, not very often.
I’ve noticed the same behaviour in the Application Menu for some time now too.
Screenshot_20250825_101437
Screenshot_20250825_101505
I do have annoying problems with KDE Launcher anyway. I posted this here: Application Launcher not working correctly
I have no idea if this has to do with each other, but the problems I have lead me in to another direction, saying: a different distribution. Maybe I have to reset the complete installation, but unfortunately up-to-know I did not find a user-friendly way to do this.
Unlikely. I imagine if it were, we would all be experiencing the same issue; I’m not. I do suspect, however, that Nvidia plays a part; I mean, it virtually always does. The information you have provided is extremely limited, so can only take blind guesses, at this point.
Please provide your system information as described (below) to help others identify other possible contibutors.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Sorry, you’re absolutely right. Reading my post again I see how it lacks necessary info.
Here is the output inxi:
$inxi -zv8
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=27ac6e93-e7a8-4b73-b799-644e8d3e2ca5 rw rootflags=subvol=@
    quiet splash resume=UUID=62175b73-942c-4e2f-aa1e-5fe64449e55a
    udev.log_priority=3 drm.edid_firmware=HDMI-A-1:edid/HDR4k_60.bin
    video=HDMI-A-1:e
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Desktop Mobo: MSI model: H270 PC MATE (MS-7A72) v: 1.0
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: 2.80 date: 07/05/2018
  System RAM: total: 16 GiB available: 15.58 GiB used: 4.38 GiB (28.1%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Kingston part-no: KHX2133C14/8G
    serial: <filter>
  Device-3: ChannelB-DIMM0 type: no module installed
  Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous unbuffered
    serial: <filter>
  Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 800 min/max: 800/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 24008
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-08; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: DP-1 off: HDMI-A-1 empty: DVI-D-1
    bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
  Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12.1:9
    chip-ID: 046d:08e5 class-ID: 0102
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2023 res: mode: 3840x2160 hz: 95 scale: 150% (1.5) to: 2560x1440
    dpi: 163 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green: x: 0.267
    y: 0.682 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1280x1024, 1280x720, 1024x768,
    800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: HDMI-A-1 model: AOC 28E850 built: 2017 res: 1920x1080 dpi: 79
    gamma: 1.2 chroma: red: x: 0.682 y: 0.310 green: x: 0.204 y: 0.694 blue:
    x: 0.149 y: 0.055 white: x: 0.314 y: 0.329 size: 480x270mm (18.9x10.63")
    diag: 707mm (27.8") ratio: 16:9 modes: 3840x2160, 1280x800, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 93
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    memory: 3.91 GiB display-ID: :0.0
  API: Vulkan v: 1.4.321 layers: 9 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1050 Ti driver: nvidia v: 580.82.09 device-ID: 10de:1c82
    surfaces: N/A
  Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI H270 PC MATE
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI H270 PC MATE
    driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8
    class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  Device-2: Qualcomm Atheros AR9227 Wireless Network Adapter driver: ath9k
    v: kernel bus-ID: 04:00.0 chip-ID: 168c:002d class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IF-ID-2: proton0 state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> type: noprefixroute scope: global
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2
    chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 1.13 TiB used: 172.4 GiB (14.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: WDC WDS240G1G0B-00RC30
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1000 scheme: GPT
  Optical-1: /dev/sr0 vendor: ASUS model: DRW-24D5MT rev: 1.00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
    used: 80.3 GiB (39.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 27ac6e93-e7a8-4b73-b799-644e8d3e2ca5
    used: 632 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 4BA8-2BF7
  ID-3: /home raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
  ID-4: /media/nicolas raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 92.09 GiB (9.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 94cf02d6-049d-45ab-91a0-9edca19f8e81
  ID-5: /var/cache raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
  ID-6: /var/log raw-size: 206.14 GiB size: 206.14 GiB (100.00%)
  ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
    uuid: 62175b73-942c-4e2f-aa1e-5fe64449e55a
  Device-1: 1-5:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 1-6:3 info: 8BitDo Ultimate Wireless Controller type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 2dc8:3109 class-ID: 0300
    serial: <filter>
  Hub-2: 1-12:4 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-12.1:9 info: Logitech C920 PRO HD Webcam type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.1
  Hub-3: 1-12.4:5 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 1-12.4.1:6 info: PCPlay Barcode PCP-BCG4209 type: keyboard,mouse
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 400mA
    chip-ID: 13ba:0018 class-ID: 0301
  Device-2: 1-12.4.2:7 info: Logitech G102 LIGHTSYNC Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c09d class-ID: 0300 serial: <filter>
  Device-3: 1-12.4.3:8 info: LG USA 27UP850 - WK.AEUDCSN External Monitor 4K
    type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 043e:9a39 class-ID: 0a00 serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  Hub-5: 2-4:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Hub-6: 2-4.4:3 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-7: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 39.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1576 pm: pacman pkgs: 1567 libs: 470 tools: pamac pm: flatpak
    pkgs: 9
  Active pacman repo servers in: /etc/pacman.conf
    1: https://github.com/LizardByte/pacman-repo/releases/latest/download
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    3: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 315
  1: cpu: 29.6% command: firefox pid: 2346 mem: 751.8 MiB (4.7%)
  2: cpu: 20.6% command: kwin_wayland pid: 693 mem: 324.3 MiB (2.0%)
  3: cpu: 18.8% command: firefox pid: 2726 mem: 345.7 MiB (2.1%)
  4: cpu: 14.1% command: konsole pid: 3687 mem: 311.2 MiB (1.9%)
  5: cpu: 13.5% command: steamwebhelper pid: 3112 mem: 448.5 MiB (2.8%)
  Memory top: 5 of 315
  1: mem: 751.8 MiB (4.7%) command: firefox pid: 2346 cpu: 29.6%
  2: mem: 478.8 MiB (3.0%) command: firefox pid: 1748 cpu: 6.1%
  3: mem: 448.5 MiB (2.8%) command: steamwebhelper pid: 3112 cpu: 13.5%
  4: mem: 441.0 MiB (2.7%) command: exe pid: 1546 cpu: 13.1%
  5: mem: 433.6 MiB (2.7%) command: plasmashell pid: 848 cpu: 2.4%
  Processes: 315 Power: uptime: 9m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.39
I too was having weird little glitches in Wayland. One was that in Xnviewmp, the menu for changing a border color was missing options. I installed the Weston compositor and that fixed the issue. You will be running Weston/Wayland.
One presumes you have taken the usual steps to rule out local environmental issues.
1. Delete the cache directory:
Logout, switch to a TTY and login, issue the following command;
rm -rf ~/.cache
Reboot and login normally; see if the issue persists.
(the cache will bebuild itself as you use the machine)
2. Create a new user account:
Create a new account (for testing purposes), reboot and login to that account, and verify whether or not the described issue persists.
Have tried both things, to no avail. The visual glitch still happens with a clean cache and with a new user.
