Hi since yesterday i suddenly noticed that before the kernel gets loaded i get this message on the screen:
error: sparse file not allowed.
press any key to continue...
It waits a few seconds and then boots normally though.
(I can’t press any key because the keyboard isn’t activated yet, i know because it’s lights are off)
The only thing i can recall is that i installed another kernel to test, and thus rebuild the initrd etc.
sudo mkinitcpio -P && sudo update-grub
cat /etc/mkinitcpio.conf | xclip
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=(
crc32c-intel
# https://forum.manjaro.org/t/howto-use-wayland-with-proprietary-nvidia-drivers/36130
nvidia
nvidia_modeset
nvidia_uvm
nvidia_drm
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev autodetect modconf block keyboard keymap consolefont resume filesystems bootsplash-manjaro"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
COMPRESSION_OPTIONS=(-19)
# MODULES_DECOMPRESS
# Decompress kernel modules during initramfs creation.
# Enable to speedup boot process, disable to save RAM
# during early userspace. Switch (yes/no).
#MODULES_DECOMPRESS="yes"
I tried with the COMPRESSION lines commented out also, but it stays same…
cat /etc/default/grub | xclip
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="resume=UUID=d0e8e1cc-12bb-4105-a185-114fe02793e9 udev.log_priority=3 intel_iommu=on nvidia-drm.modeset=1 bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT="true"
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
cat /proc/cmdline | xclip
BOOT_IMAGE=/@/boot/vmlinuz-6.0-x86_64 root=UUID=74357a56-4b24-4eaf-94b5-5547de52b278 rw rootflags=subvol=@ resume=UUID=d0e8e1cc-12bb-4105-a185-114fe02793e9 udev.log_priority=3 intel_iommu=on nvidia-drm.modeset=1 bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash
sudo find /boot -name initramfs-\*-x86_64.img -exec lsinitcpio -a '{}' ';' | xclip
==> Image: /boot/initramfs-5.15-x86_64.img
==> Created with mkinitcpio 32
==> Kernel: 5.15.78-1-MANJARO
==> Size: 82.81 MiB
==> Compressed with: zstd
-> Uncompressed size: 133.15 MiB (.621 ratio)
-> Estimated decompression time: 0.725s
==> Included modules:
blake2b_generic crc-itu-t mmc_core raid6_pq usb-storage
btrfs firewire-core nvidia-drm [explicit] sha256-ssse3 virtio_blk
cdrom firewire-sbp2 nvidia [explicit] sr_mod xhci-pci
crc32c_generic libcrc32c nvidia-modeset [explicit] uas xor
crc32c-intel [explicit] mmc_block nvidia-uvm [explicit] usbhid xxhash_generic
==> Included binaries:
blkid busybox kmod mount switch_root systemd-tmpfiles udevadm
==> Early hook run order:
udev
==> Hook run order:
udev
keymap
resume
==> Cleanup hook run order:
udev
==> Image: /boot/initramfs-6.0-x86_64.img
==> Kernel: 6.0.8-1-MANJARO
==> Size: 84.48 MiB
-> Uncompressed size: 151.26 MiB (.558 ratio)
-> Estimated decompression time: 0.670s
blake2b_generic firewire-core nvidia [explicit] raid6_pq virtio_blk
btrfs firewire-sbp2 nvidia-modeset [explicit] sha256-ssse3 xhci-pci
cdrom libcrc32c nvidia-uvm [explicit] sr_mod xhci-pci-renesas
crc32c_generic mmc_block nvme uas xor
crc32c-intel [explicit] mmc_core nvme-common usbhid xxhash_generic
crc-itu-t nvidia-drm [explicit] nvme-core usb-storage
udev
==> Hook run order:
udev
keymap
resume
udev
inxi -v 2 | xclip
Host: manjaro Kernel: 6.0.8-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.26.3 Distro: Manjaro Linux
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: X99-PRO/USB 3.1 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4101
date: 07/10/2019
Info: 6-core Intel Core i7-5820K [MT MCP] speed (MHz): avg: 1210
min/max: 1200/3600
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] driver: nvidia v: 520.56.06
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 driver: X:
loaded: nvidia unloaded: modesetting gpu: nvidia,nvidia-nvswitch
resolution: 2560x1080~60Hz
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce GTX 1080
Ti/PCIe/SSE2
Device-1: Intel Ethernet I218-V driver: e1000e
Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
Local Storage: total: 9.24 TiB used: 1.15 TiB (12.4%)
Processes: 306 Uptime: 1h 39m Memory: 31.26 GiB used: 3.48 GiB (11.1%)
Shell: Zsh inxi: 3.3.23
