Strange case: Enter BIOS without even changing anything results in 'HALT&BEEP' state
Hello Manjourney’ers,
First time posting, but this special situation requires it.
So I have an Acer Aspire TC-885 8th gen i7 core.
It had Windows pre-installed when I bought it but the very first day I wiped everything away from a live medium…which resulted in much fun bending and curse’ing to get things eventually rolling.
I since opened my case front -literally- and replaced, added or removed HW along the way.
The problem I’m facing now isn’t one of losing any data or situation where I’m forced to re-install but it’s a nuissance which I can’t wrap my head around.
latest manjaro iso, stable branch, is installed and runs smoothly with kernel 6.6.
BUT whenever I try to do anything, albeit just having a look in my BIOS I can’t quit without my pc just making a Halt, stop there and start to start a continuous Beep.
The only way I can restart normal is pressing the power button until the pc shutdown and pull the power cord out of my case, smoke a sigaret, push the power button 30sec and the insert the power cord which makes my pc start normally.
Any other scenario and I can’t even reach bios boot screen, it just starts Beeping again.
So I’ll post my required system information and hope the manjaro community can solve this strange one.
sudo inxi --full --admin --filter --width
  Kernel: 6.6.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=dabf4e5f-0262-4d90-8c13-b4f3d2cf37ac rw rootflags=subvol=@
    nowatchdog quiet splash udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland dm: SDDM
  Type: Desktop Mobo: Acer model: Aspire TC-885 v: V:1.1 serial: <filter>
    UEFI: American Megatrends v: R01-C3 date: 04/08/2020
  Info: model: Intel Core i7-8700 socket: LGA1151 (U3E1) note: check bits: 64
    type: MT MCP arch: Coffee Lake gen: core 8 level: v3 note: check built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
    microcode: 0xF4
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1114 high: 4574 min/max: 800/4600 base/boost: 3200/8300
    scaling: driver: intel_pstate governor: powersave volts: 1.0 V
    ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 4574 bogomips: 76831
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1,HDMI-A-2
    empty: DP-1,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
  Display: server: X.Org v: 23.2.2 with: Xwayland v: 23.2.2
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
    s-diag: 1055mm (41.55") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: Medion MD 20430 serial: <filter> built: 2013
    res: 1920x1080 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
    diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: HDMI-A-2 model: Samsung built: 2007 res: 1920x1080 dpi: 305
    gamma: 1.2 size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
    device-ID: 8086:3e92 memory: 15.14 GiB unified: yes
  API: Vulkan v: 1.3.269 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
    v: 23.1.9-manjaro1.1 device-ID: 8086:3e92 surfaces: xcb,xlib
  Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  API: ALSA v: k6.6.1-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.85 status: n/a (root, process) with:
    1: pipewire-pulse status: active 2: pipewire-media-session status: active
    3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 2.06 TiB used: 607.37 GiB (28.8%)
    model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
  SMART: yes health: PASSED on: 120d 11h cycles: 2,004
    read-units: 22,349,959 [11.4 TB] written-units: 35,214,408 [18.0 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100 family: 3.5"
    DT01ACA... Desktop HDD size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: A8K0 temp: 25 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 3y 114d 0h cycles: 2888
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM035-1RK172
    family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
    serial: <filter> fw-rev: ACM1 temp: 24 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 253d 16h cycles: 3511
    read: 19.02 TiB written: 20.91 TiB Old-Age: g-sense error rate: 568 Pre-Fail:
    attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
  ID-4: /dev/sdc maj-min: 8:32 model: USB DISK 3.0 size: 14.46 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
    scheme: MBR
  ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
    used: 38.17 GiB (16.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2
    used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
    maj-min: 259:2
  ID-4: /var/log raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
    maj-min: 259:2
  Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
    zswap: yes compressor: zstd max-pool: 20%
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  System Temperatures: cpu: 35.0 C pch: 61.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 313 Uptime: 8m wakeups: 0 Memory: total: 16 GiB
  available: 15.5 GiB used: 2.54 GiB (16.4%) igpu: 32 MiB Init: systemd v: 254
  Packages: pm: pacman pkgs: 1201 libs: 346 tools: pamac Shell: Sudo (sudo)
  v: 1.9.15p2 default: Bash v: 5.2.15 running-in: konsole inxi: 3.3.31```
sudo dmesg --level emerg,alert,crit,err,warn
[    0.095569] x86/cpu: SGX disabled by BIOS.
[    0.103521] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.103521] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.109329] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.391632] hpet_acpi_add: no address or irqs in _CRS
[    1.370652] usb: port power management may be unreliable
[    1.379129] nvme nvme0: missing or invalid SUBNQN field.
[    2.217308] BTRFS error (device nvme0n1p2: state M): unrecognized mount option 'fstrim.timer'
[    2.414842] systemd[1]: systemd-remount-fs.service: Failed with result 'exit-code'.
[    2.447652] systemd[1]: Failed to start Remount Root and Kernel File Systems.
[    3.194529] mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x400000
[    3.216491] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[    3.216493] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[    3.216494] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[    3.216495] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[    3.216496] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[    3.216497] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[    3.216498] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[    3.216499] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[    3.216500] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[    3.216501] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[    3.216501] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[    3.216502] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[    3.216503] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[    3.216504] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[    3.216505] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[    3.216506] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[    3.216507] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[    3.615369] thermal thermal_zone2: failed to read out thermal zone (-61)
[    4.208826] sd 6:0:0:0: [sdc] No Caching mode page found
[    4.208829] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[    5.520501] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[    5.525445] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[   11.852590] kwin_wayland[707]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[   12.773655] warning: `kded5' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
journalctl --catalog --priority=3 --boot=-1
Nov 22 22:39:38 janduchau-aspiretc885 kernel: BTRFS error (device nvme0n1p2: state M): unrecognized mount option 'fstrim.timer'
Nov 22 22:39:38 janduchau-aspiretc885 systemd[1]: Failed to start Remount Root and Kernel File Systems.
Nov 22 22:39:38 janduchau-aspiretc885 systemd-remount-fs[293]: /usr/bin/mount for / exited with exit status 32.
Nov 22 22:39:39 janduchau-aspiretc885 systemd-remount-fs[515]: /usr/bin/mount for / exited with exit status 32.
Nov 22 22:39:39 janduchau-aspiretc885 kernel: BTRFS error (device nvme0n1p2: state M): unrecognized mount option 'fstrim.timer'
Nov 22 22:39:39 janduchau-aspiretc885 systemd[1]: Failed to start Remount Root and Kernel File Systems.
-- Subject: A start job for unit systemd-remount-fs.service has failed
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/support
-- A start job for unit systemd-remount-fs.service has finished with a failure.
-- The job identifier is 262 and the job result is failed.
Nov 22 22:39:40 janduchau-aspiretc885 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Nov 22 22:39:40 janduchau-aspiretc885 bluetoothd[558]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
Nov 22 22:39:40 janduchau-aspiretc885 bluetoothd[558]: Failed to clear UUIDs: Failed (0x03)
Nov 22 22:39:40 janduchau-aspiretc885 bluetoothd[558]: Failed to add UUID: Failed (0x03)
Nov 22 22:39:40 janduchau-aspiretc885 bluetoothd[558]: Failed to set mode: Failed (0x03)
Nov 22 22:39:48 janduchau-aspiretc885 bluetoothd[558]: Failed to add UUID: Failed (0x03)
Nov 22 22:39:49 janduchau-aspiretc885 libddcutil[950]: busno=2, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[ENXIO in ddc_write_read_with_retry, causes: ENXIO]
Nov 22 23:18:38 janduchau-aspiretc885 bluetoothd[558]: Failed to remove UUID: Failed (0x03)
Nov 22 23:18:47 janduchau-aspiretc885 bluetoothd[558]: Failed to add UUID: Failed (0x03)
Nov 22 23:18:49 janduchau-aspiretc885 libddcutil[7547]: busno=2, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[ENXIO in ddc_write_read_with_retry, causes: ENXIO]
Nov 22 23:28:34 janduchau-aspiretc885 bluetoothd[558]: Failed to remove UUID: Failed (0x03)
cat /var/log/Xorg.0.log
[     8.736] (--) Log file renamed from "/var/log/Xorg.pid-643.log" to "/var/log/Xorg.0.log"
[     8.737]
X.Org X Server 1.21.1.9
[     8.737] Current Operating System: Linux janduchau-aspiretc885 6.6.1-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Nov  9 04:27:49 UTC 2023 x86_64
[     8.737] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64 root=UUID=dabf4e5f-0262-4d90-8c13-b4f3d2cf37ac rw rootflags=subvol=@ nowatchdog quiet splash udev.log_priority=3
[     8.738]
[     8.738] Current version of pixman: 0.42.2
[     8.738]    Before reporting problems, check http://wiki.x.org
[     8.738] Markers: (--) probed, (**) from config file, (==) default setting,
[     8.738] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 22 23:47:31 2023
[     8.739] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     8.739] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.740] (==) No Layout section.  Using the first Screen section.
[     8.740] (==) No screen section available. Using defaults.
[     8.740] (**) |-->Screen "Default Screen Section" (0)
[     8.740] (**) |   |-->Monitor "<default monitor>"
[     8.741] (==) No monitor specified for screen "Default Screen Section".
[     8.741] (==) Automatically adding devices
[     8.741] (==) Automatically enabling devices
[     8.741] (==) Automatically adding GPU devices
[     8.741] (==) Automatically binding GPU devices
[     8.741] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     8.742] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     8.742]    Entry deleted from font path.
[     8.742] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     8.742] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     8.742] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     8.742] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     8.742] (==) ModulePath set to "/usr/lib/xorg/modules"
[     8.742] (II) The server relies on udev to provide the list of input devices.
[     8.742] (II) Module ABI versions:
[     8.742]    X.Org ANSI C Emulation: 0.4
[     8.742]    X.Org Video Driver: 25.2
[     8.742]    X.Org XInput driver : 24.4
[     8.742]    X.Org Server Extension : 10.0
[     8.744] (++) using VT number 2
[     8.744] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     8.747] (II) xfree86: Adding drm device (/dev/dri/card1)
[     8.747] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card1
[     8.761] (--) PCI:*(0@0:2:0) 8086:3e92:1025:1238 rev 0, Mem @ 0xa1000000/16777216, 0x90000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[     8.761] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     8.761] (II) LoadModule: "glx"
[     8.762] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.769] (II) Module glx: vendor="X.Org Foundation"
[     8.769]    compiled for 1.21.1.9, module version = 1.0.0
[     8.769]    ABI class: X.Org Server Extension, version 10.0
[     8.769] (==) Matched modesetting as autoconfigured driver 0
[     8.769] (==) Matched fbdev as autoconfigured driver 1
[     8.769] (==) Matched vesa as autoconfigured driver 2
[     8.769] (==) Assigned the driver to the xf86ConfigLayout
[     8.769] (II) LoadModule: "modesetting"
[     8.769] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     8.772] (II) Module modesetting: vendor="X.Org Foundation"
[     8.772]    compiled for 1.21.1.9, module version = 1.21.1
[     8.772]    Module class: X.Org Video Driver
[     8.772]    ABI class: X.Org Video Driver, version 25.2
[     8.772] (II) LoadModule: "fbdev"
[     8.773] (WW) Warning, couldn't open module fbdev
[     8.773] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     8.773] (II) LoadModule: "vesa"
[     8.773] (WW) Warning, couldn't open module vesa
[     8.773] (EE) Failed to load module "vesa" (module does not exist, 0)
[     8.773] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     8.787] (II) modeset(0): using drv /dev/dri/card1
[     8.787] (II) modeset(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[     8.787] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[     8.787] (==) modeset(0): RGB weight 888
[     8.787] (==) modeset(0): Default visual is TrueColor
[     8.787] (II) Loading sub module "glamoregl"
[     8.787] (II) LoadModule: "glamoregl"
[     8.787] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     8.798] (II) Module glamoregl: vendor="X.Org Foundation"
[     8.798]    compiled for 1.21.1.9, module version = 1.0.1
[     8.798]    ABI class: X.Org ANSI C Emulation, version 0.4
[     8.999] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CFL GT2)
[     8.999] (II) modeset(0): glamor initialized
[     8.999] (==) modeset(0): VariableRefresh: disabled
[     8.999] (==) modeset(0): AsyncFlipSecondaries: disabled
[     9.027] (II) modeset(0): Output HDMI-1 has no monitor section
[     9.055] (II) modeset(0): Output HDMI-2 has no monitor section
[     9.055] (II) modeset(0): Output DP-1 has no monitor section
[     9.081] (II) modeset(0): Output HDMI-3 has no monitor section
[     9.109] (II) modeset(0): EDID for output HDMI-1
[     9.109] (II) modeset(0): Manufacturer: MED  Model: 36a2  Serial#: 16843009
[     9.109] (II) modeset(0): Year: 2013  Week: 0
[     9.109] (II) modeset(0): EDID Version: 1.3
[     9.109] (II) modeset(0): Digital Display Input
[     9.109] (II) modeset(0): DFP 1.x compatible TMDS
[     9.109] (II) modeset(0): Max Image Size [cm]: horiz.: 52  vert.: 29
[     9.109] (II) modeset(0): Gamma: 2.20
[     9.109] (II) modeset(0): DPMS capabilities: Off
[     9.109] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     9.109] (II) modeset(0): First detailed timing is preferred mode
[     9.109] (II) modeset(0): redX: 0.643 redY: 0.342   greenX: 0.317 greenY: 0.628
[     9.109] (II) modeset(0): blueX: 0.148 blueY: 0.064   whiteX: 0.313 whiteY: 0.329
[     9.109] (II) modeset(0): Supported established timings:
[     9.109] (II) modeset(0): 720x400@70Hz
[     9.109] (II) modeset(0): 640x480@60Hz
[     9.109] (II) modeset(0): 640x480@67Hz
[     9.109] (II) modeset(0): 640x480@72Hz
[     9.109] (II) modeset(0): 640x480@75Hz
[     9.109] (II) modeset(0): 800x600@56Hz
[     9.109] (II) modeset(0): 800x600@60Hz
[     9.109] (II) modeset(0): 800x600@72Hz
[     9.109] (II) modeset(0): 800x600@75Hz
[     9.109] (II) modeset(0): 832x624@75Hz
[     9.109] (II) modeset(0): 1024x768@60Hz
[     9.109] (II) modeset(0): 1024x768@70Hz
[     9.109] (II) modeset(0): 1024x768@75Hz
[     9.109] (II) modeset(0): 1280x1024@75Hz
[     9.109] (II) modeset(0): 1152x864@75Hz
[     9.109] (II) modeset(0): Manufacturer's mask: 0
[     9.109] (II) modeset(0): Supported standard timings:
[     9.109] (II) modeset(0): #0: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     9.109] (II) modeset(0): #1: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[     9.109] (II) modeset(0): #2: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     9.110] (II) modeset(0): #3: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[     9.110] (II) modeset(0): #4: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     9.110] (II) modeset(0): #5: hsize: 1440  vsize 900  refresh: 75  vid: 3989
[     9.110] (II) modeset(0): #6: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[     9.110] (II) modeset(0): #7: hsize: 1400  vsize 1050  refresh: 60  vid: 16528
[     9.110] (II) modeset(0): Supported detailed timing:
[     9.110] (II) modeset(0): clock: 148.5 MHz   Image Size:  521 x 293 mm
[     9.110] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     9.110] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     9.110] (II) modeset(0): clock: 85.5 MHz   Image Size:  521 x 293 mm
[     9.110] (II) modeset(0): h_active: 1360  h_sync: 1424  h_sync_end 1536 h_blank_end 1792 h_border: 0
[     9.110] (II) modeset(0): v_active: 768  v_sync: 771  v_sync_end 777 v_blanking: 795 v_border: 0
[     9.110] (II) modeset(0): Ranges: V min: 55 V max: 76 Hz, H min: 29 H max: 81 kHz, PixClock max 175 MHz
[     9.110] (II) modeset(0): Monitor name: MD 20430
[     9.110] (II) modeset(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[     9.110] (II) modeset(0): clock: 74.2 MHz   Image Size:  521 x 293 mm
[     9.110] (II) modeset(0): h_active: 1920  h_sync: 1936  h_sync_end 1980 h_blank_end 2640 h_border: 0
[     9.110] (II) modeset(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[     9.110] (II) modeset(0): h_active: 1280  h_sync: 1720  h_sync_end 1760 h_blank_end 1980 h_border: 0
[     9.110] (II) modeset(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[     9.110] (II) modeset(0): clock: 27.0 MHz   Image Size:  521 x 293 mm
[     9.110] (II) modeset(0): h_active: 720  h_sync: 732  h_sync_end 796 h_blank_end 864 h_border: 0
[     9.110] (II) modeset(0): v_active: 576  v_sync: 581  v_sync_end 586 v_blanking: 625 v_border: 0
[     9.110] (II) modeset(0): Number of EDID sections to follow: 1
[     9.110] (II) modeset(0): EDID (in hex):
[     9.110] (II) modeset(0):   00ffffffffffff0034a4a23601010101
[     9.110] (II) modeset(0):   0017010381341d782aa725a45751a026
[     9.110] (II) modeset(0):   105054bfef80b300a940950081408180
[     9.110] (II) modeset(0):   950f714f9040023a801871382d40582c
[     9.110] (II) modeset(0):   450009252100001e662150b051001b30
[     9.110] (II) modeset(0):   4070360009252100001e000000fd0037
[     9.110] (II) modeset(0):   4c1d5111000a202020202020000000fc
[     9.110] (II) modeset(0):   004d442032303433300a20202020014c
[     9.110] (II) modeset(0):   020322f14f9f14131211161510050403
[     9.110] (II) modeset(0):   02070601230907018301000065030c00
[     9.110] (II) modeset(0):   1000023a80d072382d40102c45800925
[     9.110] (II) modeset(0):   2100001f011d80d0721c1620102c2500
[     9.110] (II) modeset(0):   09252100009f011d00bc52d01e20b828
[     9.110] (II) modeset(0):   554009252100001e8c0ad09020403120
[     9.110] (II) modeset(0):   0c405500092521000018023a80187138
[     9.110] (II) modeset(0):   2d40582c450009252100001e0000009f
[     9.110] (II) modeset(0): Printing probed modes for output HDMI-1
[     9.110] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[     9.110] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     9.110] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     9.110] (II) modeset(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[     9.110] (II) modeset(0): Modeline "1920x1080i"x50.0   74.25  1920 1936 1980 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[     9.110] (II) modeset(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[     9.110] (II) modeset(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[     9.110] (II) modeset(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     9.110] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[     9.110] (II) modeset(0): Modeline "1400x1050"x59.9  101.00  1400 1448 1480 1560  1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[     9.110] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     9.110] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     9.110] (II) modeset(0): Modeline "1440x900"x75.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     9.110] (II) modeset(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     9.110] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     9.110] (II) modeset(0): Modeline "1360x768"x60.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[     9.110] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     9.110] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     9.110] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[     9.110] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     9.111] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     9.111] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     9.111] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     9.111] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     9.111] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     9.111] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     9.111] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     9.111] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     9.111] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     9.111] (II) modeset(0): Modeline "720x576i"x50.0   13.50  720 732 795 864  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[     9.111] (II) modeset(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     9.111] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     9.111] (II) modeset(0): Modeline "720x480i"x60.0   13.51  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[     9.111] (II) modeset(0): Modeline "720x480i"x59.9   13.50  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[     9.111] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     9.111] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[     9.111] (II) modeset(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     9.111] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     9.111] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     9.111] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     9.138] (II) Quirked EDID physical size to 0x0 cm
[     9.138] (II) modeset(0): EDID for output HDMI-2
[     9.138] (II) modeset(0): Manufacturer: SAM  Model: 3bc  Serial#: 0
[     9.138] (II) modeset(0): Year: 2007  Week: 47
[     9.138] (II) modeset(0): EDID Version: 1.3
[     9.138] (II) modeset(0): Digital Display Input
[     9.138] (II) modeset(0): Indeterminate output size
[     9.138] (II) modeset(0): Gamma: 2.20
[     9.138] (II) modeset(0): No DPMS capabilities specified
[     9.138] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     9.138] (II) modeset(0): First detailed timing is preferred mode
[     9.138] (II) modeset(0): redX: 0.640 redY: 0.330   greenX: 0.300 greenY: 0.600
[     9.138] (II) modeset(0): blueX: 0.150 blueY: 0.060   whiteX: 0.312 whiteY: 0.329
[     9.138] (II) modeset(0): Supported established timings:
[     9.138] (II) modeset(0): 640x480@60Hz
[     9.138] (II) modeset(0): 800x600@60Hz
[     9.138] (II) modeset(0): 1024x768@60Hz
[     9.138] (II) modeset(0): Manufacturer's mask: 0
[     9.138] (II) modeset(0): Supported standard timings:
[     9.138] (II) modeset(0): #0: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     9.138] (II) modeset(0): #1: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[     9.138] (II) modeset(0): Supported detailed timing:
[     9.138] (II) modeset(0): clock: 148.5 MHz   Image Size:  160 x 90 mm
[     9.138] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     9.138] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     9.138] (II) modeset(0): clock: 85.5 MHz   Image Size:  160 x 90 mm
[     9.138] (II) modeset(0): h_active: 1360  h_sync: 1424  h_sync_end 1536 h_blank_end 1792 h_border: 0
[     9.138] (II) modeset(0): v_active: 768  v_sync: 771  v_sync_end 777 v_blanking: 795 v_border: 0
[     9.138] (II) modeset(0): Ranges: V min: 23 V max: 61 Hz, H min: 26 H max: 76 kHz, PixClock max 235 MHz
[     9.138] (II) modeset(0): Monitor name: SAMSUNG
[     9.138] (II) modeset(0): clock: 74.2 MHz   Image Size:  160 x 90 mm
[     9.138] (II) modeset(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[     9.138] (II) modeset(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[     9.138] (II) modeset(0): h_active: 1280  h_sync: 1720  h_sync_end 1760 h_blank_end 1980 h_border: 0
[     9.138] (II) modeset(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[     9.138] (II) modeset(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[     9.138] (II) modeset(0): Number of EDID sections to follow: 1
[     9.139] (II) modeset(0): EDID (in hex):
[     9.139] (II) modeset(0):   00ffffffffffff004c2dbc0300000000
[     9.139] (II) modeset(0):   2f110103801009780aee91a3544c9926
[     9.139] (II) modeset(0):   0f50542108008180a940010101010101
[     9.139] (II) modeset(0):   010101010101023a801871382d40582c
[     9.139] (II) modeset(0):   4500a05a0000001e662150b051001b30
[     9.139] (II) modeset(0):   40703600a05a0000001e000000fd0017
[     9.139] (II) modeset(0):   3d1a4c17000a202020202020000000fc
[     9.139] (II) modeset(0):   0053414d53554e470a202020202001d3
[     9.139] (II) modeset(0):   020327f14b901f041305140312202122
[     9.139] (II) modeset(0):   2309070783010000e2000fe305030167
[     9.139] (II) modeset(0):   030c002000b82d011d007251d01e206e
[     9.139] (II) modeset(0):   285500a05a0000001e011d00bc52d01e
[     9.139] (II) modeset(0):   20b8285540a05a0000001e011d801871
[     9.139] (II) modeset(0):   1c1620582c2500a05a0000009e011d80
[     9.139] (II) modeset(0):   d0721c1620102c2580a05a0000009e00
[     9.139] (II) modeset(0):   0000000000000000000000000000000d
[     9.139] (--) modeset(0): HDMI max TMDS frequency 225000KHz
[     9.139] (II) modeset(0): Printing probed modes for output HDMI-2
[     9.139] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[     9.139] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080"x30.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080"x25.0   74.25  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080"x30.0   74.18  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[     9.139] (II) modeset(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     9.139] (II) modeset(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     9.139] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     9.139] (II) modeset(0): Modeline "1360x768"x60.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[     9.139] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     9.139] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[     9.139] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     9.139] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     9.139] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     9.139] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     9.139] (II) modeset(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     9.139] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     9.139] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     9.139] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     9.139] (II) modeset(0): EDID for output DP-1
[     9.165] (II) modeset(0): EDID for output HDMI-3
[     9.165] (II) modeset(0): Output HDMI-1 connected
[     9.165] (II) modeset(0): Output HDMI-2 connected
[     9.165] (II) modeset(0): Output DP-1 disconnected
[     9.165] (II) modeset(0): Output HDMI-3 disconnected
[     9.165] (II) modeset(0): Using spanning desktop for initial modes
[     9.165] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[     9.165] (II) modeset(0): Output HDMI-2 using initial mode 1920x1080 +1920+0
[     9.165] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[     9.165] (==) modeset(0): DPI set to (96, 96)
[     9.165] (II) Loading sub module "fb"
[     9.165] (II) LoadModule: "fb"
[     9.165] (II) Module "fb" already built-in
[     9.184] (==) modeset(0): Backing store enabled
[     9.184] (==) modeset(0): Silken mouse enabled
[     9.471] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[     9.471] (==) modeset(0): DPMS enabled
[     9.471] (II) modeset(0): [DRI2] Setup complete
[     9.471] (II) modeset(0): [DRI2]   DRI driver: iris
[     9.471] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[     9.471] (II) Initializing extension Generic Event Extension
[     9.472] (II) Initializing extension SHAPE
[     9.472] (II) Initializing extension MIT-SHM
[     9.472] (II) Initializing extension XInputExtension
[     9.473] (II) Initializing extension XTEST
[     9.473] (II) Initializing extension BIG-REQUESTS
[     9.474] (II) Initializing extension SYNC
[     9.474] (II) Initializing extension XKEYBOARD
[     9.474] (II) Initializing extension XC-MISC
[     9.475] (II) Initializing extension SECURITY
[     9.475] (II) Initializing extension XFIXES
[     9.475] (II) Initializing extension RENDER
[     9.476] (II) Initializing extension RANDR
[     9.476] (II) Initializing extension COMPOSITE
[     9.477] (II) Initializing extension DAMAGE
[     9.477] (II) Initializing extension MIT-SCREEN-SAVER
[     9.477] (II) Initializing extension DOUBLE-BUFFER
[     9.478] (II) Initializing extension RECORD
[     9.478] (II) Initializing extension DPMS
[     9.478] (II) Initializing extension Present
[     9.479] (II) Initializing extension DRI3
[     9.479] (II) Initializing extension X-Resource
[     9.479] (II) Initializing extension XVideo
[     9.479] (II) Initializing extension XVideo-MotionCompensation
[     9.480] (II) Initializing extension GLX
[     9.502] (II) AIGLX: Loaded and initialized iris
[     9.502] (II) GLX: Initialized DRI2 GL provider for screen 0
[     9.502] (II) Initializing extension XFree86-VidModeExtension
[     9.502] (II) Initializing extension XFree86-DGA
[     9.502] (II) Initializing extension XFree86-DRI
[     9.502] (II) Initializing extension DRI2
[     9.503] (II) modeset(0): Damage tracking initialized
[     9.503] (II) modeset(0): Setting screen physical size to 1016 x 285
[     9.566] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[     9.566] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     9.566] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     9.566] (**) Power Button: Applying InputClass "system-keyboard"
[     9.566] (II) LoadModule: "libinput"
[     9.566] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     9.569] (II) Module libinput: vendor="X.Org Foundation"
[     9.569]    compiled for 1.21.1.8, module version = 1.4.0
[     9.569]    Module class: X.Org XInput Driver
[     9.569]    ABI class: X.Org XInput driver, version 24.4
[     9.569] (II) Using input driver 'libinput' for 'Power Button'
[     9.569] (**) Power Button: always reports core events
[     9.569] (**) Option "Device" "/dev/input/event2"
[     9.572] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     9.572] (II) event2  - Power Button: device is a keyboard
[     9.572] (II) event2  - Power Button: device removed
[     9.593] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[     9.593] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     9.593] (**) Option "xkb_layout" "be"
[     9.593] (**) Option "xkb_variant" "nodeadkeys"
[     9.606] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     9.606] (II) event2  - Power Button: device is a keyboard
[     9.606] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[     9.606] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     9.606] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     9.606] (**) Video Bus: Applying InputClass "system-keyboard"
[     9.606] (II) Using input driver 'libinput' for 'Video Bus'
[     9.606] (**) Video Bus: always reports core events
[     9.606] (**) Option "Device" "/dev/input/event10"
[     9.607] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[     9.607] (II) event10 - Video Bus: device is a keyboard
[     9.607] (II) event10 - Video Bus: device removed
[     9.707] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input11/event10"
[     9.707] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     9.707] (**) Option "xkb_layout" "be"
[     9.707] (**) Option "xkb_variant" "nodeadkeys"
[     9.711] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[     9.711] (II) event10 - Video Bus: device is a keyboard
[     9.713] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     9.713] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     9.713] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     9.713] (**) Power Button: Applying InputClass "system-keyboard"
[     9.713] (II) Using input driver 'libinput' for 'Power Button'
[     9.713] (**) Power Button: always reports core events
[     9.713] (**) Option "Device" "/dev/input/event1"
[     9.716] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     9.716] (II) event1  - Power Button: device is a keyboard
[     9.717] (II) event1  - Power Button: device removed
[     9.740] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     9.740] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[     9.740] (**) Option "xkb_layout" "be"
[     9.740] (**) Option "xkb_variant" "nodeadkeys"
[     9.744] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     9.744] (II) event1  - Power Button: device is a keyboard
[     9.746] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[     9.746] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     9.746] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     9.746] (**) Sleep Button: Applying InputClass "system-keyboard"
[     9.746] (II) Using input driver 'libinput' for 'Sleep Button'
[     9.746] (**) Sleep Button: always reports core events
[     9.747] (**) Option "Device" "/dev/input/event0"
[     9.749] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     9.750] (II) event0  - Sleep Button: device is a keyboard
[     9.750] (II) event0  - Sleep Button: device removed
[     9.776] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[     9.777] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[     9.777] (**) Option "xkb_layout" "be"
[     9.777] (**) Option "xkb_variant" "nodeadkeys"
[     9.780] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     9.780] (II) event0  - Sleep Button: device is a keyboard
[     9.785] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event4)
[     9.785] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[     9.785] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[     9.785] (**) Logitech USB Keyboard: Applying InputClass "system-keyboard"
[     9.785] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[     9.785] (**) Logitech USB Keyboard: always reports core events
[     9.785] (**) Option "Device" "/dev/input/event4"
[     9.790] (II) event4  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[     9.790] (II) event4  - Logitech USB Keyboard: device is a keyboard
[     9.791] (II) event4  - Logitech USB Keyboard: device removed
[     9.813] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:046D:C31C.0001/input/input4/event4"
[     9.813] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 10)
[     9.813] (**) Option "xkb_layout" "be"
[     9.813] (**) Option "xkb_variant" "nodeadkeys"
[     9.819] (II) event4  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[     9.819] (II) event4  - Logitech USB Keyboard: device is a keyboard
[     9.823] (II) config/udev: Adding input device Logitech USB Keyboard Consumer Control (/dev/input/event5)
[     9.823] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[     9.823] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[     9.823] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[     9.823] (II) Using input driver 'libinput' for 'Logitech USB Keyboard Consumer Control'
[     9.823] (**) Logitech USB Keyboard Consumer Control: always reports core events
[     9.823] (**) Option "Device" "/dev/input/event5"
[     9.828] (II) event5  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     9.828] (II) event5  - Logitech USB Keyboard Consumer Control: device is a keyboard
[     9.828] (II) event5  - Logitech USB Keyboard Consumer Control: device removed
[     9.866] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C31C.0002/input/input5/event5"
[     9.867] (II) XINPUT: Adding extended input device "Logitech USB Keyboard Consumer Control" (type: KEYBOARD, id 11)
[     9.867] (**) Option "xkb_layout" "be"
[     9.867] (**) Option "xkb_variant" "nodeadkeys"
[     9.872] (II) event5  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[     9.873] (II) event5  - Logitech USB Keyboard Consumer Control: device is a keyboard
[     9.876] (II) config/udev: Adding input device Logitech USB Keyboard System Control (/dev/input/event6)
[     9.877] (**) Logitech USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[     9.877] (**) Logitech USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[     9.877] (**) Logitech USB Keyboard System Control: Applying InputClass "system-keyboard"
[     9.877] (II) Using input driver 'libinput' for 'Logitech USB Keyboard System Control'
[     9.877] (**) Logitech USB Keyboard System Control: always reports core events
[     9.877] (**) Option "Device" "/dev/input/event6"
[     9.881] (II) event6  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[     9.882] (II) event6  - Logitech USB Keyboard System Control: device is a keyboard
[     9.882] (II) event6  - Logitech USB Keyboard System Control: device removed
[     9.903] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:046D:C31C.0002/input/input6/event6"
[     9.903] (II) XINPUT: Adding extended input device "Logitech USB Keyboard System Control" (type: KEYBOARD, id 12)
[     9.903] (**) Option "xkb_layout" "be"
[     9.903] (**) Option "xkb_variant" "nodeadkeys"
[     9.909] (II) event6  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[     9.909] (II) event6  - Logitech USB Keyboard System Control: device is a keyboard
[     9.913] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse (/dev/input/event7)
[     9.913] (**) YICHIP TrustWireless Silent Mouse: Applying InputClass "evdev pointer catchall"
[     9.913] (**) YICHIP TrustWireless Silent Mouse: Applying InputClass "libinput pointer catchall"
[     9.913] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse'
[     9.913] (**) YICHIP TrustWireless Silent Mouse: always reports core events
[     9.913] (**) Option "Device" "/dev/input/event7"
[     9.918] (II) event7  - YICHIP TrustWireless Silent Mouse: is tagged by udev as: Mouse
[     9.918] (II) event7  - YICHIP TrustWireless Silent Mouse: device is a pointer
[     9.919] (II) event7  - YICHIP TrustWireless Silent Mouse: device removed
[     9.966] (II) libinput: YICHIP TrustWireless Silent Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[     9.967] (II) libinput: YICHIP TrustWireless Silent Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[     9.967] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:145F:021F.0004/input/input7/event7"
[     9.967] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse" (type: MOUSE, id 13)
[     9.967] (**) Option "AccelerationScheme" "none"
[     9.967] (**) YICHIP TrustWireless Silent Mouse: (accel) selected scheme none/0
[     9.967] (**) YICHIP TrustWireless Silent Mouse: (accel) acceleration factor: 2.000
[     9.967] (**) YICHIP TrustWireless Silent Mouse: (accel) acceleration threshold: 4
[     9.972] (II) event7  - YICHIP TrustWireless Silent Mouse: is tagged by udev as: Mouse
[     9.973] (II) event7  - YICHIP TrustWireless Silent Mouse: device is a pointer
[     9.976] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse (/dev/input/mouse0)
[     9.976] (II) No input driver specified, ignoring this device.
[     9.977] (II) This device may have been added with another device file.
[     9.980] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse System Control (/dev/input/event8)
[     9.980] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "evdev keyboard catchall"
[     9.980] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "libinput keyboard catchall"
[     9.980] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "system-keyboard"
[     9.980] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse System Control'
[     9.980] (**) YICHIP TrustWireless Silent Mouse System Control: always reports core events
[     9.980] (**) Option "Device" "/dev/input/event8"
[     9.985] (II) event8  - YICHIP TrustWireless Silent Mouse System Control: is tagged by udev as: Keyboard
[     9.985] (II) event8  - YICHIP TrustWireless Silent Mouse System Control: device is a keyboard
[     9.985] (II) event8  - YICHIP TrustWireless Silent Mouse System Control: device removed
[    10.003] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:145F:021F.0004/input/input8/event8"
[    10.003] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse System Control" (type: KEYBOARD, id 14)
[    10.003] (**) Option "xkb_layout" "be"
[    10.004] (**) Option "xkb_variant" "nodeadkeys"
[    10.009] (II) event8  - YICHIP TrustWireless Silent Mouse System Control: is tagged by udev as: Keyboard
[    10.009] (II) event8  - YICHIP TrustWireless Silent Mouse System Control: device is a keyboard
[    10.012] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse Consumer Control (/dev/input/event9)
[    10.012] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[    10.012] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    10.012] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "system-keyboard"
[    10.013] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse Consumer Control'
[    10.013] (**) YICHIP TrustWireless Silent Mouse Consumer Control: always reports core events
[    10.013] (**) Option "Device" "/dev/input/event9"
[    10.017] (II) event9  - YICHIP TrustWireless Silent Mouse Consumer Control: is tagged by udev as: Keyboard
[    10.018] (II) event9  - YICHIP TrustWireless Silent Mouse Consumer Control: device is a keyboard
[    10.018] (II) event9  - YICHIP TrustWireless Silent Mouse Consumer Control: device removed
[    10.040] (II) libinput: YICHIP TrustWireless Silent Mouse Consumer Control: needs a virtual subdevice
[    10.040] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:145F:021F.0004/input/input9/event9"
[    10.040] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse Consumer Control" (type: MOUSE, id 15)
[    10.040] (**) Option "AccelerationScheme" "none"
[    10.040] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) selected scheme none/0
[    10.040] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) acceleration factor: 2.000
[    10.040] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) acceleration threshold: 4
[    10.045] (II) event9  - YICHIP TrustWireless Silent Mouse Consumer Control: is tagged by udev as: Keyboard
[    10.046] (II) event9  - YICHIP TrustWireless Silent Mouse Consumer Control: device is a keyboard
[    10.047] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event11)
[    10.048] (II) No input driver specified, ignoring this device.
[    10.048] (II) This device may have been added with another device file.
[    10.049] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[    10.049] (II) No input driver specified, ignoring this device.
[    10.049] (II) This device may have been added with another device file.
[    10.050] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[    10.050] (II) No input driver specified, ignoring this device.
[    10.050] (II) This device may have been added with another device file.
[    10.052] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event14)
[    10.052] (II) No input driver specified, ignoring this device.
[    10.052] (II) This device may have been added with another device file.
[    10.053] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event15)
[    10.053] (II) No input driver specified, ignoring this device.
[    10.053] (II) This device may have been added with another device file.
[    10.054] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event16)
[    10.054] (II) No input driver specified, ignoring this device.
[    10.054] (II) This device may have been added with another device file.
[    10.056] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event17)
[    10.056] (II) No input driver specified, ignoring this device.
[    10.056] (II) This device may have been added with another device file.
[    10.057] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event18)
[    10.057] (II) No input driver specified, ignoring this device.
[    10.057] (II) This device may have been added with another device file.
[    10.058] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[    10.058] (II) No input driver specified, ignoring this device.
[    10.058] (II) This device may have been added with another device file.
[    10.103] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[    10.103] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    10.103] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "system-keyboard"
[    10.103] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse Consumer Control'
[    10.103] (**) YICHIP TrustWireless Silent Mouse Consumer Control: always reports core events
[    10.103] (**) Option "Device" "/dev/input/event9"
[    10.103] (II) libinput: YICHIP TrustWireless Silent Mouse Consumer Control: is a virtual subdevice
[    10.103] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:145F:021F.0004/input/input9/event9"
[    10.103] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse Consumer Control" (type: KEYBOARD, id 16)
[    10.103] (**) Option "xkb_layout" "be"
[    10.103] (**) Option "xkb_variant" "nodeadkeys"
[    10.785] (II) event2  - Power Button: device removed
[    10.823] (II) event10 - Video Bus: device removed
[    10.863] (II) event1  - Power Button: device removed
[    10.896] (II) event0  - Sleep Button: device removed
[    10.920] (II) event4  - Logitech USB Keyboard: device removed
[    10.937] (II) event5  - Logitech USB Keyboard Consumer Control: device removed
[    10.970] (II) event6  - Logitech USB Keyboard System Control: device removed
[    10.987] (II) event7  - YICHIP TrustWireless Silent Mouse: device removed
[    11.020] (II) event8  - YICHIP TrustWireless Silent Mouse System Control: device removed
[    11.037] (II) event9  - YICHIP TrustWireless Silent Mouse Consumer Control: device removed
[    11.053] (II) AIGLX: Suspending AIGLX clients for VT switch
Moderator edit: Fixed formatting
Thx Mod for formatting…I myself was doing it at the same time but you were the quickest :smile:
Well given that Acer seems to have stopped supporting that model in 2020 the first thing I’d try is an older kernel like 6.1 LTS or 5.15 LTS and see if the issue still happens there.
Will do with next reboot, which won’t be long since pipewire started playing up and being not deaf this is annoying to say the least.
Will report later…
EDIT: I thought that newer kernels were older ones with new stuff added.
Maybe a too simple thought but kinda difficult to grasp.
If someone would like to explain in a short understandable alinea…
Not just added, sometimes things are changed to work better at the price of requiring modern hardware. That’s why older LTS kernels are still maintained, to support hardware that doesn’t meet newer kernel requirements.
It’s also possible that newer kernels have newer bugs which only affect older hardware. In that case it will likely get fixed at some point.
I don’t know for sure that this is your problem but;
  • You have a problem which seems to be BIOS related
  • Acer stopped providing BIOS updates for that system in 2020
  • So the first step in solving your problem is to see if it is specific to the latest kernel or not
Good news people,
I dismantled my pc almost completly…removed some stuff, added some, cleaned it and screwed in some bolts that were originally to hold the outer case on the inner frame (where needed - thought having the pc look complete for the BIOS would matter) and behold…instant fix.
I even gained some UEFI capabillities it now seems.
Don’t know if this matters but I turned all options under power saving settings to disabled, even deep sleep power and restore to X state when AC power loss occurs.
VR and SYS fan disabled
Intel AES-NI left disabled and sha1sum aswell.
Don’t know if I did something that improves or decreases performance or disable any abbilty that matters but for now = OK!
I’ll provide some more logs for the interested
  Kernel: 6.1.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    microcode: 0xF4
  Speed (MHz): avg: 800 min/max: 800/4600 base/boost: 3200/8300 scaling:
    driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
    10: 800 11: 800 12: 800 bogomips: 76831
    vulnerable
    empty: DP-1,HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e92
    class-ID: 0300
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95") monitors: <missing: xrandr>
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: ALSA v: k6.1.62-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.85 status: off with: 1: pipewire-pulse
    status: active 2: wireplumber status: off 3: pipewire-alsa type: plugin
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.52 TiB used: 609.88 GiB (23.6%)
    fw-rev: 2B2QEXM7 temp: 27.9 C scheme: GPT
  SMART: yes health: PASSED on: 120d 21h cycles: 2,019
    read-units: 22,388,443 [11.4 TB] written-units: 35,258,213 [18.0 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
    family: based SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 4B6Q temp: 28 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 175d 13h cycles: 2101
    written: 10.47 TiB
  ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA100 family: 3.5"
    serial: <filter> fw-rev: A8K0 temp: 30 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 3y 114d 20h cycles: 2892
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000LM035-1RK172
    serial: <filter> fw-rev: ACM1 temp: 26 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 254d 5h cycles: 3515
    read: 19.03 TiB written: 20.91 TiB Old-Age: g-sense error rate: 568 Pre-Fail:
  ID-5: /dev/sdd maj-min: 8:48 model: USB Flash Memory size: 7.27 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: PMAP scheme: MBR
  ID-6: /dev/sdf maj-min: 8:80 model: USB DISK 3.0 size: 14.46 GiB
    scheme: MBR
    used: 42.46 GiB (18.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2
    maj-min: 259:1
    maj-min: 259:2
    maj-min: 259:2
  ID-1: swap-1 type: file size: 512 MiB used: 24.5 MiB (4.8%) priority: -2
  System Temperatures: cpu: 31.0 C pch: 54.0 C mobo: N/A
  Processes: 318 Uptime: 5h 59m wakeups: 0 Memory: total: 16 GiB
  available: 15.5 GiB used: 3.99 GiB (25.8%) igpu: 32 MiB Init: systemd v: 254
  Packages: pm: pacman pkgs: 1211 libs: 353 tools: pamac Shell: Sudo (sudo)
[    0.091354] x86/cpu: SGX disabled by BIOS.
[    0.103321] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.103321] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.103321]   #7  #8  #9 #10 #11
[    0.111335] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.567501] hpet_acpi_add: no address or irqs in _CRS
[    0.963168] ata1.00: supports DRM functions and may not be fully accessible
[    0.968317] ata1.00: supports DRM functions and may not be fully accessible
[    1.538482] usb: port power management may be unreliable
[    1.550499] nvme nvme0: missing or invalid SUBNQN field.
[    4.311876] BTRFS error (device nvme0n1p2: state M): unrecognized mount option 'fstrim.timer'
[    4.525486] systemd[1]: systemd-remount-fs.service: Failed with result 'exit-code'.
[    4.540868] systemd[1]: Failed to start Remount Root and Kernel File Systems.
[    5.196971] mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x400000
[19971.278758] sd 8:0:0:0: [sdf] No Caching mode page found
[19971.278760] sd 8:0:0:0: [sdf] Assuming drive cache: write through
[    10.305] (--) Log file renamed from "/var/log/Xorg.pid-674.log" to "/var/log/Xorg.0.log"
[    10.306]
[    10.306] Current Operating System: Linux janduchau-aspiretc885 6.1.62-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Nov  9 03:01:44 UTC 2023 x86_64
[    10.306] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64 root=UUID=dabf4e5f-0262-4d90-8c13-b4f3d2cf37ac rw rootflags=subvol=@ nowatchdog quiet splash udev.log_priority=3
[    10.306]
[    10.306] Current version of pixman: 0.42.2
[    10.306]    Before reporting problems, check http://wiki.x.org
[    10.306] Markers: (--) probed, (**) from config file, (==) default setting,
[    10.306] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Nov 24 18:24:38 2023
[    10.307] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    10.307] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    10.307] (==) No Layout section.  Using the first Screen section.
[    10.307] (==) No screen section available. Using defaults.
[    10.307] (**) |-->Screen "Default Screen Section" (0)
[    10.307] (**) |   |-->Monitor "<default monitor>"
[    10.307] (==) No monitor specified for screen "Default Screen Section".
[    10.307] (==) Automatically adding devices
[    10.307] (==) Automatically enabling devices
[    10.307] (==) Automatically adding GPU devices
[    10.307] (==) Automatically binding GPU devices
[    10.307] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    10.308] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    10.308]    Entry deleted from font path.
[    10.308] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    10.308] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    10.308] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    10.308] (==) FontPath set to:
[    10.308] (==) ModulePath set to "/usr/lib/xorg/modules"
[    10.308] (II) The server relies on udev to provide the list of input devices.
[    10.308] (II) Module ABI versions:
[    10.308]    X.Org ANSI C Emulation: 0.4
[    10.308]    X.Org Video Driver: 25.2
[    10.308]    X.Org XInput driver : 24.4
[    10.308]    X.Org Server Extension : 10.0
[    10.308] (++) using VT number 2
[    10.308] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    10.309] (II) xfree86: Adding drm device (/dev/dri/card0)
[    10.309] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[    10.311] (--) PCI:*(0@0:2:0) 8086:3e92:1025:1238 rev 0, Mem @ 0xa1000000/16777216, 0x90000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[    10.311] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    10.311] (II) LoadModule: "glx"
[    10.312] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    10.315] (II) Module glx: vendor="X.Org Foundation"
[    10.315]    compiled for 1.21.1.9, module version = 1.0.0
[    10.315]    ABI class: X.Org Server Extension, version 10.0
[    10.315] (==) Matched modesetting as autoconfigured driver 0
[    10.315] (==) Matched fbdev as autoconfigured driver 1
[    10.315] (==) Matched vesa as autoconfigured driver 2
[    10.315] (==) Assigned the driver to the xf86ConfigLayout
[    10.315] (II) LoadModule: "modesetting"
[    10.315] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    10.317] (II) Module modesetting: vendor="X.Org Foundation"
[    10.317]    compiled for 1.21.1.9, module version = 1.21.1
[    10.317]    Module class: X.Org Video Driver
[    10.317]    ABI class: X.Org Video Driver, version 25.2
[    10.317] (II) LoadModule: "fbdev"
[    10.317] (WW) Warning, couldn't open module fbdev
[    10.317] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    10.317] (II) LoadModule: "vesa"
[    10.317] (WW) Warning, couldn't open module vesa
[    10.317] (EE) Failed to load module "vesa" (module does not exist, 0)
[    10.317] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    10.327] (II) modeset(0): using drv /dev/dri/card0
[    10.327] (II) modeset(0): Creating default Display subsection in Screen section
[    10.327] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    10.327] (==) modeset(0): RGB weight 888
[    10.327] (==) modeset(0): Default visual is TrueColor
[    10.327] (II) Loading sub module "glamoregl"
[    10.327] (II) LoadModule: "glamoregl"
[    10.327] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    10.331] (II) Module glamoregl: vendor="X.Org Foundation"
[    10.331]    compiled for 1.21.1.9, module version = 1.0.1
[    10.331]    ABI class: X.Org ANSI C Emulation, version 0.4
[    10.445] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CFL GT2)
[    10.445] (II) modeset(0): glamor initialized
[    10.445] (==) modeset(0): VariableRefresh: disabled
[    10.445] (==) modeset(0): AsyncFlipSecondaries: disabled
[    10.473] (II) modeset(0): Output HDMI-1 has no monitor section
[    10.482] (II) modeset(0): Output HDMI-2 has no monitor section
[    10.482] (II) modeset(0): Output DP-1 has no monitor section
[    10.516] (II) modeset(0): Output HDMI-3 has no monitor section
[    10.544] (II) modeset(0): EDID for output HDMI-1
[    10.544] (II) modeset(0): Manufacturer: MED  Model: 36a2  Serial#: 16843009
[    10.544] (II) modeset(0): Year: 2013  Week: 0
[    10.544] (II) modeset(0): EDID Version: 1.3
[    10.544] (II) modeset(0): Digital Display Input
[    10.544] (II) modeset(0): DFP 1.x compatible TMDS
[    10.544] (II) modeset(0): Max Image Size [cm]: horiz.: 52  vert.: 29
[    10.544] (II) modeset(0): Gamma: 2.20
[    10.544] (II) modeset(0): DPMS capabilities: Off
[    10.544] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    10.544] (II) modeset(0): First detailed timing is preferred mode
[    10.544] (II) modeset(0): redX: 0.643 redY: 0.342   greenX: 0.317 greenY: 0.628
[    10.544] (II) modeset(0): blueX: 0.148 blueY: 0.064   whiteX: 0.313 whiteY: 0.329
[    10.544] (II) modeset(0): Supported established timings:
[    10.544] (II) modeset(0): 720x400@70Hz
[    10.544] (II) modeset(0): 640x480@60Hz
[    10.544] (II) modeset(0): 640x480@67Hz
[    10.544] (II) modeset(0): 640x480@72Hz
[    10.544] (II) modeset(0): 640x480@75Hz
[    10.544] (II) modeset(0): 800x600@56Hz
[    10.544] (II) modeset(0): 800x600@60Hz
[    10.544] (II) modeset(0): 800x600@72Hz
[    10.544] (II) modeset(0): 800x600@75Hz
[    10.544] (II) modeset(0): 832x624@75Hz
[    10.544] (II) modeset(0): 1024x768@60Hz
[    10.544] (II) modeset(0): 1024x768@70Hz
[    10.544] (II) modeset(0): 1024x768@75Hz
[    10.544] (II) modeset(0): 1280x1024@75Hz
[    10.544] (II) modeset(0): 1152x864@75Hz
[    10.544] (II) modeset(0): Manufacturer's mask: 0
[    10.544] (II) modeset(0): Supported standard timings:
[    10.544] (II) modeset(0): #0: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[    10.544] (II) modeset(0): #1: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
[    10.544] (II) modeset(0): #2: hsize: 1440  vsize 900  refresh: 60  vid: 149
[    10.544] (II) modeset(0): #3: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[    10.544] (II) modeset(0): #4: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    10.544] (II) modeset(0): #5: hsize: 1440  vsize 900  refresh: 75  vid: 3989
[    10.544] (II) modeset(0): #6: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[    10.544] (II) modeset(0): #7: hsize: 1400  vsize 1050  refresh: 60  vid: 16528
[    10.544] (II) modeset(0): Supported detailed timing:
[    10.544] (II) modeset(0): clock: 148.5 MHz   Image Size:  521 x 293 mm
[    10.544] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[    10.544] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    10.544] (II) modeset(0): clock: 85.5 MHz   Image Size:  521 x 293 mm
[    10.544] (II) modeset(0): h_active: 1360  h_sync: 1424  h_sync_end 1536 h_blank_end 1792 h_border: 0
[    10.544] (II) modeset(0): v_active: 768  v_sync: 771  v_sync_end 777 v_blanking: 795 v_border: 0
[    10.544] (II) modeset(0): Ranges: V min: 55 V max: 76 Hz, H min: 29 H max: 81 kHz, PixClock max 175 MHz
[    10.544] (II) modeset(0): Monitor name: MD 20430
[    10.544] (II) modeset(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[    10.544] (II) modeset(0): clock: 74.2 MHz   Image Size:  521 x 293 mm
[    10.544] (II) modeset(0): h_active: 1920  h_sync: 1936  h_sync_end 1980 h_blank_end 2640 h_border: 0
[    10.544] (II) modeset(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[    10.544] (II) modeset(0): h_active: 1280  h_sync: 1720  h_sync_end 1760 h_blank_end 1980 h_border: 0
[    10.544] (II) modeset(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[    10.544] (II) modeset(0): clock: 27.0 MHz   Image Size:  521 x 293 mm
[    10.544] (II) modeset(0): h_active: 720  h_sync: 732  h_sync_end 796 h_blank_end 864 h_border: 0
[    10.544] (II) modeset(0): v_active: 576  v_sync: 581  v_sync_end 586 v_blanking: 625 v_border: 0
[    10.544] (II) modeset(0): Number of EDID sections to follow: 1
[    10.544] (II) modeset(0): EDID (in hex):
[    10.544] (II) modeset(0):   00ffffffffffff0034a4a23601010101
[    10.544] (II) modeset(0):   0017010381341d782aa725a45751a026
[    10.544] (II) modeset(0):   105054bfef80b300a940950081408180
[    10.544] (II) modeset(0):   950f714f9040023a801871382d40582c
[    10.544] (II) modeset(0):   450009252100001e662150b051001b30
[    10.544] (II) modeset(0):   4070360009252100001e000000fd0037
[    10.544] (II) modeset(0):   4c1d5111000a202020202020000000fc
[    10.545] (II) modeset(0):   004d442032303433300a20202020014c
[    10.545] (II) modeset(0):   020322f14f9f14131211161510050403
[    10.545] (II) modeset(0):   02070601230907018301000065030c00
[    10.545] (II) modeset(0):   1000023a80d072382d40102c45800925
[    10.545] (II) modeset(0):   2100001f011d80d0721c1620102c2500
[    10.545] (II) modeset(0):   09252100009f011d00bc52d01e20b828
[    10.545] (II) modeset(0):   554009252100001e8c0ad09020403120
[    10.545] (II) modeset(0):   0c405500092521000018023a80187138
[    10.545] (II) modeset(0):   2d40582c450009252100001e0000009f
[    10.545] (II) modeset(0): Printing probed modes for output HDMI-1
[    10.545] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    10.545] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    10.545] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[    10.545] (II) modeset(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[    10.545] (II) modeset(0): Modeline "1920x1080i"x50.0   74.25  1920 1936 1980 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    10.545] (II) modeset(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    10.545] (II) modeset(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[    10.545] (II) modeset(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[    10.545] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    10.545] (II) modeset(0): Modeline "1400x1050"x59.9  101.00  1400 1448 1480 1560  1050 1053 1057 1080 +hsync -vsync (64.7 kHz e)
[    10.545] (II) modeset(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    10.545] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    10.545] (II) modeset(0): Modeline "1440x900"x75.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[    10.545] (II) modeset(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    10.545] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[    10.545] (II) modeset(0): Modeline "1360x768"x60.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[    10.545] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    10.545] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    10.545] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    10.545] (II) modeset(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    10.545] (II) modeset(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    10.545] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    10.545] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    10.545] (II) modeset(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    10.545] (II) modeset(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    10.545] (II) modeset(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    10.545] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    10.545] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    10.545] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    10.545] (II) modeset(0): Modeline "720x576i"x50.0   13.50  720 732 795 864  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[    10.545] (II) modeset(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    10.545] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    10.545] (II) modeset(0): Modeline "720x480i"x60.0   13.51  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[    10.545] (II) modeset(0): Modeline "720x480i"x59.9   13.50  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[    10.545] (II) modeset(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    10.545] (II) modeset(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    10.545] (II) modeset(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    10.545] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    10.545] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    10.545] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    10.554] (II) modeset(0): EDID for output HDMI-2
[    10.554] (II) modeset(0): EDID for output DP-1
[    10.590] (II) modeset(0): EDID for output HDMI-3
[    10.590] (II) modeset(0): Output HDMI-1 connected
[    10.590] (II) modeset(0): Output HDMI-2 disconnected
[    10.590] (II) modeset(0): Output DP-1 disconnected
[    10.590] (II) modeset(0): Output HDMI-3 disconnected
[    10.590] (II) modeset(0): Using exact sizes for initial modes
[    10.590] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[    10.590] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    10.590] (==) modeset(0): DPI set to (96, 96)
[    10.590] (II) Loading sub module "fb"
[    10.590] (II) LoadModule: "fb"
[    10.590] (II) Module "fb" already built-in
[    10.601] (==) modeset(0): Backing store enabled
[    10.601] (==) modeset(0): Silken mouse enabled
[    10.743] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    10.743] (==) modeset(0): DPMS enabled
[    10.744] (II) modeset(0): [DRI2] Setup complete
[    10.744] (II) modeset(0): [DRI2]   DRI driver: iris
[    10.744] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[    10.744] (II) Initializing extension Generic Event Extension
[    10.744] (II) Initializing extension SHAPE
[    10.744] (II) Initializing extension MIT-SHM
[    10.744] (II) Initializing extension XInputExtension
[    10.744] (II) Initializing extension XTEST
[    10.744] (II) Initializing extension BIG-REQUESTS
[    10.744] (II) Initializing extension SYNC
[    10.744] (II) Initializing extension XKEYBOARD
[    10.744] (II) Initializing extension XC-MISC
[    10.744] (II) Initializing extension SECURITY
[    10.744] (II) Initializing extension XFIXES
[    10.744] (II) Initializing extension RENDER
[    10.744] (II) Initializing extension RANDR
[    10.744] (II) Initializing extension COMPOSITE
[    10.744] (II) Initializing extension DAMAGE
[    10.745] (II) Initializing extension MIT-SCREEN-SAVER
[    10.745] (II) Initializing extension DOUBLE-BUFFER
[    10.745] (II) Initializing extension RECORD
[    10.745] (II) Initializing extension DPMS
[    10.745] (II) Initializing extension Present
[    10.745] (II) Initializing extension DRI3
[    10.745] (II) Initializing extension X-Resource
[    10.745] (II) Initializing extension XVideo
[    10.745] (II) Initializing extension XVideo-MotionCompensation
[    10.745] (II) Initializing extension GLX
[    10.750] (II) AIGLX: Loaded and initialized iris
[    10.750] (II) GLX: Initialized DRI2 GL provider for screen 0
[    10.750] (II) Initializing extension XFree86-VidModeExtension
[    10.750] (II) Initializing extension XFree86-DGA
[    10.750] (II) Initializing extension XFree86-DRI
[    10.750] (II) Initializing extension DRI2
[    10.750] (II) modeset(0): Damage tracking initialized
[    10.750] (II) modeset(0): Setting screen physical size to 508 x 285
[    10.791] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    10.791] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    10.791] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    10.791] (**) Power Button: Applying InputClass "system-keyboard"
[    10.791] (II) LoadModule: "libinput"
[    10.791] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    10.794] (II) Module libinput: vendor="X.Org Foundation"
[    10.794]    compiled for 1.21.1.8, module version = 1.4.0
[    10.794]    Module class: X.Org XInput Driver
[    10.794]    ABI class: X.Org XInput driver, version 24.4
[    10.794] (II) Using input driver 'libinput' for 'Power Button'
[    10.794] (**) Power Button: always reports core events
[    10.794] (**) Option "Device" "/dev/input/event2"
[    10.798] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    10.798] (II) event2  - Power Button: device is a keyboard
[    10.798] (II) event2  - Power Button: device removed
[    10.820] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    10.820] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    10.820] (**) Option "xkb_layout" "be"
[    10.820] (**) Option "xkb_variant" "nodeadkeys"
[    10.832] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    10.832] (II) event2  - Power Button: device is a keyboard
[    10.833] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[    10.833] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    10.833] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    10.833] (**) Video Bus: Applying InputClass "system-keyboard"
[    10.833] (II) Using input driver 'libinput' for 'Video Bus'
[    10.833] (**) Video Bus: always reports core events
[    10.833] (**) Option "Device" "/dev/input/event10"
[    10.833] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    10.833] (II) event10 - Video Bus: device is a keyboard
[    10.834] (II) event10 - Video Bus: device removed
[    10.876] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input11/event10"
[    10.876] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    10.876] (**) Option "xkb_layout" "be"
[    10.877] (**) Option "xkb_variant" "nodeadkeys"
[    10.877] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    10.877] (II) event10 - Video Bus: device is a keyboard
[    10.878] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    10.878] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    10.878] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    10.878] (**) Power Button: Applying InputClass "system-keyboard"
[    10.878] (II) Using input driver 'libinput' for 'Power Button'
[    10.878] (**) Power Button: always reports core events
[    10.878] (**) Option "Device" "/dev/input/event1"
[    10.878] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    10.878] (II) event1  - Power Button: device is a keyboard
[    10.878] (II) event1  - Power Button: device removed
[    10.893] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[    10.893] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    10.893] (**) Option "xkb_layout" "be"
[    10.893] (**) Option "xkb_variant" "nodeadkeys"
[    10.894] (II) event1  - Power Button: is tagged by udev as: Keyboard
[    10.894] (II) event1  - Power Button: device is a keyboard
[    10.894] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[    10.894] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    10.894] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    10.894] (**) Sleep Button: Applying InputClass "system-keyboard"
[    10.894] (II) Using input driver 'libinput' for 'Sleep Button'
[    10.894] (**) Sleep Button: always reports core events
[    10.894] (**) Option "Device" "/dev/input/event0"
[    10.895] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[    10.895] (II) event0  - Sleep Button: device is a keyboard
[    10.895] (II) event0  - Sleep Button: device removed
[    10.910] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[    10.910] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    10.910] (**) Option "xkb_layout" "be"
[    10.910] (**) Option "xkb_variant" "nodeadkeys"
[    10.911] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[    10.911] (II) event0  - Sleep Button: device is a keyboard
[    10.912] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event3)
[    10.912] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    10.912] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    10.912] (**) Logitech USB Keyboard: Applying InputClass "system-keyboard"
[    10.912] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[    10.912] (**) Logitech USB Keyboard: always reports core events
[    10.912] (**) Option "Device" "/dev/input/event3"
[    10.913] (II) event3  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[    10.913] (II) event3  - Logitech USB Keyboard: device is a keyboard
[    10.913] (II) event3  - Logitech USB Keyboard: device removed
[    10.927] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:046D:C31C.0001/input/input3/event3"
[    10.927] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 10)
[    10.927] (**) Option "xkb_layout" "be"
[    10.927] (**) Option "xkb_variant" "nodeadkeys"
[    10.928] (II) event3  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[    10.928] (II) event3  - Logitech USB Keyboard: device is a keyboard
[    10.928] (II) config/udev: Adding input device Logitech USB Keyboard Consumer Control (/dev/input/event4)
[    10.928] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[    10.928] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    10.928] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[    10.928] (II) Using input driver 'libinput' for 'Logitech USB Keyboard Consumer Control'
[    10.928] (**) Logitech USB Keyboard Consumer Control: always reports core events
[    10.928] (**) Option "Device" "/dev/input/event4"
[    10.929] (II) event4  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    10.929] (II) event4  - Logitech USB Keyboard Consumer Control: device is a keyboard
[    10.930] (II) event4  - Logitech USB Keyboard Consumer Control: device removed
[    10.970] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:046D:C31C.0002/input/input4/event4"
[    10.970] (II) XINPUT: Adding extended input device "Logitech USB Keyboard Consumer Control" (type: KEYBOARD, id 11)
[    10.970] (**) Option "xkb_layout" "be"
[    10.970] (**) Option "xkb_variant" "nodeadkeys"
[    10.971] (II) event4  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    10.971] (II) event4  - Logitech USB Keyboard Consumer Control: device is a keyboard
[    10.972] (II) config/udev: Adding input device Logitech USB Keyboard System Control (/dev/input/event5)
[    10.972] (**) Logitech USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[    10.972] (**) Logitech USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[    10.972] (**) Logitech USB Keyboard System Control: Applying InputClass "system-keyboard"
[    10.972] (II) Using input driver 'libinput' for 'Logitech USB Keyboard System Control'
[    10.972] (**) Logitech USB Keyboard System Control: always reports core events
[    10.972] (**) Option "Device" "/dev/input/event5"
[    10.973] (II) event5  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[    10.973] (II) event5  - Logitech USB Keyboard System Control: device is a keyboard
[    10.973] (II) event5  - Logitech USB Keyboard System Control: device removed
[    10.987] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:046D:C31C.0002/input/input5/event5"
[    10.987] (II) XINPUT: Adding extended input device "Logitech USB Keyboard System Control" (type: KEYBOARD, id 12)
[    10.987] (**) Option "xkb_layout" "be"
[    10.987] (**) Option "xkb_variant" "nodeadkeys"
[    10.988] (II) event5  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[    10.988] (II) event5  - Logitech USB Keyboard System Control: device is a keyboard
[    10.988] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse (/dev/input/event6)
[    10.988] (**) YICHIP TrustWireless Silent Mouse: Applying InputClass "evdev pointer catchall"
[    10.988] (**) YICHIP TrustWireless Silent Mouse: Applying InputClass "libinput pointer catchall"
[    10.988] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse'
[    10.988] (**) YICHIP TrustWireless Silent Mouse: always reports core events
[    10.988] (**) Option "Device" "/dev/input/event6"
[    10.989] (II) event6  - YICHIP TrustWireless Silent Mouse: is tagged by udev as: Mouse
[    10.989] (II) event6  - YICHIP TrustWireless Silent Mouse: device is a pointer
[    10.990] (II) event6  - YICHIP TrustWireless Silent Mouse: device removed
[    11.033] (II) libinput: YICHIP TrustWireless Silent Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[    11.033] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:145F:021F.0004/input/input6/event6"
[    11.033] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse" (type: MOUSE, id 13)
[    11.033] (**) Option "AccelerationScheme" "none"
[    11.033] (**) YICHIP TrustWireless Silent Mouse: (accel) selected scheme none/0
[    11.033] (**) YICHIP TrustWireless Silent Mouse: (accel) acceleration factor: 2.000
[    11.033] (**) YICHIP TrustWireless Silent Mouse: (accel) acceleration threshold: 4
[    11.034] (II) event6  - YICHIP TrustWireless Silent Mouse: is tagged by udev as: Mouse
[    11.034] (II) event6  - YICHIP TrustWireless Silent Mouse: device is a pointer
[    11.035] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse (/dev/input/mouse0)
[    11.035] (II) No input driver specified, ignoring this device.
[    11.035] (II) This device may have been added with another device file.
[    11.036] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse System Control (/dev/input/event7)
[    11.036] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "evdev keyboard catchall"
[    11.036] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "libinput keyboard catchall"
[    11.036] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "system-keyboard"
[    11.036] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse System Control'
[    11.036] (**) YICHIP TrustWireless Silent Mouse System Control: always reports core events
[    11.036] (**) Option "Device" "/dev/input/event7"
[    11.037] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: is tagged by udev as: Keyboard
[    11.037] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: device is a keyboard
[    11.037] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: device removed
[    11.060] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:145F:021F.0004/input/input7/event7"
[    11.060] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse System Control" (type: KEYBOARD, id 14)
[    11.060] (**) Option "xkb_layout" "be"
[    11.060] (**) Option "xkb_variant" "nodeadkeys"
[    11.061] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: is tagged by udev as: Keyboard
[    11.061] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: device is a keyboard
[    11.062] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse Consumer Control (/dev/input/event8)
[    11.062] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.062] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.062] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "system-keyboard"
[    11.062] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse Consumer Control'
[    11.062] (**) YICHIP TrustWireless Silent Mouse Consumer Control: always reports core events
[    11.062] (**) Option "Device" "/dev/input/event8"
[    11.063] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: is tagged by udev as: Keyboard
[    11.063] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: device is a keyboard
[    11.063] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: device removed
[    11.086] (II) libinput: YICHIP TrustWireless Silent Mouse Consumer Control: needs a virtual subdevice
[    11.087] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:145F:021F.0004/input/input8/event8"
[    11.087] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse Consumer Control" (type: MOUSE, id 15)
[    11.087] (**) Option "AccelerationScheme" "none"
[    11.087] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) selected scheme none/0
[    11.087] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) acceleration factor: 2.000
[    11.087] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) acceleration threshold: 4
[    11.088] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: is tagged by udev as: Keyboard
[    11.088] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: device is a keyboard
[    11.088] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event11)
[    11.088] (II) No input driver specified, ignoring this device.
[    11.088] (II) This device may have been added with another device file.
[    11.088] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[    11.089] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[    11.089] (II) No input driver specified, ignoring this device.
[    11.089] (II) This device may have been added with another device file.
[    11.089] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event14)
[    11.089] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event15)
[    11.089] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event16)
[    11.090] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event17)
[    11.090] (II) No input driver specified, ignoring this device.
[    11.090] (II) This device may have been added with another device file.
[    11.090] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event18)
[    11.090] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[    11.110] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.110] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.110] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "system-keyboard"
[    11.110] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse Consumer Control'
[    11.110] (**) YICHIP TrustWireless Silent Mouse Consumer Control: always reports core events
[    11.110] (**) Option "Device" "/dev/input/event8"
[    11.110] (II) libinput: YICHIP TrustWireless Silent Mouse Consumer Control: is a virtual subdevice
[    11.110] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:145F:021F.0004/input/input8/event8"
[    11.110] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse Consumer Control" (type: KEYBOARD, id 16)
[    11.110] (**) Option "xkb_layout" "be"
[    11.110] (**) Option "xkb_variant" "nodeadkeys"
[    11.521] (II) event2  - Power Button: device removed
[    11.546] (II) event10 - Video Bus: device removed
[    11.633] (II) event1  - Power Button: device removed
[    11.690] (II) event0  - Sleep Button: device removed
[    11.713] (II) event3  - Logitech USB Keyboard: device removed
[    11.730] (II) event4  - Logitech USB Keyboard Consumer Control: device removed
[    11.763] (II) event5  - Logitech USB Keyboard System Control: device removed
[    11.780] (II) event6  - YICHIP TrustWireless Silent Mouse: device removed
[    11.813] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: device removed
[    11.830] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: device removed
[    11.846] (II) AIGLX: Suspending AIGLX clients for VT switch
[  1697.670] (II) config/udev: removing device Power Button
[  1697.670] (II) UnloadModule: "libinput"
[  1697.671] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[  1697.671] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1697.671] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1697.671] (**) Power Button: Applying InputClass "system-keyboard"
[  1697.671] (II) Using input driver 'libinput' for 'Power Button'
[  1697.671] (**) Power Button: always reports core events
[  1697.671] (**) Option "Device" "/dev/input/event2"
[  1697.672] (II) event2  - Power Button: is tagged by udev as: Keyboard
[  1697.672] (II) event2  - Power Button: device is a keyboard
[  1697.672] (II) event2  - Power Button: device removed
[  1697.706] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[  1697.706] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[  1697.706] (**) Option "xkb_layout" "be"
[  1697.706] (**) Option "xkb_variant" "nodeadkeys"
[  1697.707] (II) config/udev: removing device Video Bus
[  1697.707] (II) UnloadModule: "libinput"
[  1697.707] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[  1697.707] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[  1697.707] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[  1697.707] (**) Video Bus: Applying InputClass "system-keyboard"
[  1697.707] (II) Using input driver 'libinput' for 'Video Bus'
[  1697.707] (**) Video Bus: always reports core events
[  1697.707] (**) Option "Device" "/dev/input/event10"
[  1697.708] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[  1697.708] (II) event10 - Video Bus: device is a keyboard
[  1697.708] (II) event10 - Video Bus: device removed
[  1697.733] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input11/event10"
[  1697.733] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[  1697.733] (**) Option "xkb_layout" "be"
[  1697.733] (**) Option "xkb_variant" "nodeadkeys"
[  1697.734] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse (/dev/input/mouse0)
[  1697.734] (II) No input driver specified, ignoring this device.
[  1697.734] (II) This device may have been added with another device file.
[  1697.734] (II) config/udev: removing device Power Button
[  1697.734] (II) UnloadModule: "libinput"
[  1697.735] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[  1697.735] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[  1697.735] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[  1697.735] (**) Power Button: Applying InputClass "system-keyboard"
[  1697.735] (II) Using input driver 'libinput' for 'Power Button'
[  1697.735] (**) Power Button: always reports core events
[  1697.735] (**) Option "Device" "/dev/input/event1"
[  1697.736] (II) event1  - Power Button: is tagged by udev as: Keyboard
[  1697.736] (II) event1  - Power Button: device is a keyboard
[  1697.736] (II) event1  - Power Button: device removed
[  1697.769] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[  1697.769] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[  1697.769] (**) Option "xkb_layout" "be"
[  1697.769] (**) Option "xkb_variant" "nodeadkeys"
[  1697.770] (II) config/udev: removing device Sleep Button
[  1697.770] (II) UnloadModule: "libinput"
[  1697.770] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[  1697.770] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[  1697.770] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[  1697.770] (**) Sleep Button: Applying InputClass "system-keyboard"
[  1697.770] (II) Using input driver 'libinput' for 'Sleep Button'
[  1697.770] (**) Sleep Button: always reports core events
[  1697.770] (**) Option "Device" "/dev/input/event0"
[  1697.771] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[  1697.771] (II) event0  - Sleep Button: device is a keyboard
[  1697.772] (II) event0  - Sleep Button: device removed
[  1697.799] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[  1697.799] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[  1697.799] (**) Option "xkb_layout" "be"
[  1697.799] (**) Option "xkb_variant" "nodeadkeys"
[  1697.800] (II) config/udev: removing device Logitech USB Keyboard Consumer Control
[  1697.800] (II) UnloadModule: "libinput"
[  1697.801] (II) config/udev: Adding input device Logitech USB Keyboard Consumer Control (/dev/input/event4)
[  1697.801] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[  1697.801] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  1697.801] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[  1697.801] (II) Using input driver 'libinput' for 'Logitech USB Keyboard Consumer Control'
[  1697.801] (**) Logitech USB Keyboard Consumer Control: always reports core events
[  1697.801] (**) Option "Device" "/dev/input/event4"
[  1697.802] (II) event4  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[  1697.803] (II) event4  - Logitech USB Keyboard Consumer Control: device is a keyboard
[  1697.803] (II) event4  - Logitech USB Keyboard Consumer Control: device removed
[  1697.829] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:046D:C31C.0002/input/input4/event4"
[  1697.830] (II) XINPUT: Adding extended input device "Logitech USB Keyboard Consumer Control" (type: KEYBOARD, id 11)
[  1697.830] (**) Option "xkb_layout" "be"
[  1697.830] (**) Option "xkb_variant" "nodeadkeys"
[  1697.830] (II) config/udev: removing device Logitech USB Keyboard System Control
[  1697.830] (II) UnloadModule: "libinput"
[  1697.830] (II) config/udev: Adding input device Logitech USB Keyboard System Control (/dev/input/event5)
[  1697.830] (**) Logitech USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[  1697.830] (**) Logitech USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[  1697.830] (**) Logitech USB Keyboard System Control: Applying InputClass "system-keyboard"
[  1697.830] (II) Using input driver 'libinput' for 'Logitech USB Keyboard System Control'
[  1697.830] (**) Logitech USB Keyboard System Control: always reports core events
[  1697.830] (**) Option "Device" "/dev/input/event5"
[  1697.831] (II) event5  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[  1697.831] (II) event5  - Logitech USB Keyboard System Control: device is a keyboard
[  1697.832] (II) event5  - Logitech USB Keyboard System Control: device removed
[  1697.853] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:046D:C31C.0002/input/input5/event5"
[  1697.853] (II) XINPUT: Adding extended input device "Logitech USB Keyboard System Control" (type: KEYBOARD, id 12)
[  1697.853] (**) Option "xkb_layout" "be"
[  1697.853] (**) Option "xkb_variant" "nodeadkeys"
[  1697.853] (II) config/udev: removing device Logitech USB Keyboard
[  1697.853] (II) UnloadModule: "libinput"
[  1697.854] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event3)
[  1697.854] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[  1697.854] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[  1697.854] (**) Logitech USB Keyboard: Applying InputClass "system-keyboard"
[  1697.854] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[  1697.854] (**) Logitech USB Keyboard: always reports core events
[  1697.854] (**) Option "Device" "/dev/input/event3"
[  1697.855] (II) event3  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[  1697.855] (II) event3  - Logitech USB Keyboard: device is a keyboard
[  1697.855] (II) event3  - Logitech USB Keyboard: device removed
[  1697.869] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:046D:C31C.0001/input/input3/event3"
[  1697.869] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 10)
[  1697.869] (**) Option "xkb_layout" "be"
[  1697.869] (**) Option "xkb_variant" "nodeadkeys"
[  1697.870] (II) config/udev: removing device YICHIP TrustWireless Silent Mouse
[  1697.870] (II) UnloadModule: "libinput"
[  1697.870] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse (/dev/input/event6)
[  1697.870] (**) YICHIP TrustWireless Silent Mouse: Applying InputClass "evdev pointer catchall"
[  1697.870] (**) YICHIP TrustWireless Silent Mouse: Applying InputClass "libinput pointer catchall"
[  1697.870] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse'
[  1697.870] (**) YICHIP TrustWireless Silent Mouse: always reports core events
[  1697.870] (**) Option "Device" "/dev/input/event6"
[  1697.871] (II) event6  - YICHIP TrustWireless Silent Mouse: is tagged by udev as: Mouse
[  1697.871] (II) event6  - YICHIP TrustWireless Silent Mouse: device is a pointer
[  1697.872] (II) event6  - YICHIP TrustWireless Silent Mouse: device removed
[  1697.903] (II) libinput: YICHIP TrustWireless Silent Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[  1697.903] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:145F:021F.0004/input/input6/event6"
[  1697.903] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse" (type: MOUSE, id 13)
[  1697.903] (**) Option "AccelerationScheme" "none"
[  1697.903] (**) YICHIP TrustWireless Silent Mouse: (accel) selected scheme none/0
[  1697.903] (**) YICHIP TrustWireless Silent Mouse: (accel) acceleration factor: 2.000
[  1697.903] (**) YICHIP TrustWireless Silent Mouse: (accel) acceleration threshold: 4
[  1697.903] (II) config/udev: removing device YICHIP TrustWireless Silent Mouse System Control
[  1697.903] (II) UnloadModule: "libinput"
[  1697.904] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse System Control (/dev/input/event7)
[  1697.904] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "evdev keyboard catchall"
[  1697.904] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "libinput keyboard catchall"
[  1697.904] (**) YICHIP TrustWireless Silent Mouse System Control: Applying InputClass "system-keyboard"
[  1697.904] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse System Control'
[  1697.904] (**) YICHIP TrustWireless Silent Mouse System Control: always reports core events
[  1697.904] (**) Option "Device" "/dev/input/event7"
[  1697.905] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: is tagged by udev as: Keyboard
[  1697.905] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: device is a keyboard
[  1697.905] (II) event7  - YICHIP TrustWireless Silent Mouse System Control: device removed
[  1697.936] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:145F:021F.0004/input/input7/event7"
[  1697.936] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse System Control" (type: KEYBOARD, id 14)
[  1697.936] (**) Option "xkb_layout" "be"
[  1697.936] (**) Option "xkb_variant" "nodeadkeys"
[  1697.936] (II) config/udev: removing device YICHIP TrustWireless Silent Mouse Consumer Control
[  1697.937] (II) UnloadModule: "libinput"
[  1697.937] (II) config/udev: removing device YICHIP TrustWireless Silent Mouse Consumer Control
[  1697.937] (II) config/udev: Adding input device YICHIP TrustWireless Silent Mouse Consumer Control (/dev/input/event8)
[  1697.937] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[  1697.937] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[  1697.937] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "system-keyboard"
[  1697.937] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse Consumer Control'
[  1697.937] (**) YICHIP TrustWireless Silent Mouse Consumer Control: always reports core events
[  1697.937] (**) Option "Device" "/dev/input/event8"
[  1697.939] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: is tagged by udev as: Keyboard
[  1697.939] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: device is a keyboard
[  1697.939] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: device removed
[  1697.970] (II) libinput: YICHIP TrustWireless Silent Mouse Consumer Control: needs a virtual subdevice
[  1697.970] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:145F:021F.0004/input/input8/event8"
[  1697.970] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse Consumer Control" (type: MOUSE, id 15)
[  1697.970] (**) Option "AccelerationScheme" "none"
[  1697.970] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) selected scheme none/0
[  1697.970] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) acceleration factor: 2.000
[  1697.970] (**) YICHIP TrustWireless Silent Mouse Consumer Control: (accel) acceleration threshold: 4
[  1697.970] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[  1697.970] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[  1697.970] (**) YICHIP TrustWireless Silent Mouse Consumer Control: Applying InputClass "system-keyboard"
[  1697.970] (II) Using input driver 'libinput' for 'YICHIP TrustWireless Silent Mouse Consumer Control'
[  1697.970] (**) YICHIP TrustWireless Silent Mouse Consumer Control: always reports core events
[  1697.970] (**) Option "Device" "/dev/input/event8"
[  1697.970] (II) libinput: YICHIP TrustWireless Silent Mouse Consumer Control: is a virtual subdevice
[  1697.970] (EE) libinput: YICHIP TrustWireless Silent Mouse Consumer Control: Parent device not available
[  1697.971] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: is tagged by udev as: Keyboard
[  1697.971] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: device is a keyboard
[  1697.971] (II) event8  - YICHIP TrustWireless Silent Mouse Consumer Control: device removed
[  1697.999] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:145F:021F.0004/input/input8/event8"
[  1697.999] (II) XINPUT: Adding extended input device "YICHIP TrustWireless Silent Mouse Consumer Control" (type: KEYBOARD, id 16)
[  1697.999] (**) Option "xkb_layout" "be"
[  1697.999] (**) Option "xkb_variant" "nodeadkeys"
[  1698.000] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event15)
[  1698.000] (II) No input driver specified, ignoring this device.
[  1698.000] (II) This device may have been added with another device file.
[  1698.001] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event13)
[  1698.001] (II) No input driver specified, ignoring this device.
[  1698.001] (II) This device may have been added with another device file.
[  1698.001] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event14)
[  1698.001] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event11)
[  1698.001] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[  1698.002] (II) No input driver specified, ignoring this device.
[  1698.002] (II) This device may have been added with another device file.
[  1698.002] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event16)
[  1698.002] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[  1698.002] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event18)
[  1698.003] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event17)
[  1698.003] (II) No input driver specified, ignoring this device.
[  1698.003] (II) This device may have been added with another device file.
