Hi, I have experiencing really strange problem last about 2 week. After PC start I have problem to go to almost every website via browser (Firefox, Chromium) and Thunderbird won’t download messages. It’s too slow or website isn’t loaded at all. But internet works - for example downloading updates is fast as always. Nothing what I do (restart, Firefox safe mode…) helps. And for some time browser and Thunderbird stars works normally as there was no problem at all.
DNS settings maybe?
By default most modern browsers (including FF and Chromium) use their own DNS unless you disable it.
I find this annoying because I want my browser to follow my system DNS settings.
It may not be related to your current situation … but given the discrepancies in performance … its possible.
This can be disabled in the browsers, ala:
In Chrom*:
- Use Secure DNS > Off
In Firefox:
- DNS over HTTPS > Off
Also … heres a DNS speed test in script form …
#!/usr/bin/env bash
# dns speed test
if [[ -z "$DOMAIN" ]]; then
DOMAIN=wikipedia.org
fi;
CURRENTDNS=$(dig "$DOMAIN" | grep SERVER | awk -F'[)(]' '{print $2}')
if [[ -z "$SKIP" ]]; then
echo
echo " Test common resolvers by calculating average response times of 3 queries."
echo
annc() {
echo
echo " DNS Primary Secondary"
echo
echo " Adguard 94.140.14.14 94.140.15.15"
echo " Comodo 8.26.56.26 8.20.247.20"
echo " Control-D 76.76.2.2 76.76.10.2"
echo " Cloudflare 1.1.1.1 1.0.0.1"
echo " CyberGhost 38.132.106.139 194.187.251.67"
echo " Google 8.8.8.8 8.8.4.4"
echo " Neustar 156.154.70.5 156.154.71.2"
echo " NextDNS 45.90.28.97 45.90.30.97"
echo " OpenDNS 208.67.222.222 208.67.220.220"
echo " Quad9 9.9.9.9 149.112.112.112"
echo
printf '%*s\n' "${COLUMNS:-$(tput cols)}" '' | tr ' ' -
annc | column -tL
fi;
if [[ -n "$TESTDNS" ]]; then
echo "Custom Test DNS $TESTDNS"
fi
echo
while true; do
read -p " Do you wish to flush the DNS cache? " yn
case $yn in
[Yy]* ) resolvectl flush-caches; break;;
[Nn]* ) break;;
* ) echo -e "\n Please answer yes or no.\n";;
esac
done
echo
echo "Current DNS $CURRENTDNS"
for reps in {1..3}
do
dig "$DOMAIN" | awk '/time/ {print $4 " ms"}'
sleep 1
done | awk '/ms/ {sum+=$1} END {print "Avg time: ",sum/3, " ms"}'
echo
rank() {
for resolver in "Adguard 94.140.14.14" "Comodo 8.26.56.26" "Control-D 76.76.2.2" "Cloudflare 1.1.1.1" "CyberGhost 38.132.106.139" "Google 8.8.8.8" "Neustar 156.154.70.5" "NextDNS 45.90.28.97" "OpenDNS 208.67.222.222" "Quad9 9.9.9.9";
do
echo $resolver
for reps in {1..3}
do
dig "$DOMAIN" "@${resolver#* }" | awk '/time/ {print $4 " ms"}'
sleep 1
echo
done
rank;
fi;
for reps in {1..3}
do
dig "$DOMAIN" "@$TESTDNS" | awk '/time/ {print $4 " ms"}'
sleep 1
echo
fi
exit
Notes:
Of course you can modify it to add or remove servers.
And it relies on dig
which is provided by the bind
package.
Hi, secure DNS is off, that was my guess too. What is really strange is, that Manjaro site mostly works fine, but other sites (czech) show this behaviour. Also google is really slow.
There is output from script:
Do you wish to flush the DNS cache? y
Failed to flush caches: Unit dbus-org.freedesktop.resolve1.service not found.
Current DNS 192.168.1.1
Avg time: 39.6667 ms
Avg time: 0 ms
Comodo 8.26.56.26
Avg time: 0 ms
Control-D 76.76.2.2
Avg time: 0 ms
Cloudflare 1.1.1.1
Avg time: 0 ms
Avg time: 0 ms
Google 8.8.8.8
Avg time: 0 ms
Avg time: 0 ms
NextDNS 45.90.28.97
Avg time: 0 ms
Avg time: 0 ms
Quad9 9.9.9.9
Avg time: 0 ms
I could change DNS server… Is less ms better? And what means 0 ms exactly?
Hi again, after while of tinkering, it seems that problem is in my modem!
But, my question about DNS still stands
Less would be better, but the 0’s are probably the result of failure.
Try using NextDNS
ok, thx
