Strange behaviour with my vulcan aimo 120
Hello,
I have some strange issues with my ROCCAT Vulcan AMIO 120.
First of all I want do exclude the fact that my keyboard has an unique factory failure. I’ve tested this behaviour with my gf’s keyboard (same as mine) and have the same issues.
When I plug the keyboard in the backpanel of my tower my USB headset microfone does not work. The mic is detected but not able to record sound. The earphones work.
When I plug the keyboard in the frontpanel my headset works fine.
An other strange thing I’ve noticed is that sometimes when I start my PC the login screen is like freezing. Every hover effect and my mouse cursor is working. But when I try to select my user by eather clicking with my mouse or pressing enter on my keyboard nothing happen. When I then unplug my keyboard it seams like all the commands I pressed are fired and my user is selcted magically. When I then plug my keyboard back in I can type normaly and the full UI is working.
Do you have some Ideas how to fix?
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  1. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
  2. Update your BIOS first if there is a newer version as this smells like a firmware issue.
    :+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
Sorry about missing information. This is my first post on this forum and i didnt thought on that.
I’ve checked my BIOS version. I’ve version 4801 which seems to be the latest. My profile now includes some information about my setup.
The output of inxi --admin --verbosity=7 --filter --no-host --width is:
  Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  root=UUID=dba5375f-f172-4893-a27a-368cd69de8ea rw quiet splash apparmor=1
  security=apparmor udev.log_priority=3 radeon.cik_support=0
  radeon.si_support=0 amdgpu.cik_support=1 amdgpu.si_support=1 amdgpu.dc=1
  Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
  Distro: Manjaro Linux
  Type: Desktop Mobo: ASUSTeK model: P9X79 PRO v: Rev 1.xx serial: <filter>
  UEFI: American Megatrends v: 4801 date: 07/25/2014
  RAM: total: 31.3 GiB used: 8.48 GiB (27.1%)
  Info: 6-Core model: Intel Core i7-3960X bits: 64 type: MT MCP
  arch: Sandy Bridge family: 6 model-id: 2D (45) stepping: 7 microcode: 71A
  L2 cache: 15 MiB bogomips: 79281
  Speed: 3602 MHz min/max: 1200/3900 MHz Core speeds (MHz): 1: 3602 2: 3602
  3: 3602 4: 3602 5: 3602 6: 3602 7: 3602 8: 3602 9: 3602 10: 3602 11: 3602
  12: 3602
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept est
  flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
  mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ss
  ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: AMD Hawaii PRO [Radeon R9 290/390] vendor: XFX Pine driver: amdgpu
  v: kernel alternate: radeon bus ID: 01:00.0 chip ID: 1002:67b1
  class ID: 0300
  Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver:
  loaded: amdgpu note: n/a (using device driver) - try sudo/root display ID: 0
  OpenGL: renderer: AMD Radeon R9 390 Series (HAWAII DRM 3.40.0
  5.10.15-1-MANJARO LLVM 11.0.1)
  v: 4.6 Mesa 20.3.4 direct render: Yes
  Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1d20
  class ID: 0403
  Device-2: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
  vendor: XFX Pine driver: snd_hda_intel v: kernel bus ID: 01:00.1
  chip ID: 1002:aac8 class ID: 0403
  Device-3: Logitech HD Webcam C525 type: USB driver: snd-usb-audio,uvcvideo
  bus ID: 2-1.3:4 chip ID: 046d:0826 class ID: 0e02 serial: <filter>
  Device-4: Sennheiser Sennheiser 3D G4ME1 type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-1.6:6 chip ID: 1395:1000
  class ID: 0300
  Sound Server: ALSA v: k5.10.15-1-MANJARO
  Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
  driver: e1000e v: kernel port: f040 bus ID: 00:19.0 chip ID: 8086:1503
  class ID: 0200
  IP v4: <filter> type: secondary dynamic noprefixroute scope: global
  IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
  IP v6: <filter> type: deprecated dynamic mngtmpaddr noprefixroute
  scope: global
  IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
  IF-ID-1: br-0ed93c289cb0 state: down mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: virbr0 state: down mac: <filter>
  Device-1: ASUSTek Bluetooth Adapter type: USB driver: btusb v: 0.8
  bus ID: 2-1.8:8 chip ID: 0b05:179c class ID: e001
  Message: Required tool hciconfig not installed. Check --recommends
  Local Storage: total: 3.41 TiB used: 1.64 TiB (48.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA300 size: 2.73 TiB
  block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: ABB0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
  size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 EVO 250GB
  size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: BB6Q scheme: GPT
  ID-1: / raw size: 232.59 GiB size: 227.94 GiB (98.00%)
  used: 173.42 GiB (76.1%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
  uuid: dba5375f-f172-4893-a27a-368cd69de8ea
  ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
  uuid: 5CBA-937D
  ID-3: /mnt/96A0068DA00673D1 raw size: 2.73 TiB size: 2.73 TiB (100.00%)
  used: 1.47 TiB (54.0%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Games
  uuid: 96A0068DA00673D1
  ID-1: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: vfat label: N/A
  uuid: 708E-C367
  ID-3: /dev/sdb2 maj-min: 8:18 size: 465.46 GiB fs: ext4 label: N/A
  uuid: 2f110939-61e3-4262-94c9-e3431e8f80c4
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
  speed: 480 Mb/s chip ID: 8087:0024 class ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.2:3 info: SteelSeries ApS SteelSeries Rival 300 Gaming Mouse
  type: HID,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 1.1
  speed: 12 Mb/s chip ID: 1038:1710 class ID: 0300
  Device-2: 2-1.3:4 info: Logitech HD Webcam C525 type: Audio,Video
  Hub-5: 2-1.4:5 info: Realtek RTS5411 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
  chip ID: 0bda:5411 class ID: 0900
  Device-1: 2-1.4.2:9 info: ROCCAT Vulcan 120 AIMO type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
  chip ID: 1e7d:3098 class ID: 0300
  Device-2: 2-1.6:6 info: Sennheiser Sennheiser 3D G4ME1 type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  speed: 12 Mb/s chip ID: 1395:1000 class ID: 0300
  Device-3: 2-1.8:8 info: ASUSTek Bluetooth Adapter type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 0b05:179c
  class ID: e001
  Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  chip ID: 1d6b:0003 class ID: 0900
  Hub-8: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-9: 5-1:2 info: VIA Labs Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  chip ID: 2109:3431 class ID: 0900
  Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-11: 6-1:2 info: VIA Labs VL81x Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip ID: 2109:0810 class ID: 0900
  System Temperatures: cpu: 57.0 C mobo: N/A gpu: amdgpu temp: 62.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1469
  Processes: 408 Uptime: 8h 54m wakeups: 0 Init: systemd v: 247 Compilers:
  gcc: 10.2.0 clang: 11.0.1 Packages: 1659 pacman: 1649 lib: 524 flatpak: 0
  snap: 10 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.3.01
  1. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
    (as that makes both our lives much easier)
  2. No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed. :wink:
  3. You’re on Gnome, so I can only give you general instructions as I’m on KDE:
    • Go to keyboard hardware and layout (not keyboard settings)
    • set the keyboard model to the one that most closely resembles yours.
That’s all the advice I can give you, so if that doesn’t work, we’ll need a Gnome expert to help you out.
:+1:
