Hello good people, I recently switched from Pop_OS! 20.10 to manjaro and so far everything seems good, RTX 2070 Super is working with the Nvidia drivers, my Games from Steam and GOG Run very well… I have Just one anoying issue: my gamepad (Steelseries Stratus Duo for what it is worth) hast two Problems:
The X and Y Button are switched, they show up in the Steam Controller Layout properly but in Games they are Always Mixed Up (X working as the Y button and vice versa)
Even more anoying: the Left and Right Trigger Buttons are not … there. They already Show Up empty in the Steam Controller Setup (where you can review and Change all Buttons and mapping/action ) and I cannot activate them there and also in Games I cannot bind them to any action.
However before the Switch, with Pop_Os, the Controller worked perfectly fine, so I was wondering If there is a package Missing that I can Install, or anything…
UPDATE: added a screenshot of the Steam Controller Layout overview with - what I think - is the problem.
Any help is much appreciated!
