Strange behavior of icons-only task manager
Hello,
My “Icon-only” task manager freezes every now and then for about 20 to 30 seconds.
There’s nothing unusual in the log.
inxi
  Kernel: 6.19.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64
    root=UUID=a2c104c7-14bf-4d19-b775-e2095cc8d407 rw sysrq_always_enabled=1
    udev.log_priority=3 nmi_watchdog=0 nowatchdog acpi_enforce_resources=lax
  Desktop: KDE Plasma v: 6.6.3 tk: Qt v: N/A info: frameworks v: 6.24.0
    wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
    Firmware: UEFI vendor: American Megatrends v: 3827 date: 02/06/2026
  System RAM: total: 64 GiB available: 62.45 GiB used: 6.35 GiB (10.2%)
  Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK64GX5M2B5600Z40 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 9900X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
  Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 960 KiB desc: d-12x48 KiB; i-12x32 KiB L2: 12 MiB
    desc: 12x1024 KiB L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
  Speed (MHz): avg: 605 min/max: 605/5576 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 605 2: 605 3: 605
    4: 605 5: 605 6: 605 7: 605 8: 605 9: 605 10: 605 11: 605 12: 605 13: 605
    14: 605 15: 605 16: 605 17: 605 18: 605 19: 605 20: 605 21: 605 22: 605
    23: 605 24: 605 bogomips: 210790
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
    ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
    perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
    stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
    umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: Tul / PowerColor Reaper driver: amdgpu v: kernel
    arch: RDNA-4 code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie:
    gen: 5 speed: 32 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3,
    HDMI-A-1, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2024 res: mode: 2560x1440 hz: 180 scale: 100% (1) dpi: 93 gamma: 1.2
    chroma: red: x: 0.686 y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43")
    diag: 800mm (31.5") ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x720,
    1024x768, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
    gfx1201 ACO DRM 3.64 6.19.9-1-MANJARO) device-ID: 1002:7550
    memory: 15.62 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.341 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 26.0.3-arch1.1
    device-ID: 1002:7550 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: amd-smi, amdgpu_top, lact
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-2: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
    chip-ID: 0b05:1a52 class-ID: 0300
  API: ALSA v: k6.19.9-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:125c
    class-ID: 0200
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp10s0 state: up mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5
    chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
    lmp-v: 12 sub-v: 2602 hci-v: 12 rev: 2410 class-ID: 6c0104
  Info: acl-mtu: 1021:6 sco-mtu: 240:8 link-policy: rswitch sniff
    link-mode: peripheral accept service-classes: rendering, capturing, audio,
    telephony
  Local Storage: total: 3.18 TiB used: 530.53 GiB (16.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR003 temp: 32.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS5C3020ALA632
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5940 serial: <filter> fw-rev: A580 scheme: MBR
  ID-1: / raw-size: 864.68 GiB size: 850.03 GiB (98.31%)
    used: 530.51 GiB (62.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: a2c104c7-14bf-4d19-b775-e2095cc8d407
    used: 23.1 MiB (7.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 5C2E-2A1A
  ID-1: swap-1 type: partition size: 66.54 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: d95afaf3-44fe-47d6-9938-66d0dee66ea5
  ID-1: /dev/sda1 maj-min: 8:1 size: 292.97 GiB fs: ext4 label: xfce
    uuid: d8c3b26b-f771-48c7-a11e-fc09d6d99a3e
  ID-2: /dev/sda2 maj-min: 8:2 size: 161.79 GiB fs: ext4 label: Timeshift
    uuid: ed8facc8-ca20-417c-8a2e-49692c97eeec
  ID-3: /dev/sda3 maj-min: 8:3 size: 11 GiB fs: swap label: N/A
    uuid: 8e7033b8-3797-442c-8c0c-aea22c7404de
  ID-4: /dev/sdb1 maj-min: 8:17 size: 1.15 TiB fs: ntfs label: Daten3
    uuid: 86E470A6E47099DF
  ID-5: /dev/sdb2 maj-min: 8:18 size: 686.12 GiB fs: ext4 label: BackupII
    uuid: e0967a4a-9a0d-4483-a7fa-10fc96595cb7
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: ASUSTek USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-2: 1-7:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Hub-2: 1-8:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-11:5 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 5-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 5-2.1:3 info: RY Micro Geeky GK65 gaming Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 480mA
    chip-ID: 3532:c0c2 class-ID: 0300 serial: <filter>
  Device-2: 5-2.2:4 info: Razer USA Basilisk V3 type: mouse,keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0099 class-ID: 0300
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 6-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  System Temperatures: cpu: 32.5 C mobo: 27.0 C gpu: amdgpu temp: 47.0 C
    mem: 66.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 604 fan-3: 533 fan-4: 466 fan-5: 0
    fan-6: 533 fan-7: 0 gpu: amdgpu fan: 0
  Packages: 2033 pm: pacman pkgs: 2020 libs: 495 tools: pamac,yay pm: flatpak
    pkgs: 13
    1: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/unstable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
    3: https://ftp.halifax.rwth-aachen.de/manjaro/unstable/$repo/$arch
    4: https://manjaro.kurdy.org/unstable/$repo/$arch
    5: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
    6: https://mirror.23m.com/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 478
  1: cpu: 5.2% command: steamwebhelper pid: 6459 mem: 576.7 MiB (0.9%)
  2: cpu: 4.2% command: firefox pid: 13061 mem: 882.1 MiB (1.3%)
  3: cpu: 3.7% command: plasmashell pid: 1670 mem: 383.8 MiB (0.6%)
  4: cpu: 3.6% command: kwin_wayland pid: 1490 mem: 329.3 MiB (0.5%)
  5: cpu: 2.3% command: firefox pid: 14038 mem: 542.3 MiB (0.8%)
  Memory top: 5 of 478
  1: mem: 991.7 MiB (1.5%) command: clamd pid: 871 cpu: 0.0%
  2: mem: 882.1 MiB (1.3%) command: firefox pid: 13061 cpu: 4.2%
  3: mem: 576.7 MiB (0.9%) command: steamwebhelper pid: 6459 cpu: 5.2%
  4: mem: 559.0 MiB (0.8%) command: ./steamwebhelper pid: 6295 cpu: 0.4%
  5: mem: 542.3 MiB (0.8%) command: firefox pid: 14038 cpu: 2.3%
  Processes: 478 Power: uptime: 4h 27m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.92 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: yakuake
    inxi: 3.3.40
    ~  sudo inxi -zv8m         ✔
[sudo] password for alexander:
  Desktop: KDE Plasma v: 6.6.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
    serial: <filter> part-nu: SKU uuid: 2500e437-a72d-7062-a7d6-60cf8477243b
  System RAM: total: 64 GiB available: 62.45 GiB used: 6.53 GiB (10.5%)
    (unregistered) size: 32 GiB speed: 4800 MT/s volts: curr: 1.1 min: 1.1
    max: 1.1 width (bits): data: 64 total: 64 manufacturer: Corsair
  Slot: 0 type: PCIe gen: 5 status: in use length: long volts: 3.3
    bus-ID: 00:01.1 children: 1: 01:00.0 class-ID: 0604 type: bridge children:
    1: 02:00.0 class-ID: 0604 type: bridge children: 1: 03:00.0 class-ID: 0300
    type: display 2: 03:00.1 class-ID: 0403 type: audio
  Slot: 1 type: PCIe gen: 4 status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 2 type: PCIe gen: 4 status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 3 type: PCIe gen: 4 status: available length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 4 type: N/A status: available info: M.2 length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 5 type: N/A status: in use info: M.2 length: long volts: 3.3
    bus-ID: 00:02.2 children: 1: 0d:00.0 class-ID: 0108 type: mass-storage
  Slot: 6 type: N/A status: available info: M.2 length: long volts: 3.3
    bus-ID: 00:1f.7
  Slot: 7 type: N/A status: in use info: M.2 length: short volts: 3.3
    bus-ID: 05:0b.0
  Info: model: AMD Ryzen 9 9900X3D socket: AM5 bits: 64 type: MT MCP
    arch: Zen 5 gen: 5 level: v4 note: check built: 2024+ process: TSMC n4 (4nm)
    family: 0x1A (26) model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
    base/boost: 4400/5550 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.3 V ext-clock: 100 MHz cores: 1: 605 2: 605 3: 605 4: 605 5: 605
    6: 605 7: 605 8: 605 9: 605 10: 605 11: 605 12: 605 13: 605 14: 605
    15: 605 16: 605 17: 605 18: 605 19: 605 20: 605 21: 605 22: 605 23: 605
    affected
  Display: unspecified server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: Vulkan v: 1.4.341 layers: 5 device: 0 type: discrete-gpu name: AMD
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top,lact wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Server-2: PipeWire v: 1.6.2 status: n/a (root, process) with:
    3: pipewire-alsa type: plugin 4: pw-jack type: plugin
    class-ID: 0200
    telephony
    scheme: GPT
  SMART: yes health: PASSED on: 243d 20h cycles: 1,384
    read-units: 137,080,261 [70.1 TB] written-units: 127,648,662 [65.3 TB]
    family: based SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 2B6Q temp: 26 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 101d 11h cycles: 2387
    written: 14.37 TiB
    family: Deskstar 5K3000 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B sata: 2.6 speed: 6.0 Gb/s tech: HDD rpm: 5940
    serial: <filter> fw-rev: A580 temp: 28 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 4y 315d 12h cycles: 8783
    used: 530.51 GiB (62.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: a2c104c7-14bf-4d19-b775-e2095cc8d407
    used: 23.1 MiB (7.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 5C2E-2A1A
    serial: <filter>
  System Temperatures: cpu: 33.0 C mobo: 27.0 C gpu: amdgpu temp: 48.0 C
    mem: 66.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 607 fan-3: 543 fan-4: 479 fan-5: 0
    fan-6: 545 fan-7: 0 gpu: amdgpu fan: 0
    pkgs: 13
Processes:
  CPU top: 5 of 492
  1: cpu: 5.1% command: steamwebhelper pid: 6459 mem: 572.6 MiB (0.8%)
  2: cpu: 4.4% command: firefox pid: 13061 mem: 862.4 MiB (1.3%)
  3: cpu: 3.7% command: plasmashell pid: 1670 mem: 384.0 MiB (0.6%)
  4: cpu: 3.6% command: kwin_wayland pid: 1490 mem: 327.1 MiB (0.5%)
  5: cpu: 2.3% command: firefox pid: 14038 mem: 541.3 MiB (0.8%)
  Memory top: 5 of 492
  2: mem: 862.4 MiB (1.3%) command: firefox pid: 13061 cpu: 4.4%
  3: mem: 572.6 MiB (0.8%) command: steamwebhelper pid: 6459 cpu: 5.1%
  4: mem: 559.0 MiB (0.8%) command: ./steamwebhelper pid: 6295 cpu: 0.3%
  5: mem: 541.3 MiB (0.8%) command: firefox pid: 14038 cpu: 2.3%
  Processes: 492 Power: uptime: 4h 32m states: freeze,mem,disk suspend: deep
    tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p2
    default: Bash v: 5.3.9 running-in: yakuake inxi: 3.3.40
I think the problem has been around since the major KDE update around March 18.
Has anyone else experienced similar issues?
1. Logout to SDDM/PlasmaLogin and enter a TTY
2. Delete the Cache directory:
rm -rf ~/.cache
3. Reboot
If no improvement, create a new User account to test and verify whether or not the issue persists there.
Yes, but in Arch. I created a new user. The issue was gone. And now seems to be gone in old user as well. :face_with_spiral_eyes:
Same here.
I cleared the cache and rebooted. The problem persisted.
I created a new user account - tested half a day - no problem.
Back to my original user account, and everything’s been working perfectly ever since…strange…
Update:
I celebrated too soon… it just started freeze up again :frowning:
I’ll try to match up the detailed journals…wish me luck
As if by magic.
Yes, same here, so the magical fix was not there. During a plasmashell freeze of almost 15 minutes the log shows:
23-03-2026 12:16	plasmashell	DataControlOffer: timeout reading from pipe for mimeType SAVE_TARGETS
23-03-2026 12:19	plasmashell	DataControlOffer: timeout reading from pipe for mimeType text/plain;charset=utf-8
23-03-2026 12:21	plasmashell	DataControlOffer: timeout reading from pipe for mimeType text/plain
23-03-2026 12:22	plasmashell	DataControlOffer: timeout reading from pipe for mimeType text/plain;charset=utf-8
23-03-2026 12:24	plasmashell	DataControlOffer: timeout reading from pipe for mimeType text/plain
23-03-2026 12:26	plasmashell	DataControlOffer: timeout reading from pipe for mimeType text/html
23-03-2026 12:27	plasmashell	DataControlOffer: timeout reading from pipe for mimeType text/_moz_htmlcontext
23-03-2026 12:29	plasmashell	DataControlOffer: timeout reading from pipe for mimeType text/_moz_htmlinfo
23-03-2026 12:29	kwin_wayland	Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
I have no idea if this is any help … and btw during the freeze alt-space / krunner keeps on running ok.
I have similar entries from plasmashell. icontask (which is presumably my icon-only taskmanager) is complaining that the mainscript is missing?!
It’s also noticeable that the click events aren’t lost. It just seems as though it has to wake up first and then process them.
Mär 22 19:53:51 alexander-AMD plasmashell[1648]: Could not find required file "mainscript" for package "/usr/share/plasma/plasmoids/org.kde.plasma.icontasks/" should be QList("ui/main.qml")
Mär 22 19:53:52 alexander-AMD plasmashell[1648]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Mär 22 19:53:52 alexander-AMD plasmashell[1648]: No object for name "alsa_output.usb-Generic_USB_Audio-00.HiFi_5_1__Speaker__sink.monitor"
Mär 22 20:08:26 alexander-AMD plasmashell[1648]: Failed to find service for Unity Launcher "gldriverquery.desktop"
Mär 23 00:24:42 alexander-AMD plasmashell[1648]: DataControlOffer: timeout reading from pipe for mimeType SAVE_TARGETS
Mär 23 00:26:22 alexander-AMD plasmashell[1648]: DataControlOffer: timeout reading from pipe for mimeType SAVE_TARGETS
from my experience, the plasmashell[1648]: DataControlOffer: timeout line correlate with the freezes. but i think they are more the result than the cause
when i query the journal with priority=5, i got this line before the freeze:
Mär 24 01:26:29 alexander-AMD wpa_supplicant[1328]: wlp10s0: CTRL-EVENT-REGDOM-BEACON-HINT after freq=2472 max_tx_power=2000
Mär 24 01:26:29 alexander-AMD wpa_supplicant[1328]: wlp10s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mär 24 01:26:29 alexander-AMD wpa_supplicant[1328]: wlp10s0: CTRL-EVENT-REGDOM-BEACON-HINT before freq=2472 max_tx_power=2000 no_ir=1
Mär 24 01:26:29 alexander-AMD wpa_supplicant[1328]: wlp10s0: CTRL-EVENT-REGDOM-BEACON-HINT before freq=5180 max_tx_power=2000 no_ir=1
Mär 24 01:26:29 alexander-AMD wpa_supplicant[1328]: wlp10s0: CTRL-EVENT-REGDOM-BEACON-HINT after freq=5180 max_tx_power=2000
Mär 24 01:26:30 alexander-AMD ModemManager[906]: <wrn> [plugin-manager] task 3,wlp10s0: error when checking support with plugin 'generic': (generic) Missing port probe for port (net/wlp10s0)
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: SME: Trying to authenticate with 2c:91:ab:bd:bb:7f (SSID='THOR' freq=5180 MHz)
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: PMKSA-CACHE-ADDED 2c:91:ab:bd:bb:7f 0
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: Trying to associate with 2c:91:ab:bd:bb:7f (SSID='THOR' freq=5180 MHz)
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: Associated with 2c:91:ab:bd:bb:7f
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: p2p-dev-wlp10s0: Channel list changed: 6 GHz was enabled
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: Channel list changed: 6 GHz was enabled
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: WPA: Key negotiation completed with 2c:91:ab:bd:bb:7f [PTK=CCMP GTK=CCMP]
Mär 24 01:26:31 alexander-AMD wpa_supplicant[1328]: wlp10s0: CTRL-EVENT-CONNECTED - Connection to 2c:91:ab:bd:bb:7f completed [id=0 id_str=]
Mär 24 01:26:32 alexander-AMD ModemManager[906]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0a.0/0000:09:00.0': not supported by any plugin
Mär 24 01:26:32 alexander-AMD ModemManager[906]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0b.0/0000:0a:00.0': not supported by any plugin
Mär 24 01:26:50 alexander-AMD kernel: amdgpu 0000:03:00.0: amdgpu: VM memory stats for proc kscreenlocker_g(9127) task kscreenloc:cs0(9118) is non-zero when fini
Mär 24 01:28:16 alexander-AMD kioworker[9624]: <input>:1:135167: Could not resolve property: #linearGradient8471
Mär 24 01:28:16 alexander-AMD kioworker[9624]: <input>:1:135167: Could not resolve property: #linearGradient8473
Mär 24 01:28:33 alexander-AMD kioworker[9622]: Not a JPEG file: starts with 0x89 0x50
Mär 24 01:30:16 alexander-AMD wireplumber[1497]: wp-event-dispatcher: <WpAsyncEventHook:0x56529d960870> failed: failed to activate item: Object activation aborted: proxy destroyed
Mär 24 01:30:18 alexander-AMD keepassxc[8594]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Mär 24 01:31:30 alexander-AMD wireplumber[1497]: wp-event-dispatcher: <WpAsyncEventHook:0x56529d960870> failed: failed to activate item: Object activation aborted: proxy destroyed
Mär 24 01:34:51 alexander-AMD wpa_supplicant[1328]: wlp10s0: RSN: Group rekeying completed with 2c:91:ab:bd:bb:7f [GTK=CCMP]
bunch of wifi problems and a msg from kernel which scares me.
but sadly i lack the experience, what to do with it :frowning:
@soundofthunder Maybe it makes sense to move this into a separate thread?
I just found a bug in the kde bugtracker related to our problem.
The plasma panel freezes after copying the text in firefox when “Keep the selection and clipboard the same” is enabled
But i’m not shure that it only freezes when i was copiing something :thinking:
I’ve disabled the option now and will keep an eye on it
Great find! I un-checked the klipper option and the freeze is gone. In the test user I had created (in Arch) this option was unchecked from the beginning so that explains why the freeze dit not occur there.
