I have a fresh install of Manjaro with KDE. (desktop PC)
After about 10 mins the screen goes off, it’s quite annoying, and I don’t find how to stop this.
I saw on the net that is should be apparently a “power management” section under settings, but there is not.
the solution was from user @Oldhabbits , so mark it properly…
did you install the minimal version of kde? since the powerdevil was not installed by default?
This is my first install of Manjaro and it took me days to understand that i have a problem, i now i don’t remember if I choose a “minimal version of KDE”
I tried to remember if i uninstalled by mistake this package but i can’t figure out how this happen.
I see also that i don’t have screen brightness setting.
It has to be ?
at least its now fixed…
if you mean the screen brightness setting under the energy saving settings, its because i have a laptop … youre on desktop so you dont have it
