So I couldn’t figure out what my issue was with PipeWire giving me scratchy audio at the start of everything I started watching or really any noise the system produced, it made a popping scratching sound.
So I’ve swapped to PulseAudio to try and fix it from here instead. Probably not the best move but still learning Linux so figured why not.
[jorogumo4@leo-x470aorusultragaming ~]$ screenfetch
██████████████████ ████████ jorogumo4@leo-x470aorusultragaming
██████████████████ ████████ OS: Manjaro 23.0.0 UltimaThule
██████████████████ ████████ Kernel: x86_64 Linux 6.1.31-2-MANJARO
██████████████████ ████████ Uptime: 56m
████████ ████████ Packages: 1234
████████ ████████ ████████ Shell: bash 5.1.16
████████ ████████ ████████ Resolution: 7680x1440
████████ ████████ ████████ DE: Xfce4
████████ ████████ ████████ WM: Xfwm4
████████ ████████ ████████ WM Theme: Matcha-sea
████████ ████████ ████████ GTK Theme: Matcha-dark-sea [GTK2]
████████ ████████ ████████ Icon Theme: Papirus-Maia
████████ ████████ ████████ Font: Noto Sans 10
████████ ████████ ████████ Disk: 329G / 953G (37%)
CPU: AMD Ryzen 7 2700X Eight-Core @ 16x 3.7GHz
GPU: AMD Radeon RX 7900 XT (gfx1100, LLVM 15.0.7, DRM 3.49, 6.1.31-2-MANJARO)
RAM: 6355MiB / 48124MiB
[jorogumo4@leo-x470aorusultragaming ~]$ inxi -Aazy
Device-1: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0d:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: Yamaha Steinberg UR24C driver: snd-usb-audio type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-3:2 chip-ID: 0499:174d
class-ID: 0103
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: off tools: pw-cat,pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Here’s what I’ve done so far.
/etc/pulse/daemon.conf
avoid-resampling = yes (changed from false)
default-sample-rate = 48000 (changed from 44100)
default-fragments = 5 (changed from 4)
default-fragment-size-msec = 2 (changed from 25)
/etc/pulse/default.pa
load-module module-udev-detect tsched=0 (added)
load-module module-suspend-on-idle (added)
This seems to have taken away the scratching at least at the moment I’m not experiencing it, but when I click on say a youtube video, it takes about 1-2 seconds for that audio to start playing.
Any ideas? I’ve been trying to follow the wiki for this, but alas haven’t fixed the issue so far. PulseAudio/Troubleshooting - ArchWiki
After making these changes I did also run the following;
pulseaudio -k
pulseaudio --start
EDIT:
I’ve discovered that load-module module-suspend-on-idle
was actually already in default.pa, so I removed the part that I added and commented out the one that was there, unfortunately still having audio delay issues. Once the audio gets going it’s fine, but it just, takes a moment to get started so video is ahead of the audio.
