Still hangs the system
Still hangs the system.
vulkaninfo --summary
driverInfo         = Mesa 25.0.3-arch1.1
inxi --filter --verbosity=8        ─╯
  Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
    root=UUID=61f9c467-a20f-466a-9aa4-26f85422db3b rw rootflags=subvol=@
    quiet splash resume=UUID=72d4bd70-dd75-46eb-bce8-63a0ce26043d
    udev.log_priority=3
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402XV_GA402XV
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: GA402XV v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: GA402XV.318
    date: 04/22/2024
  ID-1: BAT0 charge: 33.7 Wh (47.0%) condition: 71.7/76.0 Wh (94.4%)
    power: 17.8 W volts: 15.1 min: 15.9 model: AS3FYCe3KC GA40249 type: Unknown
    serial: <filter> status: discharging
  System RAM: total: 32 GiB available: 30.56 GiB used: 4.99 GiB (16.3%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: MTC8C1084S1SC48BA1 serial: N/A
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: 9905790-068.A00G serial: <filter>
  Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
    microcode: 0xA704107
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1785 min/max: 400/5263 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1785 2: 1785 3: 1785
    4: 1785 5: 1785 6: 1785 7: 1785 8: 1785 9: 1785 10: 1785 11: 1785 12: 1785
    13: 1785 14: 1785 15: 1785 16: 1785 bogomips: 127765
    apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
    cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
    driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s ports:
    active: none empty: DP-9,HDMI-A-1,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:28e0
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: ASUSTeK
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
    bus-ID: 65:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 42.0 C
  Device-3: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 3277:0018
    class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: TL140ADXP02-0 built: 2022 res: 2560x1600 dpi: 216
    gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.263 y: 0.690 blue:
    x: 0.149 y: 0.059 white: x: 0.314 y: 0.329 size: 301x188mm (11.85x7.4")
    diag: 355mm (14") ratio: 16:10 modes: 2560x1600, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
    800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown flag 16 2: parse_edid: unknown tag
    112
  API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
    platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2
    drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia surfaceless:
    drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi phoenix
    LLVM 19.1.7 DRM 3.61 6.14.0-1-MANJARO) device-ID: 1002:15bf
    memory: 500 MiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.309 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Laptop GPU driver: nvidia v: 570.133.07
    device-ID: 10de:28e0 surfaces: xcb,xlib,wayland device: 1
    type: integrated-gpu name: AMD Radeon 780M (RADV PHOENIX)
    driver: mesa radv v: 25.0.3-arch1.1 device-ID: 1002:15bf
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo
    gpu: nvidia-settings,nvidia-smi x11: xprop
  Device-1: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 65:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: ASUSTeK driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 65:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 65:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.14.0-1-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF-ID-1: br-195b540ed9e2 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  Info: services: NetworkManager, nginx, systemd-networkd,
    systemd-timesyncd, wpa_supplicant
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0489:e0f6
  Local Storage: total: 1.82 TiB used: 145.53 GiB (7.8%)
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 4B2QEXM7 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 490.55 GiB size: 490.55 GiB (100.00%)
    used: 145.5 GiB (29.7%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
    label: root uuid: 61f9c467-a20f-466a-9aa4-26f85422db3b
  ID-2: /boot/efi raw-size: 800 MiB size: 798.4 MiB (99.80%)
    used: 31.5 MiB (3.9%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: E7E3-ADE5
  ID-3: /home raw-size: 490.55 GiB size: 490.55 GiB (100.00%)
  ID-4: /var/cache raw-size: 490.55 GiB size: 490.55 GiB (100.00%)
  ID-5: /var/log raw-size: 490.55 GiB size: 490.55 GiB (100.00%)
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 72d4bd70-dd75-46eb-bce8-63a0ce26043d
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 124.36 GiB fs: ntfs label: N/A
    uuid: 824641B14641A72F
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 643 MiB fs: ntfs label: N/A
    uuid: 2EB4ACFAB4ACC625
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1.21 TiB fs: ntfs label: Files
    uuid: CE70DA2870DA1755
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-3:2 info: ASUSTek N-KEY Device type: keyboard
    driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
  Device-2: 1-5:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0f6 class-ID: e001 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: Sonix USB2.0 FHD UVC WebCam type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0018 class-ID: 0e02
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 44.4 C mobo: 42.5 C gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: 1192 pm: pacman pkgs: 1145 libs: 352
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 47
    1: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    2: https://manjaro.ynh.ovh/stable/$repo/$arch
    3: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    4: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    5: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    6: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    7: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    8: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 469
  1: cpu: 64.2% command: localsearch-extractor-3 pid: 79200
    mem: 39.7 MiB (0.1%)
  2: cpu: 19.6% command: gnome-shell pid: 1669 mem: 388.6 MiB (1.2%)
  3: cpu: 19.2% command: chrome pid: 3623 mem: 398.7 MiB (1.2%)
  4: cpu: 11.2% command: chrome pid: 12603 mem: 261.8 MiB (0.8%)
  5: cpu: 10.9% command: chrome pid: 3152 mem: 356.3 MiB (1.1%)
  Memory top: 5 of 469
  1: mem: 514.6 MiB (1.6%) command: chrome pid: 3094 cpu: 10.5%
  2: mem: 398.7 MiB (1.2%) command: chrome pid: 3623 cpu: 19.2%
  3: mem: 397.6 MiB (1.2%) command: chrome pid: 3229 cpu: 1.3%
  4: mem: 388.6 MiB (1.2%) command: gnome-shell pid: 1669 cpu: 19.6%
  5: mem: 368.6 MiB (1.1%) command: mariadbd pid: 899 cpu: 0.0%
  Processes: 469 Power: uptime: 38m states: freeze,mem,disk suspend: s2idle
    image: 12.19 GiB services: gsd-power,upowerd Init: systemd v: 257
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: flatpak-session inxi: 3.3.38
If you are using jetbrains ide, you can see at the very start by loading the application window that there are problems (frame it loads with delay and graphic lags).
After some time in the interface begin graphical artifacts (some icons are replaced by multicolored pixels), under the cursor appears the same multicolored pixels and all ends with a full or partial hang with subsequent crash on the login screen or shutdown through the power button.
I tried Fedora Linux and everything is the same there.
After a similar crash, a report like this was found:
https://bugzilla.redhat.com/show_bug.cgi?id=2349702
As I understand the alternative now is to use x11 session instead of wayland. At least there are no lags with jetbrains application frame loading. Maybe the system won’t crash there.
Your post has been moved to a dedicated topic.
Please do not add your Support request to another member’s topic; often referred to as hijacking; always create your own topic.
Update Announcements
System Information
or the short form:
inxi -zv8
Required reading
Resources
