I’ve tried adjusted the settings to get rid of the sounds, to no avail:
[jr@fm ~]$ inxi -Fxxx
System: Host: fm Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: TUF B450M-PLUS GAMING v: Rev X.0x
serial: <superuser/root required> UEFI: American Megatrends v: 1002 date: 03/07/2019
CPU: Topology: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ rev: 2
L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118222
Speed: 2192 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 2200 2: 2175
3: 2181 4: 2187 5: 2027 6: 2193 7: 2188 8: 2195 9: 2180 10: 2190 11: 1886 12: 2190
13: 2186 14: 2187 15: 2225 16: 2181
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: ASUSTeK driver: nvidia v: 440.100
bus ID: 07:00.0 chip ID: 10de:1e82
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia resolution:
1: 1920x1080~60Hz 2: 1920x1080~60Hz s-dpi: 94
OpenGL: renderer: GeForce RTX 2080/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 07:00.1 chip ID: 10de:10f8
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 09:00.3 chip ID: 1022:1457
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-4:6
chip ID: 046d:0825 serial: 8D1EA6E0
Sound Server: ALSA v: k5.4.67-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: f000 bus ID: 05:00.0 chip ID: 10ec:8168
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 40:b0:76:5c:8c:4c
Drives: Local Storage: total: 1.36 TiB used: 62.35 GiB (4.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB
speed: 31.6 Gb/s lanes: 4 serial: S4EVNG0M116780W rev: 1B2QEXM7 scheme: GPT
ID-2: /dev/sda type: USB vendor: Seagate model: Expansion size: 931.51 GiB
serial: NA8GPRR8 rev: 0707 scheme: MBR
Partition: ID-1: / size: 109.37 GiB used: 26.10 GiB (23.9%) fs: ext4 dev: /dev/nvme0n1p3
Swap: ID-1: swap-1 type: partition size: 69.34 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6
Sensors: System Temperatures: cpu: 37.9 C mobo: N/A gpu: nvidia temp: 31 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Info: Processes: 341 Uptime: 5d 7h 28m Memory: 62.81 GiB used: 25.93 GiB (41.3%) Init: systemd
v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1267 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.05
[jr@fm ~]$
