Hi so I am trying to run a dedicated server for a game… Where I have a problem is step 3 and 4. On debian based distro’s to accomplish this I need to install multiverse repo and add 32 bit architecture… then only can I install the package. Anyone know what the package is called on manjaro? or if i can even install it (lib32stdc++6). Also if it helps anything step 4 is (steamcmd.sh +login anonymous +force_install_dir server +app_update 416880 validate +quit
) Thank you in advance
Which steps, which package, which game?
$ LANG=C pamac search --files lib32/libstdc++.so.6
/usr/lib32/libstdc++.so.6 is owned by lib32-gcc-libs
/usr/lib32/libstdc++.so.6.0.30 is owned by lib32-gcc-libs
pamac install lib32-gcc-libs
Also what @mithrial says…
So the steps are
- Create a server folder where you want and enter into it:
mkdir SteamCMD
cd SteamCMD
- Download SteamCMD (link above) and extract it. then, remove the tag.gz.
wget steamcdn-a.akamaihd/client/installer/steamcmd_linux.tar.gz(removed link parts)
tar -xf steamcmd_linux.tar.gz
rm -f steamcmd_linux.tar.gz
- Install basic support lib support for your SteamCMD:
sudo apt-get install lib32stdc++6
- At SteamCMD’s folder, type the following command to DOWNLOAD/UPDATE Ballistic Overkill dedicated server:
The game: Ballistic Overkill
The package: lib32stdc++6
without this package it just tells me cannot find steamcmd.sh command
This:
zsh: command not found: steamcmd.sh
It doesn’t show any additional information as to why
To run it you need:
cd steamcmd_linux/
./steamcmd.sh <parameters>
Anyway… on Manjaro I would do this:
pamac build steamcmd
steamcmd +login anonymous +force_install_dir server +app_update 416880 validate +quit
Thanks a bunch! One last question. Where does this install to like the folder where I would find the server files
In your steam folder… normally ~/.local/share/Steam/
Nefarious, check the steamcmd
parameters, there are many to do many things, here is a sample script for example.
@ShutdownOnFailedCommand 1 //set to 0 if updating multiple servers at once
@NoPromptForPassword 1 // set to 0 it will prompt for password
@sSteamCmdForcePlatformType windows // to force a platform type, here it is windows
set_download_throttle 5000 // to limit the bandwidth in Kb/S
force_install_dir ./DOWNLOADS/PS/ // to set the installation folder, to be set before starting any download
login anonymous // some game servers need to login with an account owning the licence of what you install
app_update 746200 validate // set the App ID and also force verification of files
quit
I have this in a text file and you simply run it like this ./steamcmd.sh +runscript thisfile.txt
You can also interactively put commands in steamcdm.
There is absolutely no need to do that, download steamcmd
to any folder you own, execute it from there. I don’t know why the user would not have this quite standard library, I get that the AUR package would install all it needs so there’s that, but I use it quite often and I’m surprised of all these problems he got. This package is part of the ROOT packages (I guess for ALL ISO?).
Hey @omano,
if you know a better way then go for it and spread it. I literally never use steamcmd and just run it as a normal user would.
Cheers
What I meant is that I never heard about anyone in the game server “industry”, who installs steamcmd
as a system package. Every single server Admin or host I had relation with use the tool most likely how I showed above or simply executing steamcmd.sh
and working in it from there.
I’m not sure it is better or not, it is just that I never heard about doing that like that.
//EDIT:
My mistake, the lib32-gcc-libs
is not part of the shared ROOT packages, it is the non 32 bits one which is included.
However, I think Steam is shipped with all Manjaro ISO, and the lib32-gcc-libs
package is a dependency, so in theory, all Manjaro ISO still should have this required, very common, library. Only the MINIMAL ISO may not have it.
Besides Steam there are many packages or libraries requiring it so I guess it would be difficult on a Manjaro normal ISO to avoid having it (and if you go with a MINIMAL ISO, I assume installing things, finding packages, reading basic documentation, and so on, is not unknown to you).
So, how did you end up without that library?
