I’m not exactly sure why it won’t launch. If you require more information to better understand the issue, I’ll gladly provide.
Here’s a sample output of steam-runtime. The last 6-7 lines repeat indefinitely:
$ steam-runtime ~
Running Steam on manjarolinux 21.1.0 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Can't find 'steam-runtime-check-requirements', continuing anyway
WARNING: Using default/fallback debugger launch
/home/jose/.local/share/Steam/ubuntu12_32/steam
[2021-07-15 11:52:04] Startup - updater built Mar 23 2021 20:11:00
ILocalize::AddFile() failed to load file "public/steambootstrapper_english.txt".
Installing breakpad exception handler for appid(steam)/version(0)
SteamUpdateUI: An X Error occurred
X Error of failed request: BadName (named color or font does not exist)
Major opcode of failed request: 45 (X_OpenFont)
Serial number of failed request: 46
xerror_handler: X failed, continuing
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2021-07-15 11:52:04] Loading cached metrics from disk (/home/jose/.local/share/Steam/package/steam_client_metrics.bin)
[2021-07-15 11:52:04] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-07-15 11:52:04] Using the following download hosts for Public, Realm steamglobal
[2021-07-15 11:52:04] 1. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
Installing breakpad exception handler for appid(steam)/version(1.0)
[2021-07-15 11:52:04] Checking for update on startup
[2021-07-15 11:52:04] Checking for available update...
[2021-07-15 11:52:04] Downloading manifest: http://media.steampowered.com/client/steam_client_ubuntu12
X Error of failed request: BadFont (invalid Font parameter)
Major opcode of failed request: 55 (X_CreateGC)
Resource id in failed request: 0x0
Serial number of failed request: 49
$ STEAM_RUNTIME=0 steam
STEAM_RUNTIME is disabled by the user
[2021-07-15 16:22:02] Startup - updater built Mar 23 2021 20:11:00
[2021-07-15 16:22:02] Loading cached metrics from disk (/home/jose/.local/share/Steam/package/steam_client_metrics.bin)
[2021-07-15 16:22:02] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-07-15 16:22:02] Using the following download hosts for Public, Realm steamglobal
[2021-07-15 16:22:02] 1. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-07-15 16:22:02] Checking for update on startup
[2021-07-15 16:22:02] Checking for available update...
[2021-07-15 16:22:02] Downloading manifest: http://media.steampowered.com/client/steam_client_ubuntu12
Well try the hammer and nail method, since something messed with steam:
mv ~/.local/share/Steam ~/steam_backup
Now Steam should recreate its files… maybe that helps. At least your games if saved on the default path, should be there under your home folder at ~/steam_backup/steamapps/common/
I’ve moved the folder away. The GTK dialog that asked for a reinstallation showed up fine. Yet, the original symptoms remain.
However! I’ve decided to wait just a little bit longer to see how long the logs would be. After 10 extra seconds, Steam continued to execute as if nothing happened. I was able to install one game and play it for a bit. No issues whatsoever.
I hope this sheds some light to those who struggle with the initial blank dialog.
