I have a problem with steam that I have been working on for the past few hours.
At some point before this I reset my bios, I doubt this is related, but it’s worth mentioning.
It won’t connect to the steam network.
There have been a few times where I was able to log in, but once inside, nothing was connecting. No updates, I could not post in the forums, I can’t view my profile, it doesn’t even show my avatar.
I tried exiting the beta, but It can’t download the new client. It just tells me steam needs to be connected to a network. Now I am stuck.
What I have tried.
3 wireless networks, 1 wired network
Removing and reinstalling the steam client
2 other computers (both logged me in as normal), one with manjaro and one with windows.
At this point I can’t even open the steam client, because it attempts to update, but can’t.
Any suggestions?
This is the terminal output.
I can go to any of the links in the terminal, and download the files.
I also renamed .local/share/Steam/ to something else, and regenerated the folder.
It still didn’t work.
Running Steam on manjarolinux 21.1.1 64-bit
STEAM_RUNTIME is enabled automatically
Steam runtime environment up-to-date!
Steam client's requirements are satisfied
WARNING: Using default/fallback debugger launch
/home/admin/.local/share/Steam/ubuntu12_32/steam
[2021-09-04 06:29:34] Startup - updater built Aug 31 2021 20:57:58
[2021-09-04 06:29:34] Loading cached metrics from disk (/home/admin/.local/share/Steam/package/steam_client_metrics.bin)
[2021-09-04 06:29:34] Using the following download hosts for Public, Realm steamglobal
[2021-09-04 06:29:34] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-09-04 06:29:34] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-09-04 06:29:34] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-09-04 06:29:34] Verifying installation...
[2021-09-04 06:29:34] Unable to read and verify install manifest /home/admin/.local/share/Steam/package/steam_client_ubuntu12.installed
[2021-09-04 06:29:34] Verification complete
[2021-09-04 06:29:34] Downloading update...
[2021-09-04 06:29:34] Checking for available updates...
[2021-09-04 06:29:34] Downloading manifest: https://cdn.cloudflare.steamstatic.com/client/steam_client_ubuntu12
[2021-09-04 06:29:34] Download failed: http error 0 (cdn.cloudflare.steamstatic.com/client/steam_client_ubuntu12)
[2021-09-04 06:29:34] Downloading manifest: https://cdn.akamai.steamstatic.com/client/steam_client_ubuntu12
[2021-09-04 06:29:35] Download failed: http error 0 (cdn.akamai.steamstatic.com/client/steam_client_ubuntu12)
[2021-09-04 06:29:35] Downloading manifest: http://media.steampowered.com/client/steam_client_ubuntu12
[2021-09-04 06:29:35] Download failed: http error 0 (media.steampowered.com/client/steam_client_ubuntu12)
[2021-09-04 06:29:35] DownloadManifest - exhausted list of download hosts
[2021-09-04 06:29:35] failed to load manifest from buffer.
[2021-09-04 06:29:35] Failed to load manifest
[2021-09-04 06:29:35] Error: Download failed: http error 0
[2021-09-04 06:29:35] Saving metrics to disk (/home/admin/.local/share/Steam/package/steam_client_metrics.bin)
[2021-09-04 06:29:35] Error: Steam needs to be online to update. Please confirm your network connection and try again.
[2021-09-04 06:29:46] Shutdown
src/tier0/threadtools.cpp (3580) : Assertion Failed: Illegal termination of worker thread 'Thread(0x0x574f0f30/0x0xec1ffa'
omano
4 September 2021 16:07
3
You can try to force the use of other DNS server and reboot to see if it fixes the issue.
Thanks for the reply,
I tried using OpenDNS, this did not fix the issue.
I restored a timeshift snapshot from a couple of days ago, and it works now. I wish I knew what went wrong.
Also, whoever decided to include timeshift in this distro…Big Thanks! I would have ended up nuking this install today.
cevad
5 September 2021 01:56
6
Same problem here with steam after update. Nothing changes except update. I don’t want to timeshift restore. Any suggestions?
cevad
5 September 2021 02:13
7
Steam beta solved the problem for me.
@cevad
Did you have a look here at the Stable Update page?
Known issues and solutions
Please don’t post to say everything was great on my side but leave the space for people having issues, or even better: for people having solutions!
New issues:
Freetype2 update may break applications such as Steam. For Steam the latest stable client update resolves the issue.
You might have issues to install …
Under “If Steam breaks completely and only shows a black screen:”.
EDIT: Just checked my steam & also got the black screen. Beta fixed it. Always remember to check the stable update page before updating.
cevad
5 September 2021 03:17
9
Thank you for the info.
I was just trying to give feedback to my problem I reported and the working solution method.
This was yesterday before the update, and I was already in the beta. The only thing I updated yesterday was visualstudiocode-bin.
system
Closed
7 September 2021 20:22
11
