Hi all,
Just installed Manjaro, and having issue getting Steam to launch. Originally had issues logging in, but eventually fixed that.
Now when I start it from the shell I get:
Running Steam on manjarolinux 21.0.7 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Can’t find ‘steam-runtime-check-requirements’, continuing anyway
WARNING: Using default/fallback debugger launch
/home/chris/.local/share/Steam/ubuntu12_32/steam
Looking at other people who had similar issues I’ve already installed lib32-nvidia-utils, and it didn’t change anything.
Welcome to the forum!
Please post your system info as outlined here:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
Nothing from that output is unusual. Please also post a full log running steam
as outlined above with proper formatting. Steam spits out a lot more than that whether it launches or not
