I just did a system upgrade, but now Steam keeps showing the Logging in… screen. Does anyone else have this issue? I could not find anything on google
Always post inxi and journal.
inxi --admin --verbosity=5 --filter --no-host --width
journalctl -p 3 -xb
I’m not updated Manjaro yet, but i had a steam update 1hour ago and it was running fine.
I pasted it into terminal, but the forum says it contains link and won’t allow me to post the terminals output.
I think you pressed the wrong button and inserted a hyperlink?
Post your terminal output with crtl+v in this forum and after marking the text, press this button then </> to format the text for code.
Result of inxi --admin --verbosity=5 --filter --no-host --width
Kernel: 6.8.9-lqx2-4-lqx arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: tsc avail: hpet,acpi_pm parameters: audit=0
intel_pstate=disable BOOT_IMAGE=/boot/vmlinuz-linux-lqx
root=UUID=d92f87cd-0059-4b0a-b211-aa0be9ab5b98 rw quiet
cryptdevice=UUID=b9a56bf0-98c5-46d7-beba-96a7d684b24f:luks-b9a56bf0-98c5-46d7-beba-96a7d684b24f
root=/dev/mapper/luks-b9a56bf0-98c5-46d7-beba-96a7d684b24f splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-59140e6a-895b-427f-918c-3eee0eee88d9
udev.log_priority=3
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
Type: Desktop System: MM-Vision product: TUF-GAMING-B550M-E-1002 v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: TUF GAMING B550M-E v: Rev X.0x
UEFI: American Megatrends v: 2407 date: 07/13/2021
System RAM: total: 32 GiB available: 31.26 GiB used: 4.77 GiB (15.3%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF3600C16D4/16GX serial: <filter>
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 3961 high: 4671 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4173 2: 3599
3: 3590 4: 4650 5: 4650 6: 4671 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700
12: 3700 bogomips: 88802
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-2,DP-3 empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 0d:00.0
chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Samsung C27F591 serial: <filter> built: 2018
res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-3 model: AOC 22V2WG5 serial: <filter> built: 2019
res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55")
diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
navi22 LLVM 17.0.6 DRM 3.57 6.8.9-lqx2-4-lqx) device-ID: 1002:73df
memory: 11.72 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.6-manjaro1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: FiiO BTR5 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:13 chip-ID: 2972:0047
class-ID: fe01
API: ALSA v: k6.8.9-lqx2-4-lqx status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pw-cat,pw-cli
Server-3: PulseAudio v: 17.0 status: off (using pipewire-pulse)
tools: pacat,pactl
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 1.59 TiB (87.6%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 43.9 C
scheme: GPT
ID-1: / raw-size: 922.41 GiB size: 906.86 GiB (98.31%)
used: 787.82 GiB (86.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b9a56bf0-98c5-46d7-beba-96a7d684b24f label: N/A
uuid: d92f87cd-0059-4b0a-b211-aa0be9ab5b98
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3 label: N/A
uuid: A9BB-B479
compressor: lz4 max-pool: 20%
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-59140e6a-895b-427f-918c-3eee0eee88d9 label: swap
uuid: 45dd9747-207f-4419-8d84-8e0c6ae707c4
System Temperatures: cpu: 47.6 C mobo: N/A gpu: amdgpu temp: 50.0 C
mem: 44.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 437 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: gsd-power,
tool: systemctl
Packages: 1857 pm: pacman pkgs: 1820 libs: 531 tools: gnome-software,pamac
pm: flatpak pkgs: 37 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.34
Result of journalctl -p 3 -xb:
maj 14 14:47:57 Manjaro-At-Home kernel: usb 3-4: device descriptor read/64, error -71
maj 14 14:47:57 Manjaro-At-Home kernel: usb 3-4: device not accepting address 6, error -71
maj 14 14:47:57 Manjaro-At-Home kernel: usb 3-4: device not accepting address 7, error -71
maj 14 14:47:57 Manjaro-At-Home kernel: usb usb3-port4: unable to enumerate USB device
maj 14 14:47:57 Manjaro-At-Home kernel: usb 3-4: device not accepting address 10, error -71
maj 14 14:47:57 Manjaro-At-Home kernel: usb 3-4: device not accepting address 11, error -71
maj 14 14:48:19 Manjaro-At-Home gdm-password][1360]: gkr-pam: unable to locate daemon control file
maj 14 14:48:20 Manjaro-At-Home systemd[1378]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 154 and the job result is failed.
lines 1-23
I don’t see a steam error, did you just reboot your PC and try’d it again?
Maybe a router restart could help too, for resetting your IP.
Maybe try a LTS Kernel if nothing helps, is my last guess… right now.
