Steam-runtime launches steam-native
I recently switched from using steam-runtime to steam-native, due to the freetype bug that was recently resolved. After not running steam-runtime for a while, I now notice that it seems to launch steam-native every time no matter what. I’ve tried running STEAM_RUNTIME=1 steam-runtime just to try to force it, but the window that launches always says Steam (Native).
There’s a chance that everything is working fine but the window is simply mislabeled for some reason, but I’m unable to confirm. It appears to be running steam-runtime in the logs, but maybe I’m missing something.
Log output from running steam-runtime in the command line:
Running Steam on manjarolinux 21.1.2 64-bit
STEAM_RUNTIME is enabled by the user
Steam runtime environment up-to-date!
Steam client's requirements are satisfied
WARNING: Using default/fallback debugger launch
/home/doctor_ew/.local/share/Steam/ubuntu12_32/steam
Installing breakpad exception handler for appid(steam)/version(1631572918)
Loaded SDL version 2.0.17-6744061
(steam:126990): Gtk-WARNING **: 08:59:02.256: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Adwaita-maia-compact-dark/gtk-2.0/main.rc:733: error: unexpected identifier 'direction', expected character '}'
(steam:126990): Gtk-WARNING **: 08:59:02.257: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Adwaita-maia-compact-dark/gtk-2.0/hacks.rc:28: error: invalid string constant "normal_entry", expected valid string constant
Runtime for steamwebhelper: defaulting to /home/doctor_ew/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
+ exec /home/doctor_ew/.local/share/Steam/ubuntu12_64/steam-runtime-heavy.sh --unpack-dir=/home/doctor_ew/.local/share/Steam/ubuntu12_64 --runtime=steam-runtime-heavy -- ./steamwebhelper -lang=en_US -cachedir=/home/doctor_ew/.local/share/Steam/config/htmlcache -steampid=126990 -buildid=1631572918 -steamid=0 -cachedir=/home/doctor_ew/.local/share/Steam/config/htmlcache -steamuniverse=Public -realm=Global -clientui=/home/doctor_ew/.local/share/Steam/clientui --enable-blink-features=ResizeObserver,Worklet,AudioWorklet --enable-media-stream --enable-smooth-scrolling --password-store=basic --log-file=/home/doctor_ew/.local/share/Steam/logs/cef_log.txt --disable-quick-menu
Proceed to auto login
CAppInfoCacheReadFromDiskThread took 136 milliseconds to initialize
Opted-in Controller Mask for AppId 0: f
(steam:126990): Gtk-WARNING **: 08:59:03.381: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 15029 bytes.
roaming config store loaded successfully - 15029 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 17ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/doctor_ew/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 5.61 seconds
(steam:126990): LIBDBUSMENU-GLIB-WARNING **: 08:59:05.106: Trying to remove a child that doesn't believe we're it's parent.
(steam:126990): LIBDBUSMENU-GLIB-WARNING **: 08:59:05.107: Trying to remove a child that doesn't believe we're it's parent.
(steam:126990): LIBDBUSMENU-GLIB-WARNING **: 08:59:05.108: Trying to remove a child that doesn't believe we're it's parent.
BuildCompleteAppOverviewChange: 439
RegisterForAppOverview 1: 24ms
RegisterForAppOverview 2: 25ms
Exiting workitem thread
(steam:126990): GLib-GObject-CRITICAL **: 09:00:39.001: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(steam:126990): GLib-GObject-WARNING **: 09:00:39.003: invalid (NULL) pointer instance
(steam:126990): GLib-GObject-CRITICAL **: 09:00:39.003: g_signal_handlers_disconnect_matched: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(steam:126990): GLib-GObject-CRITICAL **: 09:00:39.003: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
[2021-09-15 08:58:59] Startup - updater built Sep 13 2021 22:00:59
[2021-09-15 08:58:59] Loading cached metrics from disk (/home/doctor_ew/.local/share/Steam/package/steam_client_metrics.bin)
[2021-09-15 08:58:59] Using the following download hosts for Public, Realm steamglobal
[2021-09-15 08:58:59] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-09-15 08:58:59] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-09-15 08:58:59] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-09-15 08:58:59] Verifying installation...
[2021-09-15 08:58:59] Verification complete
[2021-09-15 09:00:39] Shutdown
Yes, it is. I’m not sure why it does that.
