Hey people,
Just installed manjaro Nybia 64 bit on (SSD, AMD Ryzen 5 2600, Nvidia 1060, LXQT 0.16.0)
Updated all system, tried to install steam-manjaro package, all ok.
When trying to run steam, I get this log:
Linux 5.9.16-1-MANJARO x86_64 20.2.1 Nibia
~ >>> steam
Running Steam on manjarolinux 20.2.1 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Steam client's requirements are satisfied
[2021-01-12 10:56:34] Startup - updater built Dec 20 2020 23:07:02
Installing breakpad exception handler for appid(steam)/version(1608507519)
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
SteamUpdateUI: An X Error occurred
X Error of failed request: GLXBadContext
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 151 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 45
xerror_handler: X failed, continuing
Minor opcode of failed request: 6 (X_GLXIsDirect)
Serial number of failed request: 46
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2021-01-12 10:56:34] Loading cached metrics from disk (/home/luis/.local/share/Steam/package/steam_client_metrics.bin)
[2021-01-12 10:56:34] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2021-01-12 10:56:34] Using the following download hosts for Public, Realm steamglobal
[2021-01-12 10:56:34] 1. .............., /client/, Realm 'steamglobal', weight was 100, source = 'baked in'
[2021-01-12 10:56:34] 2. ..............., /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-01-12 10:56:34] Checking for update on startup
[2021-01-12 10:56:34] Checking for available updates...
[2021-01-12 10:56:34] Downloading manifest: ........................
[2021-01-12 10:56:34] Download skipped: /client/steam_client_ubuntu12 version 1608507519, installed version 1608507519, downloaded version 0
[2021-01-12 10:56:34] Nothing to do
[2021-01-12 10:56:34] Verifying installation...
[2021-01-12 10:56:34] Performing checksum verification of executable files
[2021-01-12 10:56:35] Verification complete
Loaded SDL version 2.0.14-6278618
Gtk-Message: 10:56:35.373: Failed to load module "xapp-gtk3-module"
(steam:17706): Gtk-WARNING **: 10:56:35.376: Unable to locate theme engine in module_path: "adwaita",
(steam:17706): Gtk-WARNING **: 10:56:35.377: Unable to locate theme engine in module_path: "adwaita",
(steam:17706): Gtk-WARNING **: 10:56:35.378: Unable to locate theme engine in module_path: "murrine",
(steam:17706): Gtk-WARNING **: 10:56:35.379: Unable to locate theme engine in module_path: "murrine",
(steam:17706): Gtk-WARNING **: 10:56:35.380: Unable to locate theme engine in module_path: "murrine",
Steam: An X Error occurred
Serial number of failed request: 52
Serial number of failed request: 51
X Error of failed request: BadMatch (invalid parameter attributes)
Serial number of failed request: 53
assert_20210112105634_1.dmp[17768]: Uploading dump (out-of-process)
/tmp/dumps/assert_20210112105634_1.dmp
/home/......../.local/share/Steam/steam.sh: line 759: 17706 Segmentation fault (core dumped) $STEAM_DEBUGGER "$STEAMROOT/$STEAMEXEPATH" "$@"
~ >>> assert_20210112105634_1.dmp[17768]: Finished uploading minidump (out-of-process): success = yes
assert_20210112105634_1.dmp[17768]: response: CrashID=bp-47e5197b-2589-472c-bdac-2fe742210112
assert_20210112105634_1.dmp[17768]: file ''/tmp/dumps/assert_20210112105634_1.dmp'', upload yes: ''CrashID=bp-47e5197b-2589-472c-bdac-2fe742210112''
Can you guys help me figure out how to ru steam properly, may this be related to wayland and lxqt ?
EDIT [FIXED]: Install lib32-nvidia-utils package -> sudo pacman -S lib32-nvidia-utils
