Whenever I restart, I have to manually find and use my standard downloads folder each time. How do I fix this?
Give more information as in a standard installation you do not have to do that.
When I check the used folders for installing, the usual place in my hard drive where I install games is gone, and I have to manually re add it each time.
If you continue to hold on relevant information nobody can help.
What do you want me to provide exactly?
Iâm running Kernel 5.10, Steam Native client, and KDE Plasma on the latest version of Manjaro.
Obviously what folders are you talking about first⌠Weâre not in your head so when you talk about something make sure we can understand what youâre talking about.
I am trying to ensure that my hard drive folder is the default installation folder
So: run/media/me/harddriveuuid/SteamLibrary
Every time I restart, that path is deleted from my download settings on Steam, and it goes back to my Steam folder under home.
OK it is not standard folder then.
Make sure your disk is mounted before you run Steam. If it is not auto mounted, or manually mounted, of course Steam will not be able to use it because it doesnât exist.
I think the issue is that you donât have that HDD automounted. I had to add mine to /etc/fstab.
I created a folder in /mnt called Games and I made my HDD mount to /mnt/Games (as that HDD was for games only) and SteamLibrary folder is in there.
How could I manually add the drive to etc/fstab?
In the wiki is some info about fstab:
https://archived-wiki.manjaro.org/index.php?title=Fstab
Personally I used Gnome Disks for this, but I donât recommend it because you will not learn anything from it.
- Make a folder in
/mntwith whatever name you want, lets say âHDD2â for now. - Use
sudo blkidto find the UUID of your drive or partition sudo nano /etc/fstab- Input:
UUID=<your UUID> /mnt/HDD2 ext4 defaults 0 0
- Save
Now it should automount to /mnt/HDD2 every time you boot into your computer.
If you donât know what the above fstab stuff means, here is an example:
# <device> <dir> <type> <options> <dump> <fsck>
UUID=0a3407de-014b-458b-b5c1-848e92a327a3 /mnt/HDD2 ext4 defaults 0 0
So say if I download games, will it take up twice the space, or is it more of a link to the drive that can be accessed?
All it does is auto mounts your HDD to a specific folder instead of self generating a folder in /run every time.
So the files wonât necessary take up space in /mnt?
No, it only takes up space in that hard drive that is mounted to the specific folder.
Itâs similar to some people having a /home partition. You mount the partition or another HDD to /home, so it only takes up space in /home, it doesnât take up space of the HDD or partition containing that mounts /.
Or if you have a partition mounted to /boot/efi. It doesnât take up space in / or /boot.
So, i just put the /mnt folder in my Steam downloads, then the client downloads my files into the folder where the UUID is (HDD), rather than my SSD. Am I correct on this?
/run is a temporary folder that will be reset at each reboot. Itâs a Linux feature.
Check also this:
Difficulty: â ââââ Disk device recognition Manjaro uses udev (see Arch Wiki) to load devices at boot time. The loading of devices is arbitrary and therefore you cannot predict which device will be available at a given path. But static device names do exist and you can assign specific locations to your device and thus ensure e.g. scripts will work as expected. What to learn Overview of system mount units Structure and Content of a mount unit Mount at boot (immediate mount) Mount on demand (mâŚ
You put /mnt/HDD2 to your Steam downloads, make that your primary (in Steam), and it should generate âSteamLibraryâ folder, and all your games will download into /mnt/HDD2/SteamLibrary iirc. I havenât done it in a while since I already have Steam setup on my 3 computers years ago.
(change HDD2 to what you want)
So, just a general question. How does that work? Iâm pretty new to Manjaro and Linux in general.
